07-IP Multicast Configuration Guide
HomeSupportSwitchesS10500 SeriesConfigure & DeployConfiguration GuidesH3C S10500 Configuration Guides-R7523P01-6W10007-IP Multicast Configuration Guide
09-Multicast VPN configuration
09-Multicast VPN configuration 694.89 KB
Configuring multicast VPN
Overview
Multicast VPN implements multicast delivery in VPNs. A VPN contains multiple customer network sites and the public network provided by the network service provider. The sites communicate through the public network.
As shown in Figure 1:
·     VPN A contains Site 1, Site 3, and Site 5.
·     VPN B contains Site 2, Site 4, and Site 6.
Figure 1 Typical VPN networking diagram
A VPN has the following types of devices:
·     Provider (P) device—Core device on a service provider network. A P device does not directly connect to CE devices.
·     Provider edge (PE) device—Edge device on a service provider network. A PE device directly connects to one or more customer edge (CE) devices and processes VPN routing.
·     CE device—Edge device on a customer network. A CE device implements route distribution on the customer network. The device can be a router, a switch, or a host.
As shown in Figure 1, the network that runs multicast VPN provides independent multicast services for the public network, VPN A, and VPN B. The multicast device PE supports multiple VPN instances and acts as multiple independent multicast devices. Each VPN forms a plane, and all these planes are isolated from each other. For example, in Figure 1, PE 1 supports the public network, VPN A, and VPN B. You can consider these instances on PE 1 to be independent virtual devices, which are PE 1', PE 1", and PE 1'". Each virtual device works on a plane, as shown in Figure 2.
Figure 2 Multicast in multiple VPN instances
Through multicast VPN, multicast data of VPN A for a multicast group can only arrive at receiver hosts in Site 1, Site 3, and Site 5 of VPN A. The stream is multicast in these sites and on the public network.
The prerequisites for implementing multicast VPN are as follows:
1.     Within each site, multicast for a single VPN instance is supported.
2.     On the public network, multicast for the public network is supported.
3.     The PE devices support multiple VPN instances as follows:
¡     Connecting with different sites through VPN instances and supporting multicast for each VPN instance.
¡     Connecting with the public network and supporting multicast for the public network.
¡     Supporting information exchange and data conversion between the public network and VPNs.
The device implements multicast VPN by using the multicast domain (MD) method. This multicast VPN implementation is referred to as MD VPN.
The most significant advantage of MD VPN is that it requires only the PE devices to support multiple VPN instances. There is no need to upgrade CE devices and P devices or change their original PIM configurations. Therefore, the MD VPN solution is transparent to CE devices and P devices.
MD VPN overview
The basic MD VPN concepts are described in Table 1.
Table 1 Basic MD VPN concepts
Concept
Multicast domain (MD)
An MD is a set of PE devices that are in the same VPN instance. Each MD uniquely corresponds to a VPN instance.
Multicast distribution tree (MDT)
An MDT is a multicast distribution tree constructed by all PE devices in the same VPN. MDT types include default-MDT and data-MDT.
Multicast tunnel (MT)
An MT is a tunnel that interconnects all PEs in an MD for delivering VPN traffic within the MD.
Multicast tunnel interface (MTI)
An MTI is the entrance or exit of an MT, equivalent to an entrance or exit of an MD. PE devices use the MTI to access the MT. An MTI handles only multicast packets, not unicast packets. The MTI interfaces are automatically created when the MD for the VPN instance is created.
Default-group
On the public network, each MD is assigned a unique multicast address, called a default-group. A default-group is the unique identifier of an MD on the public network. It helps build the default-MDT for an MD on the public network.
Default-MDT
A default-MDT uses a default-group address as its group address. In a VPN, the default-MDT is uniquely identified by the default-group. A default-MDT is automatically created after the default-group is specified and will always exist on the public network, regardless of the presence of any multicast services on the public network or the VPN.
Data-group
When the multicast traffic of a VPN reaches or exceeds a threshold, the ingress PE device assigns it an independent multicast address called data-group. It also notifies other PE devices that they must use this address to forward the multicast traffic for that VPN. This initiates the switchover to the data-MDT.
Data-MDT
A data-MDT is an MDT that uses a data-group as it group address. At MDT switchover, PE devices with downstream receivers join a data-group, building a data-MDT. The ingress PE forwards the encapsulated VPN multicast traffic along the data-MDT over the public network.
Introduction to MD VPN
The main points in MD VPN implementation are as follows:
·     The public network of the service provider supports multicast:
¡     The PE devices must support the public network and multiple VPN instances.
¡     Each instance runs PIM independently.
VPN multicast traffic between the PE devices and the CE devices is transmitted on a per-VPN-instance basis. However, the public network multicast traffic between the PE devices and the P devices is transmitted through the public network.
·     An MD logically defines the transmission boundary of the multicast traffic of a specific VPN over the public network. It also physically identifies all the PE devices that support that VPN instance on the public network. Different VPN instances correspond to different MDs.
As shown in Figure 2, the ellipse area in the center of each VPN instance plane represents an MD that provides services for a particular VPN instance. All the VPN multicast traffic in that VPN is transmitted within that MD.
·     Inside an MD, all the private traffic is transmitted through the MT. The process of multicast traffic transmission through an MT is as follows:
a.     The local PE device encapsulates a VPN multicast packet into a public network multicast packet.
b.     The encapsulated multicast packet is sent by the PE device and travels over the public network.
c.     After receiving the multicast packet, the remote PE device decapsulates the multicast packet to get the original VPN multicast packet.
·     The local PE device sends VPN data out of the MTI. The remote PE devices receive the private data from their MTI interfaces.
As shown in Figure 3, you can think of an MD as a private data transmission pool and an MTI as an entrance or exit of the pool. The local PE device puts the private data into the transmission pool (MD) through the entrance (MTI). The transmission pool automatically duplicates the private data and transmits the data to each exit (MTI) of the transmission pool. Then, a remote PE device that needs the data can get it from its exit (MTI).
Figure 3 Relationship between PIM on the public network and an MD in a VPN instance
·     Each VPN instance is assigned a unique default-group address. The VPN data is transparent to the public network.
A PE device encapsulates a VPN multicast packet (a multicast protocol packet or a multicast data packet) into a public network multicast packet. The default-group address is used as the public network multicast group. Then, the PE sends this multicast packet to the public network.
·     A default-group corresponds to a unique MD. For each default-group, a unique default-MDT is constructed through the public network resources for multicast data forwarding. All the VPN multicast packets transmitted in this VPN are forwarded along this default-MDT, regardless of which PE device they used to enter the public network.
·     An MD is assigned a unique data-group range for MDT switchover. When the rate of a VPN multicast stream that entered the public network at a PE device reaches or exceeds the switchover threshold, the PE does the following:
¡     Selects an address that is least used from the data-group range.
¡     Uses the address to encapsulate the multicast packets for that VPN.
·     All the PE devices on the network monitor the forwarding rate on the default-MDT.
a.     When the rate of a VPN multicast stream that entered the public network at a specific PE device exceeds the threshold, the PE device creates an MDT switchover message. The message travels to the downstream along the default-MDT. This causes a data-MDT to be built by using the data-group between that PE device and the remote PE devices with downstream receivers.
b.     After a data-delay period has passed, an MDT switchover process starts. All VPN multicast packets that have entered the public network through that PE device are not encapsulated with the default-group address. They are encapsulated into public network multicast packets with the data-group address. Then they are switched from the default-MDT to the data-MDT.
For more information about MDT switchover, see "MDT switchover."
A VPN uniquely corresponds to an MD and an MD provides services for only one VPN, which is called a one-to-one relationship. Such a relationship exists between VPN, MD, MTI, default-group, and the data-group range.
PIM neighboring relationships in MD VPN
Figure 4 PIM neighboring relationships in MD VPN
PIM neighboring relationships are established between two or more directly interconnected devices on the same subnet. As shown in Figure 4, the following types of PIM neighboring relationships exist in MD VPN:
·     PE-P PIM neighboring relationship—Established between the public network interface on a PE device and the peer interface on the P device over the link.
