- H3C SR8800-X-S Router Series Installation Guide-5W103
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Router to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B FRUs and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Slot arrangement and port numbering
- 11-Appendix E Cables
- 12-Appendix F Cable Management
- 13-Appendix G Engineering Labels for Cables
| 07-Appendix A Chassis Views and Technical Specifications | 2.95 MB |
Appendix A Chassis views and technical specifications
Module power consumption and total power consumption
Chassis views
The SR8800-X-S AC and DC chassis are similar in appearance.
The figures in this chapter are for illustration only.
NOTE: The available chassis models and accessories vary by country and region. This document describes only the preceding models. For the chassis models and accessories available in your country or region, contact the local H3C marketing personnel. |
SR8802-X-S
Figure 1 SR8802-X-S front and rear views
(2) MPU section |
(3) Service module section |
(4) Fan tray section |
(5) PoE PEM (reserved) |
SR8803-X-S
Figure 2 SR8803-X-S front view
(1) MPU section |
(2) Service module section |
(3) Power supply section |
SR8806-X-S
Figure 3 SR8806-X-S front view
(1) MPU section |
SR8810-X-S
Figure 4 SR8810-X-S front view
(1) Service module section |
(2) MPU section |
Technical specifications
Weights and dimensions
Table 1 Chassis weights and dimensions
Model |
Weight (full configuration) |
Height |
Width |
Depth |
SR8802-X-S |
≤ 29 kg (63.93 lb) |
175 mm (6.89 in) (4 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
SR8803-X-S |
≤ 56 kg (123.46 lb) |
441 mm (17.36 in) (10 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
SR8806-X-S |
≤ 74 kg (163.14 lb) |
575 mm (22.64 in) (13 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
SR8810-X-S |
≤ 95 kg (209.44 lb) |
708 mm (27.87 in) (16 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
NOTE: Rack height is measured in RUs. One RU is 44.45 mm (1.75 in). |
Table 2 Card weights and dimensions
Model |
Net weight |
Height |
Width |
Depth |
1.40 kg (3.08 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
352 mm (13.86 in) |
SR07MPUA3 |
1.55 kg (3.42 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
352 mm (13.86 in) |
SR07SRPUA1 |
4.35 kg (9.59 lb) |
46 mm (1.81 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
3.40 kg (7.50 lb) |
46 mm (1.81 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SR07SRPUC1 |
3.30 kg (7.28 lb) |
46 mm (1.81 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
4.15 kg (9.15 lb) |
46 mm (1.81 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GT48LA1 |
3.31 kg (7.30 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPC-GE24L-E |
4.45 kg (9.81 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP24LA1 |
3.01 kg (6.64 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP48LA1 |
3.25 kg (7.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP48LB |
3.25 kg (7.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP24XP2LA |
3.08 kg (6.79 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP24XP2LB |
3.08 kg (6.79 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPC-GP24GE8XP2L-E |
4.45 kg (9.81 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPC-GE16XP4L-E |
4.35 kg (9.59 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP44XP4LA |
3.55 kg (7.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-GP44XP4LC |
3.60 kg (7.94 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP2LA1 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP4LA1 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP4LB |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP8LA |
3.44 kg (7.58 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP8LB |
3.44 kg (7.58 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP12LC |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XP24LC |
4.20 kg (9.26 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-XLP2XP4LC |
3.20 kg (7.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-CP1LC |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-CP2LB |
4.06 kg (8.95 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPC-CP2LA |
4.06 kg (8.95 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
MPE-1104 |
3.52 kg (7.76 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
SPEX-1204 |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPEX-1104-E |
3.45 kg (7.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPEX-1304S |
3.75 kg (8.27 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPEX-1404S |
3.65 kg (8.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
CSPEX-1504S |
3.85 kg (8.49 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
PIC-GP10L |
0.45 kg (0.99 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
PIC-XP1L |
0.45 kg (0.99 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
PIC-TCP8L |
0.40 kg (0.88 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
PIC-PSP4L |
0.40 kg (0.88 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
PIC-PS2G4L |
0.40 kg (0.88 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
PIC-PUP1L |
0.50 kg (1.10 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GT20L |
0.40 kg (0.88 lb) |
37 mm (1.46 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-ET16L |
0.33 kg (0.73 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GP4L |
0.31 kg (0.68 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GP8L |
0.29 kg (0.64 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GP10L1 |
