- 06-System
- 01-High availability group
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Session log settings
- 08-NAT log settings
- 09-AFT log settings
- 10-Threat log settings
- 11-Application audit log settings
- 12-URL filtering log settings
- 13-Bandwidth alarm logs
- 14-Attack defense log settings
- 15-NetShare log settings
- 16-Report settings
- 17-Session settings
- 18-Signature upgrade
- 19-Software upgrade
- 20-License management
- 21-Administrators
- 22-Date and time
- 23-Configuration management
- 24-Packet capture
- 25-Webpage Diagnosis
- 26-Packet trace
- 27-Fast Internet Access
- 28-SNMP
- 29-IRF
- 30-IRF advanced settings
- 30-IRF advanced settings(only for F50X0-D and F5000-AK5X5 firewalls)
- 31-Contexts
- 31-Contexts(only for F50X0-D and F5000-AK5X5 firewalls)
- 32-About
- 33-MAC address learning through a Layer 3 device
- 34-Bandwidth management logs
- 35-Configuration log settings
- 36-Context rate limit logging
- 37-Heartbeat log settings
- 38-Diagnostic Info
- 39-IP access logs
- 40-IP reputation log settings
- 41-IPsec diagnosis
- 42-Load balancing logging
- 43-Load balancing test
- 44-MAC authentication online users
- 45-Packet capture
- 45-Packet capture(only for F50X0-D and F5000-AK5X5 firewalls)
- 46-Ping
- 47-Reboot
- 48-Security policy log
- 49-Tracert
- 50-WAF log settings
| 04-BFD | 21.53 KB |
This help contains the following topics:
Introduction
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
BFD sessions use echo packets to implement detection. Echo packets are encapsulated into UDP packets with port number 3785.
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session to be down.
Configure BFD
1. Select System > High Availability > BFD.
2. Configure BFD.
Table 1 BFD configuration items
Item |
Echo packet source IPv4 |
Specify a valid unicast IPv4 address as the source IPv4 address for echo packets. As a best practice, specify an IPv4 address that is not on the same network segment as any local interface's IP address. This behavior prevents the peer from sending a large number of ICMP redirect packets, which will result in link congestion. |
Echo packet source IPv6 |
Specify a source IPv6 address for echo packets. As a best practice, specify an IPv6 address that is not on the same network segment as any local interface's IP address. This behavior prevents the peer from sending a large number of ICMPv6 redirect packets, which will result in link congestion. |
