- 11-High availability
- 01-IRF Setup with LACP MAD Configuration Examples
- 02-IRF Setup with ARP MAD Configuration Examples
- 03-IRF Setup with Members Not Directly Connected Configuration Examples
- 04-IRF Setup with Members in One Chassis Configuration Examples
- 05-IRF Setup with Members in Different Chassis Configuration Examples
- 06-Dual-Link Backup Configuration Examples
- 07-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 08-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 09-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 10-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 11-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 12-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 13-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 14-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 15-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 16-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 17-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 18-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 19-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 20-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
| 03-IRF Setup with Members Not Directly Connected Configuration Examples | 100.16 KB |
H3C Access Controllers |
IRF Setup with Members Not Directly Connected |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Setting up a two-member IRF fabric with members not directly connected
IRF topo-domain ID and MAD domain ID restrictions
Transceiver module restrictions
IRF network interface shutdown restrictions
IRF port binding removal restrictions
IRF member device bridge MAC address restrictions
Feature compatibility and configuration restrictions
Introduction
The following information provides an example for setting up a two-member IRF fabric with members not directly connected.
The Intelligent Resilient Framework (IRF) technology is proprietary to H3C. This technology is a true stacking technology that creates a large virtual stack called IRF fabric from multiple devices to provide data center class availability and scalability. IRF offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of IRF and Ethernet link aggregation.
As shown in Figure 1, use AC 1 and AC 2 to set up an IRF fabric. The IRF network interfaces of the ACs are connected through a Layer 2 switch.
When you set up an IRF fabric with members not directly connected, follow the restrictions and guidelines in this section.
Hardware compatibility
An access controller can form an IRF fabric only with access controllers of the same model.
Software requirements
All IRF member devices must run the same software image version as the master. For software synchronization, make sure the software auto-update feature is enabled. By default, this feature is enabled. To enable this feature, use the irf auto-update enable command.
IRF size restrictions
The maximum number of member devices in an IRF fabric varies by device model.
IRF member ID restrictions
Make sure each IRF member device in an IRF fabric is assigned a unique member ID. To change the member ID of a member device, use the irf member renumber command. For the new member ID to take effect, you must reboot the device. To ensure correct multi-active detection and avoid service interruption, make sure the new member ID is unique among the member devices in the same IRF MAD domain and IRF topo-domain.
The index of the IRF port on a member device must be the same as the IRF member ID of that member device.
Make sure all member devices have the same topo-domain ID and MAD domain ID. For a new topo-domain ID to take effect on a device, you must reboot the device.
An IRF fabric has only one IRF MAD domain ID. You can change the IRF MAD domain ID by using the irf domain command on the master device. The IRF MAD domain ID takes effect on all member devices. To ensure correct multi-active detection and avoid service interruption, make sure the IRF MAD domain ID is unique in the network.
IRF port binding requirements
An IRF port must have a minimum of one hybrid channel, or a minimum of one data channel and one control channel. If a hybrid channel already exists on the IRF port, do not configure a data or control channel on the IRF port. If a data or control channel already exists on the IRF port, do not configure a hybrid channel on the IRF port.
The network interfaces bound to an IRF port must operate at the same rate. The two ends of an IRF link must operate at the same rate.
For the port bindings to take effect, perform the following tasks:
1. Save the configuration.
2. Reboot the device or activate the IRF port configuration.
Do not use 100M transceiver modules to set up IRF links for 100Base-FX/1000Base-X SFP interfaces.
Do not use 1G transceiver modules to set up IRF links for 10GBase-R SFP+ interfaces.
You cannot use the shutdown command on the IRF standby device to shut down an IRF network interface if the interface is the only control channel available on the device. To shut down the IRF link in this situation, shut down the IRF network interface on the master device.
To remove a network interface from an IRF port, you must first shut down the IRF network interface.
Connectivity requirements
Make sure the member devices have Layer 2 connectivity with each other.
