03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10203-Layer 2 Command Reference
01-Ethernet Interface Commands
01-Ethernet Interface Commands 146.81 KB
Ethernet interface configuration commands
General Ethernet interface and subinterface configuration commands
combo enable
IMPORTANT
IMPORTANT:
Support for this command depends on the device model. For more information, see About the H3C Access Controllers Command References.
Use combo enable to activate the copper or fiber combo port of a combo interface.
combo enable { copper | fiber }
The copper combo port of a combo interface is activated.
Ethernet interface view (the interface must be a combo interface)
Default command level
2: System level
copper: Activates the copper combo port. In this case, use twisted pairs to connect the port.
fiber: Activates the fiber combo port. In this case, use optical fibers to connect the port.
A combo interface is a logical interface that physically contains one fiber combo port and one copper combo port on the device panel. The two ports share one forwarding interface. As a result, they cannot work simultaneously. When you activate either port, the other port is automatically disabled. You can select to activate the copper combo port or fiber combo port.
# Activate the copper combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable copper
# Activate the fiber combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable fiber
default
IMPORTANT
IMPORTANT:
Use default to restore the default settings for an Ethernet interface.
default
Ethernet interface view, Ethernet subinterface view
2: System level
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
This command will restore the default settings. Continue? [Y/N]:y
# Restore the default settings for subinterface GigabitEthernet 1/0/5.1.
[Sysname] interface gigabitethernet 1/0/5.1
[Sysname-GigabitEthernet1/0/5.1] default
description
IMPORTANT
IMPORTANT:
Use description to change the description of the interface.
The default description of an interface is the interface name plus Interface. For example, GigabitEthernet1/0/1 Interface.
2: System level
text: Specifies the interface description, a case-sensitive string of 1 to 80 characters.
When you specify a description, follow these guidelines:
·     Each Unicode character takes the space of two regular characters.
·     To use Unicode characters or symbols in an interface description, install the specific input method editor and log in to the device through remote login software that supports the character type.
·     When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character in half. This might result in garbled characters at the end of a line.
# Change the description of interface GigabitEthernet 1/0/1 to lanswitch-interface.
[Sysname-GigabitEthernet1/0/1] description lanswitch-interface
# Change the description of subinterface GigabitEthernet 1/0/5.1 to l3-subinterface1/0/5.1.
[Sysname-GigabitEthernet1/0/5.1] description l3-subinterface1/0/5.1
display interface
display interface
Use display interface to display Ethernet interface information.
display interface [ interface-type ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface interface-type { interface-number | interface-number.subnumber } [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface-number.subnumber: Specifies a subinterface number, where interface-number is an interface number, and subnumber is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094. Support for this argument depends on the device model. For more information, see About the H3C Access Controllers Command References.
down: Displays information about interfaces in the down state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no interface type is specified, this command displays information about all interfaces.
If an interface type is specified but no interface number or subinterface number is specified, this command displays information about all interfaces of the specified type.
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
<Sysname> display interface gigabitethernet 1/0/1
 GigabitEthernet1/0/1 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0000-000f-0007
 Description: GigabitEthernet1/0/1 Interface
 Loopback is not set
 Media type is twisted pair, promiscuous mode set
 1000Mbps-speed mode, full-duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 4096
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 Allow jumbo frame to pass
 PVID: 1
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Output queue: (Urgent queuing :Size/Length/Discards) 0/100/0
 Output queue: (Protocol queuing: Size/Length/Discards) 0/500/0
 Output queue: (FIFO queuing: Size/Length/Discards) 0/75/0
 Last clearing of counters:  Never
 Last 300 seconds input:  0 packets/sec 74 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 12 bytes/sec 0%
 Input (total):  21322 packets, 1748554 bytes
          68235 unicasts, 4718 broadcasts, 7852 multicasts, - pauses
 Input (normal):  21322 packets, - bytes
          1268 unicasts, 7560 broadcasts, 12494 multicasts, 0 pauses
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, - frame, - overruns, - aborts
