| 06-WLAN QoS Commands | 117.22 KB |
bandwidth-guarantee service-template
client-rate-limit direction (WLAN service-based)
display wlan bandwidth-guarantee
display wlan client-rate-limit
wmm edca client (ac-vo and ac-vi)
wmm edca client (ac-be and ac-bk)
bandwidth-guarantee enable
Use bandwidth-guarantee enable to enable bandwidth guaranteeing.
Use undo bandwidth-guarantee enable to restore the default.
Bandwidth guaranteeing is disabled.
WLAN-Radio interface view
Default command level
2: System level
This command is unavailable when a radio operates in 802.11ac mode.
# Enable bandwidth guaranteeing.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] bandwidth-guarantee enable
Use bandwidth-guarantee service-template to configure a guaranteed bandwidth percent for the specified service template.
Use undo bandwidth-guarantee service-template to cancel the guaranteed bandwidth percent configuration.
bandwidth-guarantee service-template service-template-number percent percent
undo bandwidth-guarantee { all | service-template service-template-number }
No guaranteed bandwidth percent is configured for a service template.
2: System level
service-template service-template-number: Specifies a service template by its number. The value range for the service-template-number argument is 1 to 1024.
percent percent: Specifies the percentage of the guaranteed bandwidth to the total bandwidth. The value range for the percent argument is 1 to 100.
all: Specifies all service templates.
The service template must have been bound to the radio.
For all service templates bound to the same radio, the sum of guaranteed bandwidth percents cannot exceed 100%.
# Set the guaranteed bandwidth percent to 30% for service template 1.
[Sysname-WLAN-Radio1/0/2] service-template 1
[Sysname-WLAN-Radio1/0/2] bandwidth-guarantee service-template 1 percent 30
Use client-rate-limit direction to configure WLAN service-based client rate limiting.
Use undo client-rate-limit direction to restore the default.
client-rate-limit direction { inbound | outbound } mode { dynamic | static } cir cir
undo client-rate-limit direction { inbound | outbound }
WLAN service-based client rate limiting is disabled.
Service template view
2: System level
inbound: Specifies the traffic from clients to APs (the outgoing traffic of clients).
outbound: Specifies the traffic from APs to clients (the incoming traffic of clients).
dynamic: Specifies the dynamic mode, where the rate limit for each client is the configured CIR/the number of online clients.
static: Specifies the static mode, where the rate limit for each client is the configured CIR.
cir cir: Specifies the rate limit (in kbps) for each client in static mode or specifies the total rate limit for all clients in dynamic mode. This argument ranges from 16 to 866700.
WLAN service-based client rate limiting can limit the rate of traffic from clients to APs or the rate of traffic from APs to clients. You can configure client rate limiting for both incoming traffic and outgoing traffic in the same service template.
# Configure WLAN service-based client rate limiting to limit the outgoing traffic rate of each client to 567 kbps and the total incoming traffic rate of all clients to 89 kbps.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] client-rate-limit direction inbound mode static cir 567
[Sysname-wlan-st-1] client-rate-limit direction outbound mode dynamic cir 89
Use display wlan bandwidth-guarantee to display the bandwidth guaranteeing configuration.
display wlan bandwidth-guarantee [ interface radio-interface-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface radio-interface-name: Specifies a radio interface by its name. If you do not specify a radio interface, this command displays bandwidth guaranteeing configuration of all radio interfaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display bandwidth guaranteeing configuration.
<Sysname> display wlan bandwidth-guarantee interface wlan-radio 1/0/1
Bandwidth Guarantee
Radio Mode Service-Template Percent
WLAN-Radio1/0/1 802.11n(5GHz) 1 10%
Radio |
Radio interface. |
Mode |
Radio mode: · 802.11a. · 802.11b. · 802.11g. · 802.11n(2.4GHz) · 802.11n(5GHz) |
Service-Template |
Service template number. |
Percent |
Guaranteed bandwidth percent. |
Use display wlan client-rate-limit service-template to display WLAN service-based client rate limiting information.
display wlan client-rate-limit service-template [ service-template-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
service-template service-template-number: Specifies a service template by its number. If you do not specify a service template, this command displays service-based client rate limiting information of all service templates.
