HomeSupportSwitchesS6520XE-HI SeriesConfigure & DeployConfiguration GuidesH3C S6520XE-HI Switch Series Configuration Guides-R7588-6W10009-Security Configuration Guide
16-Object group configuration
16-Object group configuration 41.39 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL to identify packets. The device supports only IPv4 address object groups that contain IPv4 address objects used to match the IPv4 address in a packet or the user from whom a packet comes.
Configuring an IPv4 address object group
1.      Enter system view.
2.      Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.      (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.      Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask } }
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ ip address[ default ] [ name object-group-name ] | name object-group-name ]
