02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10102-WLAN Command Reference
05-WLAN IDS Commands
05-WLAN IDS Commands 90.58 KB
WLAN IDS detection configuration commands
attack-detection enable
Use attack-detection enable to enable WIDS-IPS detection of various DoS attacks.
Use undo attack-detection enable to restore the default.
attack-detection enable { all | flood | spoof | weak-iv }
No WIDS-IPS detection is enabled.
WLAN IDS view
Default command level
2: System level
all: Enables detection of all kinds of attacks.
flood: Enables detection of flood attacks.
spoof: Enables detection of spoof attacks.
weak-iv: Enables weak-IV detection.
# Enable spoof attack detection.
[Sysname] wlan ids
[Sysname-wlan-ids] attack-detection enable spoof
display wlan ids history
Use display wlan ids history to display the history of attacks detected in the WLAN system. It supports a maximum of 512 entries.
display wlan ids history [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the history of attacks.
<Sysname> display wlan ids history
 Total Number of Entries: 5
  Flags:
   act = Action Frame             asr = Association Request
   aur = Authentication Request   daf = Deauthentication Frame
   dar = Disassociation Request   ndf = Null Data Frame
   pbr = Probe Request            rar = Reassociation Request
   saf = Spoofed Disassociation Frame
   sdf = Spoofed Deauthentication Frame
   wiv = Weak IV Detected
   AT - Attack Type, Ch - Channel Number, AR - Average RSSI
                              WIDS History Table
 MAC Address      AT    Ch    AR    Detected Time          AP
 0027-E699-CA71   asr   8     44    2010-06-12/19:47:54    ap12
 0015-E9A4-D7F4   wiv   8     45    2010-06-12/19:45:28    ap48
 0027-E699-CA71   asr   8     20    2010-06-12/19:18:17    ap12
 003d-B5A6-539F   pbr   8     43    2010-06-12/19:10:48    ap56
 0015-E9A4-D7F4   wiv   8     50    2010-06-12/19:01:28    ap48
MAC-Address
In case of spoof attacks, this field displays the BSSID that was spoofed. In case of other attacks, this field displays the MAC address of the device that initiated the attack.
AT
Type of attack.
Ch
Channel in which the attack was detected.
AR
Average RSSI of the attack frames.
Detected time
Time at which this attack was detected.
display wlan ids statistics
Use display wlan ids statistics to display WLAN IDS statistics.
display wlan ids statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display WLAN IDS statistics.
<Sysname> display wlan ids statistics
 Current attack tracking since: 2010-06-21/12:46:33
 Type                                            Current       Total
 Probe Request Frame Flood Attack                2             7
 Authentication Request Frame Flood Attack       0             0
 Deauthentication Frame Flood Attack             0             0
 Association Request Frame Flood Attack          1             1
 Disassociation Request Frame Flood Attack       4             8
 Reassociation Request Frame Flood Attack        0             0
 Action Frame Flood Attack                       0             0
 Null Data Frame Flood Attack                    0             0
 Weak IVs Detected                               12            21
 Spoofed Deauthentication Frame Attack           0             0
 Spoofed Disassociation Frame Attack             0             2
Current
Provides the count of attacks detected since the time specified by the current attack tracking time (specified in the field "Current attack tracking since:"). The current attack tracking time is started at the system startup and is refreshed each hour subsequently.
Total
Provides the total count of the attacks detected since the system startup.
Number of probe request frame flood attacks detected.
Number of authentication request frame flood attack detected.
Number of de-authentication frame flood attacks detected.
Number of association request frame flood attacks detected.
Number of disassociation request frame flood attacks detected.
Number of reassociation request frame flood attacks detected.
Number of action frame flood attacks detected.
Number of null data frame flood attacks detected.
Weak IVs Detected
Number of weak IVs detected.
Number of spoofed deauthentication frame attacks detected.
Number of spoofed disassociation frame attacks detected.
reset wlan ids history
Use reset wlan ids history to clear the history information of attacks detected in the WLAN.
1: Monitor level
After this command is executed, all the history information regarding attacks will be cleared, and the history table will be empty.
# Clear all history information of attacks.
<Sysname> reset wlan ids history
reset wlan ids statistics
Use reset wlan ids statistics to clear the statistics of attacks detected in the WLAN system.
1: Monitor level
This command clears both the "current" and "total" of all attack types in the WLAN IDS statistics table.
# Clear WLAN IDS statistics.
<Sysname>reset wlan ids statistics
wlan device-detection enable
Use wlan device-detection enable to configure the AP to operate in hybrid mode.
Use undo wlan device-detection enable to restore the default.
The AP operates in normal mode to provide WLAN services.
2: System level
If the AP operates in monitor mode, the command is invisible.
If the AP operates in hybrid mode, configure a service template so the AP can provide both WLAN access and rogue detection services.
# Set the hybrid operation mode for the AP.
[Sysname] wlan device-detection enable
wlan ids
Use wlan ids to enter WLAN IDS view.
wlan ids
2: System level
This view enables you to configure WLAN IDS parameters such as scan parameters and device lists.
# Enter WLAN IDS view.
[Sysname] wlan ids
[Sysname-wlan-ids]
wlan work-mode monitor
Use wlan work-mode monitor to configure the AP to operate in monitor mode.
