02-Appendix A AP view and technical specifications
| 02-Appendix A AP view and technical specifications | 92.58 KB |
1 Appendix A AP view and technical specifications
AP view
Figure1-1 AP view
Technical specifications
Table1-1 Technical specifications
Item |
Specification |
Protocol |
IEEE802.11a/b/g/n/ac/ax |
Dimensions (H × W × D) |
250 × 101 × 110 mm (9.84 × 3.98 × 4.33 in) |
Weight |
1.1 kg (2.43 lb) |
Antenna |
Built-in omnidirectional antenna: · 2.4 GHz: 3 dBi gain · 5.1 GHz: 5 dBi gain · 5.8 GHz: 5 dBi gain |
≤16.32 W |
