- 11-High availability
- 01-IRF Setup with LACP MAD Configuration Examples
- 02-IRF Setup with ARP MAD Configuration Examples
- 03-IRF Setup with Members Not Directly Connected Configuration Examples
- 04-IRF Setup with Members in One Chassis Configuration Examples
- 05-IRF Setup with Members in Different Chassis Configuration Examples
- 06-Dual-Link Backup Configuration Examples
- 07-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 08-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 09-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 10-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 11-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 12-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 13-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 14-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 15-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 16-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 17-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 18-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 19-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 20-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
| 07-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples | 305.80 KB |
H3C Access Controllers |
Remote 802.1X Authentication on an AC Hierarchy Network with Dual-link Central AC Backup |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Editing the AP configuration file
Configuring the Layer 3 switch
Configuring the Layer 2 switch
Introduction
The following information provides an example of configuring remote 802.1X authentication for clients on a network that deploys an AC hierarchy in which two central ACs are used for redundancy.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, WLAN access authentication, WLAN access, and WLAN high availability features.
Central ACs on an AC hierarchy network do not support IRF.
Example: Configuring remote 802.1X authentication on an AC hierarchy network with dual-link central AC backup
As shown in Figure 1, in the AC hierarchy network, Central AC 1 acts as the master central AC and Central AC 2 acts as the backup central AC. The AP and the client obtain IP addresses from the DHCP server, and an IMC server acts as the RADIUS server.
Configure the devices to meet the following requirements:
· The central ACs operate in active/standby mode and back up each other.
· The AP, the central ACs, and the local AC have network connectivity to one another.
¡ The AP obtains the IP addresses of the master and backup central ACs through DHCP Option 43.
¡ The AC rediscovery feature is configured on the central ACs for the AP to associate with the local AC.
¡ The AP can associate with the master central AC when the local AC fails.
· The central ACs act as the authenticator and use the RADIUS server to perform authentication, authorization, and accounting for the client. 802.1X authentication is enabled for the service template through which the client accesses the network.
Analysis
For dual-link central AC backup to operate correctly, configure the local AC and manual AP settings on both central ACs. Make sure the priority settings on the local AC, the master central AC, and the backup central AC are correctly configured so that the local AC can re-associate with the master central AC when the master central AC recovers from a failure.
For the RADIUS server to dynamically change client authorization information or forcibly disconnect a wireless client, enable the RADIUS session-control feature on the central ACs.
For GigabitEthernet 1/0/1 to forward client data traffic in VLAN 300, edit a .txt AP configuration file and upload the file to the central ACs. In the file, the port is added to VLAN 300.
To avoid dynamic authorization failures, configure the RADIUS Dynamic Authorization Extensions Server (DAS) feature on the central ACs.
When you configure remote 802.1X authentication on an AC hierarchy network with dual central ACs, follow these restrictions and guidelines:
· Make sure the master and backup central ACs run the same version of software and have the same settings.
· Use the actual serial ID of an AP to uniquely identify that AP.
· On the local AC, do not enable the auto AP feature. In addition, create a manual AP for the AP in local AC view on the central ACs for the central ACs to manage the AP.
Procedures
# Use a text editor to edit the APs' configuration file, and then upload the file to each central AC. In this example, the configuration file name is apmap.txt.
The following is the AP configuration for this example:
vlan 300
interface gigabitethernet1/0/1
port link-type trunk
port trunk permit vlan 300
Configuring Central AC 1
Configuring interfaces on Central AC 1
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a management tunnel with the local AC.
<Central-AC1> system-view
[Central-AC1] vlan 100
[Central-AC1-vlan100] quit
[Central-AC1] interface vlan-interface 100
[Central-AC1-Vlan-interface100] ip address 2.2.1.1 24
[Central-AC1-Vlan-interface100] quit
# Specify GigabitEthernet 1/0/1 that connects Central AC 1 to the Layer 3 switch as a trunk port, and assign the port to VLAN 100.