          - ignored, - parity errors
 Output (total): 1502 packets, 138924 bytes
          - unicasts, 2 broadcasts, 406 multicasts, 0 pauses
 Output (normal): - packets, - bytes
          1094 unicasts, - broadcasts, - multicasts, - pauses
 Output: 3 output errors, - underruns, - buffer failures
          - aborts, 1 deferred, 2 collisions, 0 late collisions
          - lost carrier, - no carrier
# Display information about Layer 3 interface GigabitEthernet 1/0/5.
<Sysname> display interface gigabitethernet 1/0/5 | include current state:|bytes
GigabitEthernet1/0/5 current state: DOWN ( Administratively )
Line protocol current state: DOWN
    Last 300 seconds input rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Last 300 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Input: 0 packets, 0 bytes, 0 buffers
    Output:0 packets, 0 bytes, 0 buffers
Physical state of the Ethernet interface. For more information, see Table 2.
Ethernet framing format on the interface.
Loopback
Loopback testing status of the interface.
1000Mbps-speed mode
The interface is operating at 1000 Mbps.
This field displays Unknown-speed mode when the interface is disconnected from the peer with which it will automatically negotiate a port speed.
full-duplex mode
The interface is operating in full-duplex mode.
This field displays link duplex type is force link when the duplex mode of the interface is fixed and not configurable.
The interface will negotiate a speed with its peer.
The interface will negotiate a duplex mode with its peer.
Maximum Ethernet frame length allowed on the interface.
Broadcast MAX-ratio
Broadcast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops broadcast packets.
Unicast MAX-ratio
Unknown unicast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops unknown unicast packets.
Multicast MAX-ratio
Multicast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops multicast packets.
Jumbo frames are allowed to pass through the interface.
PVID
Port VLAN ID.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged   VLAN ID
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLAN ID
VLANs for which the interface sends packets after removing VLAN tags.
Output queue
Information about the output queues. This field is displayed only for WX5510E ACs.
Urgent queuing
Protocol queuing
FIFO queuing
Size
Number of packets in the queue. This field is displayed only for WX5510E ACs.
Length
Length of the queue. This field is displayed only for WX5510E ACs.
Discards
Number of discarded packets. This field is displayed only for WX5510E ACs.
Time when the reset counters interface command was last used to clear statistics on the interface. Never indicates that the reset counters interface command was never used since the device was started.
Last 300 seconds input:  0 packets/sec 0 bytes/sec
Last 300 seconds output:  0 packets/sec 0 bytes/sec
Average rate of input and output traffic in the last 300 seconds, in pps and Bps.
Inbound traffic statistics (in packets and bytes) for the interface. All inbound normal and abnormal packets (including unicast, broadcast, and multicast), and pause frames were counted.
Inbound normal traffic (including unicast, broadcast, and multicast) and pause frame statistics (in packets and bytes) for the interface.
input errors
Statistics of error packets received on the interface.
runts
Inbound frames that are shorter than 64 bytes, that are in correct format, and that contain valid CRCs.
giants
Inbound frames larger than the maximum frame length supported on the interface.
·     For an Ethernet interface that does not permit jumbo frames, giants refer to frames larger than 1536 bytes (without VLAN tags) or 1540 bytes (with VLAN tags).
·     For an Ethernet interface that permits jumbo frames, giants refer to frames larger than the maximum size of Ethernet frames that are allowed to pass through, which is configured when you configure jumbo frame support on the interface.
- throttles
Number of times that the port shut down because of buffer or CPU overload.
CRC
Total number of inbound frames that had a normal length but contained checksum errors.
frame
Total number of inbound frames that contained checksum errors and a non-integer number of bytes.
- overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length can be an integer or non-integer value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integer or non-integer length). For an Ethernet interface that does not permit jumbo frames, jabber frames refer to CRC error frames greater than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, jabber frames refer to CRC error frames greater than the maximum size of Ethernet frames that are allowed to pass through the interface (which is configured when you configure jumbo frame support on the interface).
