- 11-High availability
- 01-IRF Setup with LACP MAD Configuration Examples
- 02-IRF Setup with ARP MAD Configuration Examples
- 03-IRF Setup with Members Not Directly Connected Configuration Examples
- 04-IRF Setup with Members in One Chassis Configuration Examples
- 05-IRF Setup with Members in Different Chassis Configuration Examples
- 06-Dual-Link Backup Configuration Examples
- 07-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 08-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 09-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 10-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 11-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 12-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 13-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 14-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 15-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 16-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 17-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 18-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 19-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 20-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
| 05-IRF Setup with Members in Different Chassis Configuration Examples | 348.15 KB |
H3C Access Controller Modules |
IRF Setup with Members in Different Chassis |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Setting up an IRF fabric with access controller modules in different chassis
IRF topo-domain ID and MAD domain ID restrictions
IRF network interface shutdown restrictions
IRF port binding removal restrictions
IRF member device bridge MAC address restrictions
Feature compatibility and configuration restrictions
Introduction
The following information provides an example for setting up an IRF fabric with access controller modules in different chassis.
The Intelligent Resilient Framework (IRF) technology is proprietary to H3C. This technology is a true stacking technology that creates a large virtual stack called IRF fabric from multiple devices to provide data center class availability and scalability. IRF offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of IRF and Ethernet link aggregation.
As shown in Figure 1, AC 1 is inserted into slot 1 on Switch A and AC 2 is inserted into slot 4 on Switch B. Switch A and Switch B are in an IRF fabric named IRF 1.
Use AC 1 and AC 2 to set up an IRF fabric named IRF 2. Configure LACP MAD on the multi-member link aggregation to IRF 1.
When you set up an IRF fabric with members in different chassis, follow the restrictions and guidelines in this section.
Hardware compatibility
An access controller module can form an IRF fabric only with access controller modules of the same model.
Software requirements
All IRF member devices must run the same software image version as the master. For software synchronization, make sure the software auto-update feature is enabled.
IRF size restrictions
The maximum number of member devices in an IRF fabric varies by device model.
IRF member ID restrictions
Make sure each IRF member device in an IRF fabric is assigned a unique member ID. To change the member ID of a member device, use the irf member renumber command. For the new member ID to take effect, you must reboot the device. To ensure correct multi-active detection and avoid service interruption, make sure the new member ID is unique among the member devices in the same IRF MAD domain and IRF topo-domain.
The index of the IRF port on a member device must be the same as the IRF member ID of that member device.
Make sure all member devices have the same topo-domain ID and MAD domain ID. For a new topo-domain ID to take effect on a device, you must reboot the device.
An IRF fabric has only one IRF MAD domain ID. You can change the IRF MAD domain ID by using the irf domain command on the master device. The IRF MAD domain ID takes effect on all member devices. To ensure correct multi-active detection and avoid service interruption, make sure the IRF MAD domain ID is unique in the network.
IRF port binding requirements
An IRF port must have a minimum of one hybrid channel, or a minimum of one data channel and one control channel. If a hybrid channel already exists on the IRF port, do not configure a data or control channel on the IRF port. If a data or control channel already exists on the IRF port, do not configure a hybrid channel on the IRF port.
The network interfaces bound to an IRF port must operate at the same rate. The two ends of an IRF link must operate at the same rate.
For the port bindings to take effect, perform the following tasks:
1. Save the configuration.
2. Reboot the device or activate the IRF port configuration.
You cannot use the shutdown command on the IRF standby device to shut down an IRF network interface if the interface is the only control channel available on the device. To shut down the IRF link in this situation, shut down the IRF network interface on the master device.
To remove a network interface from an IRF port, you must first shut down the IRF network interface.
Connectivity requirements
Make sure the member devices have Layer 2 connectivity with each other.
If the IRF fabric contains only two member devices, you can connect the member devices directly or through Layer 2 intermediate devices. If the IRF fabric contains more than two member devices, you must connect the member devices through Layer 2 intermediate devices.
IRF merge restrictions
If the IRF fabric splits, do not change the IRF settings on any IRF member devices before they reunite.
Member devices cannot join the same IRF fabric if they have the same bridge MAC address.
Ethernet link aggregation restrictions
On the Layer 2 intermediate devices, you must configure the aggregate interfaces connected to IRF network interfaces to operate in static mode. If you configure the aggregate interfaces to operate in dynamic mode, the devices might get stuck and the IRF fabric might even split.