If the IRF fabric contains only two member devices, you can connect the member devices directly or through Layer 2 intermediate devices. If the IRF fabric contains more than two member devices, you must connect the member devices through Layer 2 intermediate devices.
IRF merge restrictions
If the IRF fabric splits, do not change the IRF settings on any IRF member devices before they reunite.
Member devices cannot join the same IRF fabric if they have the same bridge MAC address.
Ethernet link aggregation restrictions
On the Layer 2 intermediate devices, you must configure the aggregate interfaces connected to IRF network interfaces to operate in static mode. If you configure the aggregate interfaces to operate in dynamic mode, the devices might get stuck and the IRF fabric might even split.
On the Layer 2 intermediate devices, you must configure the aggregate interfaces used for LACP MAD to operate in dynamic mode.
On the Layer 2 intermediate devices, do not configure per-packet load sharing on the Layer 2 link aggregation groups that connect to multiple member devices of the IRF fabric.
After the IRF fabric is successfully established, configure Layer 2 dynamic Ethernet aggregate interfaces on the IRF fabric for service packet transmission.
VLAN restrictions
Do not assign IRF links to VLANs that run on links that forward data traffic.
NAT restrictions
NAT is not supported on an IRF fabric.
Spanning tree feature restrictions
On the Layer 2 intermediate devices, disable the spanning tree feature on the ports through which packets of an IRF member device reaches another IRF member device.
If LACP MAD is used, do not enable the spanning tree feature on the IRF member devices and on the ports that connect the Layer 2 intermediate devices to the IRF network interfaces. Any violation might cause service interruption.
Procedures
Configuring AC 1
# Assign Ten-GigabitEthernet 1/0/25 to the IRF port.
<AC1> system-view
[AC1] irf-port 1
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/25
[AC1-irf-port1] quit
# Specify the member priority as 2. AC 1 will be the master device.
[AC1] irf member 1 priority 2
# Save the configuration.
[AC1] save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
# Activate the IRF port configuration.
[AC1] irf-port-configuration active
Configuring AC 2
# Change the IRF member ID to 2.
<AC2> system-view
[AC2] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[
Y/N]:y
[AC2] quit
# Reboot the AC for the new member ID to take effect.
<AC2> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
Now rebooting, please wait...
# Assign Ten-GigabitEthernet 2/0/25 to the IRF port.
<AC2> system-view
[AC2] irf-port 2
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/25
[AC2-irf-port2] quit
[AC2] save
[AC2] irf-port-configuration active
AC 1 and AC 2 perform master election. AC 2 fails the master election and reboots to form an IRF fabric with AC 1.
Configuring the IRF fabric
# Change the name of the IRF fabric to IRF.
<AC1> system-view
[AC1] system-name IRF
# Configure descriptions for AC 1 and AC 2, respectively.
[IRF] irf member 1 description AC 1
[IRF] irf member 2 description AC 2
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the aggregation group of the aggregate interface to operate in dynamic mode.
[IRF] interface bridge-aggregation 1
[IRF-Bridge-Aggregation1] link-aggregation mode dynamic
# Enable LACP MAD on Bridge-Aggregation 1.
[IRF-Bridge-Aggregation1] mad enable
[IRF-Bridge-Aggregation1] quit
# Enable link-aggregation traffic redirection.
[IRF] link-aggregation lacp traffic-redirect-notification enable
# Assign GigabitEthernet 1/0/1 to aggregation group 1.
[IRF] interface gigabitethernet 1/0/1
[IRF-GigabitEthernet1/0/1] port link-aggregation group 1
[IRF-GigabitEthernet1/0/1] quit
# Assign GigabitEthernet 2/0/1 to aggregation group 1.
[IRF] interface gigabitethernet 2/0/1
[IRF-GigabitEthernet2/0/1] port link-aggregation group 1
[IRF-GigabitEthernet2/0/1] quit
Configuring Switch
Configure links for interfaces connected to the IRF network interfaces:
