02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10102-WLAN Command Reference
04-WLAN RRM Commands
04-WLAN RRM Commands 153.57 KB
autochannel-set avoid-dot11h
Use autochannel-set avoid-dot11h to configure that only the non-dot11h channels of the country code are scanned during initial channel selection.
Use undo autochannel-set avoid-dot11h to restore the default.
RRM scans all channels supported by the country code.
WLAN RRM view
Default command level
2: System level
Some of 802.11h channels, also called radar channels, overlap some 802.11a channels. If the device operates on an overlapping channel, its service quality may be affected. With this command enabled, the device selects a working channel from non-802.11h channels belonging to the configured country code to avoid channel collision.
# Configure RRM to scan only non-dot11h channels.
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
display wlan rrm
Use display wlan rrm to display basic RRM configuration information.
display wlan rrm [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display RRM configuration information.
<Sysname>display wlan rrm
                                 RRM Configuration
 11a Configured Rates (Mbps)
   Mandatory                   : 6, 12, 24
   Supported                   : 9, 18, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 11b Configured Rates (Mbps)
   Mandatory                   : 1, 2
   Supported                   : 5.5, 11
   Disabled                    : -NA-
   Multicast                   : Auto
 11g Configured Rates (Mbps)
   Mandatory                   : 1, 2, 5.5, 11
   Supported                   : 6, 9, 12, 18, 24, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 11a Configuration
   Automatic Channel Selection : Disabled
   Automatic Power Selection   : Disabled
   Calibration Mode-Channel    : -NA-
   Mesh Calibration Mode-Channel: -NA-
   Calibration Mode-Power      : -NA-
   exclude-channel             : -NA-
   Calibration Interval (min)  : 8
   Interference Threshold (%)  : 50
   Tolerance Level (%)         : 20
   Adjacency Factor            : 3
   CRC-Error Threshold (%)     : 20
   Power Threshold (dBm)       : 191
   Minimum Power (dBm)         : 1
   max-bandwidth (kbps)        : 30000
 11bg Configuration
 11b Configuration
   max-bandwidth (kbps)        : 7000
 11g Configuration
   11g Protection              : Disabled
   11g Protection Mode         : CTS-to-Self
 11n Configuration
   Mandatory Maximum MCS       : -NA-
   Supported Maximum MCS       : 76
   Multicast MCS               : -NA-
   11n Protection              : Disabled
   11n Protection Mode         : CTS-to-Self
   max-bandwidth (kbps)        : 250000
 11h Configuration
   Spectrum Management         : Disabled
   Power Constraint (dBm)      : 0
   Channel Set                 : All
 11ac Configuration
   Mandatory Maximum NSS       : -NA-
   Support Maximum NSS         : 8
   Multicast NSS               : -NA-
   Multicast VHT-MCS           : -NA-
 Band Navigation Configuration
   Band Navigation             : Disabled
<Sysname>
802.11a rates. The same field for 802.11b and 802.11g has the same meaning.
Mandatory
Rates that at least one of the APs is required to support.
Supported
Additional rates supported by the client or AP.
Disabled
Rates at which an AP does not transmit data.
Multicast
Rate at which an AP sends multicast data to clients. The multicast rate must be selected from the mandatory rates.
11a Configuration
802.11a configuration. The same field for 802.11b and 802.11n has the same meaning.
Whether DFS is enabled or disabled. DFS is not supported in the current software version.
Whether Transmit power control (TPC) is enabled or disabled. TPC is not supported in the current software version.
·         Self-decisive—Auto DFS.
·         Pronto—One-time DFS.
·         -NA-—Not configured.
·         Self-decisive—Mesh auto DFS.
·         Pronto—Mesh one-time DFS.
·         Self-decisive—Auto TPC.
·         Pronto—One-time TPC.
Exclude-channel
Channels to be excluded.
Calibration interval.
Channel interference threshold.
Tolerance Level (%)
Tolerance factor.
Adjacency Factor
Adjacency facto.
CRC-error threshold.
Power adjustment threshold in dBm.
Minimum Power (dBm)
Minimum transmission power in dBm.
11g Protection
802.11g protection: Enabled or Disabled.
11g Protection Mode
802.11g protection mode: CTS-to-Self or RTS/CTS.
11n Protection Mode
802.11n protection mode: CTS-to-Self or RTS/CTS.
11h Configuration
802.11h configuration.
Spectrum Management
Enabled or disabled.
Power constraint for all 802.11a radios.
Channel Set
All or Non-dot11h.
dot11a
Use dot11a to configure 802.11a rates.
Use undo dot11a to restore the default 802.11a rates.
dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
·          Disabled rates: none.
·          Mandatory rates: 6, 12, and 24.
·          Multicast rates: automatically selected from the mandatory rates.