·     Symbol error frames—Frames that contained at least one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not accord with the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
- parity errors
Total number of frames with parity errors.
Outbound traffic statistics (in packets and bytes) for the port. All outbound normal and abnormal packets (including unicast, broadcast, and multicast), and pause frames were counted.
Outbound normal traffic (including unicast, broadcast, and multicast) and pause frame statistics (in packets and bytes) for the interface.
output errors
Statistics of error packets sent out of the interface.
- underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
- buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits, because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter applies to serial WAN interfaces.
- no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter applies to serial WAN interfaces.
If an output field is not available, a hyphen (-) is displayed.
Table 2 Description on the possible physical states of a Layer 2 Ethernet interface
UP
The interface is physically up.
DOWN
The interface is physically down because no physical connection exists (possibly because the network cable is disconnected or faulty).
The interface was shut down with the shutdown command. To restore its physical state, use the undo shutdown command.
DOWN ( Link-Aggregation interface down )
The interface is down because the aggregate interface corresponding to the aggregation group to which it belongs was shut down with the shutdown command.
DOWN ( OAM connection failure )
The interface is down because an OAM connection failed to be established on it or the OAM connection is disconnected.
DOWN ( DLDP connection failure )
The interface is down because a DLDP connection failed to be established on it or the DLDP connection is disconnected.
DOWN ( Loopback detection-protected )
The interface is shut down because a loop is detected on it.
DOWN ( BPDU-protected )
The interface is shut down by the BPDU guard function.
DOWN ( Monitor-Link uplink down )
The interface is down because the uplink of the monitor link group to which it belongs is down.
# Display information about Layer 3 subinterface GigabitEthernet 1/0/5.1.
<Sysname> display interface gigabitethernet 1/0/5.1
GigabitEthernet1/0/5.1 current state: DOWN
Description: GigabitEthernet1/0/5.1 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e212-ff11
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e212-ff11
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
State of the Ethernet subinterface:
·     DOWN ( Administratively )—The Ethernet subinterface was shut down with the shutdown command. The subinterface is administratively down.
·     DOWN ( Link-Aggregation interface down )—The Ethernet subinterface is physically down because the aggregate interface corresponding to the aggregation group to which the Ethernet subinterface belongs was shut down with the shutdown command.
·     DOWN—The Ethernet subinterface is administratively up but physically down (possibly because no physical link is present or the link has failed).
·     UP—The Ethernet subinterface is both administratively and physically up.
Link layer state of the subinterface:
·     DOWN—The subinterface is physically down.
·     UP—The subinterface is physically up.
Disabled indicates that the subinterface cannot process IP packets.
For a subinterface configured with an IP address, this field changes to Internet Address is.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
# Display brief information about all interfaces.
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
NULL0                UP   UP(s)    --
Vlan1                UP   UP       192.168.11.1
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
BAGG1                UP   2G(a)   F(a)   A    1
GE1/0/1              UP   1G      F(a)   A    1
GE1/0/2              UP   1G      F(a)   A    1
# Filter the brief interface information to display the line starting with the (s) string and all subsequent lines.
<Sysname> display interface brief | begin (s)
NULL0                UP   UP(s)    --
When you use the begin keyword to filter the output, the system only searches the Layer 2 interface list.
# Display brief information about all UP interfaces.
<Sysname> display interface brief | include UP
NULL0                UP   UP(s)    --
# Display the brief information about all interfaces except Ethernet interfaces.
<Sysname> display interface brief | exclude GE
NULL0                UP   UP(s)    --
# Display information about interfaces in the down state and the relevant causes.
GE1/0/2             ADM  Administratively
The command displays brief information about Layer 3 interfaces.
Link layer state of the interface:
·     ADM—The interface has been shut down by the network administrator. To recover its physical layer state, use the undo shutdown command.