# Display WLAN service-based client rate limiting information.
<Sysname> display wlan client-rate-limit service-template
Client Rate Limit
Service Template Direction Mode CIR(kbps)
1 Inbound Dynamic 1000
2 Outbound Static 150
3 Inbound Static 300
Service Template |
Direction |
Rate-limited direction: · Inbound. · Outbound. |
Mode |
Rate limiting mode: · Dynamic (shared bandwidth). · Static (exclusive bandwidth). |
CIR(kbps) |
Rate limit (in kbps). |
display wlan wmm
Use display wlan wmm radio to display the WMM information of the specified AP's radio or all radios.
Use display wlan wmm client to display the WMM information of the client identified by the specified MAC address, of the clients associated with the specified AP, or of all clients.
display wlan wmm { radio [ interface wlan-radio wlan-radio-number ] | client { all | interface wlan-radio wlan-radio-number | mac-address mac-address } } [ | { begin | exclude | include } regular-expression ]
2: System level
radio: Displays radio WMM information.
client: Displays client WMM information.
all: Displays WMM information about all radios or clients.
interface wlan-radio wlan-radio-number: Specifies a WLAN-radio interface.
mac-address mac-address: Specifies a client by its MAC address.
# Display the WMM information of all radios.
<Sysname> display wlan wmm radio
Radio interface : WLAN-Radio1/0/1
Client EDCA update count : 0
QoS Mode : WMM Radio chip QoS mode : WMM
Radio chip max AIFSN : 255 Radio chip max ECWmin : 10
Radio chip max TXOPLimit : 32767 Radio chip max ECWmax : 10
CAC Information
Client accepted : 0
Voice : 0
Video : 0
Total request mediumtime(us) : 0
Voice(us) : 0
Video(us) : 0
Calls rejected due to insufficient resource : 0
Calls rejected due to invalid parameters : 0
Calls rejected due to invalid mediumtime : 0
Calls rejected due to invalid delaybound : 0
QoS Mode : WMM
Admission Control Policy : Users
Threshold users count : 20
CAC-Free's AC Request Policy : Response Success
CAC Unauthed Frame Policy : Downgrade
CAC Medium Time Limitation(us) : 100000
CAC AC-VO's Max Delay(us) : 50000
CAC AC-VI's Max Delay(us) : 300000
SVP packet mapped AC number : Disabled
Radio's WMM Parameters:
AC-BK AC-BE AC-VI AC-VO
ECWmin 4 4 3 2
ECWmax 10 6 4 3
AIFSN 7 3 1 1
TXOPLimit 0 0 94 47
AckPolicy Normal Normal Normal Normal
Client's WMM Parameters:
ECWmin 4 4 3 2
ECWmax 10 10 4 3
AIFSN 7 3 2 2
TXOPLimit 0 0 94 47
CAC Disable Disable Disable Disable
Radio interface : WLAN-Radio1/0/2
CAC Information
Client accepted : 0
Voice : 0
Video : 0
Voice(us) : 0
Video(us) : 0
QoS Mode : WMM
ECWmin 4 4 3 2
ECWmax 10 6 4 3
AIFSN 7 3 1 1
TXOPLimit 0 0 94 47
ECWmin 4 4 3 2
ECWmax 10 10 4 3
AIFSN 7 3 2 2
TXOPLimit 0 0 94 47
Radio interface |
WLAN-Radio interface. |
Client EDCA update count |
Number of client EDCA parameters updates. |
QoS mode |
QoS mode: · WMM—Indicates that the WMM function is supported. · None—Indicates that the WMM function is not supported. |
Radio chip QoS mode |
Indicates whether the radio chip supports the QoS mode. |
Radio chip max AIFSN |
Maximum AIFSN allowed by the radio chip. |
Radio chip max ECWmin |
Maximum ECWmin allowed by the radio chip. |
Radio chip max TXOPLimit |
Maximum TXOPLimit allowed by the radio chip. |
Radio chip max ECWmax |
Maximum ECWmax allowed by the radio chip. |
Client accepted |
Number of clients that have been admitted to access the radio. |
Total request mediumtime(us) |
Total medium time of traffic (in microseconds per second). |
Calls rejected due to insufficient resource |
Number of requests rejected due to insufficient resources. |
Calls rejected due to invalid parameters |
Number of requests rejected due to invalid parameters. |
Calls rejected due to invalid mediumtime |
Number of requests rejected due to invalid medium time. |
Calls rejected due to invalid delaybound |