·     PE-PE PIM neighboring relationship—Established between PE devices that are in the same VPN instance after they receive the PIM hello packets.
·     PE-CE PIM neighboring relationship—Established between a PE interface that is bound with the VPN instance and the peer interface on the CE device over the link.
Protocols and standards
RFC 6037, Cisco Systems' Solution for Multicast in BGP/MPLS IP VPNs
How MD VPN works
This section describes default-MDT establishment, multicast traffic delivery based on the default-MDT, and inter-AS MD VPN implementation.
For a VPN instance, multicast data transmission on the public network is transparent. The VPN data is exchanged between the MTIs of the local PE and the remote PE. This implements the seamless transmission of the VPN data over the public network. However, the multicast data transmission process (the MDT transmission process) over the public network is very complicated.
Default-MDT establishment
The multicast routing protocol running on the public network can be PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM. The process of creating a default-MDT is different in these PIM modes.
Default-MDT establishment in a PIM-DM network
Figure 5 Default-MDT establishment in a PIM-DM network
As shown in Figure 5, PIM-DM is enabled on the network, and all the PE devices support VPN instance A. The process of establishing a default-MDT is as follows:
1.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
a.     Encapsulates the PIM protocol packet of the private network into a public network multicast data packet. PE 1 does this by specifying the source address as the IP address of the MD source interface and the multicast group address as the default-group address.
b.     Sends the multicast data packet to the public network.
For other PE devices that support VPN instance A as default-group members, PE 1 of VPN instance A initiates a flood-prune process in the entire public network. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network. This forms an SPT with PE 1 as the root, and PE 2 and PE 3 as leaves.
2.     At the same time, PE 2 and PE 3 separately initiate a similar flood-prune process.
Finally, three independent SPTs are established in the MD, constituting the default-MDT in the PIM-DM network.
Default-MDT establishment in a PIM-SM network
Figure 6 Default-MDT establishment in a PIM-SM network
As shown in Figure 6, PIM-SM is enabled on the network, and all the PE devices support VPN instance A. The process of establishing a default-MDT is as follows:
1.     PE 1 initiates a join to the public network RP by specifying the multicast group address as the default-group address in the join message. A (*, 239.1.1.1) state entry is created on each device along the path on the public network.
2.     At the same time, PE 2 and PE 3 separately initiate a similar join process.
Finally, an RPT is established in the MD, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
3.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
The public network interface of PE 1 registers the multicast source with the public network RP, and the public network RP initiates a join to PE 1. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network.
4.     At the same time, PE 2 and PE 3 separately initiate a similar register process.
Finally, three SPTs between the PE devices and the RP are established in the MD.
In the PIM-SM network, the RPT, or the (*, 239.1.1.1) tree, and the three independent SPTs constitute the default-MDT.
Default-MDT establishment in a BIDIR-PIM network
Figure 7 Default-MDT establishment in a BIDIR-PIM network
As shown in Figure 7, BIDIR-PIM runs on the network, and all the PE devices support VPN instance A. The process of establishing a default-MDT is as follows:
At the same time, PE 2 and PE 3 separately initiate a similar join process. Finally, a receiver-side RPT is established in the MD, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
2.     PE 1 sends a multicast packet with the default-group address as the multicast group address. The DF of each network segment on the public network forwards the multicast packet to the RP. Each device on the path creates a (*, 239.1.1.1) state entry.
At the same time, PE 2 and PE 3 separately initiate a similar process. Finally, three source-side RPTs are established in the MD, with PE 1, PE 2, and PE 3 as the roots and as the public network RP as the leave.
3.     The receiver-side RPT and the three source-side RPTs constitute the default-MDT in the BIDIR-PIM network.
Default-MDT establishment in a PIM-SSM network
Figure 8 Default-MDT establishment in a PIM-SSM network
As shown in Figure 8, PIM-SSM runs on the network, and all the PE devices support VPN instance A. The process of establishing a default-MDT is as follows:
1.     PE 1, PE 2, and PE 3 exchange MDT route information (including BGP interface address and the default-group address) through BGP.
2.     PE 1 sends a subscribe message to PE 2 and PE 3. Each device on the public network creates an (S, G) entry. An SPT is established in the MD with PE 1 as the root and PE 2 and PE 3 as the leaves.
At the same time, PE 2 and PE 3 separately initiate a similar process, and establish an SPT with itself as the root and the other PEs as the leaves.
3.     The three independent SPTs constitute the default-MDT in the PIM-SSM network.
In PIM-SSM, the term "subscribe message" refers to a join message.
Default-MDT characteristics
No matter which PIM mode is running on the public network, the default-MDT has the following characteristics:
·     All PE devices that support the same VPN instance join the default-MDT.
·     All multicast packets that belong to this VPN are forwarded along the default-MDT to every PE device on the public network, even if no active downstream receivers exist.
Default-MDT-based delivery
The default-MDT delivers multicast protocol packets and multicast data packets differently.
Multicast protocol packet delivery
To forward the multicast protocol packets of a VPN over the public network, the local PE device encapsulates them into public network multicast data packets. These packets are transmitted along the default-MDT and are then decapsulated on the remote PE device to go into the normal protocol procedure. Finally a distribution tree is established across the public network.
The following describes how multicast protocol packets are forwarded in different circumstances:
·     If the VPN network runs PIM-DM or PIM-SSM:
¡     Hello packets are forwarded through MTI interfaces to establish PIM neighboring relationships.
¡     A flood-prune process (in PIM-DM) or a join process (in PIM-SSM) is initiated across the public network to establish an SPT across the public network.
·     If the VPN network runs PIM-SM:
¡     If the receivers and the VPN RP are in different sites, a join process is initiated across the public network to establish an RPT.
¡     If the multicast source and the VPN RP are in different sites, a registration process is initiated across the public network to establish an SPT.
·     If the VPN network runs BIDIR-PIM:
¡     If the receivers and the VPN RP are in different sites, a join process is initiated across the public network to establish a receiver-side RPT.
¡     If the multicast sources and the VPN RP are in different sites, join processes are initiated across the public network to establish source-side RPTs.
PIM mode must be the same for all interfaces that belong to the same VPN, including those interfaces that are bound with the VPN instance and the MTI interfaces on PE devices.
As shown in Figure 9:
·     PIM-SM is running in both the public network and the VPN network.
·     Receiver for the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2.
·     CE 1 of Site 1 acts as the RP for group G (225.1.1.1).
·     The default-group address used to forward public network data is 239.1.1.1.
Figure 9 Transmission of multicast protocol packets
The multicast protocol packet is delivered as follows:
1.     Receiver sends an IGMP report to CE 2 to join the multicast group G. CE 2 creates a local state entry (*, 225.1.1.1) and sends a join message to the VPN RP (CE 1).
2.     After receiving the join message from CE 2, the VPN instance on PE 2 creates a state entry (*, 225.1.1.1) and specifies the MTI interface as the upstream interface. The VPN instance on PE 2 considers the join message to have been sent out of the MTI interface, because step 3 is transparent to the VPN instance.
3.     PE 2 encapsulates the join message into a public network multicast data packet (11.1.2.1, 239.1.1.1) by using the GRE method. In this multicast data packet, the source address is the MD source interface IP address 11.1.2.1, and the destination address is the default-group address 239.1.1.1. PE 2 then forwards this packet to the public network.
4.     The default-MDT forwards the multicast data packet (11.1.2.1, 239.1.1.1) to the public network instance on all the PE devices. After receiving this packet, every PE device decapsulates it to get the original join message to be sent to the VPN RP. Then, each PE device examines the VPN RP address in the join message. If the VPN RP is in the site to which a PE device is connected, the PE passes the join message to the VPN instance on the PE. Otherwise, the PE discards the join message.
5.     When receiving the join message, the VPN instance on PE 1 considers the received message to be from the MTI. PE 1 creates a local state entry (*, 225.1.1.1), with the downstream interface being the MTI and the upstream interface being the one that leads to CE 1. At the same time, the VPN instance sends a join message to CE 1, which is the VPN RP.
6.     After receiving the join message from the VPN instance on PE 1, CE 1 creates a local state entry (*, 225.1.1.1) or updates the entry if the entry already exists.