·     Stby—The interface is a standby interface. You can use the display standby state command to check the corresponding primary interface.
If the network layer protocol state of an interface is shown as UP but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag, (a letter s in parentheses). This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·     UP—The link is up.
·     DOWN—The link is physically down.
·     ADM—The link has been administratively shut down. To recover its physical state, use the undo shutdown command.
Protocol
Protocol connection state of the interface:
·     UP.
·     DOWN.
·     UP(s).
Interface description.
Information displayed in this field is restricted by space. To view the complete interface description, use the display interface command without specifying the brief keyword.
Brief information about Layer 2 interfaces.
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, the letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the following options:
·     (a)/A—Auto negotiation.
·     H—Half negotiation.
·     F—Full negotiation.
Link type options for Ethernet interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·     A—Auto negotiation.
·     F—Full duplex.
·     F(a)—Auto-negotiated full duplex.
·     H—Half duplex.
·     H(a)—Auto-negotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Table 5 Causes for the physical state of an interface to be DOWN
Not connected
No physical connection exists (possibly because the network cable is disconnected or faulty).
Administratively
The port was shut down with the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
The aggregate interface corresponding to the aggregation group to which the interface belongs was shut down with the shutdown command.
The OAM connection failed (possibly because the connection failed to be established or the connection is disconnected).
The DLDP connection failed (possibly because the connection failed to be established or the connection is disconnected).
The interface is shut down because a loop was detected on it.
BPDU-protected
The uplink of the monitor link group to which the interface belongs is down.
interface
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default duplex mode of the Ethernet interface.
duplex { auto | full | half }
undo duplex
Ethernet interfaces operate in auto negotiation mode.
2: System level
auto: Sets the interface to operate in auto negotiation mode.
full: Sets the interface to operate in full duplex mode.
half: Sets the interface to operate in half-duplex mode. This keyword is not available for 10-GE interfaces.
Support for this command varies with device models. For more information, see About the H3C Access Controllers Command References.
# Configure interface GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
flow-control
Use flow-control to enable TxRx mode generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control on an Ethernet interface is disabled.
2: System level
TxRx mode flow control allows an Ethernet interface to receive common pause frames from its peer, and send common pause frames to notify its peer of congestion.
With the flow-control command configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from its peer, the interface suspends sending packets.
To implement flow control on a link, enable the generic flow control function at both ends of the link.
# Enable TxRx mode generic flow control on the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-interval
Use flow-interval to set the interface statistics polling interval.
Use undo flow-interval to restore the default interval.
flow-interval interval
undo flow-interval
The interface statistics polling interval is 300 seconds.
2: System level
interval: Sets the statistics polling interval, in seconds. It is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
interface
IMPORTANT
IMPORTANT:
Use interface to enter interface view.
2: System level
# Enter GigabitEthernet 1/0/1 interface view (assuming that the interface is a Layer 2 Ethernet interface).
# Enter GigabitEthernet 1/0/5 interface view.
[Sysname-GigabitEthernet1/0/5]
# Create Layer 3 Ethernet subinterface GigabitEthernet 1/0/5.1 and enter its view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through an Ethernet interface, a group of Ethernet interfaces, or all Ethernet interfaces.
Use undo jumboframe enable to prevent jumbo frames from passing through an Ethernet interface, a group of Ethernet interfaces, or all Ethernet interfaces.
jumboframe enable [ value ]
The device allows jumbo frames within a specified length to pass through Layer 2 Ethernet interfaces.
Layer 2 Ethernet interface view, port group view
2: System level
value: Sets the maximum size of Ethernet frames that are allowed to pass through. Support for this argument, and the valid value range and default setting of this argument vary with device models. For more information, see About the H3C Access Controllers Command References. If you set the value argument multiple times, the last configuration takes effect.
In Ethernet interface view, this command applies only to the Ethernet interface.
In port group view, this command applies to the Ethernet interfaces in the port group.
