- 09-Network Management Configuration Guide
- 01-System Maintenance and Debugging Configuration
- 02-NQA Configuration
- 03-NTP Configuration
- 04-IPC Configuration
- 05-SNMP Configuration
- 06-RMON Configuration
- 07-Mirroring Configuration
- 08-Information Center Configuration
- 09-sFlow Configuration
- 10-Flow Log Configuration
| 00-Preface | 114.12 KB |
Preface
The Network Management and Monitoring Configuration Guide describes system maintenance and debugging, NQA, NTP, IPC, SNMP, RMON, mirroring, information center, sFlow, and flow log configurations.
NOTE: Support of the H3C access controllers for features might vary by device model. For the feature matrixes, see About the H3C Access Controllers Configuration Guides. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
