- H3C Comware 7 Security Products Safety & Configuration Cautions and Guidelines-6W100
- 01-Hardware Safety Guidelines
- 02-CLI-based configuration cautions and guidelines
- 03-Web-Based Configuration Cautions and Guidelines
- 04-Web-Based Configuration Cautions and Guidelines
- 05-Web-Based Configuration Cautions and Guidelines
- 06-Web-Based Configuration Cautions and Guidelines
00-Preface | 102.19 KB |
Preface
This document describes important information that if not understood or followed can result in undesirable situations, including bodily injury, hardware damage, service interruption, or service anomalies. It contains hardware safety guidelines, CLI-based and Web-based configuration cautions and guidelines. Before you work on or configure your device, read the information in this document carefully.
· Audience.
Audience
· Network planners.
· Network administrators.
This document is not restricted to specific software or hardware versions. If a conflict occurs between this document and a product-specific document, the product-specific document overrides.
This document provides only generic technical information, some of which might not apply to your devices.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