By now, the construction of an RPT across the public network is completed.
Multicast data packet delivery
After the default-MDT is established, the multicast source forwards the VPN multicast data to the receivers in each site along the default-MDT. The VPN multicast packets are encapsulated into public network multicast packets on the local PE device, and transmitted along the default-MDT. Then, they are decapsulated on the remote PE device and transmitted in that VPN site.
VPN multicast data packets are forwarded across the public network differently in the following circumstances:
·     If PIM-DM or PIM-SSM is running in the VPN, the multicast source forwards multicast data packets to the receivers along the VPN SPT across the public network.
·     When PIM-SM is running in the VPN:
¡     Before the RPT-to-SPT switchover, if the multicast source and the VPN RP are in different sites, the VPN multicast data packets travel to the VPN RP along the VPN SPT across the public network. If the VPN RP and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN RPT over the public network.
¡     After the RPT-to-SPT switchover, if the multicast source and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN SPT across the public network.
·     When BIDIR-PIM is running in the VPN, if the multicast source and the VPN RP are in different sites, the multicast source sends multicast data to the VPN RP across the public network along the source-side RPT. If the VPN RP and the receivers are in different sites, the multicast data packets travel to the receivers across the public network along the receiver-side RPT.
For more information about RPT-to-SPT switchover, see "Configuring PIM."
The following example explains how multicast data packets are delivered based on the default-MDT when PIM-DM is running in both the public network and the VPN network.
As shown in Figure 10:
·     PIM-DM is running in both the public network and the VPN sites.
·     Receiver of the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2.
·     Source in Site 1 sends multicast data to multicast group (G).
·     The default-group address used to forward public network multicast data is 239.1.1.1.
Figure 10 Multicast data packet delivery
A VPN multicast data packet is delivered across the public network as follows:
1.     Source sends a VPN multicast data packet (192.1.1.1, 225.1.1.1) to CE 1.
2.     CE 1 forwards the VPN multicast data packet along an SPT to PE 1, and the VPN instance on PE 1 examines the MVRF.
If the outgoing interface list of the forwarding entry contains an MTI, PE 1 processes the VPN multicast data packet as described in step 3. The VPN instance on PE 1 considers the VPN multicast data packet to have been sent out of the MTI, because step 3 is transparent to it.
3.     PE 1 encapsulates the VPN multicast data packet into a public network multicast packet (11.1.1.1, 239.1.1.1) by using the GRE method. The source IP address of the packet is the MD source interface 11.1.1.1, and the destination address is the default-group address 239.1.1.1. PE 1 then forwards it to the public network.
4.     The default-MDT forwards the multicast data packet (11.1.1.1, 239.1.1.1) to the public network instance on all the PE devices. After receiving this packet, every PE device decapsulates it to get the original VPN multicast data packet, and passes it to the corresponding VPN instance. If a PE device has a downstream interface for an SPT, it forwards the VPN multicast packet down the SPT. Otherwise, it discards the packet.
5.     The VPN instance on PE 2 looks up the MVRF and finally delivers the VPN multicast data to Receiver.
By now, the process of transmitting a VPN multicast data packet across the public network is completed.
MDT switchover
Switching from default-MDT to data-MDT
When a multicast packet of a VPN is transmitted through the default-MDT on the public network, the packet is forwarded to all PE devices that support that VPN instance. This occurs whether or not any active receivers exist in the attached sites. When the rate of the multicast traffic of that VPN is high, multicast data might get flooded on the public network. This increases the bandwidth use and brings extra burden on the PE devices.
To optimize multicast transmission of large VPN multicast traffic that enters the public network, the MD solution introduces a dedicated data-MDT. The data-MDT is built between the PE devices that connect VPN multicast receivers and multicast sources. When specific network criteria are met, a switchover from the default-MDT to the data-MDT occurs to forward VPN multicast traffic to receivers.
The process of default-MDT to data-MDT switchover is as follows:
1.     The source-side PE device (PE 1, for example) periodically examines the forwarding rate of the VPN multicast traffic. The default-MDT switches to the data-MDT only when the following criteria are both met:
¡     The VPN multicast data has passed the ACL rule filtering for default-MDT to data-MDT switchover.
¡     The traffic rate of the VPN multicast stream has exceeded the switchover threshold and stayed higher than the threshold for a certain length of time.
2.     PE 1 selects a least-used address from the data-group range. Then, it sends an MDT switchover message to all the other PE devices down the default-MDT. This message contains the VPN multicast source address, the VPN multicast group address, and the data-group address.
3.     Each PE device that receives this message examines whether it interfaces with a VPN that has receivers of that VPN multicast stream.
If so, it joins the data-MDT rooted at PE 1. Otherwise, it caches the message and will join the data-MDT when it has attached receivers.
4.     After sending the MDT switchover message, PE 1 starts the data-delay timer. When the timer expires, PE 1 uses the default-group address to encapsulate the VPN multicast data. The multicast data is then forwarded down the data-MDT.
5.     After the multicast traffic is switched from the default-MDT to the data-MDT, PE 1 continues sending MDT switchover messages periodically. Subsequent PE devices with attached receivers can then join the data-MDT. When a downstream PE device no longer has active receivers attached to it, it leaves the data-MDT.
For a given VPN instance, the default-MDT and the data-MDT are both forwarding tunnels in the same MD. A default-MDT is uniquely identified by a default-group address, and a data-MDT is uniquely identified by a data-group address. Each default-group is uniquely associated with a data-group range.
Backward switching from data-MDT to default-MDT
After the VPN multicast traffic is switched to the data-MDT, the multicast traffic conditions might change and no longer meet the switchover criterion. In this case, PE 1, as in the preceding example, initiates a backward MDT switchover process when any of the following criteria are met:
·     The traffic rate of the VPN multicast data has dropped below the switchover threshold. In addition, the traffic rate has stayed lower than the threshold for a certain length of time (known as the data-holddown period).
·     The associated data-group range is changed, and the data-group address for encapsulating the VPN multicast data is out of the new address range.
·     The ACL rule for controlling the switchover from the default-MDT to the data-MDT has changed, and the VPN multicast data fails to pass the new ACL rule.
Inter-AS MD VPN
In an inter-AS VPN networking scenario, VPN sites are located in multiple ASs. These sites must be interconnected. Inter-AS VPN provides the following solutions:
·     VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
·     EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·     Multihop EBGP redistribution of labeled VPN-IPv4 routes between PE routers—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
For more information about the three inter-AS VPN solutions, see "Configuring MPLS L3VPN."
Based on these solutions, there are three ways to implement inter-AS MD VPN:
·     MD VPN inter-AS option A
·     MD VPN inter-AS option B
·     MD VPN inter-AS option C
As shown in Figure 11:
·     Two VPN instances are in AS 1 and AS 2.
·     PE 3 and PE 4 are ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through their respective VPN instance and treat each other as a CE device.
Figure 11 MD VPN inter-AS option A
To implement MD VPN inter-AS option A, a separate MD must be created in each AS. Multicast data is transmitted between the VPNs in different ASs through the MDs.
Multicast packets of VPN instance 1 are delivered as follows:
1.     CE 1 forwards the multicast packet of VPN instance 1 to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network packet and forwards it to PE 3 through the MTI interface in MD 1.
3.     PE 3 considers PE 4 as a CE device of VPN instance 1, so PE 3 forwards the multicast packet to PE 4.
4.     PE 4 considers PE 3 as a CE device of VPN instance 2, so it forwards the multicast packet to PE 2 through the MTI interface in MD 2 on the public network.
5.     PE 2 forwards the multicast packet to CE 2.
Because only VPN multicast data is forwarded between ASBRs, different PIM modes can run within different ASs. However, the same PIM mode must run on all interfaces that belong to the same VPN (including interfaces with VPN bindings on ASBRs).
In MD VPN inter-AS option B, RPF vector and BGP connector are introduced:
·     RPF vector—Attribute encapsulated in a PIM join message. It is the next hop of BGP MDT route from the local PE device to the remote PE device. Typically, it is the ASBR in the local AS.
