03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10203-Layer 2 Command Reference
04-MAC Address Table Commands
04-MAC Address Table Commands 63.42 KB
MAC address table commands
The MAC address table contains only Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
This document covers only the configuration of unicast MAC address entries, including static, dynamic, and destination blackhole MAC address entries.
display mac-address
Use display mac-address to display MAC address entries.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole ] [ vlan vlan-id ] [ count ] ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
blackhole: Displays destination blackhole MAC address entries. These entries do not age, but you can add or remove them. The packets whose destination MAC addresses match destination blackhole MAC address entries are dropped.
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094.
count: Displays the number of MAC address entries that match all entry attributes you specify in the command. When this keyword is used, the command displays only the number of specified MAC address entries, rather than related information about these MAC address entries.
mac-address: Specifies a MAC address in the format of H-H-H.
dynamic: Displays dynamic MAC address entries, which can be aged.
static: Displays static MAC address entries, which do not age.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you execute this command without specifying any parameters, it displays all MAC address entries on the device.
# Display the MAC address entry for MAC address 000f-e201-0101.
<Sysname> display mac-address 000f-e201-0101
MAC ADDR        VLAN ID    STATE            PORT INDEX              AGING TIME(s)
000f-e201-0101  1          Learned          GigabitEthernet1/0/1    AGING
  ---  1 mac address(es) found  ---
MAC ADDR
MAC address.
VLAN ID
ID of the VLAN to which the MAC address belongs.
STATE
State of a MAC address entry:
·     Config static—Static entry manually configured by the user.
·     Config dynamic—Dynamic entry manually configured by the user.
·     Learned—Entry learned by the device.
·     Blackhole—Destination blackhole entry.
PORT INDEX
Outgoing interface for packets that are destined for the MAC address. This field displays N/A for a blackhole MAC address entry.
AGING TIME(s)
Aging time:
·     AGING—The entry is aging.
·     NOAGED—The entry does not age.
Number of matching MAC address entries.
·     mac-address
·     mac-address timer
display mac-address aging-time
Use display mac-address aging-time to display the aging timer for dynamic MAC address entries.
display mac-address aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the aging timer for dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The output shows that the aging timer for dynamic entries in the MAC address table is 300 seconds.
·     display mac-address
·     mac-address (interface view)
·     mac-address (system view)
·     mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the MAC address learning status of the specified or all Layer 2 Ethernet, Layer 2 aggregate, and WLAN-ESS interfaces.
display mac-address mac-learning [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display MAC address learning status of all Ethernet interfaces.
<Sysname> display mac-address mac-learning
Mac address learning status of the switch: enable
PortName                    Learning Status
Bridge-Aggregation1               enable
GigabitEthernet1/0/1              enable
GigabitEthernet1/0/2              enable
GigabitEthernet1/0/3              enable
GigabitEthernet1/0/4              enable
Ten-GigabitEthernet1/0/5          enable
WLAN-ESS0                         enable
WLAN-DBSS0:2                      enable
Mac-address learning status of the switch
Global MAC address learning status (enabled or disabled).
Learning Status
MAC address learning status (enabled or disabled) for an interface.
display mac-address statistics
Use display mac-address statistics to display the statistics of the MAC address table.
display mac-address statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the statistics of the MAC address table.
<Sysname> display mac-address statistics
MAC TYPE            LEARNED   USER-DEFINED   SYSTEM-DEFINED IN-USE    AVAILABLE
Dynamic   Unicast   20         0             0              20
Static    Unicast   0          0             0              0         8192
Total     Unicast                                           20        8192
Dynamic Multicast   0          0             0              0
Static  Multicast   0          0             0              0         0
Total   Multicast                                           0         0
MAC TYPE
MAC address type:
·     Dynamic Unicast.
·     Static Unicast.
·     Total Unicast.
LEARNED
Dynamically learned MAC addresses.
USER-DEFINED
User defined MAC addresses (dynamic and static).
SYSTEM-DEFINED
MAC addresses generated by the system (for example, 802.1X and MAC authentication).
IN-USE
Number of existing MAC addresses of a specific type.
AVAILABLE
Maximum number of MAC addresses supported by the system.
Use mac-address to add or modify a MAC address entry on a specified interface.
Use undo mac-address to remove a MAC address entry on the interface.