0.30 kg (0.66 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GP10L-V2 |
0.35 kg (0.77 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-SP4L |
0.33 kg (0.73 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-SP8L |
0.30 kg (0.66 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-CLP2L |
0.32 kg (0.71 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-CLP4L |
0.33 kg (0.73 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-GP20L |
0.50 kg (1.10 lb) |
37 mm (1.46 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-XP2L |
0.29 kg (0.64 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-XP2L-LAN |
0.28 kg (0.62 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-XP4L1 |
0.30 kg (0.66 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-CP1L |
0.55 kg (1.21 lb) |
37 mm (1.46 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-CQ1L1 |
0.50 kg (1.10 lb) |
37 mm (1.46 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-PSP4L |
0.40 kg (0.88 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-TCP8L |
0.40 kg (0.88 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-XP5L |
0.30 kg (0.66 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-XP5L1 |
0.35 kg (0.77 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
MIC-QP1L |
0.35 kg (0.77 lb) |
18 mm (0.71 in) |
171 mm (6.73 in) |
157 mm (6.18 in) |
LSU1FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
LSU3FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
LSU1IPSBEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
LSU1ADECEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NOTE: The card dimensions are expressed in Height (H) × Width (W) × Depth (D) format. · H—Height of the front panel of the card. · W—Width of the front panel of the card. · D—Depth from the front panel of the card to the connector. |
Table 3 Power supply adapter weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
Compatible power supplies |
LSQM1PWRSPA |
4.42 kg (9.74 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in) |
PSR650-A and PSR650-D |
LSQM1PWRSPB |
4.95 kg (10.91 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in)) |
PSR1200-A and PSR1200-D |
Table 4 Power supply weights and dimensions
Model |
Net weight |
Height |
Width |
Depth |
PSR320-A |
1.9 kg (4.19 lb) |
40 mm (1.57 in) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-A |
2.5 kg (5.51 lb) |
40 mm (1.57 in) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-D |
2.3 kg (5.07 lb) |
40 mm (1.57 in) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1200-A |
2.6 kg (5.73 lb) |
40 mm (1.57 in)/1 RU |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1200-D |
2.5 kg (5.51 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1400-A |
8.3 kg (18.30 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in) |
PSR1400-D |
9.3 kg (20.50 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in) |
PSR2500-12AHD |
5.7 kg (12.57 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in) |
PSR2500-12D |
5.7 kg (12.57 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
382 mm (15.04 in) |
Table 5 Fan tray weights and dimensions
Model |
Net weight |
Height |
Width |
Depth |
SR8802-X-S fan tray |
0.9 kg (1.98 lb) |
27 mm (1.06 in) |
115 mm (4.53 in) |
338 mm (13.31 in) |
SR8803-X-S fan tray |
1.6 kg (3.53 lb) |
27 mm (1.06 in) |
203 mm (7.99 in) |
365 mm (14.37 in) |
SR8806-X-S fan tray |
2.2 kg (4.85 lb) |
28 mm (1.10 in) |
331 mm (13.03 in) |
365 mm (14.37 in) |
SR8810-X-S- fan tray |
3.0 kg (6.61 lb) |
28 mm (1.10 in) |
497 mm (19.57 in) |
380 mm (14.96 in) |
Total power consumption
The total power consumption equals the power consumption of all cards plus the fan tray power consumption:
· The minimum total power consumption equals the minimum static power consumption of all cards plus the minimum fan tray power consumption.
For example, the SR8803-X-S has two SR07SRPUA1 MPUs, three SPC-XP2LA1 cards, and one SR8803-X-S fan tray. Its minimum total power consumption is 2 × 49 + 3 × 43 + 16 = 243 W.
· The maximum total power consumption equals the maximum dynamic power consumption of all cards plus the maximum fan tray power consumption.
For example, the maximum total power consumption of the SR8803-X-S is 2 × 75 + 3 × 75 + 28 = 403 W.
To install a card into an operating device, make sure the remaining output power of the device is equal to or greater than 250 W. Otherwise, the card cannot operate correctly. The remaining output power equals the maximum output power minus the total power consumption.
For a router to successfully start up, make sure its total power consumption meets the following requirements:
· Does not exceed the maximum output power of the power supply on the router when the power supply mode is backup.
· Does not exceed the total maximum output power of both power supplies on the router when the power supply mode is load balancing.
For information about the power supply modes of the power supplies, see H3C SR8800-X Routers Probe Command Reference.
Card power consumption
The power consumption of the cards varies by card model and state. Table 6 shows the power consumption for different card models.
· The static power consumption of a card refers to the power consumed by the card under the following conditions:
¡ The card is running.
¡ All ports on the card are down.
¡ No transceiver module is available on the optical interface of the card.
· The dynamic power consumption of a card refers to the power consumed by the card when all the ports on the card are fully configured and send broadcasts.
