- 09-Network Management Configuration Guide
- 01-System Maintenance and Debugging Configuration
- 02-NQA Configuration
- 03-NTP Configuration
- 04-IPC Configuration
- 05-SNMP Configuration
- 06-RMON Configuration
- 07-Mirroring Configuration
- 08-Information Center Configuration
- 09-sFlow Configuration
- 10-Flow Log Configuration
| 07-Mirroring Configuration | 111.06 KB |
Local port mirroring implementation
Configuring local port mirroring
Local port mirroring configuration task list
Creating a local mirroring group
Configuring source ports for the local mirroring group
Configuring the monitor port for the local mirroring group
Displaying and maintaining port mirroring
Port mirroring configuration example
Configuring port mirroring
Support for this feature depends on the device model. For more information, see About the H3C Access Controllers Configuration Guides.
Overview
Port mirroring copies packets passing through a port to a monitor port that is connected to a monitoring device for packet analysis.
Mirroring source
The mirroring source can be one or more monitored ports. The monitored ports are called source ports. The device where the mirroring sources reside is called a source device.
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Mirroring destination
The mirroring destination is the destination port (also known as the monitor port) of mirrored packets. It connects to the data monitoring device.
The device where the monitor port resides is called the destination device. The monitor port forwards mirrored packets to its connected monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port 1 when the following conditions exist:
· Port 1 is monitoring bidirectional traffic of Port 2 and Port 3 on the same device.
· The packet travels from Port 2 to Port 3.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
· Inbound—Copies packets received on a mirroring source.
· Outbound—Copies packets sent out of a mirroring source.
· Bidirectional—Copies packets both received on and sent out of a mirroring source.
Mirroring group
Port mirroring is implemented through mirroring groups. For more information about mirroring groups, see "Local port mirroring implementation."
In local port mirroring, the following conditions exist:
· The source device is directly connected to a data monitoring device.
· The source device acts as the destination device to forward mirrored packets to the data monitoring device.
A local mirroring group is a mirroring group that contains the mirroring sources and the mirroring destination on the same device.
Figure 1 Local port mirroring implementation
As shown in Figure 1, configure local port mirroring to copy inbound packets on the source port Ethernet 1/1 to the monitor port Ethernet 1/2. Ethernet 1/2 then forwards the packets to the data monitoring device for analysis.
Local port mirroring takes effect only when the source ports and the monitor port are configured.
Complete these tasks to configure local port mirroring:
Task |
Remarks |
Required. |
Required. |
Required. |
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a local mirroring group. |
mirroring-group group-id local |
No local mirroring group exists by default. |
A mirroring group can contain multiple source ports.
To configure source ports for a local mirroring group, use one of the following methods:
· Assign a list of source ports to the mirroring group in system view.
· Assign a port to the mirroring group as a source port in interface view.
To assign multiple ports to the mirroring group as source ports in interface view, repeat the operation.
Configuring source ports for a local mirroring group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source ports. |
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound } |
By default, no source port is configured for a local mirroring group. |
Configuring a source port for a local mirroring group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure the current port as a source port. |
[ mirroring-group group-id ] mirroring-port { both | inbound | outbound } |
By default, a port does not serve as a source port for any local mirroring group. |
To configure the monitor port for a mirroring group, use one of the following methods:
· Configure the monitor port for the mirroring group in system view.
· Assign a port to the mirroring group as the monitor port in interface view.
When you configure the monitor port for the local mirroring group, follow these restrictions and guidelines:
· A mirroring group contains only one monitor port.
· Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
Configuring the monitor port of a local mirroring group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the monitor port. |
mirroring-group group-id monitor-port monitor-port-id |
By default, no monitor port is configured for a local mirroring group. |
Configuring the monitor port of a local mirroring group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the current port as the monitor port. |
[ mirroring-group group-id ] monitor-port |
By default, a port does not serve as the monitor port for any local mirroring group. |
Task |
Command |
Remarks |
Display mirroring group information. |
display mirroring-group { group-id | all | local } [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Network requirements
As shown in Figure 2, configure local port mirroring on the AC to enable the server to monitor the traffic of the IP network.
Configuring the AC
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
# Configure GigabitEthernet 1/0/1 as the mirroring port of the local mirroring group.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
# Configure GigabitEthernet 1/0/2 as the monitor port of the local mirroring group.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/2
# Display the configuration of local mirroring group 1.
[Sysname] display mirroring-group 1
mirroring-group 1:
type: local
status: active
mirroring port:
GigabitEthernet1/0/1 both
monitor port: GigabitEthernet1/0/2
