| 06-Appendix B LEDs | 71.97 KB |
6 Appendix B LEDs
LEDs
(1) 100/1000MBASE-T autosensing port LEDs |
(2) 10GBASE-R-SFP+ autosensing port LEDs |
(3) 2.5G/1000BASE-T autosensing port LED |
(4) System status LED (SYS) |
LED description
LED |
Mark |
Status |
System status LED |
SYS |
Flashing green (4 Hz) |
The system is starting up. |
Flashing green (0.5 Hz) |
The system is operating correctly. |
Steady red |
A critical alarm has occurred, such as a power supply alarm, fan tray alarm, high temperature alarm, or software missing alarm. |
Off |
The device has not started up. |
100/1000BASE-T autosensing port LEDs |
N/A |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 1000 Mbps. |
Steady yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
The port is receiving or transmitting data at 100 Mbps. |
Off |
No link is present on the port. |
10GBASE-R- SFP+ autosensing port LEDs |
N/A |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 10 Gbps. |
Steady yellow |
A 1 Gbps link is present on the port. |
Flashing yellow |
The port is receiving or transmitting data at 1 Gbps. |
Off |
N/A |
Steady green |
A 2.5 Gbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 2.5 Gbps. |
Steady yellow |
Flashing yellow |
The port is receiving or transmitting data at 2.5 Mbps. |
Off |