Use undo wlan work-mode monitor to restore the default.
2: System level
If the AP operates in monitor mode, the AP can only operate as a monitor AP and cannot operate as an access AP, and cannot provide WLAN services.
Before switching the AP operating mode from hybrid to normal, use the undo wlan device-detection enable command to disable the hybrid mode.
# Set the monitor operation mode for the AP.
[Sysname] wlan work-mode monitor
Blacklist and whitelist configuration commands
display wlan blacklist
Use display wlan blacklist to display the static or dynamic blacklist entries.
display wlan blacklist { static | dynamic } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
static: Displays static blacklist entries.
dynamic: Displays dynamic blacklist entries.
# Display information about the static blacklist.
<Sysname> display wlan blacklist static
Total Number of Entries: 3
                               Static Blacklist
 MAC-Address
 0014-6c8a-43ff
 0016-6F9D-61F3
 0019-5B79-F04A
MAC-Address
MAC addresses of clients.
# Display information about the dynamic blacklist.
<Sysname> display wlan blacklist dynamic
                               Dynamic Blacklist
 MAC-Address    APID Lifetime(s) Blacklisted For (hh:mm:ss)   Reason
 000f-e2cc-0001 1    60          00:02:11                     Assoc-Flood
 000f-e2cc-0002 2    60          00:01:17                     Deauth-Flood
 000f-e2cc-0003 3    60          00:02:08                     Auth-Flood
MAC-Address
MAC address of the device inserted into the dynamic blacklist.
APID
AP ID of the corresponding entry in the dynamic blacklist.
Lifetime(s)
Lifetime of the corresponding entry in seconds.
Time elapsed since the entry was last updated.
Reason
Reason why the entry was added into the dynamic blacklist.
display wlan whitelist
Use display wlan whitelist to display the configured white list.
display wlan whitelist [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the white list.
<Sysname> display wlan whitelist
                               Whitelist
 MAC-Address
 000e-35b2-000e
 0019-5b8e-b709
 001c-f0bf-9c92
 0000-0000-00EE
 0400-0000-0000
 0400-0000-00EE
Table 5 Command output
MAC-Address
MAC addresses of clients in the white list.
dynamic-blacklist enable
Use dynamic-blacklist enable to enable the dynamic blacklist feature.
Use undo dynamic-blacklist enable to disable the dynamic blacklist feature.
The dynamic blacklist feature is disabled.
WLAN IDS view
2: System level
enable: Enables the dynamic blacklist feature.
With this feature, a WLAN device, upon detecting flood attacks from a device, adds the device to the dynamic blacklist, and denies any packets from this device until the dynamic blacklist entry ages out.
The maximum number of entries in the dynamic blacklists depends on the device model.
# Enable the dynamic blacklist feature.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist enable
dynamic-blacklist lifetime
Use dynamic-blacklist lifetime to set the lifetime for dynamic blacklist entries.
Use undo dynamic-blacklist lifetime to restore the default.
dynamic-blacklist lifetime lifetime
The lifetime is 300 seconds.
WLAN IDS view
2: System level
lifetime: Interval, in the range of 60 to 3600 seconds.
If a dynamic blacklist entry is not detected within the lifetime, the entry is removed from the dynamic blacklist.
# Specify a lifetime of 1200 seconds for dynamic blacklist entries.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist lifetime 1200
reset wlan dynamic-blacklist
Use reset wlan dynamic-blacklist to remove a specified entry or all entries from the dynamic blacklist.
reset wlan dynamic-blacklist { mac-address mac-address | all }
1: Monitor level
mac-address mac-address: Removes an entry with the specified MAC address from the dynamic blacklist.
all: Removes all entries from the dynamic blacklist.
The maximum number of entries in the dynamic blacklist is 128.
# Remove a client with MAC address 001d-0f31-87d from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address 001d-0f31-87d
static-blacklist mac-address
Use static-blacklist mac-address to add a client with a specified MAC address to the static blacklist.
Use undo static-blacklist to remove the client with the specified MAC address or all clients from the static blacklist.
static-blacklist mac-address mac-address
undo static-blacklist { mac-address mac-address | all }
WLAN IDS view
2: System level
mac-address: Adds/deletes a client to/from the static blacklist.
all: Deletes all entries from the static blacklist.
No static blacklist exists.
Clients in the static blacklist cannot get associated with the AP.
The maximum number of entries in the static blacklist depends on the device model.
# Add the client with MAC address 0014-6c8a-43ff to the static blacklist.
[Sysname] wlan ids
[Sysname-wlan-ids] static-blacklist mac-address 0014-6c8a-43ff
whitelist mac-address
Use whitelist mac-address to add a client with a specified MAC address to the white list.
Use undo whitelist to remove the client with the specified MAC address or all clients from the white list.
whitelist mac-address mac-address
undo whitelist { mac-address mac-address | all }
WLAN IDS view
2: System level
mac-address: Adds/deletes the client with the MAC address to/from the white list.
all: Deletes all entries from the white list.
No white list exists.
Clients in the white list can be associated with the AP.
The maximum number of entries in the white list depends on the device model.
# Add the client with MAC address 001c-f0bf-9c92 to the white list.
[Sysname] wlan ids
[Sysname-wlan-ids] whitelist mac-address 001c-f0bf-9c92