[Central-AC1] interface gigabitethernet 1/0/1
[Central-AC1-GigabitEthernet1/0/1] port link-type trunk
[Central-AC1-GigabitEthernet1/0/1] port trunk permit vlan 100
[Central-AC1-GigabitEthernet1/0/1] quit
Configuring a local AC for Central AC 1
# Create local AC 3510 with model WX3510H and enter local AC view.
[Central-AC1] wlan local-ac name 3510 model WX3510H
# Specify the serial ID of the local AC.
[Central-AC1-wlan-local-ac-3510] serial-id 210235A1JNB165000120
# Set the priority to 7 for tunnel establishment to the local AC.
[Central-AC1-wlan-local-ac-3510] priority 7
# Enable master CAPWAP tunnel preemption.
[Central-AC1-wlan-local-ac-3510] wlan tunnel-preempt enable
[Central-AC1-wlan-local-ac-3510] quit
Configuring RADIUS-based 802.1X authentication
1. Configure a RADIUS scheme:
# Create RADIUS scheme imc and enter its view.
[Central-AC1] radius scheme imc
# Specify the IP address of the primary RADIUS authentication server.
[Central-AC1-radius-imc] primary authentication 192.168.0.111
# Specify the IP address of the primary RADIUS accounting server.
[Central-AC1-radius-imc] primary accounting 192.168.0.111
# Set the shared key to 123456 in plaintext form for secure communication with the RADIUS authentication server.
[Central-AC1-radius-imc] key authentication simple 123456
# Set the shared key to 123456 in plaintext form for secure communication with the RADIUS accounting server.
[Central-AC1-radius-imc] key accounting simple 123456
# Exclude the domain name from usernames sent to the RADIUS servers.
[Central-AC1-radius-imc] user-name-format without-domain
# Specify IP address 2.2.1.1 as the source IP address for outgoing RADIUS packets.
[Central-AC1-radius-imc] nas-ip 2.2.1.1
[Central-AC1-radius-imc] quit
# Enable RADIUS session-control.
[Central-AC1] radius session-control enable
2. Configure an authentication domain:
# Create ISP domain imc and enter its view.
[Central-AC1] domain imc
# Configure the ISP domain to use RADIUS scheme imc for 802.1X user authentication, authorization, and accounting.
[Central-AC1-isp-imc] authentication lan-access radius-scheme imc
[Central-AC1-isp-imc] authorization lan-access radius-scheme imc
[Central-AC1-isp-imc] accounting lan-access radius-scheme imc
[Central-AC1-isp-imc] quit
3. Configure EAP relay as the method for the AC to exchange packets with the RADIUS server.
[Central-AC1] dot1x authentication-method eap
Configuring a service template
# Create service template dot1x and set the SSID of the service template.
[Central-AC1] wlan service-template dot1x
[Central-AC1-wlan-st-dot1x] ssid l18341-fc-3510-bd-dot1x
# Configure APs to forward client data traffic from all VLANs. If APs act as the client data traffic forwarder by default, skip this step.
[Central-AC1-wlan-st-dot1x] client forwarding-location ap
# Specify central ACs as the authenticator.
[Central-AC1-wlan-st-dot1x] client-security authentication-location central-ac
# Set the AKM mode to 802.1X, specify the CCMP cipher suite, enable the RSN IE in beacon and probe responses, set the access authentication mode to 802.1X authentication, and specify ISP domain imc for authenticating the 802.1X client.
[Central-AC1-wlan-st-dot1x] akm mode dot1x
[Central-AC1-wlan-st-dot1x] cipher-suite ccmp
[Central-AC1-wlan-st-dot1x] security-ie rsn
[Central-AC1-wlan-st-dot1x] client-security authentication-mode dot1x
[Central-AC1-wlan-st-dot1x] dot1x domain imc
# Enable the service template.
[Central-AC1-wlan-st-dot1x] service-template enable
[Central-AC1-wlan-st-dot1x] quit
Creating a manual AP
NOTE: In a large-scale network, configure AP settings in AP group view instead of AP view as a best practice. |
