H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
03-Software Upgrade Examples
03-Software Upgrade Examples 134.57 KB
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides software upgrade examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of FTP and TFTP.
General restrictions and guidelines
When you upgrade software, follow these restrictions and guidelines:
·          Make sure the switch has sufficient storage space for the upgrade file. If the switch does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
·          Save the configuration before the upgrade for the configuration to survive a reboot.
Example: Using the switch as a TFTP client to upgrade software
As shown in Figure 1, use TFTP to download a software upgrade file from a TFTP server to upgrade the switch.
Figure 1 Network diagram
Hardware
Software version
S6800 switch series
S6860 switch series
S6861 switch series
Release 2702
Procedures
1.        Configure the TFTP server:
# Assign the IP address 192.168.100.14/24 to the TFTP server. (Details not shown.)
# Start the TFTP server and specify a working directory. This example uses the 3CDaemon TFTP server. (Details not shown.)
Figure 2 Configuring the TFTP server
2.        Upgrade the switch:
# Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the TFTP server.
<Switch> system-view
[Switch] interface m-gigabitethernet 0/0/0
[Switch-M-GigabitEthernet0/0/0] ip address 192.168.100.66 255.255.255.0
[Switch-M-GigabitEthernet0/0/0] quit
[Switch] quit
# Verify that the switch can ping the TFTP server.
<Switch> ping 192.168.100.14
Ping 192.168.100.14 (192.168.100.14): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.100.14: icmp_seq=0 ttl=64 time=10.701 ms
56 bytes from 192.168.100.14: icmp_seq=1 ttl=64 time=2.678 ms
56 bytes from 192.168.100.14: icmp_seq=2 ttl=64 time=2.282 ms
56 bytes from 192.168.100.14: icmp_seq=3 ttl=64 time=1.617 ms
56 bytes from 192.168.100.14: icmp_seq=4 ttl=64 time=1.701 ms
--- Ping statistics for 192.168.100.14 ---
round-trip min/avg/max/std-dev = 1.617/3.796/10.701/3.474 ms
# Save the configuration.
<Switch> save
# Use TFTP to download the upgrade file switch.ipe from the TFTP server to the root directory of the storage medium on the switch.
<Switch> tftp 192.168.100.14 get switch.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 58.7M  100 58.7M    0     0  1193k      0  0:00:50  0:00:50 --:--:-- 1127k
# Specify switch.ipe as the main startup image file.
<Switch> boot-loader file flash:/switch.ipe slot 1 main
Verifying the file flash:/switch.ipe on slot 1.....Done.
Images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file switch.bin to flash:/boot.bin.........Done.
Decompressing file switch.bin to flash:/system.bin...........................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Reboot the switch.
<Switch> reboot
# Verify that the software has been upgraded.
<Switch> display version
H3C Comware Software, Version 7.1.070, Release xxxx
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.
H3C S6800-32Q uptime is 0 weeks, 0 days, 0 hours, 19 minutes
Last reboot reason : User reboot
Boot image: flash:/boot.bin
Boot image version: 7.1.070, Release xxxx
  Compiled Jun 18 2019 17:52:09
System image: flash:/system.bin
System image version: 7.1.070, Release xxxx
---- More ----
# Display the current software images and startup software images.
<Switch> display boot-loader
Software images on slot 1:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
None
Configuration files
interface M-GigabitEthernet0/0/0
Example: Using the switch as an FTP client to upgrade software
As shown in Figure 3, use FTP to download a software upgrade file from an FTP server to upgrade the switch.
Figure 3 Network diagram
Hardware
Software version
S6800 switch series
S6860 switch series
S6861 switch series
Release 2702
Procedures
1.        Configure the FTP server:
# Assign the IP address 192.168.100.14/24 to the FTP server. (Details not shown.)
# Start the FTP server and specify a working directory. This example uses the 3CDaemon FTP server. (Details not shown.)
# Add a local user account. (Details not shown.)
# Set the username to 123456 and the password to 123456 for the user account.
Figure 4 Configuring the FTP server
# Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the FTP server.
[Switch] quit
# Verify that the switch can ping the FTP server.
<Switch> save
Configuration is saved to  mainboard device successfully.
# Use the username 123456 and the password 123456 to log in to the FTP server.
<Switch> ftp 192.168.100.14
Connected to 192.168.100.14 (192.168.100.14).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Use FTP to download the upgrade file switch.ipe from the FTP server to the root directory of the storage medium on the switch.
ftp> get switch.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
50445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
Images in IPE:
  boot.bin
  system.bin
Decompressing file switch.bin to flash:/system.bin.................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on on slot 1.
<Switch> reboot
---- More ----
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
None
Configuration files
Example: Using the switch as an FTP server to upgrade software
As shown in Figure 5:
·          Enable the FTP server on the switch.
·          Use FTP to upload a software upgrade file from an FTP client to upgrade the switch.
Figure 5 Network diagram
Analysis
To use the switch as an FTP server, you must create a local user account on the switch to provide FTP service.
Hardware
Software version
S6800 switch series
S6860 switch series
S6861 switch series
Release 2702
You must set the file transfer mode to binary for FTP to transfer files correctly.
Procedures
# Add a local user account. Set the username to abc and the password to 123456.
[Switch] local-user abc
[Switch-luser-abc] password simple 123456
# Assign the network-admin user role to the user account.
[Switch-luser-abc] authorization-attribute user-role network-admin
# Remove the default network-operator user role.
[Switch-luser-abc] undo authorization-attribute user-role network-operator
# Assign FTP service to the user account.
[Switch-luser-abc] service-type ftp
[Switch-luser-abc] quit
# Enable the FTP server.
[Switch] ftp server enable
[Switch] quit
<Switch> save
2.        Configure the FTP client:
# Assign the IP address 192.168.100.14/24 to the FTP client. Make sure the FTP client can reach the switch. (Details not shown.)
# Use the username abc and the password 123456 to log in to the FTP server.
C:\Documents and Settings\Administrator> ftp 192.168.100.66
Connected to 192.168.100.66.
220 FTP service ready.
User (192.168.100.66:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Access the directory that contains the upgrade file.
ftp> lcd E:\
Local directory now E:\
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
# Transfer the upgrade file switch.ipe to the root directory of the storage medium on the FTP server.
ftp> put switch.ipe
200 PORT command successful
150 Connecting to port 2903
226 File successfully transferred
ftp: 50445056 sent in 1.05Seconds 67282.77Kbytes/sec.
# Verify that the image file is saved on the FTP server.
ftp> ls switch.ipe
150 Connecting to port 3391
switch.ipe
226 1 matches total
ftp: 24 bytes received in 0.00Seconds 24000.00Kbytes/sec.
# Close the FTP connection.
ftp> bye
3.        Upgrade the switch:
Verifying the IPE file and the images.....Done.
Images in IPE:
  boot.bin
  system.bin
<Switch> reboot
---- More ----
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
None
Configuration files
local-user abc class manage
 password hash $h$6$YMVbbwFL/vviWcQu$+CuTbYCehNZtZo5RCXiadpYbXYWa2omt5TUtEh3UPCg3fZjxYCp5WzbuE2GoowVi2YA/BK+mnSZJZqi5jRDuCg==
 service-type ftp
 ftp server enable
Related documentation
·          H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Fundamentals Configuration Guide
·          H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Fundamentals Command Reference