On the Layer 2 intermediate devices, you must configure the aggregate interfaces used for LACP MAD to operate in dynamic mode.
On the Layer 2 intermediate devices, do not configure per-packet load sharing on the Layer 2 link aggregation groups that connect to multiple member devices of the IRF fabric.
On the intermediate devices, aggregate the physical links that connect to the IRF network interfaces of the IRF fabric.
If Bridge-Aggregation 1 exists by default, delete the aggregate interface to remove all its member ports from the aggregate interface.
After the IRF fabric is successfully established, configure Layer 2 dynamic Ethernet aggregate interfaces on the IRF fabric for service packet transmission.
VLAN restrictions
Do not assign IRF links to VLANs that run on links that forward data traffic.
NAT restrictions
NAT is not supported on an IRF fabric.
Spanning tree feature restrictions
To avoid service interruption, do not enable the spanning tree feature on the access controller modules or on the ports through which packets of an IRF member device reaches another IRF member device on the Layer 2 intermediate devices.
WLAN hardware fast forwarding restrictions
To use WLAN hardware fast forwarding on an IRF fabric that contains access controller modules, follow these restrictions and guidelines:
· For the LSQM1WCMX20, LSUM1WCMX20RT, and EWPXM2WCMD0F modules, make sure the following requirements are met: Each module has one Ten-GigabitEthernet interface to act as a non-IRF network interface and the other Ten-GigabitEthernet interface to act as an IRF network interface.
· For the LSUM1WCME0, EWPXM1WCME0, LSQM1WCMX40, LSUM1WCMX40RT, and EWPXM1MAC0 modules, make sure the following requirements are met: On each module, the Ten-GigabitEthernet interfaces in one group act as non-IRF network interfaces and the Ten-GigabitEthernet interfaces in the other group act as IRF network interfaces. Ten-GigabitEthernet n/0/1 and Ten-GigabitEthernet n/0/3 belong to one group, and Ten-GigabitEthernet n/0/2 and Ten-GigabitEthernet n/0/4 belong to another group. The integer n represents the IRF member ID.
Procedures
Configuring IRF 1
In this example, IRF 1 has been set up.
1. Configure links used for transmitting LACP MAD packets between IRF 1 and IRF 2:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the aggregation group of the aggregate interface to operate in dynamic mode.
<IRF1> system-view
[IRF1] interface bridge-aggregation 1
[IRF1-Bridge-Aggregation1] link-aggregation mode dynamic
[IRF1-Bridge-Aggregation1] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/2 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 1/2/0/2
[IRF1-Ten-GigabitEthernet1/2/0/2] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet1/2/0/2] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/4 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 1/2/0/4
[IRF1-Ten-GigabitEthernet1/2/0/4] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet1/2/0/4] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/2 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 2/4/0/2
[IRF1-Ten-GigabitEthernet2/4/0/2] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet2/4/0/2] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/4 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 2/4/0/4
[IRF1-Ten-GigabitEthernet2/4/0/4] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet2/4/0/4] quit
2. Configure links used for network interfaces that connect to IRF 2:
# Create Layer 2 aggregate interface Bridge-Aggregation 2 for aggregating links to the IRF network interfaces of AC 1.
[IRF1] interface bridge-aggregation 2
[IRF1-Bridge-Aggregation2] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/1 to aggregation group 2.
[IRF1] interface ten-gigabitethernet 1/2/0/1
[IRF1-Ten-GigabitEthernet1/2/0/1] port link-aggregation group 2
[IRF1-Ten-GigabitEthernet1/2/0/1] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/3 to aggregation group 2.
[IRF1] interface ten-gigabitethernet 1/2/0/3
[IRF1-Ten-GigabitEthernet1/2/0/3] port link-aggregation group 2
[IRF1-Ten-GigabitEthernet1/2/0/3] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 3 for aggregating links to the IRF network interfaces of AC 2.
[IRF1] interface bridge-aggregation 3
[IRF1-Bridge-Aggregation3] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/1 to aggregation group 3.
[IRF1] interface ten-gigabitethernet 2/4/0/1
[IRF1-Ten-GigabitEthernet2/4/0/1] port link-aggregation group 3
[IRF1-Ten-GigabitEthernet2/4/0/1] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/3 to aggregation group 3.