When a device receives the join message with the RPF vector, it first checks whether the RPF vector is its own IP address. If so, the device removes the RPF vector, and sends the message to its upstream neighbor according to the route to the remote PE device. Otherwise, it keeps the RPF vector, looks up the route to the RPF vector, and sends the message to the next hop of the route. In this way, the PIM message can be forwarded across the ASs and an MDT is established.
·     BGP connector—Attribute shared by BGP peers when they exchange VPNv4 routes. It is the IP address of the remote PE device.
The local PE device fills the upstream neighbor address field with the BGP connector in a join message. This ensures that the message can pass the RPF check on the remote PE device after it travels along the MT.
To implement MD VPN inter-AS option B, only one MD needs to be established for the two ASs. VPN multicast data is transmitted between different ASs on the public network within this MD.
As shown in Figure 12:
·     A VPN network involves AS 1 and AS 2.
·     PE 3 and PE 4 are the ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through MP-EBGP and treat each other as a P device.
·     PE 3 and PE 4 advertise VPN-IPv4 routes to each other through MP-EBGP.
·     An MT is established between PE 1 and PE 2 for delivering VPN multicast traffic across the ASs.
Figure 12 MD VPN inter-AS option B
The establishment of the MDT on the public network is as follows:
1.     PE 1 originates a PIM join message to join the SPT rooted at PE 2. In the join message, the upstream neighbor address is the IP address of PE 2 (the BGP connector). The RPF vector attribute is the IP address of PE 3. PE 1 encapsulates the join message as a public network packet and forwards it through the MTI.
2.     P 1 determines that the RPF vector is not an IP address of its own. It looks up the routing table for a route to PE 3, and forwards the packet to PE 3.
3.     PE 3 removes the RPF vector because the RPF vector is its own IP address. It fails to find a BGP MDT route to PE 2, so it encapsulates a new RPF vector (IP address of PE 4) in the packet and forwards it to PE 4.
4.     PE 4 removes the RPF vector because the RPF vector is its own IP address. It has a local route to PE 2, so it forwards the packet to P 2, which is the next hop of the route to PE 2.
5.     P 2 sends the packet to PE 2.
6.     PE 2 receives the packet on the MTI and decapsulates the packet. The receiving interface is the RPF interface of the RPF route back to PE 1 for the join message, and the join message passes the RPF check. The SPT from PE 1 to PE 2 is established.
When PE 1 joins the SPT rooted at PE 1, PE 2 also initiates a join process to the SPT rooted at PE 1. A MDT is established when the two SPTs are finished.
As shown in Figure 13:
·     PEs in different ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes to each other.
Figure 13 MD VPN inter-AS option C
To implement MD VPN inter-AS option C, only one MD needs to be created for the two ASs. Multicast data is transmitted between the two ASs through the MD.
Multicast packets are delivered as follows:
1.     CE 1 forwards the VPN instance multicast packet to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network multicast packet and forwards it to PE 3 through the MTI interface on the public network.
3.     PE 3 and PE 4 are interconnected through MP-EBGP, so PE 3 forwards the public network multicast packet to PE 4 along the VPN IPv4 route.
4.     The public network multicast packet arrives at the MTI interface of PE 2 in AS 2. PE 2 decapsulates the public network multicast packet and forwards the VPN multicast packet to CE 2.
Multicast VPN does not support Layer 3 Ethernet subinterfaces or Layer 3 aggregate subinterfaces. To ensure multicast forwarding for multicast VPN, do not use these interfaces as multicast data forwarding interfaces. For more information about Layer 3 Ethernet subinterfaces, see Interface Configuration Guide. For more information about Layer 3 aggregate subinterfaces, see Layer 2LAN Switching Configuration Guide.
Multicast VPN configuration task list
Tasks at a glance
Configuring MD VPN:
·     (Required.) Enabling IP multicast routing for a VPN instance
·     (Required.) Creating an MD for a VPN instance
·     (Required.) Create an MD address family
·     (Required.) Specifying the default-group
·     (Required.) Specifying the MD source interface
·     (Optional.) Configuring MDT switchover parameters
·     (Optional.) Configuring the RPF vector feature
·     (Optional.) Enabling data-group reuse logging
Configuring BGP MDT:
·     (Required.) Configuring BGP MDT peers or peer groups
·     (Optional.) Configuring a BGP MDT route reflector
The MTI interfaces are automatically created and bound with the VPN instance when you create an MD for the VPN instance. Follow these guidelines to make sure the MTI interfaces are correctly created.
·     The MTI interfaces take effect only after the default-group and the MD source interface are specified and the MD source interface gets the public IP address.
·     To ensure correct MTI forwarding, create a service loopback group and specify the multicast tunnel service by using the service-loopback group command. For more information about this command, see Layer 2—LAN Switching Command Reference.
·     The PIM mode on the MTI must be the same as the PIM mode running on the VPN instance to which the MTI belongs. When a minimum of one interface on the VPN instance is enabled with PIM, the MTI is enabled with PIM accordingly. When all interfaces on the VPN instance are PIM-disabled, PIM is also disabled on the MTI.
Configuring MD VPN
This section describes how to configure MD VPN.
Configuration prerequisites
Before you configure MD VPN, complete the following tasks:
·     Configure a unicast routing protocol on the public network.
·     Configure MPLS L3VPN on the public network.
·     Configure PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM on the public network.
·     Determine the VPN instance names and RDs.
·     Determine the default-groups.
·     Determine the source address for establishing BGP peers.
·     Determine the data-group range and the MDT switchover criteria.
·     Determine the data-delay period.
Before you configure any MD VPN functionality for a VPN instance, you must create a VPN instance and enable IP multicast routing for the VPN instance.
Perform this task on PE devices.
To enable IP multicast routing for a VPN instance:
Step
Remarks
N/A
2.     Create a VPN instance and enter its view.
By default, no VPN instances exist.
For more information about this command, see MPLS Command Reference.
3.     Configure an RD for the VPN instance.
By default, a VPN instance is not configured with an RD.
4.     Return to system view.
N/A
5.     Enable IP multicast routing for the VPN instance and enter MRIB view of the VPN instance.
multicast routing vpn-instance vpn-instance-name
By default, IP multicast routing is disabled in a VPN instance.
To provide multicast services for a VPN instance, you must create an MD for the VPN instance on PE devices that belong to the VPN instance. After the MD is created, the system automatically creates MTIs and binds them with the VPN instance.
A VPN instance supports only one MD.
To create an MD for a VPN instance:
Step
Remarks
N/A
2.     Create an MD for a VPN instance and enter its view.
multicast-domain vpn-instance vpn-instance-name
By default, no MD exists.
You must create an MD IPv4 address family for a VPN instance before you can perform other MD VPN configuration tasks for the VPN instance. For a VPN instance, configurations in MD IPv4 address family view apply to IPv4 multicast packets of the instance.
To create an MD address family:
Step
Remarks
N/A
2.     Enter MD view of a VPN instance.
N/A
3.     Create an MD IPv4 address family and enter its view.
address-family ipv4
By default, no MD IPv4 address family exists.
An MTI of a VPN instance uses the default-group as the destination address to encapsulate multicast packets for the VPN instance.
When you specify the default-group, follow these restrictions and guidelines:
·     Perform this task on PE devices.
·     You must specify the same default-group on all PE devices that belong to the same MD.
·     The default-group for an MD must be different from the default-group and the data-group used by any other MD.
Configuration procedure
To specify the default-group:
Step
Remarks
N/A
2.     Enter MD view.
N/A
3.     Enter MD IPv4 address family view.
address-family ipv4
N/A
4.     Specify the default-group.
default-group group-address
By default, no default-group exists.
An MTI of a VPN instance uses the IP address of the MD source interface as the source address to encapsulate multicast packets for the VPN instance.
When you specify the MD source interface, follow these restrictions and guidelines:
·     For the PE device to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MD source interface.
To specify the MD source interface:
Step
Remarks
N/A
2.     Enter MD view.
N/A
address-family ipv4
N/A
4.     Specify the MD source interface.
source interface-type interface-number
By default, no MD source interface is specified.