·          Supported rates: 9, 18, 36, 48 and 54.
WLAN RRM view
2: System level
disabled-rate: Specifies a disabled rate.
mandatory-rate: Specifies mandatory rates.
multicast-rate: Specifies multicast rates, at which the AP sends multicasts to clients. Multicasts rates must be selected from the mandatory rates.
supported-rate: Specifies supported rates.
rate-value: The following rates can be specified:
·          6 Mbps
·          9 Mbps
·          12 Mbps
·          18 Mbps
·          24 Mbps
·          36 Mbps
·          48 Mbps
·          54 Mbps
# Configure 802.11a rates (multicast: 6; supported: 12).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a multicast-rate 6
[Sysname-wlan-rrm] dot11a supported-rate 12
dot11a exclude-channel
Use dot11a exclude-channel to configure the 5 GHz channel exclusion list.
Use undo dot11a exclude-channel to remove the channels in the 5 GHz channel list.
dot11a exclude-channel channel-list
undo dot11a exclude-channel { channel-list | all }
No channels exist in the channel exclusion list.
WLAN RRM view
2: System level
channel-list: Specifies a channel list, in the format of channel-list = { channel }& <1-10>, where channel represents a 5 GHz channel supported by the AP and &<1-10> indicates that you can specify up to 10 channels.
all: Specifies all channels.
# Add channels 149 and 153 to the 5 GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 149 153
dot11a max-bandwidth
Use dot11a max-bandwidth to configure the maximum 802.11a bandwidth.
Use undo dot11a max-bandwidth to restore the default.
dot11a max-bandwidth 11a-bandwidth
The maximum 802.11a bandwidth is 30000 kbps.
WLAN RRM view
2: System level
11a-bandwidth: Maximum 802.11a bandwidth, in the range of 16 to 30000 kbps.
# Configure the maximum 802.11a bandwidth as 15000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a max-bandwidth 15000
dot11ac mandatory maximum-nss
Use dot11ac mandatory maximum-nss to set the maximum mandatory NSS.
Use undo dot11ac mandatory maximum-nss to remove the configuration.
dot11ac mandatory maximum-nss number
No maximum mandatory NSS is set.
RRM view
2: System level
number: Specifies the maximum mandatory NSS in the range of 1 to 8.
# Set the maximum mandatory NSS to 4.
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac mandatory maximum-nss 4
dot11ac multicast-rate nss
Use dot11ac multicast-rate to set the multicast NSS and specify a VHT-MCS index.
Use undo dot11ac multicast-rate to remove the configuration.
dot11ac multicast-rate nss number vht-mcs index
No multicast NSS is set.
RRM view
2: System level
number: Specifies the multicast NSS in the range of 1 to 8.
index: Specifies a VHT-MCS index in the range of 0 to 9.
# Set the multicast NSS and VHT-MCS index to 2 and 7, respectively.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac multicast-rate nss 2 VHT-MCS 7
dot11ac support maximum-nss
Use dot11ac support maximum-nss to set the maximum supported NSS.
Use undo dot11ac support maximum-nss to remove the configuration.
dot11ac support maximum-nss number
The maximum supported NSS is 8.
RRM view
2: System level
number: Specifies the maximum supported NSS in the range of 1 to 8.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS.
# Set the maximum supported NSS to 5.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac support maximum-nss 5
dot11b
Use dot11b to configure 802.11b rates.
Use undo dot11b to restore the default rates.
dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
WLAN RRM view
2: System level
disabled-rate: Specifies disabled rates.
·          1 Mbps
·          2 Mbps
·          5.5 Mbps
·          11 Mbps
# Configure 802.11b rates (disabled: 1; multicast: 11; supported: 11).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1
[Sysname-wlan-rrm] dot11b multicast-rate 11
[Sysname-wlan-rrm] dot11b supported-rate 11
dot11b max-bandwidth
Use dot11b max-bandwidth to configure the maximum 802.11b bandwidth.
Use undo dot11b max-bandwidth to restore the default.
dot11b max-bandwidth 11b-bandwidth
The maximum 802.11b bandwidth is 7000 kbps.
WLAN RRM view
2: System level
11b-bandwidth: Maximum 802.11b bandwidth, in the range of 16 to 7000 kbps.
# Configure the maximum 802.11b bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b max-bandwidth 6000
dot11bg exclude-channel
Use dot11bg exclude-channel to configure the 2.4 GHz channel exclusion list.
Use undo dot11bg exclude-channel to remove the channels in the 2.4 GHz channel exclusion list.
dot11bg exclude-channel channel-list
undo dot11bg exclude-channel { channel-list | all }
WLAN RRM view
2: System level
# Add channels 1 and 2 to the 2.4 GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 1 2
dot11g
Use dot11g to configure 802.11g rates.
