- 03-Layer 2—LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface commands
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-Port isolation commands
- 07-Spanning tree commands
- 08-Loop detection commands
- 09-VLAN commands
- 10-MVRP commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-LLDP commands
- 14-L2PT commands
- 15-Service loopback group commands
- 16-Cut-through forwarding commands
- 17-DRNI commands
00-Preface | 100.14 KB |
Preface
This command reference describes the commands for configuring LAN switching features, including:
· Flow control and load sharing.
· Isolating users within a VLAN and configuring VLANs.
· Eliminating Layer 2 loops.
· Transmitting packets of the customer network over the service provider network.
· Modifying VLAN tags of packets.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6861 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
