- H3C CR19000-16 Core Router Installation Guide-6W102
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Connecting Cables
- 04-Chapter 4 Replacement Procedures
- 05-Chapter 5 Troubleshooting
- 06-Appendix A Engineering Labels
- 07-Appendix B Cable Management
- 08-Appendix C Repacking the Router
| 04-Chapter 4 Replacement Procedures | 9.38 MB |
Replacing an interface module that uses detachable ejector levers
Replacing an interface module with ejector levers
Replacing an interface subcard
Replacing a QSFP+ optical fiber
4 Replacement procedures
WARNING! · When replacing FRUs while the router is operating, ensure electricity safety. · To avoid bodily injury and device damage, follow the procedure in this chapter strictly to replace a module. · Long-time exposure to strong air flow might cause discomfort. To avoid this hazard, do not stand close to the air outlet vents while the router is operating. If you must be next to the router on the air outlet vent side for an extended period, avoid the air flow or take other protective measures. |
CAUTION: Before discarding a component, delete data from the storage media such as CF cards, SSDs, drives, and flash memories if the component has such media. To delete data from a medium, you can format or physically destroy the storage medium. |
The router uses a modular architecture, and supports removable components. You can replace the removable components when the router is operating.
Replacing a power supply
WARNING! · Provide a circuit breaker for each power supply. Before replacing a power supply, turn off the circuit breaker for it. · To reinstall the removed power supply in the chassis, wait until the status LED on it is off. · To avoid being hurt, allow a power supply to cool before removing it. |
To avoid device damage and bodily injury, strictly follow the procedures shown in Figure4-1 and Figure4-2 to remove and install a power supply, respectively.
Figure4-1 Power supply removal procedure
Figure4-2 Power supply installation procedure
To replace a power supply:
1. Prepare an antistatic mat to place the removed power supply.
2. Turn off the circuit breaker.
3. Wear an ESD wrist strap, and make sure it makes good skin contact and is reliably grounded.
4. Remove the cable tie, and then remove the power cord connector from the power supply.
5. Press the latch on the power supply towards the handle direction and pull the power supply part way out of the slot.
6. Holding the power supply handle with one hand and supporting the power supply bottom with the other, pull the power supply slowly out of the slot.
7. Place the removed power supply on the antistatic mat.
8. Install a new power supply. For information about the power supply installation procedure, see "Installing power supplies."
Figure4-3 Removing a power supply (AC power supply)
(1) Press the latch towards the handle direction |
(2) Pull the power supply slowly out of the slot along the guide rails |
Replacing a module
CAUTION: If you are not to install a new module in a slot after removing the old one, install a filler panel in the slot for adequate heat dissipation and dust prevention. |
Unless otherwise stated, MPUs, interface modules, interface subcards, and fabric modules are collectively referred to as "modules" in this document.
Replacing an MPU
IMPORTANT: The router supports active/standby MPU switchover when you install two MPUs for the router. For the standby MPU to operate correctly, make sure the active and standby MPUs are the same model. |
To replace an MPU:
1. Remove the cables from the MPU.
2. Prepare an antistatic mat to place the removed MPU.
4. Use a Phillips screwdriver to loosen the captive screws on the MPU.
5. Open the ejector levers on the MPU and then pull the MPU part way out of the slot.
6. Supporting the MPU bottom with the left hand, slowly pull the MPU out of the slot along the guide rails with the right hand.
7. Place the removed MPU on the antistatic mat.
8. Install a new MPU. For the installation procedure, see "Installing MPUs."
CAUTION: · Put the detachable ejector lever back to its holder after use and then attach them to the chassis or rack for future use. · The ejector lever holder is magnetic. Beware of electromagnetic interference. · Do not use only one detachable ejector lever to install or remove an interface module. · Do not hold detachable ejector levers to lift an interface module. |
To replace an interface module that uses detachable ejector levers:
1. Remove the cables from the interface module.
2. Prepare an antistatic mat to place the removed interface module.
4. Use a Phillips screwdriver to loosen the captive screws on the interface module.
5. Identify the "L" and "R" marks on the ejector levers and attach them to left and right ejector lever retainers of the interface module, respectively, with the lettering on the ejector levers facing upward. See callout 1 in Figure4-5.
6. Open the ejector levers on the interface module and then pull the interface module part way out of the slot, see callout 2 in Figure4-5.
Figure4-5 Opening a detachable ejector lever
7. Detach the ejector levers from the interface module and then attach the ejector levers to the ejector lever holder.
Keep the ejector levers secure for future use.
8. Supporting the interface module bottom with one hand, slowly pull the interface module out of the slot along the guide rails with the other hand.
9. Place the removed interface module on the antistatic mat.
10. Install a new interface module. For the installation procedure, see "Installing an interface module that uses detachable ejector levers."
Figure4-6 Removing an interface module
4. Use a Phillips screwdriver to loosen the captive screws on the module.
5. Open the ejector levers on the module and then pull the module part way out of the slot.
6. Supporting the module bottom with one hand, slowly pull the module out of the slot along the guide rails with the other hand.