Use undo dot11g to restore the default rates.
dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
·          Mandatory rates: 1, 2, 5.5, and 11.
·          Supported rates: 6, 9, 12, 18, 24, 36, 48, and 54.
WLAN RRM view
2: System level
multicast-rate: Specifies multicast rates, which are the rates at which the AP send multicasts to clients. Multicasts rates must be selected from the mandatory rates.
rate-value: The following rates can be specified.
·          1 Mbps
·          2 Mbps
·          5.5 Mbps
·          6 Mbps
·          9 Mbps
·          11 Mbps
·          12 Mbps
·          18 Mbps
·          24 Mbps
·          36 Mbps
·          48 Mbps
·          54 Mbps
# Configure 802.11g rates (disabled: 2, 36; multicast: 11; supported: 54).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g multicast-rate 11
[Sysname-wlan-rrm] dot11g supported-rate 54
dot11g max-bandwidth
Use dot11g max-bandwidth to configure the maximum 802.11g bandwidth.
Use undo dot11g max-bandwidth to restore the default.
dot11g max-bandwidth 11g-bandwidth
The maximum 802.11g bandwidth 30000 kbps.
WLAN RRM view
2: System level
11g-bandwidth: Maximum 802.11g bandwidth in kbps. It is in the range of 16 to 30000 kbps.
# Configure the maximum 802.11g bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g max-bandwidth 6000
dot11g protection enable
Use dot11g protection enable to enable 802.11g protection.
Use undo dot11g protection enable to restore the default.
802.11g protection is disabled.
WLAN RRM view
2: System level
# Enable 802.11g protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11g protection-mode
Use dot11g protection-mode to configure the 802.11g protection mode.
Use undo dot11g protection-mode to restore the default.
dot11g protection-mode { cts-to-self | rts-cts }
The 802.11g protection mode is CTS-to-Self.
WLAN RRM view
2: System level
cts-to-self: Specifies the Clear to Send (CTS)-to-Self mode.
rts-cts: Specifies the Request to Send (RTS)/CTS mode.
# Configure the 802.11g protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection-mode rts-cts
dot11n mandatory maximum-mcs
Use dot11n mandatory maximum-mcs to specify the maximum MCS index for 802.11n mandatory rates.
Use undo dot11n mandatory maximum-mcs to remove the configuration.
dot11n mandatory maximum-mcs index
No maximum MCS index is specified for 802.11n mandatory rates.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n mandatory rates, in the range of 0 to 76.
If you configure the client dot11n-only command for a radio, you must configure the maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n mandatory rates as 7.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 7
dot11n max-bandwidth
Use dot11n max-bandwidth to configure the maximum 802.11n bandwidth.
Use undo dot11n max-bandwidth to restore the default.
dot11n max-bandwidth 11n-bandwidth
The maximum 802.11n bandwidth is 250000 kbps.
WLAN RRM view
2: System level
11a-bandwidth: Maximum 802.11n bandwidth, in the range of 16 to 250000 kbps.
# Configure the maximum 802.11n bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n max-bandwidth 6000
dot11n multicast-rate
Use dot11n multicast-rate to specify the maximum MCS index for 802.11n multicast rates.
Use undo dot11n multicast-rate to remove the configuration.
dot11n multicast-rate index
The maximum MCS index for 802.11n multicast rates is not configured.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n multicast rates, in the range of 0 to 76.
The multicast MCS is adopted only when all the clients use 802.11n. When you specify the multicast MCS index, make sure all 802.11n clients support the MCS index.
If a non 802.11n client exists, multicast traffic is transmitted at a mandatory MCS data rate.
If you configure a multicast MCS index greater than the maximum MCS index supported by the radio, the maximum MCS index is adopted.
When the multicast MCS takes effect, the corresponding non-short GI data rates defined for 20 MHz are adopted no matter whether the 802.11n radio operates in 40 MHz mode or in 20 MHz mode.
# Specify the maximum MCS index for 802.11n multicast rates as 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n multicast-rate 70
dot11n protection enable
Use dot11n protection enable to enable 802.11n protection.
Use undo dot11n protection enable to restore the default.
802.11n protection is disabled.
WLAN RRM view
2: System level
# Enable 802.11n protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection enable
dot11n protection-mode
Use dot11n protection-mode to configure the 802.11n protection mode.
Use undo dot11n protection-mode to restore the default.
dot11n protection-mode { cts-to-self | rts-cts }
The 802.11n protection mode is CTS-to-Self.
WLAN RRM view
2: System level
# Configure the 802.11n protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection-mode rts-cts
dot11n support maximum-mcs
Use dot11n support maximum-mcs to specify the maximum MCS index for 802.11n supported rates.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
The maximum MCS index for 802.11n supported rates is 76.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n supported rates, in the range of 0 to 76.
