06-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40206-System
24-Packet capture
24-Packet capture 32.47 KB
This help contains the following topics:
·     Introduction
·     Restrictions and guidelines
·     Perform packet capture
¡     Start packet capture
¡     Configure packet capture settings
Introduction
The packet capture feature captures incoming and outgoing packets, generates packet capture records, and saves the records to a .cap file. The file can reside on the device or a remote file server. You can use a packet analyzer such as Wireshark to view the file for traffic analysis.
·     Only one packet capture process can run on the device.
·     You can configure packet capture parameters only when packet capture is not started.
·     Start packet capture only when necessary. Packet capture affects device performance.
·     If packet capture saves .cap files on the device, back up the .cap files on the device as required after you finish packet capture. Starting packet capture again deletes the existing .cap files.
·     Packet capture is not supported on shared interfaces of a non-default context.
1.     Select System > Diagnosis Center > Packet Capture.
2.     Click Start packet capture.
3.     Configure filters as shown in Table 1.
Table 1 Configuration items for setting filters
Item
Capture packets received or sent by an interface.
ACL
Capture packets permitted by an advanced ACL.
4.     Click Start.
On the Packet Capture page, the Packet Capture Status field displays Started.
5.     To stop packet capture, click Stop packet capture.
The Packet Capture Status field displays Stopped. The bottom pane displays information about generated .cap files.
2.     Click Set packet capture parameters.
3.     Configure packet capture parameters as shown in Table 2:
Table 2 Packet capture configuration items
Item
Maximum bytes per packet
Specify the maximum number of bytes for a capture record.
If a packet is longer than the value of this item, the system truncates the packet.
Maximum packets per file
Specify the maximum number of packet capture records for a .cap file.
The system first saves packet capture records to memory. After the maximum number of packet capture records for a file is reached, the system saves the records to a file and clears the records in memory.
A greater value for this item requires more memory space. If the available memory space is limited, decrease the value.
Save files on the device
Save the .cap files on the device.
If you select this option, you can set the Maximum storage space item to specify the maximum storage space for .cap files. After the maximum storage space is reached, the system stops capturing packets.
Save files to a remote server
Save the .cap files to an FTP or TFTP server. To save .cap files to an FTP server, you must configure the username and password for accessing the FTP server.
4.     Click OK.
