03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10203-Layer 2 Command Reference
08-PPPoE Commands
08-PPPoE Commands 69.15 KB
PPPoE commands
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
PPPoE server commands
display pppoe-server session
Use display pppoe-server session to display information about PPPoE sessions on a device operating as a PPPoE server.
display pppoe-server session all [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
all: Displays all the information about PPPoE sessions.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display all the information about PPPoE sessions. (Assume the current device is operating as a PPPoE server.)
<Sysname> display pppoe-server session all
Total PPPoE Session(s): 2
SID   Intf                      State OIntf          RemMAC       LocMAC
1     Virtual-Template1:0       UP    Vlan2         00e015004100 00e014004300
2     Virtual-Template2:0       UP    Vlan2         00e016004100 00e015004300
SID
PPPoE session ID.
Intf
Virtual-template interface.
PPPoE session state.
OIntf
Corresponding VLAN interface.
RemMAC
Peer MAC address.
LocMAC
Local MAC address.
pppoe-server abnormal-offline-count threshold
Use pppoe-server abnormal-offline-count threshold to set the upper threshold for the PPPoE abnormal offline event count in 5 minutes.
Use undo pppoe-server abnormal-offline-count threshold to restore the default.
pppoe-server abnormal-offline-count threshold number
The upper threshold for the PPPoE abnormal offline event count in 5 minutes is 65535.
2: System level
number: Specifies the upper threshold for the PPPoE abnormal offline event count in 5 minutes, in the range of 0 to 65535.
If the PPPoE abnormal offline event count in the last 5 minutes exceeds this threshold, the system outputs a trap message.
# Set the upper threshold for the PPPoE abnormal offline event count in 5 minutes to 100.
[Sysname] pppoe-server abnormal-offline-count threshold 100
pppoe-server abnormal-offline-percent threshold
Use pppoe-server abnormal-offline-percent threshold to set the upper threshold for the PPPoE abnormal offline event percentage in 5 minutes.
Use undo pppoe-server abnormal-offline-percent threshold to restore the default.
pppoe-server abnormal-offline-percent threshold number
The upper threshold for the PPPoE abnormal offline event percentage in 5 minutes is 100.
2: System level
number: Specifies the upper threshold for the PPPoE abnormal offline event percentage, in the range of 0 to 100.
If the PPPoE abnormal offline event percentage in the last 5 minutes exceeds this threshold, the system outputs a trap message.
PPPoE abnormal offline event percentage = 100 x Abnormal offline event count/(Abnormal offline event count + Normal offline event count).
# Set the upper threshold for the PPPoE abnormal offline event percentage to 10.
[Sysname] pppoe-server abnormal-offline-percent threshold 10
pppoe-server normal-offline-percent threshold
pppoe-server bind
Use pppoe-server bind to enable PPPoE on a VLAN interface and bind the VLAN interface to a VT interface.
Use undo pppoe-server bind to disable PPPoE on a VLAN interface.
pppoe-server bind virtual-template number
PPPoE is disabled.
Interface view
2: System level
virtual template number: Specifies a VT interface by its number in the range of 0 to 1023.
# Enable PPPoE on interface Vlan-interface 1 and bind the VLAN interface to interface VT 1.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] pppoe-server bind virtual-template 1
pppoe-server log-information off
Use pppoe-server log-information off to disable PPP log displaying on a device operating as a PPPoE server.
Use undo pppoe-server log-information off to restore the default.
PPP log displaying is enabled on a PPPoE server.
2: System level
With PPP log displaying enabled, large amounts of log information can affect device performance and be a nuisance to users during configuration. You can disable PPP log displaying by using the pppoe-server log-information off command.
# Disable PPP log displaying.
[Sysname] pppoe-server log-information off
pppoe-server max-sessions local-mac
Use pppoe-server max-sessions local-mac to set the maximum number of PPPoE sessions allowed with regard to the local MAC address on a device operating as a PPPoE server.
Use undo pppoe-server max-sessions local-mac to restore the default.
pppoe-server max-sessions local-mac number
The maximum number of PPPoE sessions allowed with regard to the local MAC address is 100.
2: System level
number: Specifies the maximum number of sessions allowed with regard to the local MAC address, in the range of 1 to 20480.
# Set the maximum number of PPPoE sessions allowed with regard to the local MAC address to 50. (Assume the device is operating as a PPPoE server.)
