- H3C CR19000-16 Core Router Installation Guide-6W102
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Connecting Cables
- 04-Chapter 4 Replacement Procedures
- 05-Chapter 5 Troubleshooting
- 06-Appendix A Engineering Labels
- 07-Appendix B Cable Management
- 08-Appendix C Repacking the Router
| 08-Appendix C Repacking the Router | 2.35 MB |
8 Appendix C Repacking the router
Removing cables from the router
Removing the twisted pair cables and optical fibers
Repacking the fabric module slot filler panels
Removing the chassis from the rack
This chapter describes how to repack the router chassis, power supplies, and modules.
Before repacking the router, remove all cables such as the power cords, console cable, twisted pair cables, optical fibers, and grounding cable from the router.
Removing the power cords
1. Switch off the circuit breakers at the input end of all power cords.
2. Wear an ESD wrist strap, and make sure it makes good skin contact and is reliably grounded.
3. Remove a power cord.
¡ For an AC power cord, remove the cable tie, and then remove the power cord connector from the power supply.
¡ For a DC power cord, loosen the screw on the power cord connector, and then remove the connector from the power supply.
4. Perform the same steps to remove the other power cords.
Removing the console cable
1. Pull the RJ-45 connector of the console cable out from the console port of the router.
2. Pull the DB-9 connector of the console cable out from the serial port of the PC or the terminal.
Removing the grounding cable
1. Loosen the two screws at the grounding holes in the chassis, and then remove the grounding cable from the chassis.
2. Use a wrench to loosen the hex nut on the grounding post of the grounding strip, and remove the other end of the grounding cable (with a ring terminal) from the grounding post.
You must remove all twisted pair cables and optical fibers from the ports on the router.
NOTE: After pulling out an optical fiber from a transceiver module, cover the connector of the optical fiber with a dust cap to keep the connector clean. |
Repacking the FRUs
Repacking power supplies
CAUTION: To avoid device damage and bodily injury, switch off the circuit breakers at the input ends of all power cords and remove all the power cords before removing power supplies. |
1. Prepare the original packing materials, including the anti-static bag, foam cushion, and packing box for a power supply. Make sure these packing materials are clean, dry, and not damaged.
2. Remove the power supply from the chassis.
For the power supply removal procedure, see "Replacement procedures."
3. Put the removed power supply into the anti-static bag.
4. Place the foam cushion over the power supply.
5. Place the power supply and the foam cushion in the packing box, and seal the box with tape.
6. Perform the same steps to repack the other power supplies.
Repacking the modules
1. Prepare the original packing materials, including the anti-static shielding bag, foam cushion, and packing box, for a module. Make sure these packing materials are clean, dry, and not damaged.
2. Remove the transceiver modules from the modules.
If no transceiver module is installed, skip this step.
For information about how to remove a transceiver module, see "Replacement procedures."
3. Remove a module from the chassis.
If a filler panel is provided for the module slot, install the filler panel in the slot after you remove the chassis from the rack.
For information about how to remove a module and install a filler panel, see "Replacement procedures."
4. Put the removed module into an anti-static bag.
For a module provided with a metal protection box, install the metal protection box for it before putting it into an anti-static bag.
5. Place the foam cushion over the module.
6. Put the module and the foam cushion into the box, and seal the box with tape.
7. Perform the same steps to repack the other modules.
1. Prepare the original packing materials, including the packing bag, foam cushion, and packing box, for a fabric module slot filler panel. Make sure these packing materials are clean, dry, and not damaged.
2. Remove the fabric module slot filler panel.
3. Place the removed fabric module slot filler panel in the packing bag.
4. Place the foam cushion over the packing bag.
5. Place the fabric module slot filler panel and the foam cushion in the packing box, and seal the box with tape.
6. Perform the same steps to repack the other fabric module slot filler panels.
Repacking the router chassis
The router is heavy. Use a mechanical lift to move the router.
To remove the chassis from the rack:
1. Prepare the original packaging materials for the chassis, including the wooden pallet base, carton, and packing bag. Make sure they are clean, dry, and not damaged.
2. Place the wooden pallet base at a location where you can move the chassis easily.
3. As shown by callout 1 in Figure8-1, use a Phillips screwdriver to loosen the screws that attach the mounting brackets to the rack.
4. As shown by callout 2 in Figure8-1, use a minimum of four people to slide the chassis out of the rack along the slide rails. When most part of the chassis is removed from the slide rails, lift up the chassis by holding the chassis handles to completely remove the chassis from the rack.
5. Put the chassis onto the wooden pallet base.
Figure8-1 Removing the router from the rack
(1) Loosen the captive screws that attach the mounting brackets to the rack |
1. Align the left and right edges of the chassis bottom with the left and right positioning lines respectively on the wooden pallet base. See Figure8-2 for the wooden pallet base.
2. Use screws to attach the L-type brackets to the chassis, as shown by callout 1 in Figure8-3.
Figure8-3 Attaching the L-type brackets to the pallet base
3. Move the chassis so that the mounting holes on the horizontal ear of the L-type brackets align with the mounting holes on the wooden pallet base. Use screws to attach the L-type brackets to the wooden pallet base, as shown by callout 2 in Figure8-3.
4. Cover the chassis with the packing bag from top down, and then tape the bag to the plastic cover of pallet base.
5. Use the carton to cover the chassis from top down with the mark side aligning with the front panel of the chassis. Erect one paper angle bead along each vertical edge of the chassis, as shown in Figure8-4.
Figure8-4 Using the carton to cover the chassis
6. Put the foam cushion onto the chassis top, and make sure the mounting brackets seat into the internal notches of the foam cushion.
7. Fit the accessory box into the notch of the foam cushion near to the rear end of the chassis. Then close the carton.
Figure8-5 Closing the carton