# Create manual AP ap1 and specify the AP model and serial ID.
[Central-AC1] wlan ap ap1 model WA6320
[Central-AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[Central-AC1-wlan-ap-ap1] quit
# Create AP group group1.
[Central-AC1] wlan ap-group group1
# Enable the AC rediscovery feature.
[Central-AC1-wlan-ap-group-group1] control-address enable
# Specify 2.2.2.1 as the IP address to be carried in the CAPWAP Control IP Address message element.
[Central-AC1-wlan-ap-group-group1] control-address ip 2.2.2.1
# Specify Central AC 2 as a backup AC.
[Central-AC1-wlan-ap-group-group1] backup-ac ip 2.2.1.2
# Enable vertical backup.
[Central-AC1-wlan-ap-group-group1] switch-back enable
# Configure an AP grouping rule by AP name to add AP named ap1 to the group.
[Central-AC1-wlan-ap-group-group1] ap ap1
# Deploy configuration file apmap.txt to the AP group.
[Central-AC1-wlan-ap-group-group1] ap-model WA6320
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320] map-configuration cfa0:/apmap.txt
# Bind service template dot1x to radio 1 and specify VLAN 300 for the radio.
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template dot1x vlan 300
# Enable radio 1.
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[Central-AC1-wlan-ap-group-group1-ap-model-WA6320] quit
[Central-AC1-wlan-ap-group-group1] quit
Configuring IP routing
# Configure a default route with next hop 2.2.1.100 (an IP address on the Layer 3 switch).
[Central-AC1] ip route-static 0.0.0.0 0 24 2.2.1.100
Configuring Central AC 2
Configuring interfaces on Central AC 2
<Central-AC2> system-view
[Central-AC2] vlan 100
[Central-AC2-vlan100] quit
[Central-AC2] interface vlan-interface 100
[Central-AC2-Vlan-interface100] ip address 2.2.1.2 24
[Central-AC2-Vlan-interface100] quit
# Specify GigabitEthernet1/0/1 that connects Central AC 2 to the Layer 3 switch as a trunk port, and assign the port to VLAN 100.
[Central-AC2] interface gigabitethernet 1/0/1
[Central-AC2-GigabitEthernet1/0/1] port link-type trunk
[Central-AC2-GigabitEthernet1/0/1] port trunk permit vlan 100
[Central-AC2-GigabitEthernet1/0/1] quit
Configuring a local AC for Central AC 2
# Create local AC 3510 with model WX3510H.
[Central-AC2] wlan local-ac name 3510 model WX3510H
[Central-AC2-wlan-local-ac-3510] serial-id 210235A1JNB165000120
# Set the priority to 6 for tunnel establishment to the local AC.
[Central-AC2-wlan-local-ac-3510] priority 6
[Central-AC2-wlan-local-ac-3510] wlan tunnel-preempt enable
[Central-AC2-wlan-local-ac-3510] quit
[Central-AC2] radius scheme imc
# Specify the primary RADIUS authentication server.
[Central-AC2-radius-imc] primary authentication 192.168.0.111
# Specify the primary RADIUS accounting server.
[Central-AC2-radius-imc] primary accounting 192.168.0.111
[Central-AC2-radius-imc] key authentication simple 123456
[Central-AC2-radius-imc] key accounting simple 123456
[Central-AC2-radius-imc] user-name-format without-domain
# Specify IP address 2.2.1.2 as the source IP address for outgoing RADIUS packets.
[Central-AC2-radius-imc] nas-ip 2.2.1.2
[Central-AC2-radius-imc] quit
[Central-AC2] radius session-control enable
# Enable RADIUS DAS and enter its view.
[Central-AC2] radius dynamic-author server
# Specify the RADIUS server at 192.168.0.111 as a DAC and set the shared key to 12345 in plain text for authenticating DAE packets from the RADIUS server.