# Enable jumbo frames to pass through all Ethernet interfaces in port group group1.
[Sysname] port-group manual group1
[Sysname-port-group-manual-group1] group-member gigabitethernet 1/0/2
[Sysname-port-group-manual-group1] jumboframe enable
# Enable jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
loopback
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
undo loopback
Loopback testing is disabled on Ethernet interfaces.
2: System level
external: Enables external loopback testing for all on-chip functions related to Ethernet interfaces.
internal: Enables internal loopback testing for the hardware of Ethernet interfaces.
Management Ethernet interfaces do not support this command.
Enable loopback testing for troubleshooting purposes, such as identifying an Ethernet problem.
You cannot perform internal or external loopback testing on an administratively down (ADM DOWN) port. On a physically down (DOWN) port, you can perform only internal loopback testing.
During loopback testing, the speed, duplex, and shutdown commands are not available. In addition, the port is operating in full duplex mode, regardless of its duplex configuration. After loopback testing is disabled, the duplex configuration of the port is restored.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
port link-mode
IMPORTANT
IMPORTANT:
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
For WAC360 or WAC361 access controllers, interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 operate in bridge mode, and interface GigabitEthernet 1/0/5 operates in route mode.
For WX2540E access controllers, interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 operate in bridge mode, and interfaces GigabitEthernet 1/0/5 through GigabitEthernet 1/0/6 operate in route mode.
2: System level
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
Depending on the hardware structure of interface cards, some interfaces can operate only as Layer 2 Ethernet interfaces (in bridge mode), some can operate only as Layer 3 Ethernet interfaces (in route mode), and others can operate as either Layer 2 or Layer 3 Ethernet interfaces (you can set the link mode to bridge or route).
Interface GigabitEthernet 1/0/5 on a WAC360 or WAC361 access controller does not support bridge mode.
Interfaces GigabitEthernet 1/0/5 through GigabitEthernet 1/0/6 on a WX2540E access controller do not support bridge mode.
After you change the link mode of an Ethernet interface, all settings are restored to their default values in the new link mode.
# Configure GigabitEthernet 1/0/1 to operate in route mode.
[Sysname-GigabitEthernet1/0/1] display this
 port link-mode bridge
Return
The output shows that GigabitEthernet 1/0/1 operates in bridge mode.
[Sysname-GigabitEthernet1/0/1] port link-mode route
Return
The output shows that GigabitEthernet 1/0/1 is now operating in route mode.
The display this command displays the configuration that takes effect in the current view.
port link-mode interface-list
IMPORTANT
IMPORTANT:
Use port link-mode interface-list to change the link mode of Ethernet interfaces.
port link-mode { bridge | route } interface-list
2: System level
interface-list: Specifies an Ethernet interface list, in the format of interface-type interface-number [ to interface-type interface-number ].
Configuring the port link-mode interface-list command in system view and configuring the port link-mode command in Ethernet interface view lead to the same result. The difference is that the former changes the link mode of multiple Ethernet interfaces in batch, and the latter changes the link mode of one Ethernet interface at a time.
After you change the link mode of an Ethernet interface, all the settings of the Ethernet interface are restored to their defaults under the new link mode.
The link mode configuration for an Ethernet interface in system view and that in interface view supersede each other, and the one configured last takes effect.
# Configure interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to operate in route mode.
[Sysname] port link-mode route gigabitethernet 1/0/1 to gigabitethernet 1/0/4
Use reset counters interface to clear the Ethernet interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
2: System level
Clear old statistics on the interface before collecting new traffic statistics for a specific period of time.
·     If no interface type is specified, this command clears statistics for all interfaces on the device.
·     If only the interface type is specified, this command clears statistics for all interfaces of the specified type.
·     If both the interface type and number are specified, this command only clears statistics for the specified interface.
# Clear the statistics of GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
Ethernet interfaces and subinterfaces are up.
