- 17-Network Management and Monitoring Configuration Guide
- 01-Information center configuration
- 02-Flow log configuration
- 03-Fast log output configuration
- 04-NetStream configuration
- 05-Cloud connection configuration
- 06-Mirroring configuration
- 07-Packet capture configuration
- 08-NQA configuration
- 09-Track configuration
- 10-BFD configuration
- 11-Monitor Link configuration
- 12-Smart Link configuration
- 13-Interface backup configuration
- 14-Interface collaboration configuration
- 15-System maintenance and debugging configuration
- 16-NTP configuration
- 17-EAA configuration
- 18-Process monitoring and maintenance configuration
- 19-NETCONF configuration
- 20-CWMP configuration
- 21-SNMP configuration
- 22-RMON configuration
- 23-Event MIB configuration
- 24-Process placement configuration
04-NetStream configuration | 52.48 KB |
Configuring session-based NetStream
Session-based NetStream aggregation modes
Session-based NetStream data export
Restrictions and guidelines: Session-based NetStream configuration
Display and maintenance commands session-based NetStream
About session-based NetStream
Session-based NetStream provides statistics for session-based services and exports the statistics in NetStream v9 format to NetStream servers.
For information about sessions, see session management in Security Configuration Guide.
Session-based NetStream aggregates session statistics according to the aggregation criteria of an aggregation mode and exports the statistics to NetStream servers.
Table 1 lists the available aggregation modes. In each mode, the system merges statistics for multiple sessions if each aggregation criterion is of the same value.
Table 1 Session-based NetStream aggregation modes
Aggregation mode |
Aggregation criteria |
App aggregation |
Application layer protocol ID. |
App-profile aggregation |
· Application layer protocol ID. · Traffic rule ID. |
App-user aggregation |
· Application layer protocol ID. · User IP address. |
Session-based NetStream uses an aging mechanism to export flow entry statistics to NetStream servers.
When the aging timer for a session-based NetStream entry expires, statistics about the entry is cleared from the cache and exported to the NetStream servers.
When the session-based NetStream cache is full, the device stops generating new flow entries. Statistics collection for existing flow entries is not affected.
A session-based NetStream entry is also exported in the following situations:
· The session itself ages out.
· The session is manually deleted by the administrator.
For session-based NetStream to work, DPI must be enabled on the device. For more information about DPI, see DPI Configuration Guide.
1. Enter system view.
2. Enable session-based NetStream.
session-based netstream enable
By default, session-based NetStream is disabled.
3. Enable session-based NetStream aggregation modes.
session-based netstream aggregation { app | app-profile | app-user } *
By default, all session-based NetStream aggregation modes are disabled.
4. Specify a destination host for session-based NetStream data export.
session-based netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
By default, no destination host is specified for session-based NetStream data export.
5. (Optional.) Specify a source IP address for session-based NetStream packets.
session-based netstream export source ip ip-address
By default, the source IP address of session-based NetStream packets is the primary IP address of the output interface.
6. (Optional.) Set the aging timer for cached session-based NetStream entries.
session-based netstream timeout minutes
By default, a session-based NetStream entry is can be cached for 5 minutes before being aged out.
Task |
Command |
Display session-based NetStream statistics in the cache. |
display session-based netstream aggregation-cache { app | app-profile | app-user } * |
