- 04-Layer 2 - LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-VLAN mapping configuration
- 07-Loop detection configuration
- 08-Spanning tree configuration
- 09-LLDP configuration
| 00-Preface | 100.25 KB |
Preface
This configuration guide covers Layer 2 technologies and features used on a LAN switched network.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the UniServer BX1010E Switch Module.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
