06-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40206-System
25-Webpage Diagnosis
25-Webpage Diagnosis 26.94 KB
This help contains the following topics:
·     Introduction
·     Restrictions and guidelines
·     Perform a webpage diagnosis
Introduction
This feature outputs easy-to-read diagnosis results to help you quickly troubleshoot webpage access failures of internal users. With this feature, you do not need to manually ping servers or display log messages.
·     This feature supports only IPv4.
·     This feature supports only HTTP webpages.
·     Before starting a webpage diagnosis, you must configure security policies to ensure connectivity between the following security zones:
¡     Security zone where the user resides.
¡     Security zone where the Web server resides.
¡     Security zone Local.
1.     Select System > Diagnosis Center > Webpage Diagnosis.
2.     Configure webpage diagnosis parameters.
Table 1 Webpage diagnosis configuration items
Item
User IP
IP address of the user.
User VRF
VPN instance to which the user belongs.
Webpage URL
URL that the user accessed, for example, http://www.example.com.
Webpage VRF
VPN instance to which the webpage belongs.
3.     Click Diagnose.
4.     View the webpage diagnosis result to analyze the failure and resolve the issue.
5.     (Optional.) Click Export to export the webpage diagnosis result to a .xml file.