[Central-AC2-radius-da-server] client ip 192.168.0.111 key simple 12345
[Central-AC2-radius-da-server] quit
[Central-AC2] domain imc
[Central-AC2-isp-imc] authentication lan-access radius-scheme imc
[Central-AC2-isp-imc] authorization lan-access radius-scheme imc
[Central-AC2-isp-imc] accounting lan-access radius-scheme imc
[Central-AC2-isp-imc] quit
[Central-AC2] dot1x authentication-method eap
[Central-AC2] wlan service-template dot1x
[Central-AC2-wlan-st-dot1x] ssid l18341-fc-3510-bd-dot1x
# Configure APs to forward client data traffic from all VLANs. If APs act as client traffic forwarder by default, skip this step.
[Central-AC2-wlan-st-dot1x] client forwarding-location ap
[Central-AC2-wlan-st-dot1x] client-security authentication-location central-ac
[Central-AC2-wlan-st-dot1x] akm mode dot1x
[Central-AC2-wlan-st-dot1x] cipher-suite ccmp
[Central-AC2-wlan-st-dot1x] security-ie rsn
[Central-AC2-wlan-st-dot1x] client-security authentication-mode dot1x
[Central-AC2-wlan-st-dot1x] dot1x domain imc
[Central-AC2-wlan-st-dot1x] service-template enable
[Central-AC2-wlan-st-dot1x] quit
[Central-AC2] wlan ap ap1 model WA6320
[Central-AC2-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[Central-AC2-wlan-ap-ap1] quit
[Central-AC2] wlan ap-group group1
[Central-AC2-wlan-ap-group-group1] control-address enable
[Central-AC2-wlan-ap-group-group1] control-address ip 2.2.2.1
# Specify Central AC 1 as a backup AC for the AP.
[Central-AC2-wlan-ap-group-group1] backup-ac ip 2.2.1.1
[Central-AC2-wlan-ap-group-group1] switch-back enable
# Configure a grouping rule by AP name to add the AP named ap1 to the group.
[Central-AC2-wlan-ap-group-group1] ap ap1
[Central-AC2-wlan-ap-group-group1] ap-model WA6320
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320] map-configuration cfa0:/apmap.txt
# Bind service template dot1x to radio 1 and specify VLAN 300 for radio 1.
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template dot1x vlan 300
# Enable radio 1.
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[Central-AC2-wlan-ap-group-group1-ap-model-WA6320] quit
[Central-AC2-wlan-ap-group-group1] quit
[Central-AC2] ip route-static 0.0.0.0 0 24 2.2.1.100
Configuring the local AC
1. Configure the local AC feature:
# Enable the local AC feature.
<Local AC> system-view
[Local AC] wlan local-ac enable
# Specify Central AC 1 and Central AC 2 for the local AC.
[Local AC] wlan central-ac ip 2.2.1.1
[Local AC] wlan central-ac ip 2.2.1.2
# Configure the local AC to use VLAN 100 to establish CAPWAP tunnels with the central ACs.
[Local AC] wlan local-ac capwap source-vlan 100
2. Configure interfaces:
# Create VLAN 100, create VLAN-interface 100, and assign an IP address to the VLAN interface. The local AC will use this IP address to establish CAPWAP tunnels with the central ACs.
[Local AC] vlan 100
[Local AC-vlan100] quit
[Local AC] interface vlan-interface 100
[Local AC-Vlan-interface100] ip address 2.2.1.10 255.255.255.0
[Local AC-Vlan-interface100] quit
# Create VLAN 200, create VLAN-interface 200, and assign an IP address to the VLAN interface. The local AC assigns VLAN 200 to an AP when the AP comes online.
[Local AC] vlan 200
[Local AC-vlan200] quit
[Local AC] interface vlan-interface 200
[Local AC-Vlan-interface200] ip address 2.2.2.1 255.255.255.0
[Local AC-Vlan-interface200] quit
# Create VLAN 300, create VLAN-interface 300, and assign an IP address to the VLAN interface. The local AC assigns this VLAN to a wireless client when the client comes online.
[Local AC] vlan 300
[Local AC-vlan300] quit
[Local AC] interface vlan-interface 300
[Local AC-Vlan-interface300] ip address 2.2.3.1 255.255.255.0
[Local AC-Vlan-interface300] quit
# Specify GigabitEthernet 1/0/1 that connects the local AC to the Layer 2 switch as a trunk port, and assign the port to VLANs 100 and 200.