To decrease traffic interruption caused by frequent default-MDT to data-MDT switchovers, you can specify a data-delay period. The switchover occurs a data-delay period after the multicast VPN data first arrives, regardless of whether multicast VPN data keeps arriving during the period.
To configure MDT switchover parameters:
Step
Remarks
N/A
2.     Enter MD view.
N/A
address-family ipv4
N/A
4.     Configure the data-group range and the switchover criteria.
data-group group-address { mask-length | mask } [ acl acl-number ] *
By default, no data-group range exists, and the default-MDT to data-MDT switchover never occurs.
5.     Set the data-delay period.
data-delay delay
The default setting is 3 seconds.
Enabling the RPF vector feature
This feature enables the device to insert the RPF vector (IP address of the ASBR in the local AS) in PIM join messages for other devices to perform RPF check.
Perform this task on PE devices (except the PE devices that do not have attached receivers).
To enable the RPF vector feature:
Step
Remarks
N/A
2.     Enter MRIB view of a VPN instance.
N/A
3.     Enable the RPF vector feature.
rpf proxy vector
By default, the RPF vector feature is disabled.
Enabling RPF vector compatibility
This feature enables the device to work with other manufacturers' products on RPF vectors for interoperability purposes. You must enable this feature on all H3C devices on the public network.
To enable RPF vector compatibility:
Step
Remarks
N/A
2.     Enable RPF vector compatibility.
multicast rpf-proxy-vector compatible
By default, RPF vector compatibility is disabled.
For a given VPN, the number of VPN multicast streams to be switched to data-MDTs might exceed the number of addresses in the data-group range. In this case, the VPN instance on the source-side PE device can reuse the addresses in the address range. With data-group reuse logging enabled, the address reuse information will be logged.
Attributed to the MD module, the group address reuse logging information has a severity level informational. For more information about the logging information, see Network Management and Monitoring Configuration Guide.
To enable data-group reuse logging:
Step
Remarks
N/A
2.     Enter MD view.
N/A
address-family ipv4
N/A
4.     Enable data-group reuse logging.
log data-group-reuse
By default, data-group reuse logging is disabled.
Configuring BGP MDT
If PIM-SSM is running on the public network, you must configure BGP MDT.
Before you configure BGP MDT, complete the following tasks:
·     Configure basic BGP functions on the public network.
·     Configure PIM-SSM on the public network.
·     Determine the IP addresses of the MDT peers.
·     Determine the cluster IDs of the route reflectors.
Configure a BGP MDT peer or peer group on a PE router in BGP IPv4 MDT address family view. Then, the PE router can exchange MDT information with the BGP peer or peer group. MDT information includes the IP address of the PE and default-group to which the PE belongs. On a public network running PIM-SSM, the multicast VPN establishes a default-MDT rooted at the PE (multicast source) based on the MDT information.
To configure a BGP MDT peer or peer group:
Step
Remarks
N/A
N/A
3.     Create a BGP IPv4 MDT address family and enter its view.
address-family ipv4 mdt
By default, no BGP IPv4 address family exists.
4.     Enable the device to exchange MDT routing information with the BGP peer or the peer group.
By default, the router cannot exchange BGP MDT routing information with a BGP peer or peer group.
For more information about this command, see Layer 3—IP Routing Configuration Guide.
IMPORTANT IMPORTANT:
Before you configure this command, you must create a BGP peer or peer group in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
BGP MDT peers in the same AS must be fully meshed to maintain connectivity. However, when multiple BGP MDT peers exist in an AS, connection establishment among them might result in increased costs. To reduce connections between BGP MDT peers, you can configure one of them as a route reflector and specify other routers as clients.
When clients establish BGP MDT connections with the route reflector, the route reflector forwards (or reflects) BGP MDT routing information between clients. The clients are not required to be fully meshed. To save bandwidth if the clients have been fully meshed, you can disable the routing reflection between clients by using the undo reflect between-clients command.
The route reflector and its clients form a cluster. Typically, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability. To avoid routing loops, make sure the route reflectors in a cluster have the same cluster ID.
To configure a BGP MDT route reflector:
Step
Remarks
N/A
N/A
3.     Enter BGP IPv4 MDT address family view.
N/A
4.     Configure the device as a route reflector and specify its peers or peer groups as clients.
By default, neither route reflectors nor clients exist.
5.     (Optional.) Disable route reflection between clients.
By default, route reflection between clients is disabled.
For more information about this command, see Layer 3—IP Routing Command Reference.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its router ID as the cluster ID.
Displaying and maintaining multicast VPN
Display BGP MDT peer group information.
display bgp [ instance instance-name ] group ipv4 mdt [ group-name group-name ]
Display information about BGP MDT peers or peer groups.
display bgp [ instance instance-name ] peer ipv4 mdt [ ip-address mask-length | { ip-address | group-name group-name } log-info | [ ip-address ] verbose ]
Display BGP MDT routing information.
display bgp [ instance instance-name ] routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info ] ]
Display information about BGP update groups for the BGP IPv4 MDT address family.
display bgp [ instance instance-name ] update-group ipv4 mdt [ ip-address ]
Display information about default-groups for IPv4 multicast transmission.
display multicast-domain [ vpn-instance vpn-instance-name ] default-group { local | remote }
Reset BGP sessions for BGP IPv4 MDT address family.
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } ipv4 mdt
For more information about the display bgp group, display bgp peer, display bgp update-group, and reset bgp commands, see Layer 3—IP Routing Command Reference.
Multicast VPN configuration examples
This section provides examples of configuring multicast VPN on switches.
Intra-AS MD VPN configuration example
Network requirements
As shown in Figure 14, configure intra-AS MD VPN to meet the following requirements:
Item
Multicast sources and receivers
·     In VPN instance a, S 1 is a multicast source, and R 1, R 2 and R 3 are receivers.
·     In VPN instance b, S 2 is a multicast source, and R 4 is a receiver.
·     For VPN instance a, the default-group is 239.1.1.1, and the data-group range is 225.2.2.0 to 225.2.2.15.
·     For VPN instance b, the default-group is 239.2.2, and the data-group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PE interfaces belong
·     PE 1: VLAN-interface 11 and VLAN-interface 20 belong to VPN instance a. VLAN-interface 12 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 13 belongs to VPN instance b. VLAN-interface 14 belongs to VPN instance a. VLAN-interface 15 and Loopback 1 belong to the public network instance.
·     PE 3: VLAN-interface 17 belongs to VPN instance a. VLAN-interface 18 and Loopback 2 belong to VPN instance b. VLAN-interface 19 and Loopback 1 belong to the public network instance.
Unicast routing protocols and MPLS
·     Configure OSPF on the public network, and configure RIP between the PEs and CEs.
·     Establish BGP peer connections between PE 1, PE 2, and PE 3 on their respective Loopback 1.
·     Configure MPLS on the public network.
·     Enable IP multicast routing on the P device.
·     Enable IP multicast routing on the public network on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance a on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance b on PE 2 and PE 3.
·     Enable IP multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2.
IGMP
·     Enable IGMPv2 on VLAN-interface 20 of PE 1.
·     Enable IGMPv2 on VLAN-interface 40 of CE a2, VLAN-interface 50 of CE a3, and VLAN-interface 60 of CE b2.
PIM
Enable PIM-SM on the public network and for VPN instances a and b:
·     Enable PIM-SM on all interfaces of the P device.
·     Enable PIM-SM on all public and private network interfaces of PE 1, PE 2, and PE 3.
·     Enable PIM-SM on all interfaces that have no receiver hosts connected of CE a1, CE a2, CE a3, CE b1, and CE b2.
·     Configure Loopback 1 of P as a C-BSR and a C-RP for the public network to provide services for all multicast groups.
