- H3C S12500X-2L Switch Installation Guide-5W101
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing Removalbe Components
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B Removable Components and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Cables
| 08-Appendix B Removable Components and Compatibility Matrixes | 124.29 KB |
1 Appendix B Removable components and compatibility matrixes
Chassis component ordering information
For the transceiver modules and cables available for the modules, see H3C S12500X-AF Switch Series Modules and Transceiver Modules Compatibility Matrixes.
SEUs
The switch uses a supervisor engine unit (SEU, also called MPU) for system control and management. You can install one SEU, or two SEUs for redundancy on the switch. Do not install SEUs of different models on the same switch. The LSXM1SUP02L1 SEU is available for the switch.
Table1-1 LSXM1SUP02L1 SEU specifications
Item |
Specification |
Processor |
Intel processor (Quad-Core) @ 2.2 GHz |
SDRAM |
16GB DDR4 SDRAM for one DIMM slot (two DIMM slots) |
Flash |
8 GB EMMC |
NVRAM |
512 KB |
Connector type |
· RJ-45 · LC · USB (Type A) |
Ports |
· 1 × console port · 1 × 10/100/1000BASE-T port for management and upgrade · 1 × GE SFP port for management and upgrade · 1 × USB port (USB2.0, host port) |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps · 10/100/1000BASE-T port: 10/100/1000 Mbps · SFP port: 1000 Mbps |
Cables and max transmission distance |
· Console port: 15 m (49.21 ft) over a common asynchronous serial interface cable · 10/100/1000BASE-T port: 100 m (328.08 ft) over category-5 twisted pairs |
IMPORTANT: · To verify compatibility of the module with the software release you are using, see the release notes. · The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device in the USB port. · Set the same speed and duplex mode for a management Ethernet port and its peer port. · To upgrade software or BootWare from the BootWare menu, you can only use the 10/100/1000BASE-T port (M0/0/1) rather than the GE SFP port (M0/0/0) for image file transferring. |
Interface modules
The LSXM1CGQ48KB1 interface module is available for the switch.
Table1-2 LSXM1CGQ48KB1 interface module specification
Interface module |
Connector type |
Port number |
Transmission rate |
Available transceiver modules and cables |
LSXM1CGQ48KB1 |
48-port 100GBASE Ethernet optical interface module (QSFP28) |
· MPO · LC |
48 |
100 Gbps |
· QSFP28 transceiver module · QSFP28 copper cable · QSFP28 fiber cable · QSFP+ transceiver module · QSFP+ copper cable · QSFP+ fiber cable |
Power supplies
CAUTION: You must install power supplies of the same model for the switch. |
The switch supports N+N (dual power input sources) or N+1 (single power input source) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption. Make sure the maximum total output power of the installed power supplies is greater than the system power consumption. Reserve a 20% power surplus as a best practice.
The PSR1800-56A and PSR1800-56D power supplies are available for the switch.
Table1-3 PSR1800-56A power supply specifications
Item |
Specifications |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Rated output voltage |
56 VDC |
Maximum input current |
13 A |
Maximum output current |
32.2 A |
Maximum output power |
· 1100 W @ 100 VAC to 200 VAC · 1800 W @ 201 VAC to 240 VAC · 1800 W @ 240 VDC |
Dimensions (H × W × D) |
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in) |
Ambient temperature |
Operating temperature |
–10°C to +50°C (–14°F to +122°F) |
Storage temperature |
–40°C to + 70°C (–40°F to +158°F) |
Table1-4 PSR1800-56D power supply specifications
Item |
Specifications |
–48 to –60 VDC |
56 VDC |
45 A |
32.2 A |
1800 W |
NOTE: The power supply shuts down automatically when its temperature exceeds the acceptable range. When the temperature returns to the acceptable range, the power supply automatically restarts. |
Fan trays
The FAN-120-1-A fan tray is available for the switch.
Table1-5 FAN-120-1-A fan tray specifications
Fan tray |
Number of fans |
Fan diameter |
Maximum airflow |
FAN-120-1-A |
2 |
120 mm (4.72 in) |
1240 CFM |
DC power cords
A DC power cord is used to connect a DC power supply on the switch to an external DC power source.
Table1-6 describes DC power cords available for the switch.
Table1-6 Specifications for the DC power cords
DC power cord BOM code |
Applicable power supplies |
Cable length |
0404A0RB |
PSR1800-56D |
3 m (9.84 ft) |
Connects the DC power supply to an external DC power source. |
0404A0RA |
15 m (49.21 ft) |
AC power cords
An AC power cord is used to connect an AC power supply on the switch to an external AC power source.
· Select an AC power cord with a current-carrying capacity that meets the power supply requirement.
· The connector type varies by country or region. Select a compliant connector type as needed.
· Select 16A AC power cords for the switch. For the connector types of different countries or regions, see H3C Power Cords & Cables User Guide.
To purchase chassis components, contact the sales agent or H3C sales personnel.
Table1-7 Chassis component ordering information
Product code |
Product name |
SEUs |
0231ABV3 |
LSXM1SUP02L1 |
H3C S12500X-2L supervisor engine unit |
Interface modules |
0231ABV2 |
LSXM1CGQ48KB1 |
H3C S12500X-AF 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB) |
Fan tray |
0231ABVR |
LSXM102LFAN |
H3C S12500X-2L Ethernet switch fan module |
Power supply |
0231A2KX |
LSVM3PSRA |
H3C port-to-power airflow 1800W AC power supply |
0231A2KY |
PSR1800-56D |
H3C port-to-power airflow 1800W DC power supply |
