03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10203-Layer 2 Command Reference
09-FPGA Fast Forwarding Commands
09-FPGA Fast Forwarding Commands 30.11 KB
FPGA fast forwarding configuration commands
Support for the commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
fpga portal-statistics enable
Use fpga portal-statistics enable to enable portal user traffic statistics for FPGA fast forwarding.
Use undo fpga portal-statistics enable to disable portal user traffic statistics for FPGA fast forwarding.
Portal user traffic statistics for FPGA fast forwarding is enabled.
Default command level
2: System level
# Disable portal user traffic statistics for FPGA fast forwarding.
<sysname> system-view
[sysname] undo fpga portal-statistics enable
fpga work-mode fast-forwarding
Use fpga work-mode fast-forwarding to enable FPGA fast forwarding.
Use undo fpga work-mode fast-forwarding to disable FPGA fast forwarding.
3: Manage level
# Enable FPGA fast forwarding on an AC.
[Sysname] fpga work-mode fast-forwarding
