03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10203-Layer 2 Command Reference
02-Loopback and Null Interface Commands
02-Loopback and Null Interface Commands 58.42 KB
Loopback and null interface configuration commands
default
Use default to restore the default settings for the loopback or null interface.
default
Loopback interface view, null interface view
Default command level
2: System level
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of interface loopback 0.
[Sysname] interface loopback 0
[Sysname-loopback0] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to change the text description for the current interface.
Use undo description to restore the default description.
The description of a loopback or null interface is interface name Interface, for example, Loopback0 interface.
2: System level
text: Specifies an interface description, a case-sensitive string of 1 to 80 characters.
When you specify an interface description, follow these guidelines:
·     An interface description can be a mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified string length.
·     To use Unicode characters or symbols in an interface description, install the corresponding IME and log in to the device through remote login software that supports the character type.
·     Each non-English Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line. This might break a Unicode character into two parts and create garbled characters at the end of a line.
# Set the description for interface loopback 0 to loopback0.
[Sysname-loopback0] description loopback0
display interface
display interface loopback
Use display interface loopback to display information about a loopback interface.
display interface [ loopback ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface loopback interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface-number: Specifies a loopback interface by its number. The loopback interface number is always 0.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not specify the loopback keyword, this command displays information about all interfaces on the device.
# Display detailed information about interface loopback 0.
<Sysname> display interface loopback 0
LoopBack0 current state: UP
Line protocol current state: UP (spoofing)
Description: LoopBack0 Interface
The Maximum Transmit Unit is 1536
Internet protocol processing : disabled
Physical is Loopback
Last clearing of counters:  Never
    Last 300 seconds input:  0 bytes/sec, 0 bits/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
# Display brief information about interface loopback 0.
<Sysname> display interface loopback 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Loop0                UP   UP(s)    --
# Display brief information about all loopback interfaces in DOWN state.
<Sysname> display interface loopback brief down
Loop0                ADM  Administratively
current state
Physical layer state of the interface:
·     Up—The physical layer state of the interface is up.
·     DOWN (Administratively)—The interface has been shut down manually.
Data link layer protocol state of the interface, which is always (UP) spoofing. (UP) spoofing means that the data link layer protocol state of the interface is UP, but the corresponding link might not exist, or the corresponding link is non-permanent and established on demand.
Description of the interface.
MTU of the interface.
State (enabled or disabled) of the network layer protocol (displayed as Internet Address is X.X.X.X/XX Primary).
Physical is loopback
The physical type of the interface is loopback.
Last time when statistics on the logical interface were cleared by using the reset counters interface command.
If the statistics have never been cleared since the device started, this field displays Never.
Average input rate over the last 300 seconds in Bps, bps, and pps.
Average output rate over the last 300 seconds in Bps, bps, and pps.
Total number and size (in bytes) of input packets on the interface and the number of dropped packets.
Total number and size (in bytes) of output packets on the interface and the number of dropped packets.
Brief information about Layer 3 interfaces.
Explains the Link field values:
·     ADM—Represents administratively down. The interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
·     Stby—Represents standby. The interface is operating as a backup interface. To see the primary interface, use the display standby state command in High Availability Command Reference.
Explains the Protocol field value.
(s)—Represents spoofing. If the data link layer protocol of an interface is up but its link is an on-demand link or not present at all, the Protocol field displays UP(s). This attribute is typical of interface Null 0, Inloopback 0, and loopback interfaces.
Abbreviated interface name.
Link
·     UP—The interface is up.
·     ADM—The interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
Protocol
Data link layer protocol state of the interface, which is always UP(s).
Main IP
Main IP address of the interface.
Cause
Cause of a down physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
interface loopback
display interface null
Use display interface null to display information about the null interface. Because Null 0 interface is the only null interface on a device, this command displays information about Null 0 interface even if you do not specify the 0 keyword.
display interface [ null ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface null 0 [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
0: Specifies interface Null 0. The null interface number is always 0, because the device has only one null interface.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
If you do not specify the null keyword, this command displays information about all interfaces on the device.
If you specify the null keyword, this command displays information about interface Null 0 with or without the 0 keyword, because the device supports only one null interface.
# Display detailed information about null interface Null 0.
<Sysname> display interface null 0
NULL0 current state :UP
Line protocol current state :UP (spoofing)
Description :  NULL0 Interface
The Maximum Transmit Unit is 1500
Physical is NULL DEV
# Display brief information about interface Null 0.
<Sysname> display interface null 0 brief
NULL0                UP   UP(s)    --
See Table 1 for the display interface null command output.
interface null
interface loopback
Use interface loopback to create a loopback interface or enter loopback interface view.
Use undo interface loopback to remove a loopback interface.
undo interface loopback interface-number
2: System level
# Create interface loopback 0.
[Sysname-LoopBack0]
interface null
Use interface null to enter null interface view.
interface null 0
2: System level
0: Specifies interface Null 0. The null interface number is always 0.
A device has only one null interface, which is always named Null 0 and always up. You cannot remove it or shut it down.
# Enter Null 0 interface view.
[Sysname] interface null 0
[Sysname-NULL0]
reset counters interface loopback
Use reset counters interface loopback to clear statistics for a loopback interface.
reset counters interface [ loopback [ interface-number ] ]
2: System level
Clear the existing statistics on the interface before starting to collect new traffic statistics.
If you do not specify the loopback keyword, this command clears the statistics on all interfaces in the system.
If you specify the loopback keyword without the interface-number argument, this command clears the statistics on all loopback interfaces.
# Clear statistics on loopback interface Loopback 0.
<Sysname> reset counters interface loopback 0
reset counters interface null
Use reset counters interface null to clear statistics on the null interface.
reset counters interface [ null [ 0 ] ]
2: System level
0: Specifies a null interface by its number, which is always 0.
If you do not specify the null keyword, this command clears statistics on all interfaces.
If you specify the null keyword, this command clears the statistics on interface Null 0 with or without the 0 keyword, because the device supports only one interface Null 0.
# Clear statistics for interface Null 0.
<Sysname> reset counters interface null 0
shutdown
Use shutdown to shut down the current loopback interface.
Use undo shutdown to bring up the current loopback interface.
shutdown
A loopback interface is up.
2: System level
# Shut down loopback interface loopback 0.
[Sysname-Loopback0] shutdown