# Create VLAN 400 and assign the network interfaces on IRF links to the VLAN.
<Switch> system-view
[Switch] vlan 400
[Switch-vlan400] port ten-gigabitethernet 1/0/25
[Switch-vlan400] port ten-gigabitethernet 1/0/26
[Switch-vlan400] quit
# Disable the spanning tree feature on Ten-GigabitEthernet 1/0/25 and Ten-GigabitEthernet 1/0/26.
[Switch] interface ten-gigabitethernet 1/0/25
[Switch-Ten-GigabitEthernet1/0/25] undo stp enable
[Switch-Ten-GigabitEthernet1/0/25] quit
[Switch] interface ten-gigabitethernet 1/0/26
[Switch-Ten-GigabitEthernet1/0/26] undo stp enable
[Switch-Ten-GigabitEthernet1/0/26] quit
Configure links used for transmitting service packets and LACP MAD packets between the switch and IRF fabric:
[Switch] interface bridge-aggregation 1
[Switch-Bridge-Aggregation1] link-aggregation mode dynamic
[Switch-Bridge-Aggregation1] quit
[Switch-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign GigabitEthernet 1/0/2 to aggregation group 1.
[Switch-GigabitEthernet1/0/2] port link-aggregation group 1
[Switch] link-aggregation lacp traffic-redirect-notification enable
# Display IRF information. Verify that AC 1 is the master device.
[IRF] display irf
Member ID Role Priority CPU MAC Description
*1 Master 2 50da-0051-2608 AC 1
+2 Standby 1 50da-0051-2670 AC 2
The asterisk (*) indicates the master.
The plus sign (+) indicates the device through which you are logged in.
The right angle bracket (>) indicates the device's stack capability is disabled.
Bridge MAC of the IRF: 50da-0051-2608
Auto upgrade : Enabled
MAC persistence : 6 min
Topo-domain ID : 0
Auto merge : Enabled
# Display IRF link information. Verify that the IRF network interfaces on both member devices are up.
[IRF] display irf link
Member ID Member Interfaces Status
1 XGE1/0/25(ctrl&data) Up
2 XGE2/0/25(ctrl&data) Up
# On the IRF fabric, display detailed information about aggregation groups. Verify that GigabitEthernet 1/0/1 and GigabitEthernet 2/0/1 are in aggregation group 1 and are in Selected state.
[IRF] display link-aggregation verbose
G -- Defaulted, H -- Expired
Aggregation Mode: Dynamic
System ID: 0x8000, 50da-0051-2608
Local:
Port Status Priority Oper-Key Flag
GE1/0/1 S 32768 1 {ACDEF}
GE2/0/1 S 32768 1 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE1/0/1 1 32768 1 0x8000, 3897-d633-f3c6 {ACDEF}
GE2/0/1 2 32768 1 0x8000, 3897-d633-f3c6 {ACDEF}
# On the switch, display detailed information about aggregation groups. Verify that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are in aggregation group 1 and are in Selected state.
[Switch] display link-aggregation verbose
I -- Individual, * -- Management port
Management VLAN : None
System ID: 0x8000, 3897-d633-f3c6
Local:
GE1/0/2 S 32768 1 {ACDEF}
Remote:
GE1/0/1 2 32768 1 0x8000, 50da-0051-2608 {ACDEF}
GE1/0/2 31 32768 1 0x8000, 50da-0051-2608 {ACDEF}
Configuration files
· IRF fabric:
sysname IRF
irf mac-address persistent timer
irf auto-merge enable
irf member 2 priority 1
irf-port 1
port group interface Ten-GigabitEthernet1/0/25
irf-port 2
port group interface Ten-GigabitEthernet2/0/25
interface Bridge-Aggregation1
mad enable
interface GigabitEthernet2/0/1
· Switch:
vlan 400
port access vlan 400
undo stp enable
interface Ten-GigabitEthernet1/0/26
undo stp enable
Related documentation
· High Availability Configuration Guide in H3C Access Controllers Configuration Guides
· High Availability Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