Ethernet interface view, Ethernet subinterface view, port group view
2: System level
You might need to shut down and then bring up an Ethernet interface to activate configuration changes such as speed or duplex mode changes.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
# Shut down and then bring up GigabitEthernet 1/0/5.1.
[Sysname] interface gigabitethernet1/0/5.1
[Sysname-GigabitEthernet1/0/5.1] shutdown
[Sysname-GigabitEthernet1/0/5.1] undo shutdown
# Shut down all member ports in the port group named group1.
[Sysname-port-group-manual-group1] shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | auto }
undo speed
2: System level
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
Support for this command and parameters of the command varies with device models. For more information, see About the H3C Access Controllers Command References.
# Configure GigabitEthernet 1/0/1 to operate at 100 Mbps.
[Sysname-GigabitEthernet1/0/1] speed 100
Layer 2 Ethernet interface configuration commands
broadcast-suppression
Use broadcast-suppression to set the broadcast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo broadcast-suppression to restore the default broadcast suppression threshold.
broadcast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress broadcast traffic.
2: System level
ratio: Sets the broadcast suppression threshold as a percentage of the maximum interface rate. The smaller the percentage, the less broadcast traffic is allowed to be received. This argument is in the range of 1 to 100.
pps max-pps: Specifies the maximum number of broadcast packets that the Ethernet interface can receive per second. The value range for the max-pps argument varies by device model. For more information, see About the H3C Access Controllers Command References.
·     When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The broadcast suppression threshold value configured through this keyword on an Ethernet interface might not be the one that actually takes effect. To display the actual broadcast suppression threshold value on an Ethernet interface, use the display interface command.
·     When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the broadcast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configuration takes effect only on the interface. In port group view, the configuration takes effect on all the ports in the port group.
When the received broadcast traffic exceeds the broadcast suppression threshold, the interface discards broadcast packets until broadcast traffic drops below the threshold.
If you set different broadcast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured most recently takes effect.
# Set the broadcast suppression threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression 20
# Set the broadcast suppression threshold to 20% on all ports in the manual port group named group1.
[Sysname-port-group-manual-group1] group-member GigabitEthernet 1/0/1
[Sysname-port-group-manual-group1] group-member GigabitEthernet 1/0/2
[Sysname-port-group-manual-group1] broadcast-suppression 20
display loopback-detection
Use display loopback-detection to display the status of the loop detection function.
display loopback-detection [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If loop detection is enabled, this command also displays the detection interval and all ports in a loop condition.
# Display information about loop detection.
<Sysname> display loopback-detection
 Loopback detection is running.
 Detection interval is 30 seconds.
 No port is detected with loopback.
Table 6 Command output
Detection interval time is 30 seconds.
The loop detection interval is 30 seconds.
No loops are detected on any port.
display port-group manual
Use display port-group manual to display information about port groups.
display port-group manual [ all | name port-group-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
all: Displays information about all port groups.
name port-group-name: Specifies the name of a port group, a string of 1 to 32 characters.
If the all keyword is specified, this command displays the name and member Ethernet interfaces of each port group on the device.
If a port group is specified, this command displays its name and member Ethernet interfaces.
If you do not specify the all keyword or any port group name, the command displays the name of each port group on the device.
# Display the names of all port groups.
<Sysname> display port-group manual
The following manual port group exist(s):
group1                                    group2
# Display detailed information about all port groups.
<Sysname> display port-group manual all
Member of group1:
    GigabitEthernet1/0/1            GigabitEthernet1/0/2            GigabitEthernet1/0/3
    GigabitEthernet1/0/4
Member of group2:
None
# Display detailed information about the port group named group1.
<Sysname> display port-group manual name group1
Member of group1:
group-member
Use group-member to assign Ethernet interfaces to a port group.
Use undo group-member to remove Ethernet interfaces from the port group.
group-member interface-list
undo group-member interface-list
A port group does not contain any member ports.
Port group view
2: System level
interface-list: Specifies an Ethernet interface list, in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 interfaces or interface ranges.