[IRF1] interface ten-gigabitethernet 2/4/0/3
[IRF1-Ten-GigabitEthernet2/4/0/3] port link-aggregation group 3
[IRF1-Ten-GigabitEthernet2/4/0/3] quit
# Create VLAN 400 and assign Bridge-Aggregation 2 and Bridge-Aggregation 3 to the VLAN. The VLAN will transmit traffic for IRF links.
[IRF1] vlan 400
[IRF1-vlan400] port bridge-aggregation 2
[IRF1-vlan400] port bridge-aggregation 3
[IRF1-vlan400] quit
# Disable the spanning tree feature on Bridge-Aggregation 2 and Bridge-Aggregation 3.
[IRF1-Bridge-Aggregation2] undo stp enable
[IRF1-Bridge-Aggregation3] undo stp enable
3. Enable link-aggregation traffic redirection.
[IRF1] link-aggregation lacp traffic-redirect-notification enable
Configuring AC 1
# Assign internal ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/3 to the IRF port.
<AC1> system-view
[AC1] irf-port 1
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the \"irf-port-configuration active\" command to activate the IRF ports.
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/3
[AC1-irf-port1] quit
# Specify the member priority as 2. AC 1 will be the master device.
[AC1] irf member 1 priority 2
# Save the configuration.
[AC1] save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):irf.cfg
# Activate the IRF port configuration.
[AC1] irf-port-configuration active
Configuring AC 2
# Change the IRF member ID to 2.
<AC2> system-view
[AC2] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[
Y/N]:y
[AC2] quit
# Reboot AC 2 for the new member ID to take effect.
<AC2> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
Now rebooting, please wait...
# Assign internal ports Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/3 to the IRF port.
<AC2> system-view
[AC2] irf-port 2
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/1
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/3
[AC2-irf-port2] quit
[AC2] save
Please input the file name(*.cfg)[cfa0:/ irf.cfg]
# Activate IRF port configuration.
[AC2] irf-port-configuration active
AC 1 and AC 2 perform master election. AC 2 fails the master election and reboots to form an IRF fabric with AC 1.
Configuring IRF 2
IMPORTANT: IRF split causes network conflicts, because the split IRF fabrics operate with the same IP address. To avoid this issue, configure MAD settings. |
# Change the name of the IRF fabric to IRF2.
<AC1> system-view
[AC1] system-name IRF2
# Configure descriptions for AC 1 and AC 2, respectively.
[IRF2] irf member 1 description AC 1
[IRF2] irf member 2 description AC 2
# Delete the system-defined aggregate interface named Bridge-Aggregation 1. The member ports will automatically leave the aggregation group of Bridge-Aggregation 1.
[IRF2] undo interface bridge-aggregation 1
[IRF2] interface bridge-aggregation 1
[IRF2-Bridge-Aggregation1] link-aggregation mode dynamic
# Enable LACP MAD on Bridge-Aggregation 1.
[IRF2-Bridge-Aggregation1] mad enable
[IRF2-Bridge-Aggregation1] quit
# Enable link-aggregation traffic redirection.
[IRF2] link-aggregation lacp traffic-redirect-notification enable
# Assign internal port Ten-GigabitEthernet 1/0/2 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 1/0/2
[IRF2-Ten-GigabitEthernet1/0/2] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet1/0/2] quit
# Assign internal port Ten-GigabitEthernet 1/0/4 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 1/0/4
[IRF2-Ten-GigabitEthernet1/0/4] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet1/0/4] quit
# Assign internal port Ten-GigabitEthernet 2/0/2 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 2/0/2
[IRF2-Ten-GigabitEthernet2/0/2] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet2/0/2] quit
# Assign internal port Ten-GigabitEthernet 2/0/4 to aggregation group 1.
[IRF2] interface ten-gigabitEthernet 2/0/4
[IRF2-Ten-GigabitEthernet2/0/4] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet2/0/4] quit
# Display IRF information on IRF 2. Verify that AC 1 is the master device.
[IRF2] display irf
Member ID Role Priority CPU MAC Description
*+1 Master 2 70f9-6d6d-5a10 AC 1
2 Standby 1 70f9-6d6d-5a80 AC 2
The asterisk (*) indicates the master.
The plus sign (+) indicates the device through which you are logged in.