Number of requests rejected due to invalid delay bound. |
Admission Control Policy |
Admission control policy. |
Threshold users count |
Threshold used by the admission control policy. |
CAC-Free's AC Request Policy |
Response policy used for CAC-incapable ACs. |
CAC Unauthed Frame Policy |
Policy of processing frames unauthorized by CAC. |
CAC Medium Time Limitation(us) |
Maximum medium time allowed by the CAC policy (in microseconds). |
CAC AC-VO's Max Delay(us) |
Maximum voice traffic delay allowed by the CAC policy (in microseconds). |
CAC AC-VI's Max Delay(us) |
Maximum video traffic delay allowed by the CAC policy (in microseconds). |
SVP packet mapped AC number |
AC queue to which SVP packets are mapped. |
ECWmin |
ECWmin value. |
ECWmax |
ECWmax value. |
AIFSN |
AIFSN value. |
TXOPLimit |
TXOPLimit value. |
Ack Policy |
ACK policy used by an AC queue. |
CAC |
Indicates whether an AC queue is controlled by CAC: · Disabled—Indicates that the AC queue is not controlled by CAC. · Enabled—Indicates that the AC queue is controlled by CAC. |
# Display the WMM information of all the clients.
<Sysname> display wlan wmm client all
MAC address : 000f-e23c-0000 SSID : h3c
QoS Mode : None
MAC address : 000f-e23c-0001 SSID : h3c
QoS Mode : WMM
APSD information :
Max SP Length : all
L: Legacy T: Trigger D: Delivery
AC AC-BK AC-BE AC-VI AC-VO
State T|D L T|D L
Assoc State T|D L T|D T|D
CAC information :
Uplink CAC packets : 0 Downlink CAC packets : 0
Uplink CAC bytes : 0 Downlink CAC bytes : 0
Downgrade packets : 0 Discard packets : 0
Downgrade bytes : 0 Discard bytes : 0
AC : AC-VO User Priority : 7
TID : 1 Direction : Bidirectional
PSB : 0 Surplus Bandwidth Allowance : 1.0000
Medium Time(ms) : 39.108 Nominal MSDU Size(bytes) : 1500
Mean Data Rate(Kbps): 78.125 Minimum PHY Rate(Mbps) : 2.000
Create TS time : 5s
Update TS time : 5s
Uplink TS packets : 0 Downlink TS packets : 0
Uplink TS bytes : 0 Downlink TS bytes : 0
MAC address |
MAC address of a station. |
SSID |
Service set ID. |
QoS Mode |
QoS mode: · WMM—Indicates that the WMM function is supported. · none—Indicates that the WMM function is not supported. |
Max SP Length |
Maximum service period. |
AC |
Access category. |
State |
APSD attribute of an AC queue: · T—Indicates that the AC queue is trigger-enabled. · D—Indicates that the AC queue is delivery-enabled. · T | D—Indicates that the AC queue is both trigger-enabled and delivery-enabled. · L—Indicates that the AC queue is of legacy attributes. |
Assoc State |
APSD attributes of the four AC queues specified when a client accesses the AP. |
Uplink CAC packets |
Number of uplink CAC packets. |
Uplink CAC bytes |
Number of uplink CAC bytes. |
Downlink CAC packets |
Number of downlink CAC packets. |
Downlink CAC bytes |
Number of downlink CAC bytes. |
Downgrade packets |
Number of downgraded packets. |
Downgrade bytes |
Number of downgraded bytes. |
Discard packets |
Number of dropped packets. |
Discard bytes |
Number of dropped bytes. |
Direction |
Traffic direction. |
User Priority |
User priority. |
TID |
Traffic identifier. |
PSB |
Power saving mode banner. |
Nominal MSDU Size(bytes) |
Average MSDU size (in bytes). |
Mean Data Rate(kbps) |
Average data transmission rate (in kbps). |
Minimum PHY Rate(Mbps) |
Minimum physical transmission rate (in Mbps). |
Surplus Bandwidth Allowance |
Surplus bandwidth allowance. |
Medium Time(ms) |
Medium time (in microseconds). |
Create TS time |
Time from when the TS was created to now. |
Update TS time |
Time from when the TS was updated to now. |
Uplink TS packets |
Number of uplink TS packets. |
Uplink TS bytes |
Number of uplink TS bytes. |
Downlink TS packets |
Number of downlink TS packets. |
Downlink TS bytes |
Number of downlink TS bytes. |
reset wlan wmm
Use reset wlan wmm radio to clear the WMM statistics for the radio of the specified AP or all radios.
