06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10006-Layer 2 - LAN Switching
03-HH3C-LLDP-EXT-MIB
03-HH3C-LLDP-EXT-MIB 77.51 KB
HH3C-LLDP-EXT-MIB
About this MIB
The Link Layer Discovery Protocol (LLDP) is a Layer 2 industry-standard protocol (IEEE 802.1AB) that allows network devices from different vendors to discover neighbors and exchange system and configuration information.
This MIB defines private MIB objects for the following extended LLDP management features:
·     Global LLDP configuration:
¡     Global status of LLDP.
¡     Global status of CDP compatibility.
·     LLDP port configuration:
¡     Port-specific packet transmission settings of CDP-compatible LLDP.
¡     Protection action taken on ports whose neighbors fail validation.
¡     Protection action taken on ports whose neighbors age out.
·     LLDP neighbor validation criteria:
¡     Chassis ID subtype.
¡     Chassis ID.
¡     Port ID subtype.
¡     Port ID.
·     Feature status on LLDP-enabled ports:
¡     Neighbor validation status.
¡     Neighbor aging status.
·     Trapping configuration on LLDP-enabled ports:
¡     Trapping for neighbor validation status changes.
¡     Trapping for neighbor aging status changes.
MIB file name
hh3c-lldp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei.h3c(10).h3cCommon(2).h3clldp(100)
Scalar objects
hh3clldpAdminStatus
Object (OID)
Access
Value range
Implementation
hh3clldpAdminStatus
(1.3.6.1.4.1.25506.2.100.1.1.1)
read-write
TruthValue
true(1)
false(2)
As per the MIB.
hh3clldpComplianceCDPStatus
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.2)
read-write
TruthValue
true(1)
false(2)
Not supported.
Fixed at 2.
Tabular objects
hh3clldpPortConfigTable
About this table
Use this table to configure LLDP on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3clldpPortConfigPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.3.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.3.1.1)
not-accessible
LldpPortNumber
Standard MIB values.
Port index.
As per the MIB.
hh3clldpPortConfigCDPComplianceStatus
(1.3.6.1.4.1.25506.2.100.1.1.3.1.2)
read-write
INTEGER
txAndRx(1)
disabled(2)
Packet transmission capabilities of CDP-compatible LLDP.
As per the MIB.
hh3clldpPortConfigValidationAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.3)
read-write
Integer32
As per the MIB.
h3clldpPortConfigAgingAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.4)
read-write
Integer32
As per the MIB.
h3clldpNbIdentityTable
About this table
Use this table to configure neighbor validation criteria.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3clldpNbIdentityPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.4.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.4.1.1)
not-accessible
LldpPortNumber
Port index.
As per the MIB.
h3clldpNbIdentityChassisIDSubtype
(1.3.6.1.4.1.25506.2.100.1.1.4.1.2)
read-write
INTEGER
default(0)
chassisComponent(1)
interfaceAlias(2)
portComponent(3)
macAddress(4)
networkAddress(5)
interfaceName(6)
local(7)
Chassis ID subtype.
As per the MIB.
(1.3.6.1.4.1.25506.2.100.1.1.4.1.3)
read-write
OCTET STRING
OCTET STRING (0..255)
Chassis ID.
As per the MIB.
h3clldpNbIdentityPortIDSubtype
(1.3.6.1.4.1.25506.2.100.1.1.4.1.4)
read-write
INTEGER
default(0)
interfaceAlias(1)
portComponent(2)
macAddress(3)
networkAddress(4)
interfaceName(5)
agentCircuitId(6)
local(7)
Port ID subtype.
As per the MIB.
(1.3.6.1.4.1.25506.2.100.1.1.4.1.5)
read-write
OCTET STRING
Port ID.
As per the MIB.
h3clldpNbIdentityRowStatus
(1.3.6.1.4.1.25506.2.100.1.1.4.1.6)
read-create
RowStatus
Row status.
As per the MIB.
h3clldpPortStatusTable
About this table
Use this table to obtain status of features on LLDP-enabled ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3clldpPortStatusPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.5.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.5.1.1)
accessible-for-notify
LldpPortNumber
Port index.
As per the MIB.
h3clldpPortValidationStatus
(1.3.6.1.4.1.25506.2.100.1.1.5.1.2)
read-only
Integer32
As per the MIB.
h3clldpPortAgingStatus
(1.3.6.1.4.1.25506.2.100.1.1.5.1.3)
read-only
Integer32
As per the MIB.
h3clldpRemManAddrTable
About this table
Use this table to display neighbor management addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemManAddrSubtype, and lldpRemManAddr.
The table OID is 1.3.6.1.4.1.25506.2.100.1.2.1.
Object (OID)
Access
Value range
Implementation
h3clldpRemManAddrSubtype
(1.3.6.1.4.1.25506.2.100.1.2.1.1.1)
read-only
AddressFamilyNumbers
Encoding format.
As per the MIB.
h3clldpRemManAddr
(1.3.6.1.4.1.25506.2.100.1.2.1.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
Management address.
As per the MIB.
h3clldpRemManAddrIfSubtype
(1.3.6.1.4.1.25506.2.100.1.2.1.1.3)
read-only
LldpManAddrIfSubtype
LLDP neighbor port numbers.
As per the MIB.
h3clldpRemManAddrIfId
(1.3.6.1.4.1.25506.2.100.1.2.1.1.4)
read-only
Integer32
Port number.
As per the MIB.
h3clldpRemManAddrOID
(1.3.6.1.4.1.25506.2.100.1.2.1.1.5)
read-only
OBJECT IDENTIFIER
OID.
Not supported
Notifications
h3clldpValidationStatusChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.100.2.0.1
Neighbor validation status changes.
Informational
OFF
LLDP neighbor validation enables a port to validate the identity of the neighbor based on the neighbor validation criteria configured on the port. Each incoming LLDP packet must match all the validation criteria configured on the port. If the neighbor information in a packet does not match the criteria, the system shuts down the data link layer and disables data transmission on the port.
Status control
ON
CLI: Use the lldp neighbor-protection validation command.
OFF
CLI: Use the undo lldp neighbor-protection validation command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.100.1.1.5.1.1 (h3clldpPortStatusPortNum)
Port index.
Yes
LldpPortNumber
1.3.6.1.4.1.25506.2.100.1.1.5.1.2 (h3clldpPortValidationStatus)
No
Integer32
Recommended action
Identify the cause for neighbor validation failure.
h3clldpAgingStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.100.2.0.2
Neighbor aging status changes.
Informational
OFF
The system blocks or shuts down an LLDP neighbor aging-enabled port if the neighbor on the port ages out.
Status control
ON
CLI: Use the lldp neighbor-protection aging { block | shutdown } command.
OFF
CLI: Use the undo lldp neighbor-protection aging command.
Objects
OID (object name)
Index
Value range
Port index.
Yes
LldpPortNumber
1.3.6.1.4.1.25506.2.100.1.1.5.1.3 (h3clldpPortAgingStatus)
No
Integer32
Recommended action
Check whether a neighbor has aged out.