[Sysname] pppoe-server max-sessions local-mac 50
pppoe-server max-sessions remote-mac
Use pppoe-server max-sessions remote-mac to set the maximum number of PPPoE sessions allowed with regard to a peer MAC address.
Use undo pppoe-server max-sessions remote-mac to restore the default.
pppoe-server max-sessions remote-mac number
The maximum number of PPPoE sessions allowed with regard to a peer MAC address is 100.
2: System level
number: Specifies the maximum number of PPPoE sessions that the entire system can establish with a peer MAC address, in the range of 1 to 4096.
# Set the maximum number of PPPoE sessions allowed with regard to a peer MAC address to 50.
[Sysname] pppoe-server max-sessions remote-mac 50
pppoe-server max-sessions total
Use pppoe-server max-sessions total to set the maximum number of PPPoE sessions allowed.
Use undo pppoe-server max-sessions total to restore the default.
pppoe-server max-sessions total number
The maximum number of PPPoE sessions allowed is 4096.
2: System level
number: Specifies the maximum number of PPPoE sessions allowed, in the range of 1 to 20480.
# Set the maximum number of PPPoE sessions allowed to 3000 in the system.
[Sysname] pppoe-server max-sessions total 3000
Use pppoe-server normal-offline-percent threshold to set the lower threshold for the PPPoE normal offline event percentage.
Use undo pppoe-server normal-offline-percent threshold to restore the default.
pppoe-server normal-offline-percent threshold number
The lower threshold for the PPPoE normal offline event percentage is 0.
2: System level
number: Specifies the lower threshold for the PPPoE normal offline event percentage, in the range of 0 to 100.
If the PPPoE normal offline event percentage in the last 5 minutes is lower than this threshold, the system outputs a trap message.
PPPoE normal offline event percentage = 100 – PPPoE abnormal offline event percentage.
# Set the lower threshold for the PPPoE normal offline event percentage to 10.
[Sysname] pppoe-server normal-offline-percent threshold 10
reset pppoe-server
Use reset pppoe-server to terminate a PPPoE session on the PPPoE server side.
reset pppoe-server { all | interface interface-type interface-number | virtual-template number }
2: System level
all: Terminates all the PPPoE sessions.
interface interface-type interface-number: Specifies a port by its type and number.
virtual-template number: Specifies a VT interface by its number.
# Terminate the session established based on interface Virtual-template 1 on the PPPoE server side.
<Sysname> reset pppoe-server virtual-template 1
PPPoE client commands
display pppoe-client session
Use display pppoe-client session to display information about a PPPoE session.
display pppoe-client session { packet | summary } [ dial-bundle-number number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
packet: Displays the packet statistics on PPPoE sessions.
summary: Displays PPPoE session summary.
dial-bundle-number number: Displays the statistics on a PPPoE session. The number argument ranges from 1 to 255. If this option is not specified, this command displays the statistics on all the PPPoE sessions.
# Display PPPoE session summary.
<Sysname> display pppoe-client session summary
PPPoE Client Session:
ID   Bundle  Dialer  Intf             RemMAC        LocMAC        State
1    1       1       GE1/0/5          00e014004300  00e015004100  PPPUP
ID
PPPoE session ID.
Bundle
Dialer bundle to which a PPPoE session belongs.
Dialer
Dialer interface corresponding to a PPPoE session.
Intf
Ethernet interface where the PPPoE session is present.
RemMAC
Remote MAC address.
LocMAC
Local MAC address.
PPPoE session state. PPPoE session state is the PPP protocol state. PPPUP indicates that PPP negotiation is successful.
# Display the packet statistics on PPPoE sessions.
<Sysname> display pppoe-client session packet
  ID: 1                            Interface: GE1/0/5
  InPackets: 19                    OutPackets: 19
  InBytes:   816                   OutBytes:   816
  InDrops:   0                     OutDrops:   0
ID
PPPoE session ID.
Ethernet interface corresponding to a PPPoE session.
InPackets
Number of packets received.
InBytes
Size of received packets (in bytes).
InDrops
Number of discarded incoming packets.
OutPackets
Number of packets sent.
OutBytes
Size of sent packets (in bytes).
OutDrops
Number of discarded outgoing packets.
pppoe-client
Use pppoe-client to establish a PPPoE session and specify the dialer bundle corresponding to the session.