·     Configure Loopback 1 of CE a2 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 2 of PE 3 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
Figure 14 Network diagram
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
Vlan-int19
192.168.8.1/24
S 2
10.110.8.2/24
PE 3
Vlan-int17
10.110.5.1/24
R 1
10.110.1.2/24
PE 3
Vlan-int18
10.110.6.1/24
R 2
10.110.9.2/24
PE 3
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
PE 3
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
Vlan-int10
10.110.7.1/24
P
Vlan-int12
192.168.6.2/24
CE a1
Vlan-int11
10.110.2.2/24
P
Vlan-int15
192.168.7.2/24
CE a2
Vlan-int40
10.110.9.1/24
P
Vlan-int19
192.168.8.2/24
CE a2
Vlan-int14
10.110.4.2/24
P
Loop1
2.2.2.2/32
CE a2
Vlan-int16
10.110.12.1/24
PE 1
Vlan-int12
192.168.6.1/24
CE a2
Loop1
22.22.22.22/32
PE 1
Vlan-int20
10.110.1.1/24
CE a3
Vlan-int50
10.110.10.1/24
PE 1
Vlan-int11
10.110.2.1/24
CE a3
Vlan-int17
10.110.5.2/24
PE 1
Loop1
1.1.1.1/32
CE a3
Vlan-int16
10.110.12.2/24
PE 2
Vlan-int15
192.168.7.1/24
CE b1
Vlan-int30
10.110.8.1/24
PE 2
Vlan-int13
10.110.3.1/24
CE b1
Vlan-int13
10.110.3.2/24
PE 2
Vlan-int14
10.110.4.1/24
CE b2
Vlan-int60
10.110.11.1/24
PE 2
Loop1
1.1.1.2/32
CE b2
Vlan-int18
10.110.6.2/24
1.     Configure PE 1:
# Configure a global router ID, and enable IP multicast routing on the public network.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1] multicast routing
[PE1-mrib] quit
# Create service loopback group 1, and specify the multicast tunnel service for the group.
[PE1] service-loopback group 1 type multicast-tunnel
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 11, VLAN 12, or VLAN 20.
[PE1] interface gigabitethernet 1/0/4
[PE1-GigabitEthernet1/0/4] port service-loopback group 1
[PE1-GigabitEthernet1/0/4] quit
# Configure an LSR ID, and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a and configure an RD and route targets for the VPN instance.
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-a] quit
# Enable IP multicast routing for VPN instance a.
[PE1] multicast routing vpn-instance a
[PE1-mrib-a] quit
# Create an MD for VPN instance a.
[PE1] multicast-domain vpn-instance a
# Create an MD IPv4 family address for VPN instance a.
[PE1-md-a] address-family ipv4
# Specify the default-group, the MD source interface, and the data-group range for VPN instance a.
[PE1-md-a-ipv4] default-group 239.1.1.1
[PE1-md-a-ipv4] source loopback 1
[PE1-md-a-ipv4] data-group 225.2.2.0 28
[PE1-md-a-ipv4] quit
[PE1-md-a] quit
# Assign an IP address to VLAN-interface 12.
[PE1-Vlan-interface12] ip address 192.168.6.1 24
#Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 12.
[PE1-Vlan-interface12] pim sm
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface12] quit
# Associate VLAN-interface 20 with VPN instance a.
[PE1] interface vlan-interface 20
[PE1-Vlan-interface20] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 20, and enable IGMP on the interface.
[PE1-Vlan-interface20] ip address 10.110.1.1 24
[PE1-Vlan-interface20] igmp enable
[PE1-Vlan-interface20] quit
# Associate VLAN-interface 11 with VPN instance a.
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 11, and enable PIM-SM on the interface.
[PE1-Vlan-interface11] ip address 10.110.2.1 24
[PE1-Vlan-interface11] pim sm
[PE1-Vlan-interface11] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on the interface.
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group vpn-g internal
[PE1-bgp-default] peer vpn-g connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group vpn-g
[PE1-bgp-default] peer 1.1.1.3 group vpn-g
[PE1–bgp-default] ip vpn-instance a
[PE1-bgp-default-a] address-family ipv4
[PE1-bgp-default-ipv4-a] import-route rip 2
[PE1-bgp-default-ipv4-a] import-route direct
[PE1-bgp-default-ipv4-a] quit
[PE1-bgp-default-a] quit
[PE1–bgp-default] address-family vpnv4
[PE1–bgp-default-vpnv4] peer vpn-g enable
[PE1–bgp-default-vpnv4] quit
[PE1–bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.110.1.0 0.0.0.255
[PE1-rip-2] network 10.110.2.0 0.0.0.255
[PE1-rip-2] import-route bgp
[PE1-rip-2] return
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing
[PE2-mrib] quit
[PE2] service-loopback group 1 type multicast-tunnel
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 13, VLAN 14, or VLAN 15.
[PE2] interface gigabitethernet 1/0/4
[PE2-GigabitEthernet1/0/4] port service-loopback group 1
[PE2-GigabitEthernet1/0/4] quit
# Configure an MPLS LSR ID, and enable LDP globally.
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
# Create a VPN instance named b, and configure an RD and route targets for the VPN instance.
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] route-distinguisher 200:1
[PE2-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE2-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE2-vpn-instance-b] quit
# Enable IP multicast routing for VPN instance b.
[PE2] multicast routing vpn-instance b
[PE2-mrib-b] quit
# Create an MD for VPN instance b.
[PE2] multicast-domain vpn-instance b
# Create an MD IPv4 address family for VPN instance b.
[PE2-md-b] address-family ipv4
# Specify the default-group, the MD source interface, and the data-group range for VPN instance b.
[PE2-md-b-ipv4] default-group 239.2.2.2
[PE2-md-b-ipv4] source loopback 1
[PE2-md-b-ipv4] data-group 225.4.4.0 28
[PE2-md-b-ipv4] quit
[PE2-md-b] quit
# Create a VPN instance named a, and configure an RD and route targets for VPN instance.
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] quit
[PE2] multicast routing vpn-instance a
[PE2-mrib-a] quit
[PE2] multicast-domain vpn-instance a
# Create an MD IPv4 address family for VPN instance a.
[PE2-md-a] address-family ipv4
[PE2-md-a-ipv4] default-group 239.1.1.1
[PE2-md-a-ipv4] source loopback 1
[PE2-md-a-ivp4] data-group 225.2.2.0 28
[PE2-md-a-ipv4] quit
[PE2-md-a] quit
# Assign an IP address to VLAN-interface 15.
[PE2] interface vlan-interface 15
[PE2-Vlan-interface15] ip address 192.168.7.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 15.
[PE2-Vlan-interface15] pim sm
[PE2-Vlan-interface15] mpls enable
[PE2-Vlan-interface15] mpls ldp enable
[PE2-Vlan-interface15] quit
# Associate VLAN-interface 13 with VPN instance b, assign an IP address to VLAN-interface 13, and enable PIM-SM on the interface.
[PE2] interface vlan-interface 13
[PE2-Vlan-interface13] ip binding vpn-instance b
[PE2-Vlan-interface13] ip address 10.110.3.1 24
[PE2-Vlan-interface13] pim sm
[PE2-Vlan-interface13] quit
# Associate VLAN-interface 14 with VPN instance a.
[PE2] interface vlan-interface 14
[PE2-Vlan-interface14] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 14, and enable PIM-SM on the interface.
[PE2-Vlan-interface14] ip address 10.110.4.1 24
[PE2-Vlan-interface14] pim sm
[PE2-Vlan-interface14] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 1.1.1.2 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group vpn-g internal
[PE2-bgp-default] peer vpn-g connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group vpn-g
[PE2-bgp-default] peer 1.1.1.3 group vpn-g
[PE2–bgp-default] ip vpn-instance a
[PE2-bgp-default-a] address-family ipv4
[PE2-bgp-default-ipv4-a] import-route rip 2
[PE2-bgp-default-ipv4-a] import-route direct
[PE2-bgp-default-ipv4-a] quit
[PE2-bgp-default-a] quit
[PE2–bgp-default] ip vpn-instance b
[PE2-bgp-default-b] address-family ipv4
[PE2-bgp-default-ipv4-b] import-route rip 3
[PE2-bgp-default-ipv4-b] import-route direct
[PE2-bgp-default-ipv4-b] quit
[PE2-bgp-default-b] quit
[PE2–bgp-default] address-family vpnv4
[PE2–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default-vpnv4] quit
[PE2–bgp-default] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 2 vpn-instance a
[PE2-rip-2] network 10.110.3.0 0.0.0.255
[PE2-rip-2] import-route bgp
[PE2-rip-2] quit
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.110.4.0 0.0.0.255
[PE2-rip-3] import-route bgp
[PE2-rip-3] return
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 1.1.1.3
[PE3] multicast routing
[PE3-mrib] quit
[PE3] service-loopback group 1 type multicast-tunnel
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 17, VLAN 18, or VLAN 19.
