02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10102-WLAN Command Reference
09-WLAN Optimization Commands
09-WLAN Optimization Commands 115.15 KB
wlan option broadcast-buffer enable
Use wlan option broadcast-buffer enable to enable multicast and broadcast buffering.
Use undo wlan option broadcast-buffer enable to disable multicast and broadcast buffering.
wlan option broadcast-buffer enable [ 2g | 5g ]
undo wlan option broadcast-buffer enable [ 2g | 5g ]
Multicast and broadcast buffering is enabled and the AP buffers all multicast and broadcast packets when an associated client is in sleep state.
Default command level
2: System level
2g: Specifies 2 GHz radios.
5g: Specifies 5 GHz radios.
This command is not applicable to 5 GHz radios of 802.11ac APs.
# Disable multicast and broadcast buffering.
<sysname> system-view
[sysname] undo wlan option broadcast-buffer enable
# Disable multicast and broadcast buffering for 2 GHz radios.
[sysname] undo wlan option broadcast-buffer enable 2g
# Disable multicast and broadcast buffering for 5 GHz radios.
[sysname] undo wlan option broadcast-buffer enable 5g
wlan option cca
Use wlan option cca to set the noise floor thresholds.
Use undo wlan option cca to remove the configuration.
wlan option cca { 2g | 5g } { max max-cca | min min-cca | normal normal-cca }
undo wlan option cca [ 2g | 5g ] [ max | min | normal ]
The noise floor threshold is not set.
2: System level
max-cca: Specifies the upper threshold for the noise floor, in the range of 20 to –160 dBm.
min-cca: Specifies the lower threshold for the noise floor, in the range of –20 to –160 dBm.
normal-cca: Specifies the normal noise floor, in the range of –20 to –160 dBm.
# Set the upper noise floor threshold, lower noise floor threshold, and normal noise floor for 5 GHz radios to 80 dBm, –120 dBm, and –100 dBm, respectively.
[sysname] wlan option cca 5g max 80 min 120 normal 100
wlan option channel-reuse
Use wlan option channel-reuse to set the channel reuse level.
Use undo wlan option channel-reuse to restore the default.
wlan option channel-reuse reuse-level [ 2g | 5g ]
undo wlan option channel-reuse [ 2g | 5g ]
Channel reuse adjustment is disabled.
2: System level
reuse-level: Specifies the channel reuse level in the range of 1 to 10. A smaller value represents a higher reuse level. H3C recommends that you set the reuse level to 5.
# Set the channel reuse level to 6.
[sysname] wlan option channel-reuse 6
# Set the channel reuse level to 6 for 2 GHz radios.
[sysname] wlan option channel-reuse 6 2g
# Set the channel reuse level to 6 for 5 GHz radios.
[sysname] wlan option channel-reuse 6 5g
wlan option channel-share
Use wlan option channel-share to set the power level for channel sharing adjustment.
Use undo wlan option channel-share to restore the default.
wlan option channel-share power-level [ 2g | 5g ]
undo wlan option channel-share [ 2g | 5g ]
Channel sharing adjustment is disabled.
2: System level
power-level: Specifies the power level in the range of 1 to 40. If the AP detects signals stronger than the specified power level, the AP determines that the channel is occupied. A smaller value represents a stronger channel sharing adjustment capability. H3C recommends that you set the power level to 30.
# Set the power level for channel sharing adjustment to 20.
[sysname] wlan option channel-share 20
# Set the power level for channel sharing adjustment to 20 for 2 GHz radios.
[sysname] wlan option channel-share 20 2g
# Set the power level for channel sharing adjustment to 20 for 5 GHz radios.
[sysname] wlan option channel-share 20 5g
wlan option client-rate-limit
Use wlan option client-rate-limit to configure client-type-based rate limiting.
Use undo wlan option client-rate-limit to disable rate limiting for the specified type of clients.
wlan option client-rate-limit { dot11b | dot11ag | dot11n | dot11a | dot11g | dot11an | dot11gn | dot11ac } { inbound | outbound } cir kbps [ cbs byte ]
undo wlan option client-rate-limit [ { dot11b | dot11ag | dot11n | dot11a | dot11g | dot11an | dot11gn | dot11ac } [ inbound | outbound ] ]
Client-type-based rate limiting is disabled.
