H3C S12500X-2L Switch Installation Guide-5W101
HomeSupportSwitchesS12500X-AF SeriesInstall & UpgradeInstallation GuidesH3C S12500X-2L Switch Installation Guide-5W101
05-Chapter 5 Troubleshooting
05-Chapter 5 Troubleshooting 88.01 KB
1 Troubleshooting
This chapter describes how to troubleshoot your switch.
TIP
TIP:
·     Noncompliant operating environment might cause switch failure. You need to clean your switch periodically and make sure the installation environment meets the requirements. For more information, see "Preparing for installation."
·     Periodically perform power-on test on spare switches.
Troubleshooting methods
When your switch fails, you can use the following methods to troubleshoot the switch:
·     At the CLI, you can use related commands to display hardware information, and locate hardware failures.
·     Every SEU provides LEDs for the fans, power supplies, and modules. You can locate the failures according to the LED status on the SEU. For more information about the LED status on the SEU, see "Appendix C LEDs."
·     The SEUs and interface modules provide port status LEDs, with which you can detect port failures. For more information about port status LEDs, see "Appendix C LEDs."
If you cannot locate failures by following the guidelines in this chapter, contact the local agents or technical support engineers. For more information, see "Technical support."
System failures at startup
No display on the configuration terminal
Symptom
The configuration terminal does not have display when the switch is powered on.
Solution
To resolve the issue:
1.     Verify that the power system is operating correctly.
2.     Verify that the SEU is operating correctly.
3.     Verify that the console cable connects the console port on the SEU and the serial port on the terminal correctly.
4.     Verify that the console cable is in good quality and is operating correctly.
5.     Verify that the following settings are configured for the terminal:
¡     Baud rate—9600.
¡     Data bits—8.
¡     ParityNone.
¡     Stop bits—1.
¡     Flow controlNone.
¡     EmulationVT100.
6.     If the issue persists, contract H3C support.
Garbled display on the configuration terminal
Symptom
The configuration terminal displays garbled text when the switch is powered on.
Solution
1.     Verify that the following settings are configured for the terminal:
¡     Baud rate—9600.
¡     Data bits—8.
¡     ParityNone.
¡     Stop bits—1.
¡     Flow controlNone.
¡     EmulationVT100.
2.     If the issue persists, contact H3C Support.
System failures during operation
Symptom
A system failure occurs when the switch is operating.
Solution
1.     Execute related commands to locate the fault.
2.     If a configuration error is found, re-configure the switch or restore the factory-default settings.
For more information, see H3C S12500X-AF Switch Series Fundamentals Configuration Guide.
3.     If the issue persists, contact H3C Support.
Power supply failure
Symptom
The LEDs for the power supply are in the following states:
·     On the SEU, the power supply status LED is steady red.
The power supply LED is steady green only when all the power supplies are operating correctly. When a power supply is faulty, the power supply LED is steady red.
·     On the power supply, the input LED is off, or the output LED is red.
After a power supply is disconnected from its power source, the input and output LEDs on the power supply stay on for several seconds.
Solution
1.     Verify that the power supply model is compatible with the switch.
The PSR1800-56A and PSR1800-56D power supplies are compatible with the switch.
2.     Remove and reconnect the power cord to verify that the power cord is connected securely.
3.     Replace the power cord.
4.     Remove and reinstall the power supply to verify that it is installed securely.
For more information, see "Installing power supplies."
5.     Verify that the power source is supplying power at the acceptable voltage range.
6.     Verify that the total maximum output power of all power supplies exceeds the system power consumption.
7.     Verify that the power supply does not have issues such as output short-circuit, output over-current, output over-voltage, input under-voltage, or over-temperature.
8.     Install the power supply in another empty power supply slot. If the power supply operates correctly, the previous power supply slot is faulty. If the power supply does not operate correctly, go to the next step.
9.     Install a correctly operating power supply of the same model in the same slot, and connect it to the same power source. If the new power supply can operate correctly, the old power supply has failed. Contact your sales agent or local service engineer to replace the old power supply.