[Local AC] interface gigabitEthernet 1/0/1
[Local AC-GigabitEthernet1/0/1] port link-type trunk
[Local AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Local AC-GigabitEthernet1/0/1] quit
# Create VLAN 100, create VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward data and control packets between the central ACs and the local AC.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ip address 2.2.1.100 255.255.255.0
[L3 switch-Vlan-interface100] quit
# Create VLAN 200, create VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward CAPWAP tunnel packets between the local AC and the AP.
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ip address 2.2.2.100 255.255.255.0
[L3 switch-Vlan-interface200] quit
# Create VLAN 300 for wireless clients, create VLAN-interface 300, and assign an IP address to the VLAN interface.
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ip address 2.2.3.100 255.255.255.0
[L3 switch-Vlan-interface300] quit
# Create VLAN 2 for wireless clients, create VLAN-interface 2, and assign an IP address to the VLAN interface. The VLAN interface will be used to connect to the IMC server.
[L3 switch] vlan 2
[L3 switch-vlan2] quit
[L3 switch-Vlan-interface2] ip address 192.168.0.100 255.255.255.0
[L3 switch-Vlan-interface2] quit
# Add the interface that connects the Layer 3 switch to the IMC server to VLAN 2. (Details not shown.)
# Configure GigabitEthernet 1/0/1 (the port connected to Central AC 1) as a trunk port, and assign the port to VLAN 100.
[L3 switch] interface gigabitethernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100
[L3 switch-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/3 (the port connected to Central AC 2) as a trunk port, and assign the port to VLAN 100.
[L3 switch] interface gigabitEthernet 1/0/3
[L3 switch-GigabitEthernet1/0/3] port link-type trunk
[L3 switch-GigabitEthernet1/0/3] port trunk permit vlan 100
[L3 switch-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/2 (the port connected to Central AC 2) as a trunk port, and assign the port to VLAN 200 and VLAN 300.
[L3 switch] interface gigabitethernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 200 300
[L3 switch-GigabitEthernet1/0/2] quit
# Create VLAN 100, VLAN 200, and VLAN 300.
<L2 switch> system-view
[L2 switch] vlan 100
[L2 switch-vlan100] quit
[L2 switch] vlan 200
[L2 switch-vlan200] quit
[L2 switch] vlan 300
[L2 switch-vlan300] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the Layer 3 switch) as a trunk port, and assign the port to VLAN 100, VLAN 200, and VLAN 300.
[L2 switch] interface gigabitethernet 1/0/1
[L2 switch-GigabitEthernet1/0/1] port link-type trunk
[L2 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
[L2 switch-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/3 (the port connected to the local AC) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[L2 switch] interface gigabitEthernet 1/0/3
[L2 switch-GigabitEthernet1/0/3] port link-type trunk
[L2 switch-GigabitEthernet1/0/3] port trunk permit vlan 100 200
[L2 switch-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 (the port connected to the DHCP server) as a trunk port, and assign the port to VLAN 200 and VLAN 300.
[L2 switch] interface gigabitEthernet 1/0/4
[L2 switch-GigabitEthernet1/0/4] port link-type trunk
[L2 switch-GigabitEthernet1/0/4] port trunk permit vlan 200 300
[L2 switch-GigabitEthernet1/0/4] quit
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as a trunk port, remove the port from VLAN 1, assign the port to VLAN 200 and VLAN 300, and enable PoE on the port.
[L2 switch] interface gigabitEthernet 1/0/2
[L2 switch-GigabitEthernet1/0/2] port link-type trunk
[L2 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L2 switch-GigabitEthernet1/0/2] port trunk pvid vlan 200
[L2 switch-GigabitEthernet1/0/2] port trunk permit vlan 200 300
[L2 switch-GigabitEthernet1/0/2] poe enable
[L2 switch-GigabitEthernet1/0/2] quit
Configuring the DHCP server
# Configure GigabitEthernet 1/0/1 (the port connected to the Layer 2 switch) as a trunk port, and assign the port to VLAN 200 and VLAN 300.