7. Place the removed module on the antistatic mat.
8. Install a new interface module in the slot. For the installation procedure, see "Installing an interface module with ejector levers."
Figure4-7 Removing an interface module with ejector levers
IMPORTANT: · If you are not to install a new interface subcard after removing the old one, install a filler panel in the slot. · When installing a filler panel, orient it with the blade of the screwdriver image on it facing upwards. First insert the filler panel right side into the slot, and then push the left side into the slot. |
To replace an interface subcard:
1. Remove the cables from the interface subcard.
2. Prepare an antistatic mat to place the removed interface subcard.
4. Use a Phillips screwdriver to loosen the captive screws on the interface subcard and then pull the interface subcard out of the slot along the guide rails.
5. Place the removed interface subcard on the antistatic mat.
6. Install a new interface subcard. For the installation procedure, see "Installing interface subcards."
Figure4-8 Removing an interface subcard
Replacing a fabric module
WARNING! When you hot swap a fabric module, only one fan tray is operating and it automatically increases the fan rotation speed and makes louder noise. Take protection measures such as wearing an earmuff or earplug. In addition, make good preparation before the hot swapping to minimize the operation time. |
CAUTION: · Fan trays cover fabric module slots. To remove a fabric module, first remove the fan tray that covers the fabric module. · To replace or install fabric modules in the slots covered by both fan trays when the router is operating, do not remove both fan trays at the same time. Remove one fan tray to replace or install fabric modules in slots covered by the fan tray, and then reinstall the fan tray. Make good preparations to ensure that the replacement is finished within 3 minutes. You can remove the other fan tray only after this fan tray operates correctly. |
To replace a fabric module:
1. Prepare an antistatic mat to place the removed fabric module.
2. Wear an ESD wrist strap, and make sure it makes good skin contact and is reliably grounded.
3. Press the spring clips for the ejector levers to release the ejector levers. Simultaneously open the ejector levers and pull the fabric module part way out of the slot.
4. Supporting the fabric module bottom with one hand and holding the middle part of the front panel with the other hand, pull the fabric module slowly out of the slot along the guide rails.
5. Place the removed fabric module on the antistatic mat.
6. Install a new fabric module. For the installation procedure, see "Installing fabric modules."
Figure4-9 Removing a fabric module
(1) Press the spring clips for the ejector levers |
(2) Pull the fabric module slowly out of the slot along the guide rails |
Replacing a fan tray
WARNING! · Ensure electricity safety when you hot swap a fan tray. · To avoid bodily injury, do not touch the spinning fans when you replace the fan tray. |
CAUTION: · The router provides two fan tray slots. To ensure good ventilation, make sure the router has two fan trays installed. Do not remove two fan trays from the router simultaneously. When a fan tray fails, please keep the old fan tray in the chassis until a new fan tray is ready to be installed. · Before hot swapping a fan tray, make sure the other fan tray is operating correctly. To ensure good ventilation, install a new fan tray within three minutes after removing the old one. · Do not operate the router when the router does not have fan trays installed. |
To replace a fan tray
1. Prepare an antistatic mat to place the removed fan tray.
3. Loosen the captive screws on the fan tray.
4. Holding the handles on the fan tray, pull the fan tray part way out of the slot. After the fans stop rotating, pull the fan tray out from the chassis.
5. Place the removed fan tray on the antistatic mat.
6. Install a new fan tray. For more information, see "Installing fan trays."
Figure4-10 Removing a fan tray
(2) Pull the fan tray slowly out of the chassis |
Replacing transceiver modules
WARNING! Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the router is operating. |
CAUTION: · Do not touch the golden plating on a transceiver module. · Make sure the transceiver modules at the two ends of an optical fiber are the same model. |
To replace a transceiver module and optical fiber:
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Remove the optical fibers from the transceiver module.
¡ To remove the optical fibers with an LC connector, press the clip on the connector to pull the LC connector out of the port, as shown in Figure4-11.
¡ To remove the optical fiber with an MPO connector, hold the front end of the MPO connector and then pull it out of the port, as shown in Figure4-12.
3. Pull down the bail latch on the module to the horizontal position.
Skip this step for QSFP+/QSFP28 transceiver modules with a plastic bail latch.
4. Hold the bail latch to pull the module horizontally and slowly out of the port.
5. Insert the dust plugs into the module and put the module into its original packing materials.
6. Install a new transceiver module in the port. For the installation procedure, see "Installing transceiver modules and optical fibers."
If you are not to install a new transceiver module in the port, insert the dust plug that is provided with the module into the port, to prevent particles from entering the port.
Figure4-11 Removing a transceiver module (LC port)
Figure4-12 Removing a transceiver module (MPO port)
2. Hold the pull tab of the connector and remove the optical fiber from the QSFP+ transceiver module.
3. If you are not to install a new transceiver module in the port, insert the dust plug into the fiber port.
4. Connect a new QSFP+ optical fiber. For the installation procedure, see "Connecting a QSFP+ optical fiber."
Figure4-13 Removing a QSFP+ optical fiber
