- H3C CR19000-16 Core Router Installation Guide-6W102
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Connecting Cables
- 04-Chapter 4 Replacement Procedures
- 05-Chapter 5 Troubleshooting
- 06-Appendix A Engineering Labels
- 07-Appendix B Cable Management
- 08-Appendix C Repacking the Router
| 00-Preface | 100.33 KB |
Preface
This document describes the installation procedure for the CR19000-16 core router. It includes preparing for installation, installing the router, troubleshooting, and replacement procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the CR19000-16 core router.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