<DHCP Server> system-view
[DHCP Server] interface gigabitethernet 1/0/1
[DHCP Server-GigabitEthernet1/0/1] port link-type trunk
[DHCP Server-GigabitEthernet1/0/1] port trunk permit vlan 200 300
[DHCP Server-GigabitEthernet1/0/1] quit
[DHCP Server] vlan 200
[DHCP Server-vlan200] quit
[DHCP Server] interface vlan-interface 200
[DHCP Server-Vlan-interface200] ip address 2.2.2.200 255.255.255.0
[DHCP Server-Vlan-interface100] quit
[DHCP Server] vlan 300
[DHCP Server-vlan300] quit
[DHCP Server] interface vlan-interface 300
[Dhcp Serve-Vlan-interface300] ip address 2.2.3.200 255.255.255.0
[DHCP Server-Vlan-interface300] quit
# Enable the DHCP service.
[DHCP Server] dhcp enable
# Configure DHCP address pool vlan200. In the address pool, specify the Layer 3 switch as the gateway and 2.2.2.0/24 as the subnet for dynamic allocation, and then exclude the IP addresses of the Layer 3 switch and the IP address of the local AC in VLAN 200 from dynamic allocation.
[DHCP Server] dhcp server ip-pool vlan200
[DHCP Server-dhcp-pool-vlan200] gateway-list 2.2.2.100
[DHCP Server-dhcp-pool-vlan200] network 2.2.2.0 mask 255.255.255.0
[DHCP Server-dhcp-pool-vlan200] forbidden-ip 2.2.2.100 2.2.2.1
# Configure Option 43 to deploy the IP address of central AC 1 (2.2.1.1) and the IP address of central AC 2 (2.2.1.2) to the AP.
[DHCP Server-dhcp-pool-vlan200] option 43 hex 800b0000010202010102020102
[DHCP Server-dhcp-pool-vlan200] quit
# Configure DHCP address pool vlan300. In the address pool, specify the Layer 3 switch as the gateway, 2.2.3.0/24 as the subnet for dynamic allocation, and 8.8.8.8 as the DNS server address, and then exclude the IP address of the Layer 3 switch and the IP address of the local AC in VLAN 300 from dynamic allocation.
[DHCP Server] dhcp server ip-pool vlan300
[DHCP Server-dhcp-pool-vlan300] gateway-list 2.2.3.100
[DHCP Server-dhcp-pool-vlan300] network 2.2.3.0 mask 255.255.255.0
[DHCP Server-dhcp-pool-vlan300] dns-list 8.8.8.8
[DHCP Server-dhcp-pool-vlan300] forbidden-ip 2.2.3.100 2.2.3.1
Configuring the RADIUS server
In this example, the RADIUS server runs IMC PLAT 7.1 (E0303p13), IMC EIA 7.1 (F0302p08), and IMC EIP 7.1 (F0302p08).
Adding the central ACs as access devices to IMC
This example only illustrates the process to add Central AC 1 to IMC as an access device. You can add Central AC 2 at 2.2.1.2 to IMC in the same way Central AC 1 is added.
To add Central AC 1 to IMC as an access device:
1. Log in to IMC and click the User tab.
2. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
3. Click Add.
The Add Access Device page opens.
4. In the Access Configuration area, configure the following parameters, as shown in Figure 2:
¡ Enter 123456 in the Shared Key and Confirm Shared Key fields. The shared key must be the same as the authentication and accounting shared keys configured on the AC.
¡ Use the default values for other parameters.
5. In the Device List area, click Select or Add Manually to add Central AC 1 at 2.2.1.1 as an access device.
The IP address must be the source IP address specified for outgoing RADIUS packets on the AC.
6. Click OK.
Figure 2 Adding an access device
Adding an access policy
1. From the navigation tree, select User Access Policy > Access Policy.
2. Click Add.
3. On the Add Access Policy page, configure the following parameters, as shown in Figure 3:
¡ Enter 802.1X-CAC1 in the Access Policy Name field.