[PE3] interface gigabitethernet 1/0/4
[PE3-GigabitEthernet1/0/4] port service-loopback group 1
[PE3-GigabitEthernet1/0/4] quit
[PE3] mpls lsr-id 1.1.1.3
[PE3] mpls ldp
[PE3-ldp] quit
# Create a VPN instance named a, and configure an RD and route targets for the VPN instance.
[PE3] ip vpn-instance a
[PE3-vpn-instance-a] route-distinguisher 100:1
[PE3-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE3-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE3-vpn-instance-a] quit
[PE3] multicast routing vpn-instance a
[PE3-mrib-a] quit
[PE3] multicast-domain vpn-instance a
[PE3-md-a] address-family ipv4
[PE3-md-a-ipv4] default-group 239.1.1.1
[PE3-md-a-ipv4] source loopback 1
[PE3-md-a-ipv4] data-group 225.2.2.0 28
[PE3-md-a-ipv4] quit
[PE3-md-a] quit
[PE3] ip vpn-instance b
[PE3-vpn-instance-b] route-distinguisher 200:1
[PE3-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE3-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE3-vpn-instance-b] quit
[PE3] multicast routing vpn-instance b
[PE3-mrib-b] quit
[PE3] multicast-domain vpn-instance b
[PE3-md-b] address-family ipv4
[PE3-md-b-ipv4] default-group 239.2.2.2
[PE3-md-b-ipv4] source loopback 1
[PE3-md-b-ipv4] data-group 225.4.4.0 28
[PE3-md-b-ipv4] quit
[PE3-md-b] quit
# Assign an IP address to VLAN-interface 19.
[PE3] interface vlan-interface 19
[PE3-Vlan-interface19] ip address 192.168.8.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 19.
[PE3-Vlan-interface19] pim sm
[PE3-Vlan-interface19] mpls enable
[PE3-Vlan-interface19] mpls ldp enable
[PE3-Vlan-interface19] quit
# Associate VLAN-interface 17 with VPN instance a.
[PE3] interface vlan-interface 17
[PE3-Vlan-interface17] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 17, and enable PIM-SM on the interface.
[PE3-Vlan-interface17] ip address 10.110.5.1 24
[PE3-Vlan-interface17] pim sm
[PE3-Vlan-interface17] quit
# Associate VLAN-interface 18 with VPN instance b.
[PE3] interface vlan-interface 18
[PE3-Vlan-interface18] ip binding vpn-instance b
# Assign an IP address to VLAN-interface 18, and enable PIM-SM on the interface.
[PE3-Vlan-interface18] ip address 10.110.6.1 24
[PE3-Vlan-interface18] pim sm
[PE3-Vlan-interface18] quit
[PE3] interface loopback 1
[PE3-LoopBack1] ip address 1.1.1.3 32
[PE3-LoopBack1] pim sm
[PE3-LoopBack1] quit
# Associate Loopback 2 with VPN instance b.
[PE3] interface loopback 2
[PE3-LoopBack2] ip binding vpn-instance b
# Assign an IP address to Loopback 2, and enable PIM-SM on the interface.
[PE3-LoopBack2] ip address 33.33.33.33 32
[PE3-LoopBack2] pim sm
[PE3-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP.
[PE3] pim vpn-instance b
[PE3-pim-b] c-bsr 33.33.33.33
[PE3-pim-b] c-rp 33.33.33.33
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default] group vpn-g internal
[PE3-bgp-default] peer vpn-g connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.1 group vpn-g
[PE3-bgp-default] peer 1.1.1.2 group vpn-g
[PE3–bgp-default] ip vpn-instance a
[PE3-bgp-default-a] address-family ipv4
[PE3-bgp-default-ipv4-a] import-route rip 2
[PE3-bgp-default-ipv4-a] import-route direct
[PE3-bgp-default-ipv4-a] quit
[PE3-bgp-default-a] quit
[PE3–bgp-default] ip vpn-instance b
[PE3-bgp-default-b] address-family ipv4
[PE3-bgp-default-ipv4-b] import-route rip 3
[PE3-bgp-default-ipv4-b] import-route direct
[PE3-bgp-default-ipv4-b] quit
[PE3-bgp-default-b] quit
[PE3–bgp-default] address-family vpnv4
[PE3–bgp-default-vpnv4] peer vpn-g enable
[PE3–bgp-default-vpnv4] quit
[PE3–bgp-default] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] area 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 1.1.1.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
[PE3-ospf-1] quit
# Configure RIP.
[PE3] rip 2 vpn-instance a
[PE3-rip-2] network 10.110.5.0 0.0.0.255
[PE3-rip-2] import-route bgp
[PE3-rip-2] quit
[PE3] rip 3 vpn-instance b
[PE3-rip-3] network 10.110.6.0 0.0.0.255
[PE3-rip-3] network 33.33.33.33 0.0.0.0
[PE3-rip-3] import-route bgp
[PE3-rip-3] return
4.     Configure P:
# Enable IP multicast routing on the public network.
<P> system-view
[P] multicast routing
[P-mrib] quit
[P] mpls lsr-id 2.2.2.2
[P] mpls ldp
[P-ldp] quit
[P] interface vlan-interface 12
[P-Vlan-interface12] ip address 192.168.6.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 12.
[P-Vlan-interface12] pim sm
[P-Vlan-interface12] mpls enable
[P-Vlan-interface12] mpls ldp enable
[P-Vlan-interface12] quit
[P] interface vlan-interface 15
[P-Vlan-interface15] ip address 192.168.7.2 24
[P-Vlan-interface15] pim sm
[P-Vlan-interface15] mpls enable
[P-Vlan-interface15] mpls ldp enable
[P-Vlan-interface15] quit
[P] interface vlan-interface 19
[P-Vlan-interface19] ip address 192.168.8.2 24
[P-Vlan-interface19] pim sm
[P-Vlan-interface19] mpls enable
[P-Vlan-interface19] mpls ldp enable
[P-Vlan-interface19] quit
[P] interface loopback 1
[P-LoopBack1] ip address 2.2.2.2 32
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 2.2.2.2
[P-pim] c-rp 2.2.2.2
[P-pim] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] area 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
5.     Configure CE a1:
# Enable IP multicast routing.
<CEa1> system-view
[CEa1] multicast routing
[CEa1-mrib] quit
# Assign an IP address to VLAN-interface 10, and enable PIM-SM on the interface.
[CEa1] interface vlan-interface 10
[CEa1-Vlan-interface10] ip address 10.110.7.1 24
[CEa1-Vlan-interface10] pim sm
[CEa1-Vlan-interface10] quit
[CEa1] interface vlan-interface 11
[CEa1-Vlan-interface11] ip address 10.110.2.2 24
[CEa1-Vlan-interface11] pim sm
[CEa1-Vlan-interface11] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] network 10.110.2.0 0.0.0.255
[CEa1-rip-2] network 10.110.7.0 0.0.0.255
6.     Configure CE b1:
<CEb1> system-view
[CEb1] multicast routing
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 30, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 30
[CEb1-Vlan-interface30] ip address 10.110.8.1 24
[CEb1-Vlan-interface30] pim sm
[CEb1-Vlan-interface30] quit
# Assign an IP address to VLAN-interface 13, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 13
[CEb1-Vlan-interface13] ip address 10.110.3.2 24
[CEb1-Vlan-interface13] pim sm
[CEb1-Vlan-interface13] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-3] network 10.110.3.0 0.0.0.255
[CEb1-rip-3] network 10.110.8.0 0.0.0.255
7.     Configure CE a2:
<CEa2> system-view
[CEa2] multicast routing
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 40, and enable IGMP on the interface.