The right angle bracket (>) indicates the device's stack capability is disabled.
Bridge MAC of the IRF: 70f9-6d6d-5a10
Auto upgrade : Enabled
MAC persistence : 6 min
Topo-domain ID : 0
Auto merge : Enabled
# Display IRF link information. Verify that the IRF network interfaces on both member devices are up.
[IRF2] display irf link
Member ID Member Interfaces Status
1 XGE1/0/1(ctrl&data) Up
XGE1/0/3(ctrl&data) Up
2 XGE2/0/1(ctrl&data) Up
XGE2/0/3(ctrl&data) Up
# On IRF 2, display detailed information about aggregation groups. Verify that Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/4, Ten-GigabitEthernet 2/0/2, and Ten-GigabitEthernet 2/0/4 are in aggregation group 1 and in Selected state.
[IRF2] display link-aggregation verbose
G -- Defaulted, H -- Expired
Aggregation Mode: Dynamic
Loadsharing Type: NonS
System ID: 0x8000, 50da-005b-8b98
Local:
Port Status Priority Oper-Key Flag
XGE1/0/2 S 32768 1 {ACDEF}
XGE1/0/4 S 32768 1 {ACDEF}
XGE2/0/2 S 32768 1 {ACDEF}
XGE2/0/4 S 32768 1 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
XGE1/0/2 1943 32768 3 0x8000, 741f-4a56-9890 {ACDEF}
XGE1/0/4 1944 32768 3 0x8000, 741f-4a56-9890 {ACDEF}
XGE2/0/2 2234 32768 3 0x8000, 741f-4a56-9890 {ACDEF}
XGE2/0/4 2235 32768 3 0x8000, 741f-4a56-9890 {ACDEF}
# On IRF 1, display detailed information about aggregation groups. Verify the link aggregation settings and verify that all member ports in the aggregation groups are in Selected state.
[IRF1] display link-aggregation verbose
System ID: 0x8000, 0cda-41c5-a6a0
Local:
XGE1/2/0/2 S 32768 1 {ACDEF}
XGE1/2/0/4 S 32768 1 {ACDEF}
XGE2/4/0/2 S 32768 1 {ACDEF}
XGE2/4/0/4 S 32768 1 {ACDEF}
Remote:
XGE1/2/0/2 5 32768 2 0x8000, 70f9-6d6d-5a80 {ACDEF}
XGE1/2/0/4 6 32768 2 0x8000, 70f9-6d6d-5a80 {ACDEF}
XGE2/4/0/2 11 32768 2 0x8000, 70f9-6d6d-5a80 {ACDEF}
XGE2/4/0/4 12 32768 2 0x8000, 70f9-6d6d-5a80 {ACDEF}
Aggregate Interface: Bridge-Aggregation2
Aggregation Mode: Static
XGE1/2/0/1 S 32768 3
XGE1/2/0/3 S 32768 3
Aggregate Interface: Bridge-Aggregation3
XGE2/4/0/1 S 32768 2
XGE2/4/0/3 S 32768 2
Configuration files
· IRF 2:
sysname IRF2
irf mac-address persistent timer
irf auto-update enable
irf auto-merge enable
irf member 2 priority 1
irf-port 1
port group interface Ten-GigabitEthernet1/0/1
port group interface Ten-GigabitEthernet1/0/3
irf-port 2
port group interface Ten-GigabitEthernet2/0/1
port group interface Ten-GigabitEthernet2/0/3
interface Bridge-Aggregation1
mad enable
interface Ten-GigabitEthernet1/0/4
interface Ten-GigabitEthernet2/0/2
interface Ten-GigabitEthernet2/0/4
· IRF 1:
vlan 400
interface Bridge-Aggregation2
port access vlan 400
undo stp enable
interface Bridge-Aggregation3
undo stp enable
interface Ten-GigabitEthernet1/2/0/1
port link-mode bridge
interface Ten-GigabitEthernet1/2/0/2
interface Ten-GigabitEthernet1/2/0/3
interface Ten-GigabitEthernet1/2/0/4
interface Ten-GigabitEthernet2/4/0/1
interface Ten-GigabitEthernet2/4/0/2
interface Ten-GigabitEthernet2/4/0/3
interface Ten-GigabitEthernet2/4/0/4
Related documentation
· High Availability Configuration Guide in H3C Access Controllers Configuration Guides
· High Availability Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