Use undo pppoe-client to remove a PPPoE session.
pppoe-client dial-bundle-number number [ no-hostuniq ] [ diagnose [ interval seconds ] | idle-timeout seconds [ queue-length packets ] ]
undo pppoe-client dial-bundle-number number
The Host-Uniq field is carried.
No PPPoE session is established.
Ethernet interface view, VLAN interface view
2: System level
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session, in the range of 1 to 255. A dialer bundle number uniquely identifies a PPPoE session, it can also be used as a PPPoE session ID.
no-hostuniq: Specifies the client not to carry the Host-Uniq field. diagnose: Specifies the operating mode of the PPPoE session to diagnostic.
interval seconds: Specifies the interval (in seconds) between two diagnostic PPPoE sessions. The seconds argument ranges from 5 to 65535. The default value is 120.
idle-timeout seconds: Specifies the PPPoE session idle time. The seconds argument ranges from 1 to 65535. If this option is specified, the PPPoE session operates in packet-triggered mode; if this option and the diagnose keyword are not specified, the PPPoE session established operates in permanent mode. queue-length packets: Specifies the number of the packets that can be cached before the PPPoE session is established. The packets argument ranges from 1 to 100 and defaults to 10. This option becomes valid only when the idle-timeout keyword is configured.
You can establish multiple PPPoE sessions on an Ethernet interface, or an Ethernet interface can belong to multiple dialer bundles. However, a dialer bundle can correspond to only one Ethernet interface. Each PPPoE session uniquely corresponds to a dialer bundle. If an Ethernet interface in a dialer bundle of a dialer interface is used to establish a PPPoE session, you cannot add any interfaces to the dialer bundle. Likewise, if a dialer bundle contains interfaces other than the PPPoE Ethernet interface, this dialer bundle cannot be added to an Ethernet interface operating as a PPPoE client.
A PPPoE session operates in one of the following modes:
·     Permanent mode—If you configure the pppoe-client command without specifying the idle-timeout seconds option or the diagnose keyword, the device initiates a PPPoE call to establish a PPPoE session immediately if the physical line is up. After the PPPoE session is established, it can only be terminated by the undo pppoe-client command.
·     Packet-triggered mode—If you configure the pppoe-client command with the idle-timeout seconds option specified, the device tries to establish the PPPoE session only when it has data to transmit. For a PPPoE session operating in this mode, if no data is transmitted across it within the period specified by the seconds argument, the PPPoE session is terminated automatically.
·     Diagnostic mode—If you configure the pppoe-client command with the diagnose keyword specified, the device initiates a PPPoE call to establish a PPPoE session immediately after this command is configured, and terminates the current PPPoE session and then establishes another PPPoE session each time the interval specified by interval seconds expires. By periodically establishing and terminating PPPoE sessions, this function can be used to detect whether the PPPoE link is normal. Only one diagnostic PPPoE session can be established on each device.
The difference between the reset pppoe-client command and the undo pppoe-client command lies in that the former only temporarily terminates a PPPoE session, but the latter permanently removes a PPPoE session.
After you configure the undo pppoe-client command, the PPPoE session identified by the number argument is removed permanently, regardless of the operating mode of the PPPoE session. To use the PPPoE session again, you must establish it from scratch.
# Establish a PPPoE session on interface GigabitEthernet 1/0/5.
[Sysname] interface gigabitethernet 1/0/5
[Sysname-GigabitEthernet1/0/5] pppoe-client dial-bundle-number 1
reset pppoe-client
reset pppoe-client
Use reset pppoe-client to reset a PPPoE session corresponding to a dialer bundle for the PPPoE session to be initiated again.
reset pppoe-client { all | dial-bundle-number number }
2: System level
all: Clears all the PPPoE sessions.
dial-bundle-number number: Specifies a dialer bundle by its number. The number argument ranges from 1 to 255.
A PPPoE session in permanent mode and terminated by this command will be established again in 16 seconds. A PPPoE session in packet-triggered mode and terminated by this command will be established again only when there is a need for data transmission.
The difference between the reset pppoe-client command and the undo pppoe-client command lies in: the former only temporarily terminates a PPPoE session, but the latter permanently removes a PPPoE session.
# Reset all the PPPoE sessions.
<Sysname> reset pppoe-client all
pppoe-client
