- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
| 11-PBB Configuration Examples | 77.53 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides PBB configuration examples.
This document assumes that you have basic knowledge of PBB.
Example: Configuring PBB
As shown in Figure 1, Site A and Site B both have VLANs 100 through 120.
· Configure QinQ on Device A and Device B to transmit VLANs 100 through 120 in SVLAN 1000.
· Configure PBB on BEB 1 and BEB 2 to extend the VLANs across the two sites.
Analysis
To meet the network requirements, you must perform the following tasks on BEB 1 and BEB 2:
· Configure a service instance on the downlink port to match frames that have an outer VLAN ID of 1000.
· Specify the access mode and data encapsulation type of the PBB VSI as Ethernet to retain the VLAN tags of the customer frames.
Hardware |
Software version |
S6800 switch series S6860 switch series |
Release 2702 |
S6861 switch series |
Not supported |
You need to configure PBB only on BEBs.
Procedures
Configuring BEB 1
# Create VLAN 1000 and VLAN 2000.
<BEB1> system-view
[BEB1] vlan 1000
[BEB1-vlan1000] quit
[BEB1] vlan 2000
[BEB1-vlan2000] quit
# Enable L2VPN.
[BEB1] l2vpn enable
# Create a VSI.
[BEB1] vsi test
# Assign PBB I-SID 1 to the VSI.
[BEB1-vsi-test] pbb i-sid 1
# Specify B-VLAN 2000 for the PBB VSI.
[BEB1-vsi-test-1] bvlan 2000
[BEB1-vsi-test-1] quit
[BEB1-vsi-test] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, assign it to VLAN 2000, and remove it from VLAN 1. Configure Ten-GigabitEthernet 1/0/1 as an uplink port of the PBB VSI.
[BEB1] interface ten-gigabitethernet 1/0/1
[BEB1-Ten-GigabitEthernet1/0/1] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2000
[BEB1-Ten-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[BEB1-Ten-GigabitEthernet1/0/1] pbb uplink vsi test
[BEB1-Ten-GigabitEthernet1/0/1] quit
# Configure Ten-GigabitEthernet 1/0/2 as a trunk port, assign it to VLAN 1000, and remove it from VLAN 1.
[BEB1] interface ten-gigabitethernet 1/0/2
[BEB1-Ten-GigabitEthernet1/0/2] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1000
[BEB1-Ten-GigabitEthernet1/0/2] undo port trunk permit vlan 1
# Create service instance 1 on Ten-GigabitEthernet 1/0/2.
[BEB1-Ten-GigabitEthernet1/0/2] service-instance 1
# Configure the service instance to match frames that have an outer VLAN ID of 1000. Associate the service instance with the PBB VSI, and set the access mode to Ethernet.
[BEB1-Ten-GigabitEthernet1/0/2-srv1] encapsulation s-vid 1000
[BEB1-Ten-GigabitEthernet1/0/2-srv1] xconnect vsi test access-mode ethernet
[BEB1-Ten-GigabitEthernet1/0/2-srv1] quit
[BEB1-Ten-GigabitEthernet1/0/2] quit
# Enable Ethernet encapsulation for the PBB VSI.
[BEB1] vsi test
[BEB1-vsi-test-1] encapsulation ethernet
Configuring BEB 2
# Configure BEB 2 in the same way BEB 1 is configured. (Details not shown.)
Configuring BCB
# Create VLAN 2000.
<BCB> system-view
[BCB] vlan 2000
[BCB-vlan2000] quit
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, assign them to VLAN 2000, and remove them from VLAN 1.
[BCB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[BCB-if-range] port link-type trunk
[BCB-if-range] port trunk permit vlan 2000
[BCB-if-range] undo port trunk permit vlan 1
[BCB-if-range] quit
Configuring Device A
# Create VLAN 1000.
[DeviceA] vlan 1000
[DeviceA-vlan1000] quit
# Configure Ten-GigabitEthernet 1/0/1 as an access port, and assign it to VLAN 1000.
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 1000
# Enable QinQ on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] qinq enable
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1000
[DeviceA-Ten-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[DeviceA-Ten-GigabitEthernet1/0/2] quit
Configuring Device B
# Configure Device B in the same way Device A is configured. (Details not shown.)
# Verify that correct PBB VSI uplink connections have been established between BEB 1 and BEB 2.
<BEB1> display pbb connection
BMAC BVLAN Port Type Aging
011e-8300-0001 2000 XGE1/0/1 MC N
0cda-415e-232e 2000 XGE1/0/1 UC Y
<BEB2> display pbb connection
00e0-fc58-1234 2000 XGE1/0/1 UC Y
# Verify that hosts in Site 1 and Site 2 can ping each another. (Details not shown.)
# Verify that the BCB does not learn customer MAC addresses.
<BCB> display mac-address
Configuration files
· BEB 1 and BEB 2:
vlan 1000
vlan 2000
l2vpn enable
vsi test
pbb i-sid 1
bvlan 2000
port link-mode bridge
pbb uplink vsi test
service-instance 1
· BCB:
vlan 2000
· Device A and Device B:
vlan 1000
qinq enable
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Configuration Guide