¡ Select Ungrouped from the Service Group list.
¡ Select EAP-PEAP from the Preferred EAP Type list, and select EAP-MSCHAPv2 from the Subtype list.
The certificate subtype on the IMC server must be the same as the identity authentication method configured on the wireless client.
4. Click OK.
Figure 3 Adding an access policy
Adding an access service
1. From the navigation tree, select User Access Policy > Access Service.
2. Click Add.
3. On the Add Access Service page, configure the following parameters, as shown in Figure 4:
¡ Enter 802.1X-CAC1 in the Service Name field.
¡ Select 802.1X-CAC1 from the Default Access Policy list.
4. Click OK.
Figure 4 Adding an access service
Adding an access user
1. From the navigation tree, select Access User > Access User.
The access user list opens.
2. Click Add.
The Add Access User page opens.
3. In the Access Information area, configure the following parameters, as shown in Figure 5:
a. Click Select or Add User to associate the user with IMC Platform user 802.1X-CAC.
b. Enter client in the Account Name field.
c. Enter 123456 in the Password and Confirm Password fields.
4. In the Access Service area, select 802.1X-CAC1 from the list.
5. Click OK.
Figure 5 Adding an access user account
# On the wireless client, verify that the client can pass 802.1X authentication, associate with the AP, and access the wireless network. (Details not shown.)
# Display detailed WLAN client information.
<System> display wlan client
Total number of clients: 1
MAC address User name AP name R IP address VLAN
90f0-5266-7601 client ap1 1 2.2.3.58 300
# Display online 802.1X user information.
<System> display dot1x connection
Total connections: 1
User MAC address : 90f0-5266-7601
AP name : ap1
Radio ID : 1
SSID : l18341-fc-3510-bd-dot1x
BSSID : 60da-838a-97f0
Username : client
Authentication domain : imc
IPv4 address : 2.2.3.58
Authentication method : EAP
Initial VLAN : 300
Authorization VLAN : 100
Authorization ACL number : N/A
Authorization user profile : N/A
Termination action : Default
Session timeout period : 36000001 s
Online from : 2020/12/21 11:27:11
Online duration : 0h 1m 1s
Configuration files
· Layer 3 switch:
Vlan 2
vlan 100
vlan 200
vlan 300
interface Vlan-interface2
interface Vlan-interface100
interface Vlan-interface200
interface Vlan-interface300
port trunk permit vlan 1 100
port trunk permit vlan 1 200 300
· Central AC 1:
vlan 100
akm mode dot1x
cipher-suite ccmp
security-ie rsn
dot1x domain imc
ip address 2.2.1.1 255.255.255.0
ip route-static 0.0.0.0 0 2.2.1.100
radius scheme imc
key authentication cipher $c$3$YVdYhyr5oUtYPySJKGJqNbEzSPAITDchdA==
key accounting cipher $c$3$/Vmh1lA5ctoybnGIjEUo9M7Fb5UWh0hd1g==
nas-ip 2.2.1.1
domain imc
switch-back enable
ap ap1
ap-model WA6320
map-configuration cfa0:/map.txt
radio 1
radio enable
radio 2
priority 7
· Central AC 2:
vlan 100
akm mode dot1x
cipher-suite ccmp
security-ie rsn
dot1x domain imc
ip address 2.2.1.2 255.255.255.0
radius scheme imc
nas-ip 2.2.1.2
domain imc
switch-back enable
ap ap1
ap-model WA6320
radio 1
radio enable
radio 2
priority 6
· Layer 2 switch:
vlan 100
vlan 200
vlan 300
port trunk permit vlan 1 100 200 300
poe enable
interface GigabitEthernet1/0/4
· DHCP server:
dhcp enable
vlan 200
vlan 300
dns-list 8.8.8.8
· Local AC:
vlan 100
vlan 200
vlan 300
Related documentation
· High Availability Configuration Guide in H3C Access Controllers Configuration Guides
· High Availability Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