Use reset wlan wmm client to clear the WMM statistics for the client identified by the specified MAC address, the clients associated with the specified AP, or all clients.
reset wlan wmm { radio [ interface wlan-radio wlan-radio-number ] | client { all | interface wlan-radio wlan-radio-number | mac-address mac-address } }
2: System level
radio: Clears the WMM statistics for radios.
client: Clears the WMM statistics for clients.
all: Clears the WMM statistics for all radios or clients.
interface wlan-radio wlan-radio-number: Clears the WMM statistics for the clients attached to the specified WLAN-Radio interface.
# Clear the WMM statistics for all the radios.
<Sysname> reset wlan wmm radio
wmm cac policy
Use wmm cac policy to configure the access control policy for CAC.
Use undo wmm cac policy to restore the default.
wmm cac policy { channelutilization [ channelutilization-value ] | users [ users-number ] }
undo wmm cac policy
The users-based admission policy applies, with the maximum number of admitted users being 20.
2: System level
channelutilization: Uses the channel utilization-based admission policy for CAC.
channelutilization-value: Maximum channel utilization rate, which specifies the medium time of the accepted AC-VO traffic and AC-VI traffic to the valid time during the unit time. This argument ranges from 0 to 100. It is 65 by default. The unit is % (percentage). The valid time refers to the time available for transmitting and receiving data.
users: Uses the users-based admission policy for CAC.
users-number: Maximum number of clients allowed to be connected, which ranges from 0 to 64. This argument is 20 by default. A client is counted only once, even if it is using both the AC-VO and AC-VI queues.
# Configure CAC to use the channel utilization-based admission policy, with the channel utilization rate being 70%.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] wmm cac policy channelutilization 70
wmm edca client
wmm edca radio
Use wmm edca radio to set the EDCA parameters and specify the ACK policy.
Use undo wmm edca radio to restore the default.
wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | noack } *
undo wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn | ecw | txoplimit | noack | all }
Normal ACK is used, and the default EDCA parameters are as shown in Table 5.
Table 5 The default EDCA parameters for APs
AC queue |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-BK queue |
7 |
4 |
10 |
0 |
AC-BE queue |
3 |
4 |
6 |
0 |
AC-VI queue |
1 |
3 |
4 |
94 |
AC-VO queue |
1 |
2 |
3 |
47 |
2: System level
ac-vo: Specifies the AC-VO (voice traffic) queue.
ac-vi: Specifies the AC-VI (video traffic) queue.
ac-be: Specifies the AC-BE (best-effort traffic) queue.
ac-bk: Specifies the AC-BK (background traffic) queue.
all: Specifies all the EDCA parameters.
noack: Specifies the AC queue to use the No ACK policy. The protocol defines two ACK policies: Normal ACK and No ACK.
txoplimit-value: Specifies the TXOPLimit parameter of EDCA, which ranges from 0 to 65535 (in units of 32 microseconds). The TXOP value of 0 indicates that only one MPDU can be transmitted. The range of this argument is limited by the radio chip capability.
ecwmin-value: Specifies the ECWmin parameter of EDCA, which ranges from 0 to 15. The range of this argument is limited by the radio chip capability.
ecwmax-value: Specifies the ECWmax parameter of EDCA, which ranges from 0 to 15. The range of this argument is limited by the radio chip capability.
aifsn-value: Specifies the AIFSN parameter of EDCA, which ranges from 1 to 15. The range of this argument is limited by the radio chip capability.
For description on each EDCA parameter, see WLAN Configuration Guide.
ECWmin must be no greater than ECWmax. The two parameters must be enabled or disabled simultaneously.