If you use the group-member interface-type interface-start-number to interface-type interface-end-number command to add multiple ports in batches to the specified port group, make sure all these ports are of the same type and on the same interface card, and the interface-end-number argument must be greater than the interface-start-number argument.
# Assign GigabitEthernet 1/0/1 to the port group named group1.
[Sysname-port-group-manual-group1] group-member gigabitethernet 1/0/1
loopback-detection control enable
Use loopback-detection control enable to enable loop detection control on trunk or hybrid ports.
Use undo loopback-detection control enable to restore the default.
Loop detection control is disabled on trunk and hybrid ports.
2: System level
When a hybrid or trunk port detects a loop condition, it sends traps, whether loop detection control is enabled or not. However, the port performs the protective action that you configure with the loopback-detection action command only after loop detection control is enabled.
This command is not applicable to access ports.
# Enable loop detection control on the trunk port GigabitEthernet 1/0/1.
[Sysname] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection control enable
Use loopback-detection enable to enable loop detection globally in system view or on interfaces in Ethernet interface or port group view. To use loop detection on an Ethernet interface, you must enable the function both globally and on the port.
Use undo loopback-detection enable to disable loop detection globally or on Ethernet interfaces.
Loop detection is disabled on all Ethernet interfaces.
System view, Layer 2 Ethernet interface view, port group view
2: System level
The undo loopback-detection enable command in system view disables loop detection on all interfaces.
If an interface receives a packet that it sent out, a loop has occurred. Loops might cause broadcast storms, which degrade network performance. You can enable loop detection to detect loops on an interface and, if the interface supports the loopback-detection action command, configure the protective action to take (for example, shut down the port) when a loop is detected.
In addition to the configured protective action, the device also performs other actions to alleviate the impact of the loops. For more information, see Table 7.
Table 7 Actions to take upon detection of a loop condition
Port type
Actions
No protective action is configured
A protective action is configured
Access port
·     Place the interface in controlled mode. The interface discards all incoming packets, but still forwards outgoing traffic.
·     Generate traps.
·     Delete all MAC address entries of the interface.
·     Perform the configured protective action.
·     Generate traps and log messages.
Hybrid or trunk port
·     Generate traps.
·     If loop detection control is enabled, set the interface to controlled mode. The interface discards all incoming packets, but still forwards outgoing packets.
·     If loop detection control is enabled, take the configured protective action on the interface.
# Enable loop detection on GigabitEthernet 1/0/1.
loopback-detection interval-time
Use loopback-detection interval-time to set the loop detection interval.
Use undo loopback-detection interval-time to restore the default loop detection interval.
loopback-detection interval-time time
2: System level
time: Specifies the loop detection interval in the range of 5 to 300 seconds.
# Set the loop detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
multicast-suppression
Use multicast-suppression to set the multicast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo multicast-suppression to restore the default multicast suppression threshold.
multicast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress multicast traffic.
2: System level
ratio: Sets the multicast suppression threshold as a percentage of the maximum interface rate. The value range for this argument is 1 to 100. The smaller the percentage, the less multicast traffic is allowed to be received.
pps max-pps: Specifies the maximum number of multicast packets that the Ethernet interface can receive per second. The value range for the max-pps argument varies by device model. For more information, see About the H3C Access Controllers Command References.
·     When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The multicast suppression threshold value configured through this keyword on an Ethernet interface might not be the one that actually takes effect. To display the actual multicast suppression threshold value on an Ethernet interface, use the display interface command.
·     When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the multicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configurations take effect only on the interface. In port group view, the configurations take effect on all ports in the port group.
When the received multicast traffic exceeds the threshold, the system discards multicast packets until multicast traffic drops below the threshold.
If you set different multicast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured most recently takes effect.
# Set the multicast threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression 20
# Set the multicast threshold to 20% on all ports in the port group named group1.
[Sysname-port-group-manual-group1] group-member GigabitEthernet1/0/1
[Sysname-port-group-manual-group1] group-member GigabitEthernet1/0/2
[Sysname-port-group-manual-group1] multicast-suppression 20
port-group manual
Use port-group manual to create a port group and enter port group view.