The specified maximum MCS index for 802.11n supported rates must be no less than the specified maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n supported rates as 25.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
power-constraint
Use power-constraint to enable the device to notify all 802.11a, 802.11an, and 802.11ac clients to reduce their transmit power by a specified value.
Use undo power-constraint to remove the configuration.
power-constraint power-constraint
Transmit power is not restricted on 802.11a, 802.11an, and 802.11ac clients.
WLAN RRM view
2: System level
power-constraint: Power constraint value in dBm, in the range of 0 to 30.
This command takes effect only when the spectrum-management enable command is enabled. After you configure the power constraint, the device will notify 802.11a, 802.11an, and 802.11ac clients to reduce their maximum transmit power by the specified value.
# Enable spectrum management and enable the device to notify 802.11a, 802.11an, and 802.11ac clients to reduce their maximum transmit power by 5 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
[Sysname-wlan-rrm] power-constraint 5
scan report-interval
Use scan report-interval to set the scan report interval.
Use undo scan report-interval to restore the default.
scan report-interval seconds
The scan report interval is 10 seconds.
WLAN RRM view
2: System level
seconds: Interval for sending scan reports to the AC, in the range of 5 to 120 seconds.
# Set the scan report interval to 20 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan report-interval 20
scan type
Use scan type to set the scan type.
Use undo scan type to restore the default.
scan type { active | passive }
undo scan type
The scan type is passive.
WLAN RRM view
2: System level
active: Sets the active scanning mode.
passive: Sets the passive scanning mode.
# Set the scan type to active.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan type active
Use spectrum-management enable to enable spectrum management for 802.11a radios.
Use undo spectrum-management enable to restore the default.
Spectrum management for 802.11a radios is disabled.
WLAN RRM view
2: System level
After you enable spectrum management, the AP will notify its power capabilities and power constraint on clients.
# Enable spectrum management.
[Sysname] wlan rrm
power-constraint
wlan rrm
Use wlan rrm to enter WLAN RRM view.
wlan rrm
2: System level
# Enter WLAN RRM view.
[Sysname] wlan rrm
[Sysname-wlan-rrm]
Band navigation configuration commands
band-navigation aging-time
Use band-navigation aging-time to configure the client information aging time.
Use undo band-navigation aging-time to restore the default.
band-navigation aging-time aging-time
The client information aging time is 180 seconds.
WLAN RRM view
2: System level
aging time: Client information aging time, in the range of 10 to 600 seconds.
# Configure the client information aging time as 50 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation aging-time 50
band-navigation balance access-denial
Use band-navigation balance access-denial to configure the maximum denial count of association requests sent by a 5 GHz-capable client.
Use undo band-navigation balance access-denial to restore the default.
An AP does not reject 5 GHz clients.
WLAN RRM view
2: System level
access-denial: Maximum denial count of client association requests, in the range of 1 to 10.
If the times a client has been denied reach the maximum denial count on the 5 GHz radio, the AP considers that the client is unable to associate to the 2.4 GHz radio of the AP or any other AP, and allows the 5 GHz radio to accept the client.
# Configure the maximum denial count of client association requests as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance access-denial 5
band-navigation balance session
Use band-navigation balance session to configure the band navigation load balancing session threshold and session gap.
Use undo band-navigation balance session to restore the default.
band-navigation balance session session [ gap gap ]
Load balancing for band navigation is disabled.
WLAN RRM view
2: System level
session: Band navigation load balancing session threshold for the 5GHz band, in the range of 2 to 40.
gap: Band navigation load balancing session gap, which is the number of clients on the 5 GHz band minus the number of clients on the 2.4 GHz band. It is in the range of 1 to 8, and the default session gap is 4.
# Configure the session threshold as 10 and session gap as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance session 10 gap 5
band-navigation enable
Use band-navigation enable to enable band navigation.
Use undo band-navigation enable to disable band navigation.
Band navigation is disabled.
WLAN RRM view
2: System level
# Enable band navigation.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation enable
band-navigation rssi-threshold
Use band-navigation rssi-threshold to configure the band navigation RSSI threshold.
Use undo band-navigation rssi-threshold to restore the default.
band-navigation rssi-threshold rssi-threshold
The band navigation RSSI threshold is 15.
WLAN RRM view
2: System level
rssi-threshold: Band navigation RSSI threshold, in the range of 5 to 100.
An AP directs a client to its 5 GHz radio only when the AP detects that the RSSI of the client is higher than the band navigation RSSI threshold.
# Configure the band navigation RSSI threshold as 40.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation rssi-threshold 40