When an AP uses 802.11b radio cards, H3C recommends that you set TXOPLimit values of the AC-BK, AC-BE, AC-VI, and AC-VO queues to 0, 0, 188, and 102, respectively.
# Set AIFSN to 2 for the AC-VO queue of the radio.
[Sysname-WLAN-Radio1/0/1] wmm edca radio ac-vo aifsn 2
Use wmm edca client to set EDCA parameters for the AC-BE or AC-BK queue for clients.
Use undo wmm edca client to restore the default of the specified or all EDCA parameters for the specified AC queue.
wmm edca client { ac-vo | ac-vi } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | cac } *
undo wmm edca client { ac-vo | ac-vi } { aifsn | ecw | txoplimit | cac | all }
The following table lists the default EDCA parameters of the AC-VI and AC-VO queue for clients.
Table 6 Default EDCA parameters for clients
AC queue |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-VI queue |
2 |
3 |
4 |
94 |
AC-VO queue |
2 |
2 |
3 |
47 |
2: System level
cac: Enables CAC. The AC-VO and AC-VI queues support CAC, which is disabled by default. The AC-BE and AC-BK queues do not support CAC.
aifsn-value: Specifies the AIFSN parameter of EDCA, which ranges from 2 to 15.
ECWmin must not be greater than ECWmax. The two parameters must be enabled or disabled simultaneously.
When all the clients are 802.11b terminals, H3C recommends that you set the TXOPLimit to 188 and 102 for the AC-VI and AC-VO queues, respectively.
If both 802.11b and 802.11g clients are present, H3C recommends that you use the default TXOPLimit settings in Table 6.
If CAC is enabled for an AC queue, CAC is also enabled for AC queues with higher priority. For example, if you use the wmm edca client command to enable CAC for the AC-VI queue, CAC is also enabled for the AC-VO queue. However, enabling CAC for the AC-VO queue does not enable CAC for the AC-VI queue.
# Set AIFSN to 3 for the AC-VO queue.
[Sysname-WLAN-Radio1/0/1] wmm edca client ac-vo aifsn 3
Use wmm edca client to set the EDCA parameters of the AC-VO or AC-VI queue for the clients in a BSS.
Use undo wmm edca client to restore the default.
wmm edca client { ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value } *
undo wmm edca client { ac-be | ac-bk } { aifsn | ecw | txoplimit | all }
The following table lists the default EDCA parameter settings for the AC-BK and AC-BE queues for clients.
Table 7 Default EDCA parameter settings for clients
AC queue |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-BK queue |
7 |
4 |
10 |
0 |
AC-BE queue |
3 |
4 |
10 |
0 |
2: System level
When all the clients are 802.11b terminals, H3C recommends that you set the TXOPLimit value to 0 for both the AC-BK and AC-BE queues.
If both 802.11b and 802.11g clients are present, H3C recommends that you use the default TXOPLimit settings for the AC-BK and AC-BE queues.
# Set AIFSN to 5 for the AC-BE queue.
[Sysname-WLAN-Radio1/0/1] wmm edca client ac-be aifsn 5
wmm enable
Use wmm enable to enable the WMM function.
Use undo wmm enable to disable the WMM function.
wmm enable
undo wmm enable
The WMM function is enabled.
2: System level
The 802.11n and 802.11ac protocols stipulate that all 802.11n and 802.11ac clients support WLAN QoS. Therefore, when the radio operates in 802.11an, 802.11gn, or 802.11ac mode, you must enable WMM. Otherwise, the associated 802.11n or 802.11ac clients may fail to communicate.
# Disable the WMM function.
[Sysname-WLAN-Radio1/0/1] undo wmm enable
wmm svp map-ac
Use wmm svp map-ac to map SVP packets to a specific AC queue.
Use undo wmm svp map-ac to restore the default.
wmm svp map-ac { ac-vo | ac-vi | ac-be | ac-bk }
undo wmm svp map-ac
SVP packet mapping is disabled.
2: System level
H3C recommends that you map SVP packets to the AC-VO queue in normal cases.
# Map SVP packets to the AC-VO queue.
[Sysname-WLAN-Radio1/0/1] wmm svp map-ac ac-vo
