06-System
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40206-System
16-Report settings
16-Report settings 27.03 KB
Report settings
This help contains the following topics:
·     Introduction
·     Configure report subscription
Introduction
After you add a subscriber for a report, the report will be sent to the subscriber through email.
For the subscribers to receive the report, you must configure the email server.
The device sends the daily report during the least busy hours (1 a.m. to 5 a.m.). The monthly report of the previous month is sent on the first day of each month.
The report subscription feature supports the following types of reports:
·     Summary report—Displays summarized service statistics collected over a time range.
·     Comparison report—Provides comparison of service statistics collected over two time ranges that contain the same number of days.
·     Intelligent report—Provides intelligent analysis of users' work efficiency, data leakage, and turnover risks based on their network access behaviors.
·     Comprehensive report—Illustrates the overall device operational and network security status based on analysis of critical service statistics.
Configure report subscription as shown in Figure 1.
Figure 1 Report subscription configuration procedure
1.     Click the System tab.
2.     In the navigation pane, select Report Settings > Email Server.
3.     Configure the email server.
Table 1 Email server configuration items
Item
Email server address
Enter the IP address or host name of the email server.
Sender address
Enter the email sender address.
DNS server IP
Enter the IP address of the DNS server.
Identity authentication
Select Enable to enable email client authentication.
Enable email client authentication as required by the email server.
Secure user credential transmission
Select Enable to enable secure transmission of user authentication credentials.
Username
Enter the username for connecting to the email server.
Password
Enter the password for connecting to the email server.
4.     Click Apply.
5.     Add a subscriber for a report:
a.     Go to the Report Settings > Report Subscription page.
b.     Click Add for a report.
c.     Enter the email address of the report subscriber.
d.     Click OK.