2: System level
dot11b: Specifies 802.11b clients.
dot11ag: Specifies 802.11a and 802.11g clients.
dot11n: Specifies 802.11n clients.
dot11a: Specifies 802.11a clients.
dot11g: Specifies 802.11g clients.
dot11an: Specifies 802.11an clients.
dot11gn: Specifies 802.11gn clients.
dot11ac: Specifies 802.11ac clients.
inbound: Limits the rate of incoming packets (from clients to APs).
outbound: Limits the rate of outgoing packets (from APs to clients).
cir: Sets the committed information rate (CIR) in the range of 1 to 2097152 kbps.
cbs: Sets the committed burst size (CBS) in the range of 1 to 268435456 bytes. If you do not specify this keyword, the CBS is automatically calculated from the CIR.
# Set the rate limit for packets sent from 802.11n clients to 20480 kbps.
[Sysname] wlan option client-rate-limit dot11n inbound cir 20480
wlan option client-reconnect-trigger
Use wlan option client-reconnect-trigger to enable the AP to trigger client reconnection.
Use undo wlan option client-reconnet-trigger to restore the default.
wlan option client-reconnect-trigger rssi [ signal-check ] [ 2g | 5g ]
undo wlan option client-reconnet-trigger [ 2g | 5g ]
The AP does not trigger client reconnection.
2: System level
rssi: Specifies an RSSI in the range of 1 to 40 dBm. H3C recommends that you set the RSSI to 20 dBm.
The AP triggers client reconnection when the RSSI of a client is lower than the specified RSSI to enable the client to reconnect to the AP or roam to another AP.
If you specify the signal-check keyword in the command, the AP does not trigger client reconnection immediately when the RSSI of a client is lower than the specified RSSI. The AP triggers reconnection for the client only if the next detected RSSI of the client is reduced by a minimum of 3 dBm.
# Enable client reconnection triggering.
[sysname] wlan option client-reconnect-trigger 20
# Enable client reconnection triggering for 2 GHz radios.
[sysname] wlan option client-reconnect-trigger 20 2g
# Enable client reconnection triggering for 5 GHz radios.
[sysname] wlan option client-reconnect-trigger 20 5g
wlan option client-reject
Use wlan option client-reject to enable the AP to reject clients with a signal strength lower than the specified RSSI.
Use undo wlan option client-reject to restore the default.
wlan option client-reject rssi [ 2g | 5g ]
undo wlan option client-reject [ 2g | 5g ]
The AP does not reject clients with a low RSSI.
2: System level
rssi: Specifies an RSSI in the range of 1 to 30 dBm. H3C recommends that you set the RSSI to 10 dBm.
# Enable the AP to reject clients with a signal strength lower than 10 dBm.
[sysname] wlan option client-reject 10
# Enable 2 GHz radios to reject clients with a signal strength lower than 10 dBm.
[sysname] wlan option client-reject 10 2g
# Enable 5 GHz radios to reject clients with a signal strength lower than 10 dBm.
[sysname] wlan option client-reject 10 5g
wlan option dot11n-restraint
Use wlan option dot11n-restraint to enable A-MPDU suppression.
Use undo wlan option dot11n- restraint to restore the default.
wlan option dot11n-restraint packet-number max-packets packet-length max-length [ 2g | 5g ]
undo wlan option dot11n-restraint [ 2g | 5g ]
A-MPDU suppression is disabled.
2: System level
packet-number max-packets: Specifies the threshold for the number of MPDUs aggregated in an A-MPDU, in the range of 1 to 64. H3C recommends that you set the value of the max-packets argument to 8.
packet-length max-length: Specifies the threshold for the A-MPDU length in the range of 2000 to 60000 bytes. H3C recommends that you set the value of the max-length argument to 6000.
The two thresholds take effect at the same time. If either threshold is reached, the AP stops MPDU aggregation and sends the A-MPDU.
