04-Policies
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70004-Policies
18-DLP
18-DLP 93.05 KB
DLP
This help contains the following topics:
·     Introduction
¡     DLP policies
·     Restrictions and guidelines
·     Configure DLP
¡     Configure a DLP policy
¡     Configure global configuration
¡     Configure resource management
Introduction
Data Loss Prevention (DLP) monitors and analyzes the traffic passing through network devices to identify and classify the data transmission and take the configured preventive actions against illegal data transmission.
DLP policies
A DLP policy defines one or more signatures to identify illegal data transmission and defines defensive actions, for example, output alarm logs, and send alarm emails.
A DLP policy contains the following rules:
·     Detection rules—Used to match keywords, file names, and other contents in the transmitted data.
·     Identity rules—Used to match the IP addresses, email addresses, and other identity attributes of the senders.
·     Response rules—Used to take preventive measures for data that matches detection rules and identity rules.
Deleting a resource in the resource management page might cause the cascade deletion as follows:
·     Deleting a regular expression will also delete all match conditions of detection rules that use the selected regular expression and might delete a DLP policy if no match conditions of detection rules exist in the DLP policy.
·     Deleting an email server will also delete all actions that apply to the selected email server and might delete a response rule if no actions exist in the response rule.
·     Deleting a file server simultaneously deletes all actions that apply to the selected file server and might delete a response rule if no actions exist in the response rule.
Configure DLP
Configure DLP as shown in Figure 1.
Figure 1 DLP configuration procedure
Configure a DLP policy, and then configure detection rules, identity rules, and response rules in the policy according to actual network security requirements.
1.     Click the Policies tab.
2.     In the navigation pane, select DLP > DLP policies.
3.     Click Create.
4.     Configure parameters for the DLP policy.
Table 1 DLP policy configuration items
Item
Policy name
Enter the name of the DLP policy. The name is case sensitive and valid characters include Chinese characters, letters, digits, underscores (_), and hyphens (-).
Enter a description for the DLP policy.
Scan mode
Select a scan mode:
·     Fast scan.
·     Complete scan.
Start policy
Select whether to start the DLP policy.
5.     Click the Detection rules tab.
a.     Click Create in the Add rule area to create a detection rule.
b.     Click Create in the Exceptional rules area to create an exceptional rule.
If the data matches an exceptional rule, the data does not match any detection rule. You can configure multiple detection rules and exceptional rules in a DLP policy.
Table 2 Detection rule configuration items
Item
Name
Enter the name of a detection rule. The name is case sensitive and valid characters include Chinese characters, letters, digits, underscores (_), and hyphens (-).
Severity level
Select the severity level of an event matching the detection rule:
·     High.
·     Medium.
·     Low.
·     Informational.
6.     Click Create in the Match condition area.
7.     Configure the match condition parameters.
Table 3 Match condition configuration items
Item
Match type
Select a match type for the detection rule:
·     Regular expression.
·     Keyword.
·     Fingerprint file.
·     File name.
·     File size.
·     File type.
·     Protocol.
Occurrence count method
Select an occurrence count method:
·     Count the number of matched regular expression—Select this method when the match type is set to Regular expression.
·     Check existence—Select this method when the match type is set to keyword.
·     Count the total number of matches—Select this method when the match type is set to fingerprint file.
This field is available only when the match type is set to Regular expression, keyword, or fingerprint file.
Counting scope
Select a counting scope:
·     Single file.
·     All file.
This field is available only when the match type is set to Regular expression or keyword.
Regular expression
Enter a regular expression.
This field is available only when the match type is set to Regular expression.
Case sensitive
Select whether the keyword for matching is case sensitive.
This field is available only when the match type is set to keyword.
Keyword
Select a criterion for keyword matching:
·     Match keywords—A true keyword match.
·     Match neighbor keywords—A fuzzy keyword match. You can configure left neighbor keyword, right neighbor keyword, and maximum distance.
Match whole word only
Select whether to match whole word only.
This field is available only when the match type is set to keyword. This field takes effect only for English keywords.
Fingerprint file
Select a fingerprint file for matching.
This field is available only when the match type is set to Fingerprint file.
Threshold
Enter a matching threshold with the sample file contents.
File type
Select a file type for matching.
This field is available only when the match type is set to File type.
File name
Enter a file name.
This field is available only when the match type is set to File name.
Maximum
Enter the maximum file size.
This field is available only when the match type is set to File size.
If both the maximum file size and the minimum file size are set to 0, the file size is not limited.
Minimum
Enter the minimum file size.
Protocol
Select a protocol for matching.
This field is available only when the match type is set to Protocol.
8.     Click OK.
9.     Click the Identity Rules tab.
a.     Click Create in the Add rule area to create an identity rule.
If the data matches an exceptional rule, the data does not match any identity rule. You can configure multiple identity rules and exceptional rules in a DLP policy.
Table 4 Identity rule configuration items
Item
Name
Enter the name of an identity rule. The name is case sensitive and valid characters include Chinese characters, letters, digits, underscores (_), and hyphens (-).
Severity level
Select the severity level of an event matching the identity rule:
·     High.
·     Medium.
·     Low.
·     Informational.
10.     Click Create in the Match condition area.
11.     Configure the match condition parameters.
Table 5 Match condition configuration items
Item
Match type
Select a match type for the identity rule:
·     Sender/user.
·     Recipient/user.
