- 03-Layer 2—LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface commands
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-Port isolation commands
- 07-Spanning tree commands
- 08-Loop detection commands
- 09-VLAN commands
- 10-MVRP commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-LLDP commands
- 14-L2PT commands
- 15-Service loopback group commands
- 16-Cut-through forwarding commands
- 17-DRNI commands
16-Cut-through forwarding commands | 31.33 KB |
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
