04-Policies
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70004-Policies
01-Security policy
01-Security policy 153.35 KB
This help contains the following topics:
·     Introduction
¡     Security policy name
¡     Security policy filtering criteria
¡     Security policy matching order
¡     Policy matching acceleration
¡     Security policy group
¡     Import and export
·     Restrictions and guidelines
¡     Restrictions and guidelines: Security policies
¡     Restrictions and guidelines: Security policy groups
¡     Restrictions and guidelines: Import and export
·     Configure security policies
¡     Create a security policy
¡     Insert a security policy
¡     Create a security policy group
Introduction
A security policy defines a set of filtering criteria for identifying traffic. The filtering criteria include the following types: source security zone, destination security zone, source IP address and source MAC address, destination IP address, user, application, URL category, terminal, service, VRF, and time range. The device matches packets against the security policies and takes the action stated in the policy on the matched packets. Packets that match no security policies are discarded. A policy matches all packets if no criteria are specified for the policy.
You can configure multiple security policies, each of which must be uniquely identified by its name and type.
A packet is considered matched if it matches all the criterion types in a policy. Each criterion type includes one or more criteria, and a packet matches a criterion type if it matches any criterion of the type.
The device matches packets against security policies in the order the policies were created. Follow the depth-first order during policy creation to create policies with stricter match criteria first.
Security policies on the Security Policies page are displayed in the policy creation order. Policies created first come first in the list. You can move the policies to change the policy matching order.
This feature accelerates security policy matching to enhance connection establishment and packet forwarding performance, especially for a device using multiple policies to match packets from multiple users.
Matching of security policies switched from object policies is accelerated by default. You need to activate rule matching acceleration if a policy is modified or newly added or if the acceleration feature is deactivated for certain reasons. The following methods are available for activating policy matching acceleration:
·     Manual activation—Activates security policy matching acceleration immediately after you click Activate. You can perform manual activation after a policy is modified or the acceleration feature is deactivated.
·     Automatic activation—Enables the system to detect security policy changes at specific intervals and activate security policy matching acceleration automatically if any change has been made. If there are 100 or less security policies, the interval is 2 seconds. If there are over 100 security policies, the interval is 20 seconds.
Security policy grouping allows users to enable, disable, delete, and move security policies in the same security policy group in batches. You can specify a security policy group for each security policy or specify a range of security policies for each security policy group.
A security policy takes effect only when both the security policy and its security policy group are enabled.
Import and export
This feature allows the fast migration of security policy configurations. You can export the specific or all security policy settings and perform incremental import.
When importing a file, follow these restrictions and guidelines:
·     If a configuration item (a time range for example) in the imported file has the same name as an existing item, the imported item will overwrite the existing one.
·     The import process terminates if a policy fails to be imported, but the policies that have been imported are not affected and cannot be rolled back.
·     Make sure the file is in CFG format.
·     You can move security policies to change their matching order among policies of the same type.
·     A newly added security policy is listed below the existing security policies of the same type.
·     If a security policy uses an object group that has no objects, the security policy cannot match any packets. For more information, see the online help for object groups.
·     If policy matching acceleration fails to be activated by clicking Activate, the matching of policies that have been accelerated is not affected.
·     You also need to activate policy matching acceleration if the objects in an object group used by a security policy change.
·     The aging time configured for a security policy takes precedence over the aging times configured in Session Aging Time Set.
·     When inter-VLAN bridge forwarding is configured, the statistics collection feature collects statistics only about packets discarded by the security policy. Statistics about permitted packets are not collected.
·     Only IPv4 security policies support using source MAC addresses as the filtering criteria.
·     Before configuring content security for a non-default context, make sure content security settings have been activated for the default context. To activate content security settings for a context, click Submit on the security policy page of the context.
·     If you specify a security policy group for a security policy, the policy will be added to the security policy group as its last policy.
·     If you remove the first security policy from a security policy group, the policy will be placed before the policy group. If you remove any other security policy from the security policy group, the policy will be placed after the policy group.
·     You cannot move a security policy group that does not contain any policies or move a security policy group before or after an empty security policy group.
·     You cannot move a security policy group to a place between policies in another security policy group.
·     If you move a security policy to a place before or after a security policy group, the policy joins the group automatically.
·     You can export only user-defined applications, terminals, and security zones. Predefined applications, terminals, and security zones cannot be exported.