Email addresses
Enter email addresses for matching.
Recipient type
Select a recipient type:
·     Match all address—All destination email addresses match the entered email addresses.
·     Match any address—Only a specific number of destination email addresses match the entered email addresses.
This field is available only when the match type is set to Recipient/user.
Threshold
Enter a matching threshold with the email addresses.
This field is available only when the recipient type is set to Match any address.
IP version
Select an IP version:
·     IPv4.
·     IPv6.
IP addresses
Enter IP addresses for matching.
User
Select or enter users for matching.
Host names
Enter host names for matching.
12.     Click OK.
13.     Click the Response Rules tab.
Create or select a response rule. You can configure multiple response rules for a DLP policy.
14.     Click OK.
The global configuration applies to all DLP policies.
2.     In the navigation pane, select DLP > Global Configuration.
3.     On the Internal IP addresses tab, configure the IPv4 address object groups and IPv6 address object groups.
4.     Click Apply.
5.     Click the Monitoring Direction Setting tab.
6.     Configure the monitoring direction parameters.
Table 6 Monitoring direction configuration items
Item
Select a monitoring direction:
·     Bidirection—The DLP module monitors the packets sent to the internal network from the external network or packets sent to the external network from the internal network.
·     External to internal—The DLP module monitors the packets sent to the internal network from the external network.
·     Internal to external—The DLP module monitors the packets sent to the external network from the internal network.
·     No monitoring—The DLP module does not monitor packets.
7.     Click Apply.
8.     Click the Protocol filter configuration tab and select protocols to be monitored by the DLP module.
9.     Click Apply.
Configure fingerprint indexes
2.     In the navigation pane, select DLP > Resource Management.
3.     On the Fingerprint Indexes tab, click Create.
4.     Configure the fingerprint file resource parameters.
Table 7 Fingerprint file resource configuration items
Item
Name
Enter the name of the fingerprint file resource.
Fingerprint file
Import a fingerprint file.
5.     Click OK, and then you can view the newly created fingerprint file resource on the Fingerprint Indexes tab.
Configure regular expressions
3.     On the Regular Expressions tab, click Create.
4.     Configure the regular expression parameters.
Table 8 Regular expression configuration items
Item
Name
Enter the name of the regular expression.
Regular expression
5.     Click OK, and then you can view the newly created regular expression on the Regular Expressions tab.
Configure email alarm templates
3.     On the Email Alarm Templates tab, click Create.
4.     Configure the email alarm template parameters.
Table 9 Email alarm template configuration items
Item
Name
Enter the name of the email alarm template.
Email server
Enter an email server for sending emails.
Recipients
Enter the recipient email addresses.
Cc recipients
Enter the recipient email addresses for carbon copy.
Bcc recipients
Enter the recipient email addresses for blind carbon copy.
Theme
Enter the theme of alarm emails.
Body
Enter the contents of alarm emails.
5.     Click OK, and then you can view the newly created email alarm template on the Email Alarm Templates tab.
Configure email servers
3.     On the Email Servers tab, click Create.
4.     Configure the email server parameters.
Table 10 Email server configuration items
Item
Name
Enter the name of the email server.
Server address
Enter the IP address or host name of the email server.
Encrypted
Select whether to encrypt the interaction with the email server.
Authenticated
Select whether authentication is required for accessing the email server.
Username
Enter the username for accessing the email server.
Password
Enter the password for accessing the email server.
Sender
Enter the email address of the email server for sending emails.
5.     Click OK, and then you can view the newly created email server on the Email Servers tab.
Configure file servers
3.     On the File Servers tab, click Create.
4.     Configure the file server parameters.
Table 11 File server configuration items
Item
Name
Enter the name of the file server.
Select a file server type:
·     Local.
·     FTP.
Path
Enter a file storage path, for example, ftp://1.1.1.1/abc/.
This field is available only when the file server type is FTP.
Username
Enter the username for accessing the FTP server.
Password
Enter the password for accessing the FTP server.
5.     Click OK, and then you can view the newly created file server on the File Servers tab.
Configure response rules
3.     On the Response Rules tab, click Create.
4.     Configure the response rule parameters.
Table 12 Response rule configuration items
Item
Name
Enter the name of the response rule. The name is case sensitive and valid characters include Chinese characters, letters, digits, underscores (_), and hyphens (-).
Enter a description for the response rule.
5.     Click Create in the Match condition area. You can configure multiple match conditions in a response rule.
Table 13 Match condition configuration items
Item
Match type
Select a match type for the response rule:
·     Severity level.
·     Protocol.
Operator type
Select an operator type:
·     Belong to—Indicates that the match type belongs to the specified type value.
·     Not belong to—Indicates that the match type does not belong to the specified type value.
Type value
Select a type value.
The type value varies by the selected match type.
6.     Click OK.
7.     Click Create in the Action area. You can configure multiple actions in a response rule.
Table 14 Action configuration items
Item
Action type
Select an action type for the response rule:
·     Upload files.
·     Add comments.
·     Send logs.
·     Send emails.
File server
Select a file server name.
This filed is available only when the action type is set to Upload files.
Comments
Enter the comments for suspicious data transmission.
This filed is available only when the action type is set to Add comments.
Select an email alarm template.
This filed is available only when the action type is set to Send emails.
8.     Click OK.
9.     Click OK, and then you can view the newly created response rule on the Response Rules tab.