Table 6 Card power consumption
Model |
Minimum static power consumption |
Maximum dynamic power consumption |
SR07MPUA1 |
28 W |
35 W |
SR07MPUA3 |
28 W |
35 W |
SR07SRPUA1 |
49 W |
75 W |
SR07SRPUB1 |
44 W |
60 W |
SR07SRPUC1 |
30 W |
45 W |
SR07SRPUD3 |
80 W |
110 W |
SPC-GT48LA1 |
67 W |
95 W |
CSPC-GE24L-E |
108 W |
114 W |
SPC-GP24LA1 |
47 W |
75 W |
SPC-GP48LA1 |
44 W |
95 W |
SPC-GP48LB |
43 W |
110 W |
SPC-GP24XP2LA |
54 W |
95 W |
SPC-GP24XP2LB |
51 W |
100 W |
101 W |
126 W |
CSPC-GE16XP4L-E |
107 W |
127 W |
SPC-GP44XP4LA |
83 W |
118 W |
SPC-GP44XP4LC |
90 W |
146 W |
SPC-XP2LA1 |
43 W |
55 W |
SPC-XP4LA1 |
53 W |
80 W |
SPC-XP4LB |
53 W |
80 W |
SPC-XP8LA |
117 W |
140 W |
SPC-XP8LB |
117 W |
170 W |
SPC-XP12LC |
91 W |
146 W |
SPC-XP24LC |
174 W |
250 W |
SPC-XLP2XP4LC |
91 W |
143 W |
SPC-CP1LC |
85 W |
120 W |
SPC-CP2LA |
144 W |
197 W |
SPC-CP2LB |
150 W |
197 W |
MPE-1104 |
91 W |
158 W |
SPEX-1204 |
88 W |
190 W |
CSPEX-1104-E |
79 W |
164 W |
CSPEX-1304S |
92 W |
184 W |
CSPEX-1404S |
120 W |
230 W |
CSPEX-1504S |
128 W |
261 W |
PIC-GP10L |
9.5 W |
21 W |
PIC-TCP8L |
9.70 W |
17 W |
PIC-PSP4L |
9.70 W |
18 W |
PIC-PS2G4L |
9.3 W |
16 W |
PIC-PUP1L |
14.30 W |
19 W |
PIC-XP1L |
12.5 W |
23.7 W |
MIC-GT20L |
9.2 W |
11.9 W |
MIC-ET16L |
8.6 W |
8.7 W |
MIC-CLP2L |
9.8 W |
10.9 W |
MIC-CLP4L |
9.8 W |
12.9 W |
MIC-SP4L |
9.6 W |
13.5 W |
MIC-SP8L |
14 W |
16.3 W |
MIC-GP4L |
0.8 W |
5.5 W |
MIC-GP8L |
0.6 W |
4.7 W |
MIC-GP10L1 |
2.1 W |
7.9 W |
MIC-GP10L-V2 |
9.3 W |
9.4 W |
MIC-GP20L |
7.6 W |
23 W |
MIC-XP2L |
10 W |
13 W |
MIC-XP2L-LAN |
6 W |
9 W |
MIC-XP4L1 |
11 W |
13 W |
MIC-XP5L |
10.4 W |
14.2 W |
MIC-XP5L1 |
11 W |
13 W |
MIC-QP1L |
3 W |
7 W |
MIC-CP1L |
3.3 W |
11.8 W |
MIC-CQ1L1 |
9 W |
15 W |
MIC-PSP4L |
29 W |
33 W |
MIC-TCP8L |
28 W |
30 W |
LSU1ADECEA0 |
109 W |
150 W |
LSU1FWCEA0 |
109 W |
250 W |
LSU3FWCEA0 |
109 W |
250 W |
LSU1IPSBEA0 |
109 W |
150 W |
NOTE: The maximum power consumption of an MPE, SPEX, or CSPEX card refers to the power usage when the card is fully configured with subcards that have the highest power consumption. |
Fan tray power consumption
Table 7 Fan tray power consumption
Model |
Minimum fan tray power consumption |
Maximum fan tray power consumption |
SR8802-X-S |
8 W |
15 W |
SR8803-X-S |
16 W |
28 W |
SR8806-X-S |
25 W |
43 W |
SR8810-X-S |
28 W |
50 W |
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121BTU/h.
The heat dissipation of a router depends on its power consumption. To calculate heat dissipation of the router, assume 90% power consumption is converted to heat, and the efficiency of the power supply is 80%. Heat dissipation/hour of the router is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.8 × 3.4121.
For the power consumption of the cards and fan trays for the SR8800-X-S series, see "Module power consumption and total power consumption."
Environmental specifications
Table 8 Environmental specifications
Operating |
Non-operating |
Temperature |
0°C to 45°C (32°F to 113°F) |
–40°C to +70°C (–40°F to +158°F) |
Relative humidity (noncondensing) |
10% RH to 95% RH |
5% RH to 95% RH |
Noise
The router uses fan trays that can automatically adjust the fan speed to meet the cooling requirements. The sound pressure level of the router varies by fan speed.
Model |
Sound pressure level |
At low fan speed |
At middle fan speed |
At full fan speed |
SR8802-X-S |
49.8 dBA |
51.6 dBA |
56.7 dBA |
SR8803-X-S |
51.6 dBA |
54.6 dBA |
56.1 dBA |
SR8806-X-S |
53.6 dBA |
56.2 dBA |
57.7 dBA |
SR8810-X-S |
53.5 dBA |
55.8 dBA |
56.7 dBA |