·     The file to be imported can contain only security settings available for export.
·     When exporting security zone and VRF settings, their binding relations with interfaces are not exported. You must configure interface binding for imported security zones and VRFs.
·     The export operation exports only security policy settings and does not export settings about objects used by the security policy.
·     Only one user can perform importing or exporting at a time.
Configure a security policy as shown in Figure 1.
Figure 1 Security policy configuration procedure
1.     Select Policies > Security Policies.
2.     Click Create and then select Create a policy.
3.     Create a security policy.
Table 1 Security policy configuration items
Item
Name
Enter a name for the security policy. Security policies of the same type cannot have the same name.
Auto naming
Select whether to enable the system to automatically name the security policy. With this feature enabled, you can specify only one source security policy and one destination security policy.
Specify the security policy type. Options include:
·     IPv4.
·     IPv6.
Policy group
Specify a security policy group for the security policy.
Configure a description for the security policy.
Source zone
Specify source security zones as filtering criteria.
Source address object group/location
Specify source IP/MAC address object groups or source locations as filtering criteria. Only IPv4 security policies support using source MAC address object groups for packet filtering.
Specify source IP/MAC address object groups as filtering criteria. Only IPv4 security policies support using source MAC address object groups for packet filtering.
Source IPv4 address
Specify source IP addresses, source IP ranges, or source subnets as filtering criteria.
Destination zone
Specify destination security zones as filtering criteria.
Destination address object group/location
Specify destination IP address object groups or destination locations as filtering criteria.
Specify destination IP address object groups as filtering criteria.
Destination IPv4 address
Specify destination IP addresses, source IP ranges, or source subnets as filtering criteria.
Service object group
Specify service object groups as filtering criteria.
Protocol/Port number
Specify protocols or port numbers as filtering criteria.
Application
Specify an application or application group as a filtering criterion.
URL category
Specify a URL category as a filtering criterion.
Terminal
Specify a terminal or terminal group as a filtering criterion.
User
Specify a user or user group as a filtering criterion.
Time range
Specify the time range during which the security policy rule is in effect.
VRF
Configure the security policy rule to take effect on packets of the specified VRF.
Action
Specify the security policy action. Options include:
·     Permit—Allows matched packets to pass.
·     Deny—Discards matched packets.
WAF profile
Select the WAF profile to apply to the permitted packets.
IPS profile
Select the IPS profile to apply to the permitted packets.
Data filtering profile
Select the data filtering profile to apply to the permitted packets.
File filtering profile
Select the file filtering profile to apply to the permitted packets.
Anti-virus profile
Select the anti-virus profile to apply to the permitted packets.
URL filtering profile
Select the URL filtering profile to apply to the permitted packets.
APT defense profile
Select the APT defense profile to apply to the permitted packets.
Logging
Enable logging for matched packets.
Match counting
Enable statistics collection for matched packets.
Statistics collection period
Specify the statistics collection period. Options include Permanent and Custom.
Session aging
Set the aging time for stable sessions created for packets matching the security policy.
If the aging time is not configured, stable sessions use the aging time configured on the System > Session Aging Time Set > Protocol Session Aging Set page.
Persistent session aging
Set the aging time for persistent sessions created for packets matching the security policy.
Policy status
Select whether to enable this policy.
Redundancy analysis
Select whether to access the Redundancy Analysis page after the policy creation.
4.     Click OK.
5.     For the security policy to take effect immediately, click Activate.
2.     To insert a security policy to the place before or after all existing security policies, click Insert and select First or Last. To insert a security policy to the place before or after a specific policy, select the target policy, click Insert, and then select Before or After.
3.     Configure the policy to be inserted and then click OK. For more information, see Table 1.
The inserted policy will be displayed on the Security Policies page.
4.     For the security policy to take effect immediately, click Activate.
2.     Click Create and then select Create a policy group.
3.     Create a security policy group.
Table 2 Security policy group configuration items
Item
Name
Enter a name for the security policy group.
Configure a description for the security policy group.
Specify the security policy group type. Options include:
·     IPv4.
·     IPv6.
Start policy
Specify the name of the start policy of a policy range in which all the security policies will be add to the group.
End policy
Specify the name of the end policy of a policy range in which all the security policies will be added to the group.
Make sure the end policy is listed below the start policy and policies in the specified policy range do not belong to any other policy groups.
4.     Click OK.