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
No MAC address entry is configured.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
2: System level
dynamic: Specifies dynamic MAC address entries. These entries can age.
static: Specifies static MAC address entries. These entries do not age, but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H, where 0s at the beginning of each H (16-bit hexadecimal digit) can be omitted. For example, entering "f-e2-1" indicates that the MAC address is "000f-00e2-0001."
vlan vlan-id: Specifies an existing VLAN to which the Ethernet interface belongs, in the range of 1 to 4094.
The MAC address entries configuration cannot survive a reboot unless you save it. However, the dynamic MAC address entries are lost at next reboot regardless of whether you save the configuration or not.
# Add a static entry for MAC address 000f-e201-0101 on GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0102 on Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
display mac-address
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to remove one or all MAC address entries.
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
2: System level
blackhole: Specifies destination blackhole MAC address entries. These entries do not age, but you can add or remove them. The packets whose destination MAC addresses match destination blackhole MAC address entries are dropped.
dynamic: Specifies dynamic MAC address entries, which can be aged.
interface interface-type interface-number: Specifies an outbound interface by its type and number.
A static or destination blackhole MAC address entry will not be overwritten by a dynamic MAC address entry. A dynamic MAC address entry can be overwritten by a static or destination blackhole MAC address entry.
If you execute the undo mac-address command without specifying any parameters, this command deletes all MAC address entries.
You can delete all the MAC address entries of a VLAN, or you can choose to delete a specific type (dynamic, static, or destination blackhole) of MAC address entries only.
# Add a static entry for MAC address 000f-e201-0101. All frames destined to this MAC address are sent out of GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface GigabitEthernet 1/0/1 vlan 2
display mac-address
mac-address mac-learning disable
Use mac-address mac-learning disable to disable MAC address learning globally or on a Layer 2 Ethernet interface.
Use undo mac-address mac-learning disable to enable MAC address learning globally or on a Layer 2 Ethernet interface.
MAC address learning is enabled.
System view, Layer 2 Ethernet interface view, port group view, Layer 2 aggregate interface view
2: System level
Follow these guidelines when you configure MAC address learning:
·     You might need to disable MAC address learning to prevent the MAC address table from being saturated. For example, when your device is being attacked by many packets with different source MAC addresses, it affects the update of the MAC address table.
·     Because disabling MAC address learning might result in broadcast storms, enable broadcast storm suppression after you disable MAC address learning on an interface.
# Disable global MAC address learning.
[Sysname] mac-address mac-learning disable
# Disable MAC address learning on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-address mac-learning disable
# Disable MAC address learning on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] mac-address mac-learning disable
mac-address max-mac-count
Use mac-address max-mac-count count to set the maximum number of MAC addresses that can be learned on an interface.
Use mac-address max-mac-count disable-forwarding to disable the device from forwarding frames with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit.
Use undo mac-address max-mac-count to restore the default maximum number of MAC addresses that can be learned on an Ethernet interface.
Use undo mac-address max-mac-count disable-forwarding to allow the device to forward frames received on an Ethernet interface with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit.
mac-address max-mac-count { count | disable-forwarding }
undo mac-address max-mac-count [ disable-forwarding ]
The maximum number of MAC addresses that can be learned on an interface varies with device models, and frames received are forwarded when the upper limit is reached.
2: System level
count: Sets the maximum number of MAC addresses that can be learned on an interface. When the argument is set to 0, the interface cannot learn MAC addresses. The value range for this argument varies with devices. For more information, see About the H3C Access Controller Command References.
disable-forwarding: Disables the device from forwarding frames with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit. Frames with the source MAC addresses listed in the MAC address table are forwarded.
If the command is executed in interface view, the configuration takes effect on the interface. If the command is executed in port group view, the configuration takes effect on all interfaces belonging to the port group.
# Set the maximum number of MAC addresses that can be learned on GigabitEthernet 1/0/1 to 600. After this upper limit is reached, frames received with unknown source MAC addresses on the interface are not forwarded.
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count 600
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count disable-forwarding
mac-address timer
Use mac-address timer to set the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
undo mac-address timer aging
The aging timer is 300 seconds.
2: System level
aging seconds: Sets an aging timer for dynamic MAC address entries, in the range of 10 to 630 seconds.
no-aging: Sets dynamic MAC address entries not to age.
Follow these guidelines to set the aging timer:
·     A long aging interval might cause the MAC address table to retain outdated entries and fail to accommodate the latest network changes.
·     A short aging interval might result in removal of valid entries and unnecessary broadcasts that affect the performance of the device.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
