| 07-Advanced WLAN Commands | 66.76 KB |
Multicast optimization configuration commands
display wlan multicast optimization
wlan multicast optimization aging-time
wlan multicast optimization threshold
wlan multicast optimization threshold-action
Use display wlan multicast optimization to display multicast optimization information.
display wlan multicast optimization interface wlan-radio [ radio-number ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
wlan-radio radio-number: Specifies a radio interface by its number. If you do not specify the radio-number argument, the command displays multicast optimization information for all radio interfaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display multicast optimization information for the radio interface WLAN-Radio 1/0/2.
<Sysname> display wlan multicast optimization interface wlan-radio 1/0/2
Multicast Optimization Information
WLAN-Radio1/0/2:
Total clients: 9
Action: Optimize
Multicast Address: 229.0.0.17
MAC Address:
1234-1101-ba01, 1234-1101-ba02
Multicast Address: FF0E:AC1E:A::B
MAC Address:
1234-1101-ba86, 1234-1101-ba87, 1234-1101-ba88,
1234-1101-ba89, 1234-1101-ba8a, 1234-1101-ba8c,
1234-1101-ba8d,
Total clients |
Total number of clients served by multicast optimization. If a client joins multiple multicast groups, the client is counted as multiple clients. For example, if a client has joined two multicast groups through a radio, the client is counted as two clients by multicast optimization. |
Action |
Operating status of the multicast optimization function: · Optimize—The multicast optimization function is operating. · Halt—The multicast optimization function is halted. |
Multicast Address |
Address of the multicast group that the clients has joined. |
MAC Address |
MAC addresses of the clients that have joined the multicast group. |
multicast optimization enable
Use multicast optimization enable to enable multicast optimization.
Use undo multicast optimization enable to restore the default.
Multicast optimization is disabled.
Service template view
2: System level
# Enable multicast optimization for service template 1.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] multicast optimization enable
Use wlan multicast optimization aging-time to configure the aging time for multicast optimization entries.
Use undo wlan multicast optimization aging-time to restore the default.
wlan multicast optimization aging-time time
The aging time for multicast optimization entries is 260 seconds.
2: System level
time: Specifies the aging time for multicast optimization entries, in the range of 200 to 1000 seconds.
If the AP does not receive any IGMP report from a client within the aging time, the AP removes the client from the multicast optimization entry.
# Configure the aging time for multicast optimization entries as 300 seconds.
[Sysname] wlan multicast optimization aging-time 300
· display wlan multicast optimization
· igmp-snooping enable and igmp-snooping host-aging-time in IP Multicast Commands.
Use wlan multicast optimization threshold to configure the maximum number of clients supported by multicast optimization.
Use undo wlan multicast optimization threshold to restore the default.
wlan multicast optimization threshold threshold-value
The maximum number of clients supported by multicast optimization is 6.
2: System level
threshold-value: Specifies the maximum number of clients supported by multicast optimization, in the range of 2 to 124.
A client can join up to eight multicast groups.
If a client joins multiple multicast groups, the client is counted as multiple clients in multicast optimization statistics. For example, if a client has joined two multicast groups, the client is counted as two clients in the multicast optimization statistics.
# Configure the maximum number of clients allowed for multicast optimization as 7.
[Sysname] wlan multicast optimization threshold 7
Use wlan multicast optimization threshold-action to configure the action to take when the maximum number of clients supported multicast optimization is reached.
Use undo wlan multicast optimization threshold-action to restore the default.
wlan multicast optimization threshold-action { halt | reject-client }
The multicast optimization function becomes invalid when the maximum number of clients supported multicast optimization is reached.
2: System level
halt: Invalidates the multicast optimization feature. A new client can join a multicast group and receive multicast packets, and a multicast optimization entry can be created for the client. However, the multicast optimization feature for all clients in the multicast group becomes invalid. When the number of clients drops below the upper limit, the multicast optimization feature takes effect again.
reject-client: Rejects new clients. A new client can join a multicast group, but no new multicast optimization entries can be created. If multicast optimization entries have been created for other clients in the multicast group, the client cannot receive multicast packets. If not, the client can receive multicast packets.
If you configure the halt mode first, and then configure the reject mode, the existing multicast optimization entries still take effect.
# Configure the AP to reject new clients when the maximum number of clients supported multicast optimization is reached.
[Sysname] wlan multicast optimization threshold-action reject-client
· wlan multicast optimization threshold