Use undo port-group manual to remove a port group.
port-group manual port-group-name
undo port-group manual port-group-name
No port groups exist.
2: System level
port-group-name: Sets the port group name, a string of 1 to 32 characters.
# Create port group group1.
unicast-suppression
Use unicast-suppression to set the unknown unicast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo unicast-suppression to restore the default.
unicast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress unknown unicast traffic.
2: System level
ratio: Sets the unknown unicast suppression threshold as a percentage of the maximum interface rate. The value range for this argument is 1 to 100. The smaller the percentage, the less unknown unicast traffic is allowed to be received.
pps max-pps: Specifies the maximum number of unknown unicast packets that the Ethernet interface can receive per second. The value range for the max-pps argument varies by device model. For more information, see About the H3C Access Controllers Command References.
pps max-pps: Specifies the maximum number of unknown unicast packets that the Ethernet interface can receive per second. The value range of the max-pps argument depends on the device model. For more information, see About the H3C Access Controllers Command References.
·     When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The unknown unicast suppression threshold value configured through this keyword on an Ethernet interface might not be the one that actually takes effect. To display the actual unknown unicast suppression threshold value on an Ethernet interface, use the display interface command.
·     When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the unknown unicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configuration will take effect only on the interface. In port group view, the configuration will take effect on all ports in the port group.
When the received unknown unicast traffic exceeds the threshold, the system discards unknown unicast packets until unknown unicast traffic drops below the threshold.
If you set different unknown unicast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured most recently takes effect.
# Set the unknown unicast threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression 20
# Set the unknown unicast threshold to 20% on all ports of port group group1.
[Sysname-port-group-manual-group1] unicast-suppression 20
Layer 3 Ethernet interface and subinterface configuration commands
mac-address
Use mac-address to set the MAC address of a Layer 3 Ethernet interface or subinterface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
A Layer 3 Ethernet interface uses the MAC address displayed on the RFID of the device.
The MAC address of a Layer 3 Ethernet subinterface is the same as the MAC address of its main interface.
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view
2: System level
mac-address: Specifies a MAC address, in the format of H-H-H.
Make sure the MAC address specified for a Layer 3 Ethernet subinterface is different from the MAC address of its main interface.
As a best practice, do not set a MAC address in the VRRP-reserved MAC address range for a Layer 3 Ethernet subinterface.
# Set the MAC address of GigabitEthernet 1/0/1 to 0001-0001-0001.
[Sysname-GigabitEthernet1/0/1] mac-address 1-1-1
mtu
IMPORTANT
IMPORTANT:
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
2: System level
size: Sets the maximum transmission unit (MTU) in bytes. The value range for this argument is 46 to 1560 bytes.
As the size of MTU decreases, the number of fragments grows. When setting MTU for an interface, you should consider QoS queue lengths (for example, the default FIFO queue length is 75) to avoid a too small MTU causing packet drop in QoS queuing. To achieve the best result, you can tune MTU with the mtu command or QoS queue lengths with the qos fifo queue-length command. For more information, see ACL and QoS Command Reference.
# Set the MTU to 1430 bytes for the Layer 3 Ethernet interface GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] mtu 1430
# Set the MTU to 1400 bytes for the Layer 3 Ethernet subinterface GigabitEthernet 1/0/5.1.
[Sysname-GigabitEthernet1/0/5.1] mtu 1400
promiscuous
IMPORTANT
IMPORTANT:
Use promiscuous to configure a Layer 3 Ethernet interface to operate in promiscuous mode.
Use undo promiscuous to cancel the promiscuous operating mode.
promiscuous
undo promiscuous
A Layer 3 Ethernet interface does not operate in promiscuous mode.
# Configure GigabitEthernet 1/0/5 to operate in promiscuous mode.
[Sysname-GigabitEthernet1/0/5] promiscuous
