H3C CR19000-8 Core Router Hardware Information and Specifications-6W100
HomeSupportResource CenterRoutersCR19000 Core SeriesCR19000 Core SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C CR19000-8 Core Router Hardware Information and Specifications-6W100
02-FRU Compatibility Matrixes
02-FRU Compatibility Matrixes 59.84 KB
2 FRU compatibility matrixes
For more information about transceiver modules and cables available for modules, see H3C CR19000 Core Routers Modules and Transceivers Compatibility Matrixes.
MPUs
The router uses MPUs for system configuration and monitoring, including route calculation, forwarding table maintenance, and device monitoring. They can also provide high-precision clock and time synchronization.
The CR-19K-MPU-08A and CR-19K-MPU-08B MPUs are available for the router.
Do not install the CR-19K-MPU-08A and CR-19K-MPU-08B MPUs on the same router.
Fabric modules
Fabric modules switch data between interface modules.
The CR-19K-SFU-08C and CR-19K-MSFU-08A fabric modules are available for the router. Do not install the CR-19K-SFU-08C and CR-19K-MSFU-08A fabric modules on the same router.
Interface modules
The interface modules offer line-rate forwarding. They provide different types of Ethernet fiber ports. Each port is a Layer 3 interface and supports varieties of features, including IP routing, forwarding, MPLS, security, QoS, multicasting, traffic statistics, and IPv6.
The router supports interface modules of different models.
Table2-1 describes the interface modules compatibility with fabric modules.
Table2-1 Interface modules compatibility with fabric modules
Interface module model
CR-19K-MSFU-08A
CR-19K-SFU-08C
CR-19K-LPU-CQ18
N + 1 (N5)
CR-19K-LPU-CQ12
N + 1 (N4)
CR-19K-LPU-CQ12B
N + 1 (N≥ 4)
CR-19K-LPU-CQ06B
N + 1 (N4)
N + 1 (N≥ 4)
CR-19K-LPU-CC08
N + 1 (N≥ 4)
CR-19K-LPU-CC04
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-CC04B
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-XP72
N + 1 (N4)
CR-19K-LPU-XP48
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-XP40
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-XP20CC02
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-8004
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-4004
N + 1 (N4)
N + 1 (N4)
CR-19K-LPU-2002
N + 1 (N2)
N + 1 (N2)
CR-19K-LPU-2002B
N + 1 (N2)
N + 1 (N2)
CR-19K-LPU-SP
N + 1 (N1)
N + 1 (N1)
The mark × indicates that the CR-19K-MSFU-08A is incompatible with the interface module.
Interface subcards
Table2-2 describes the interface subcard compatibility with interface modules.
Table2-2 Interface subcard compatibility with interface modules
Interface subcard model
CR-19K-LPU-8004
CR-19K-LPU-4004
CR-19K-LPU-2002B
CR-19K-LPU-2002
CR-HIC-CLGQ04F
CR-HIC-CQ02
CR-HIC-CQ01
CR-HIC-CC01
CR-HIC-QQ03
CR-HIC-XP12B
CR-HIC-XP12
CR-HIC-XP10
CR-HIC-GP12
CR-HIC-PU02
CR-HIC-PS04
CR-HIC-PHP08
CR-HIC-CLP04
CR-HIC-ET16
·     The mark √ indicates that the interface subcard is compatible with the interface module.
·     The mark × indicates that the interface subcard is incompatible with the interface module.
Power supplies
The router supports both AC and DC power supplies.
The PSR2400-54A, PSR2400-54D, and PSR3000-54A power supplies are available for the router.
Do not install power supplies of different models on the same router.
Fan trays
Fan trays on a CR19000-8 router draw ambient air into the chassis through the air vents in the MPU, fabric module, and interface module panels, pull the air through the backplane, and exhaust the air carrying heat through the air vents in the fan tray panel.
The router uses six fan trays. The FAN-120B-2-A fan trays are available for the router.
  • Become a Partner
  • Partner Resources
