02-FRU Compatibility Matrixes | 60.61 KB |
2 FRU compatibility matrixes
For more information about transceiver modules and cables available for modules, see H3C CR19000 Core Routers Modules and Transceivers Compatibility Matrixes.
MPUs
The router uses MPUs for system configuration and monitoring, including route calculation, forwarding table maintenance, and device monitoring. They can also provide high-precision timer and time synchronization.
The CR-19K-MPU-20A, CR-19K-MPU-20B, and CR-19K-MPU-20C MPUs are available for the router.
Do not install MPUs of different models on the same router.
Fabric modules
Fabric modules switch data between interface modules.
The CR-19K-SFU-20C, CR-19K-MSFU-20B, and CR-19K-MSFU-20C fabric modules are available for the router.
Do not install fabric modules of different models on the same router.
Interface modules
The interface modules offer line-rate forwarding. They provide different types of Ethernet fiber ports. Each port is a Layer 3 interface and supports varieties of features, including IP routing, forwarding, MPLS, security, QoS, multicasting, traffic statistics, and IPv6.
The router supports interface modules of different models.
Table2-1 describes the interface modules compatibility with fabric modules.
Table2-1 Interface modules compatibility with fabric modules
Interface module model |
CR-19K-MSFU-20B |
CR-19K-MSFU-20C |
CR-19K-SFU-20C |
CR-19K-LPU-CQ18 |
N + 1 (N≥ 6) |
N + 1 (N≥ 6) |
CR-19K-LPU-CQ12 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-CQ12B |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-CQ06B |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-CC08 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-CC04 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-CC04B |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-XP72 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-XP48 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-XP40 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-XP20CC02 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-8004 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-4004 |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
N + 1 (N≥ 4) |
CR-19K-LPU-2002 |
N + 1 (N≥ 2) |
N + 1 (N≥ 2) |
N + 1 (N≥ 2) |
CR-19K-LPU-2002B |
N + 1 (N≥ 2) |
N + 1 (N≥ 2) |
N + 1 (N≥ 2) |
CR-19K-LPU-SP |
N + 1 (N≥ 1) |
N + 1 (N≥ 1) |
N + 1 (N≥ 1) |
NOTE: The mark × indicates that the fabric module CR-19K-MSFU-20B is incompatible with the interface module. |
Interface subcards
Table2-2 describes the interface subcard compatibility with interface modules.
Table2-2 Interface subcard compatibility with interface modules
Interface subcard model |
CR-19K-LPU-8004 |
CR-19K-LPU-4004 |
CR-19K-LPU-2002B |
CR-19K-LPU-2002 |
CR-HIC-CLGQ04F |
CR-HIC-CQ02 |
CR-HIC-CQ01 |
CR-HIC-CC01 |
CR-HIC-QQ03 |
CR-HIC-XP12B |
CR-HIC-XP12 |
CR-HIC-XP10 |
CR-HIC-GP12 |
CR-HIC-PU02 |
CR-HIC-PS04 |
CR-HIC-PHP08 |
CR-HIC-CLP04 |
CR-HIC-ET16 |
NOTE: · The mark √ indicates that the interface subcard is compatible with the interface module. · The mark × indicates that the interface subcard is not compatible with the interface module. |
Power trays and power supplies
The power supply system on a CR19000-20 core router contains power trays and power supplies and supports DC, AC, and high-voltage DC power supplies.
Do not install power trays or power supplies of different models on the same router.
Table2-3 Power trays and power supplies available for the router
Power tray model |
Power supply model |
CR-PEM-DC2000 |
PSR2000B-54D |
CR-PEM-AC3000 |
PSR3000B-54AHD |
CR-PEM-HVDC3000 |
PSR3000B-54AHD |
Fan trays
Fan trays on a CR19000-20 router draw ambient air into the chassis through the air vents in the MPU, fabric module, and interface module front panels and exhaust the air carrying heat through the air vents in the fan tray panel.
The router uses 33 micro fan trays. FAN-120B-1-A fan trays are available for the router.
