- 11-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-iNQA configuration
- 04-NTP configuration
- 05-PTP configuration
- 06-PoE configuration
- 07-SNMP configuration
- 08-RMON configuration
- 09-Event MIB configuration
- 10-NETCONF configuration
- 11-Ansible configuration
- 12-Puppet configuration
- 13-SmartMC configuration
- 14-EPA configuration
- 15-CWMP configuration
- 16-EAA configuration
- 17-Process monitoring and maintenance configuration
- 18-Mirroring configuration
- 19-sFlow configuration
- 20-Information center configuration
- 21-Packet capture configuration
- 22-VCF fabric configuration
- 23-Cloud connection configuration
- 24-EPS agent configuration
- 25-Chef configuration
- 26-eMDI configuration
- 27-SQA configuration
| 27-SQA configuration | 62.37 KB |
Configuring SQA
About SQA
Service quality analysis (SQA) enables the device to identify SIP-based multimedia traffic and preferentially forward this traffic to ensure multimedia service quality. Use this feature to decrease multimedia stuttering and improve user experience.
Restrictions and guidelines: SQA configuration
SQA does not support analysis of encrypted SIP protocol packets.
Configuring SQA
2. Enter SQA view.
sqa
3. Enable SQA.
sqa-sip enable
By default, SQA is disabled.
4. Specify the SIP listening port number.
sqa-sip port port-number
By default, the SIP listening port number is 5060.
Make sure the SIP listening port number on the device is the same as that on the SIP server.
5. (Optional.) Specify an IP address range for SQA.
sqa-sip filter address start-address end-address
By default, no IP address range is specified for SQA. The device performs SQA on all SIP packets.
After this command is executed, the device performs SQA only on SIP calls in the specified IP address range.
Display and maintenance commands for SQA
Execute display commands in any view .
Task |
Command |
Display SIP call information. |
display sqa sip call [ [ call-id call-id ] verbose ] |
Display SIP call statistics. |
display sqa sip call-statistics |
SQA configuration examples
Example: Configuring SQA
As shown in Figure 1, the SIP server installed with third-party VoIP server software acts as both the SIP proxy server and SIP registrar to manage SIP UA registration and SIP calls. Host A and Host B installed with third-party client software can place calls to each other.
Configure SQA on Device A, Device B, and Device C to optimize multimedia traffic of SIP calls to provide high qualified multimedia services.
Assign IP addresses to interfaces, and make sure the devices can reach each other.
1. Configure the SIP server:
Install third-party VoIP server software, register UAs, and specify the usernames (phone numbers) and passwords for the clients. (Details not shown.)
2. Configure PC A and PC B:
Install third-party VoIP client software, specify the IP address of the SIP server, and configure the username (phone number), password, and other parameters on each PC. (Details not shown.)
3. Configure Device A:
# Enable SQA.
[DeviceA] sqa
[DeviceA-sqa] sqa-sip enable
# Specify 5066 as the SIP listening port number. (Make sure this SIP listening port number is the same as that on the SIP server.)
[DeviceA-sqa] sqa-sip port 5066
# Specify an IP address range for SQA. (Make sure Host A's IP address is included in the range.)
[DeviceA-sqa] sqa-sip filter address 6.159.107.200 6.159.107.200
[DeviceA-sqa] quit
4. Configure Device B and Device C:
# Configure Device B and Device C in the same way as Device A is configured. (Details not shown.)
# Place a call from Host A to Host B. (Details not shown.)
# Display brief information about all SIP calls on Device A.
<DeviceA> display sqa sip call
Caller Callee CallId
6.159.107.207:49172 6.159.108.51:52410 3101326658
6.159.107.203:49172 6.159.108.47:52410 4530332933
6.159.107.208:49172 6.159.108.52:52410 4445702693
6.159.107.206:49172 6.159.108.50:52410 8263542841
6.159.107.201:49172 6.159.108.45:52410 4752123310
6.159.107.200:49172 6.159.108.44:52410 99462146
The output shows that Device A has performed SQA on the call that Host A placed to Host B.
# Display detailed information about the SIP call that Host A placed to Host B.
<DeviceA> display sqa sip call call-id 99462146 verbose
Call ID: 99462146
Caller information:
IP: 6.159.107.200 Port: 49172 MAC: a036-9fd4-b5bd
Tag: [email protected]
Callee information:
IP: 6.159.108.44 Port: 52410 MAC: a036-9fd4-b5bc
Type: Audio VLAN: 1 StartTime: 2019-7-14 15:40:39
MOS(F): 88 MOS(R): 86
Forward flow (octet): 4793344 Forward flow (packet): 4681
Reverse flow (octet): 3810304 Reverse flow (packet): 3721
The output shows that the MOS value for both forward and reverse traffic is high, which indicates the quality of the audio service is high.
