- H3C S12500X-2L Switch Installation Guide-5W101
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing Removalbe Components
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B Removable Components and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Cables
| 00-Preface | 100.67 KB |
Preface
This installation guides you through the installation of your S12500X-2L switch. It covers preparing for installation, installing the switch, installing removable components, connecting your switch to the network, troubleshooting, and replacement procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C S12500X-2L switch.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