# Enable A-MPDU suppression, set the threshold for the number of MPDUs aggregated in an A-MPDU to 64, and set the threshold for the A-MPDU length to 4000 bytes.
[sysname] wlan option dot11n-restraint packet-number 64 packet-length 4000
# On 2 GHz radios, enable A-MPDU suppression, set the threshold for the number of MPDUs aggregated in an A-MPDU to 64, and set the threshold for the A-MPDU length to 4000 bytes.
[sysname] wlan option dot11n-restraint packet-number 64 packet-length 4000 2g
# On 5 GHz radios, enable A-MPDU suppression, set the threshold for the number of MPDUs aggregated in an A-MPDU to 64, and set the threshold for the A-MPDU length to 4000 bytes.
[sysname] wlan option dot11n-restraint packet-number 64 packet-length 4000 5g
wlan option hide-node-protection
Use wlan option hide-node-protection enable to enable hidden node protection.
Use undo wlan option hide-node-protection to restore the default.
wlan option hide-node-protection enable [ 2g | 5g ]
undo wlan option hide-node-protection [ 2g | 5g ]
Hidden node protection is disabled.
2: System level
This command enables the AP to inform clients to use RTS and CTS to avoid collision between hidden nodes.
# Enable hidden node protection.
[sysname] wlan option hide-node-protection enable
# Enable hidden node protection for 2 GHz radios.
[sysname] wlan option hide-node-protection enable 5g
# Enable hidden node protection for 5 GHz radios.
[sysname] wlan option hide-node-protection enable 2g
wlan option max-interfer-threshold
Use wlan option max-interfer-threshold to set the maximum interference threshold.
Use undo wlan option max-interfer-threshold to restore the default.
wlan option max-interfer-threshold value [ 2g | 5g ]
undo wlan option max-interfer-threshold [ 2g | 5g ]
The maximum interference threshold is 50.
2: System level
value: Specifies the maximum interference threshold in the range of 20 to 120. The default value is 50.
# Set the maximum interference threshold to 60.
[Sysname] wlan option max-interfer-threshold 60
# Set the maximum interference threshold to 60 for 2 GHz radios.
[Sysname] wlan option max-interfer-threshold 60 2g
# Set the maximum interference threshold to 60 for 5 GHz radios.
[Sysname] wlan option max-interfer-threshold 60 5g
wlan option probe-response-try
Use wlan option probe-response-try to set the maximum transmission times for probe responses.
Use undo wlan option probe-response-try to restore the default.
wlan option probe-response-try trynum [ 2g | 5g ]
undo wlan option probe-response-try [ 2g | 5g ]
The maximum transmission times for probe responses is 2.
2: System level
trynum: Specifies the maximum transmission times for probe responses, in the range of 1 to 16.
# Set the maximum transmission times for probe responses to 5.
[Sysname] wlan option probe-response-try 5
# Set the maximum transmission times for probe responses to 5 for 2 GHz radios.
[Sysname] wlan option probe-response-try 5 2g
# Set the maximum transmission times for probe responses to 5 for 5 GHz radios.
[Sysname] wlan option probe-response-try 5 5g
wlan option roam-navigation level
Use wlan option roam-navigation to enable roaming navigation.
Use undo wlan option roam-navigation to disable roaming navigation.
wlan option roam-navigation level level [ rssi client-level ] [ 2g | 5g ]
undo wlan option roam-navigation [ 2g | 5g ]
Roaming navigation is disabled.
2: System level
level level: Specifies the global roaming navigation level in the range of 1 to 30. A smaller value represents a higher roaming navigation capability. H3C recommends that you set the global roaming navigation level to 10.
rssi: Specifies the signal strength threshold for clients, in the range of 1 to 50. If the signal strength of a client is lower than the threshold, the AP performs roaming navigation for the client. H3C recommends that you set the signal strength threshold to 20.
client-level: Specifies the client roaming navigation level in the range of 1 to 30. A smaller value represents a higher roaming navigation capability. H3C recommends that you set the client roaming navigation level to 10.
# Enable roaming navigation, set the global roaming navigation level to 10, signal strength threshold to 20, and client roaming navigation level to 10.