10.     If the issue persists, contact H3C Support.
Fan tray failure
Symptom
The LEDs for the fan tray are in the following states:
·     On the SEU, the fan tray status LED is steady red.
·     On the fan tray, the OK LED is off and the FAIL LED is on.
Solution
1.     If all the LEDs are off, verify that the power supplies are operating correctly. For more information, see "Power supply failure."
2.     Execute the display fan command in any view to display the operating state of the fan tray and rectify the fault:
¡     Whether the fan tray is present.
¡     Airflow direction of the fan.
¡     Number of fans in the fan tray.
¡     Operating status of each fan.
¡     Fan speed.
3.     Verify that the air inlet and exhaust vents of the chassis are not blocked. If they are blocked, clean them to keep good ventilation.
4.     Remove and reinstall the fan tray to make sure it is installed securely in the slot.
5.     Verify that the empty interface module slots and power supply slots are installed with filler panels. Install filler panels in empty slots.
6.     Replace the fan tray.
7.     If the issue persists, contact H3C Support.
SEU failure
Symptom
The LED for the SEU is steady red or flashing red.
Solution
1.     Verify that the power system is operating correctly. For more information, see "Power supply failure."
2.     Remove and reinstall the SEU to make sure it is installed securely. For more information, see "Installing SEUs."
3.     Press the RESET button on the SEU to reset the SEU. After the SEU is reset, verify that the LED for the SEU is flashing green.
4.     If the switch has empty SEU slots, install the SEU in the empty SEU slot, and verify that the SEU can operate correctly.
5.     If the issue persists, contact H3C Support.
The SEU and interface module slot numbers are marked on the ejector lever pillow blocks at the left and right sides of the slots.
Interface module failure
Symptom
The LED for the interface module is steady red or flashing red.
Solution
1.     Verify that the SEU is operating correctly. For more information, see "SEU failure."
2.     Verify that the system software is compatible with the interface module. Upgrade the system software if it is not compatible with the interface module.
3.     Calculate the total power consumption, and make sure your power supplies can provide enough power. For more information, see "Power supplies."
4.     Remove and reinstall the interface module to make sure it is installed securely. For more information about installing an interface module, see "Installing interface modules."
5.     If the switch has empty interface module slots, install the card in an empty interface module slot. If the interface module operates correctly, the previous slot is faulty.
6.     If the issue persists, contact H3C Support.
Interface failure
Symptom
The LED for the interface is off.
A management Ethernet port has two LEDs, LINK and ACT. When the LINK LED is off, the management Ethernet port fails.
Solution
1.     Make sure the SEU or interface module where the interface resides operates correctly. For more information, see "SEU failure" or "Interface module failure."
2.     Verify that the cable is connected correctly. For how to correctly connect a cable, see "Connecting your switch to the network."
3.     Verify that the cable is in good condition. Use the cable to connect two interfaces of the same type that operate correctly. If the LEDs of the two interfaces are on, the cable is in good condition. Otherwise, the cable is faulty. Use a compliant cable to connect the interface. For more information, see "Appendix D Cables."
4.     If the interface uses a transceiver module, perform the following tasks:
a.     Make sure the interface type is compatible with the transceiver and that the transceiver is compatible with the cable. For more information, see "Appendix B Removable components and compatibility matrixes."
b.     Replace the transceiver module.
5.     Verify that the speed and duplex settings of the interfaces on the two ends are the same.
·     If an interface is brought down by the shutdown command, use the undo shutdown command to bring up the interface.
·     After an interface fails, if the switch has an idle interface of the same type, you can connect the cable to the idle interface.
Technical support
Before contacting H3C Support, prepare the following information:
·     Arrival time of the switch.
·     Serial number of the chassis (on the label at the right of the rear panel).
·     Software version, which you can view by using the display version command.
·     Maintenance agreement or warranty card.
·     Brief issue description.
·     Brief explanation of the troubleshooting measures that have been taken.