[sysname] wlan option roam-navigation level 10 20 10
# On 2 GHz radios, enable roaming navigation, set the global roaming navigation level to 10, signal strength threshold to 20, and client roaming navigation level to 10.
[sysname] wlan option roam-navigation level 10 20 10 2g
# On 5 GHz radios, enable roaming navigation, set the global roaming navigation level to 10, signal strength threshold to 20, and client roaming navigation level to 10.
[sysname] wlan option roam-navigation level 10 20 10 5g
wlan option rx-broadcast-all enable
Use wlan option rx-broadcast-all enable to enable the AP to receive all broadcast packets.
Use undo wlan option rx-broadcast-all enable to restore the default.
wlan option rx-broadcast-all enable [ 2g | 5g ]
undo wlan option rx-broadcast-all enable [ 2g | 5g ]
The AP does not receive all broadcast packets.
2: System level
# Enable the AP to receive all broadcast packets.
[sysname] wlan option rx-broadcast-all enable
# Enable 2 GHz radios to receive all broadcast packets.
[sysname] wlan option rx-broadcast-all enable 2g
# Enable 5 GHz radios to receive all broadcast packets.
[sysname] wlan option rx-broadcast-all enable 5g
wlan option signal-ignore
Use wlan option signal-ignore to enable the AP to ignore signals weaker than the specified RSSI.
Use undo wlan option signal-ignore to restore the default.
wlan option signal-ignore rssi [ 2g | 5g ]
undo wlan option signal-ignore [ 2g | 5g ]
The AP does not ignore weak signals.
2: System level
# Enable the AP to ignore signals weaker than 10 dBm.
[sysname] wlan option signal-ignore 10
# Enable 2 GHz radios to ignore signals weaker than 10 dBm.
[sysname] wlan option signal-ignore 10 2g
# Enable 5 GHz radios to ignore signals weaker than 10 dBm.
[sysname] wlan option signal-ignore 10 5g
wlan option tpc
Use wlan option tpc to enable per-packet transmit power control (TPC) based on signal strength of clients.
Use undo wlan option tpc enable to restore the default.
wlan option tpc [ rssithreshold rssithreshold | rssistep rssistep | powerstep powerstep | minpower minpower ] * enable [ 2g | 5g ]
undo wlan option tpc enable [ 2g | 5g ]
Per-packet TPC based on signal strength of clients is disabled.
2: System level
rssithreshold: Specifies the RSSI threshold for received packets, in the range of 20 to 95 dbm. The default value is 65 dbm.
rssistep: Specifies the step for RSSI modification, in the range of 1 to 20 dbm. The default value is 10 dbm.
powerstep: Specifies the step for transmission power decrease, in the range of 1 to 15 dbm. The default value is 5 dbm.
minpower: Specifies the minimum transmission power in the range of 1 to 27 dbm. The default value is 10 dbm.
# Enable TPC when the RSSI of received packets reaches 50, and set the RSSI step, power step, and minimum transmission power to 10, 5, and 10, respectively.
[Sysname] wlan option tpc rssithreshold 50 rssistep 10 powerstep 5 minpower 10 enable
# On 2 GHz radios, enable TPC when the RSSI of received packets reaches 50, and set the RSSI step, power step, and minimum transmission power to 10, 5, and 10, respectively.
[Sysname] wlan option tpc rssithreshold 50 rssistep 10 powerstep 5 minpower 10 enable 2g
# On 5 GHz radios, enable TPC when the RSSI of received packets reaches 50, and set the RSSI step, power step, and minimum transmission power to 10, 5, and 10, respectively.
[Sysname] wlan option tpc rssithreshold 50 rssistep 10 powerstep 5 minpower 10 enable 5g
Use wlan option tpc enable to enable per-packet TPC based on packet loss rate.
Per-packet TPC based on packet loss rate is disabled.
2: System level
# Enable per-packet TPC based on packet loss rate.
[sysname] wlan option tpc enable
# Enable per-packet TPC based on packet loss rate for 2 GHz radios.
[sysname] wlan option tpc enable 2g
# Enable per-packet TPC based on packet loss rate for 5 GHz radios.
[sysname] wlan option tpc enable 5g