[CEa2] interface vlan-interface 40
[CEa2-Vlan-interface40] ip address 10.110.9.1 24
[CEa2-Vlan-interface40] igmp enable
[CEa2-Vlan-interface40] quit
[CEa2] interface vlan-interface 14
[CEa2-Vlan-interface14] ip address 10.110.4.2 24
[CEa2-Vlan-interface14] pim sm
[CEa2-Vlan-interface14] quit
# Assign an IP address to VLAN-interface 16, and enable PIM-SM on the interface.
[CEa2] interface vlan-interface 16
[CEa2-Vlan-interface16] ip address 10.110.12.1 24
[CEa2-Vlan-interface16] pim sm
[CEa2-Vlan-interface16] quit
[CEa2] interface loopback 1
[CEa2-LoopBack1] ip address 22.22.22.22 32
[CEa2-LoopBack1] pim sm
[CEa2-LoopBack1] quit
[CEa2] pim
[CEa2-pim] c-bsr 22.22.22.22
[CEa2-pim] c-rp 22.22.22.22
[CEa2-pim] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] network 10.110.4.0 0.0.0.255
[CEa2-rip-2] network 10.110.9.0 0.0.0.255
[CEa2-rip-2] network 10.110.12.0 0.0.0.255
[CEa2-rip-2] network 22.22.22.22 0.0.0.0
8.     Configure CE a3:
<CEa3> system-view
[CEa3] multicast routing
[CEa3-mrib] quit
# Assign an IP address to VLAN-interface 50, and enable IGMP on the interface.
[CEa3] interface vlan-interface 50
[CEa3-Vlan-interface50] ip address 10.110.10.1 24
[CEa3-Vlan-interface50] igmp enable
[CEa3-Vlan-interface50] quit
[CEa3] interface vlan-interface 17
[CEa3-Vlan-interface17] ip address 10.110.5.2 24
[CEa3-Vlan-interface17] pim sm
[CEa3-Vlan-interface17] quit
[CEa3] interface vlan-interface 16
[CEa3-Vlan-interface16] ip address 10.110.12.2 24
[CEa3-Vlan-interface16] pim sm
[CEa3-Vlan-interface16] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] network 10.110.5.0 0.0.0.255
[CEa3-rip-2] network 10.110.10.0 0.0.0.255
[CEa3-rip-2] network 10.110.12.0 0.0.0.255
9.     Configure CE b2:
<CEb2> system-view
[CEb2] multicast routing
[CEb2-mrib] quit
# Assign an IP address to VLAN-interface 60, and enable IGMP on the interface.
[CEb2] interface vlan-interface 60
[CEb2-Vlan-interface60] ip address 10.110.11.1 24
[CEb2-Vlan-interface60] igmp enable
[CEb2-Vlan-interface60] quit
[CEb2] interface vlan-interface 18
[CEb2-Vlan-interface18] ip address 10.110.6.2 24
[CEb2-Vlan-interface18] pim sm
[CEb2-Vlan-interface18] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-3] network 10.110.6.0 0.0.0.255
[CEb2-rip-3] network 10.110.11.0 0.0.0.255
# Display information about the local default-group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-domain default-group local
MD local default-group information:
 Group address    Source address   Interface     VPN instance
 239.1.1.1        1.1.1.1          MTunnel0      a
# Display information about the local default-group for IPv4 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-domain default-group local
 239.1.1.1        1.1.1.2          MTunnel0      a
 239.1.1.1        1.1.1.2          MTunnel1      b
# Display information about the local default-group for IPv4 multicast transmission in each VPN instance on PE 3.
[PE3] display multicast-domain default-group local
 239.1.1.1        1.1.1.3          MTunnel0      a
 239.2.2.2        1.1.1.3          MTunnel1      b
MD VPN inter-AS option B configuration example
As shown inFigure 15, configure MD VPN inter-AS option B to meet the following requirements:
Item
·     In VPN instance a, S 1 is a multicast source, and R 2 is a receiver.
·     In VPN instance b, S 2 is a multicast source, and R 1 is a receiver.
·     For VPN instance a, the default-group is 232.1.1.1, and the data-group range is 232.2.2.0 to 232.2.2.15. They are in the SSM group range.
·     For VPN instance b, the default-group is 232.3.3.3, and the data-group range is 232.4.4.0 to 232.4.4.15. They are in the SSM group range.
·     PE 1: VLAN-interface 11 belongs to VPN instance a. VLAN-interface 12 belongs to VPN instance b. VLAN-interface 2 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 3, VLAN-interface 4, and Loopback 1 belong to the public network instance.
·     PE 3: VLAN-interface 4, VLAN-interface 5, and Loopback 1 belong to the public network instance.
·     PE 4: VLAN-interface 13 belongs to VPN instance a. VLAN-interface 14 belongs to VPN instance b. VLAN-interface 6 and Loopback 1 belong to the public network instance.
·     Configure OSPF separately in AS 100 and AS 200, and configure OSPF between the PEs and CEs.
·     Establish IBGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
·     Configure BGP MDT peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1 and between PE 2 and PE 3 on their respective VLAN-interface 4.
·     Establish EBGP peer connections between VLAN-interface 4 on PE 2 and PE 3.
·     Configure MPLS separately in AS 100 and AS 200.
·     Enable IP multicast routing on P 1 and P 2.
·     Enable IP multicast routing on the public network on PE 1, PE 2, PE 3, and PE 4.
·     Enable IP multicast routing for VPN instance a on PE 1 and PE 4.
·     Enable IP multicast routing for VPN instance b on PE 1 and PE 4.
·     Enable IP multicast routing on CE a1, CE a2, CE b1, and CE b2.
IGMP
·     Enable IGMPv2 on VLAN-interface 23 of CE a2.
·     Enable IGMPv2 on VLAN-interface 24 of CE b2.
PIM
Enable PIM-SSM on the public network and PIM-SM on VPN instances a and b:
·     Enable PIM-SM on all interfaces of P 1 and P 2.
·     Enable PIM-SM on all public network interfaces of PE 2 and PE 3.
·     Enable PIM-SM on all public and private network interfaces of PE 1 and PE 4.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE a1, CE a2, CE b1, and CE b2.
·     Configure VLAN-interface 11 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure VLAN-interface 12 of CE b1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
RPF vector
Enable the RPF vector feature on PE 1 and PE 4.
Figure 15 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
Vlan-int2
10.1.1.1/24
PE 3
Vlan-int5
10.4.1.1/24
PE 1
Vlan-int11
11.1.1.1/24
PE 3
Vlan-int4
10.3.1.2/24
PE 1
Vlan-int12
11.2.1.1/24
PE 3
Loop1
3.3.3.3/32
PE 1
Loop1
1.1.1.1/32
PE 4
Vlan-int6
10.5.1.2/24
PE 2
Vlan-int3
10.2.1.2/24
PE 4
Vlan-int13
11.3.1.1/24
PE 2
Vlan-int4
10.3.1.1/24
PE 4
Vlan-int14
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/24
P 1
Vlan-int2
10.1.1.2/24
P 2
Vlan-int6
10.5.1.1/24
P 1
Vlan-int3
10.2.1.1/24
P 2
Vlan-int5
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
Vlan-int21
12.1.1.1/24
CE b1
Vlan-int22
12.2.1.1/24
CE a1
Vlan-int11
11.1.1.2/24
CE b1
Vlan-int12
11.2.1.2/24
CE a2
Vlan-int23
12.3.1.1/24
CE b2
Vlan-int24
12.4.1.1/24
CE a2
Vlan-int13
11.3.1.2/24
CE b2
Vlan-int14
11.4.1.2/24
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 2, VLAN 11, or VLAN 12.
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a, and configure the RD and route targets for the VPN instance.
# Enable the RPF vector feature.
[PE1-mrib-a] rpf proxy vector
[PE1-mrib-a] quit
[PE1-md-a-ipv4] default-group 232.1.1.1
[PE1-md-a-ipv4] data-group 232.2.2.0 28
[PE1-md-a] quit
# Create a VPN instance named b, and configure the RD and route targets for VPN instance.
[PE1] ip vpn-instance b
[PE1-vpn-instance-b] route-distinguisher 200:1
[PE1-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE1-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE1-vpn-instance-b] quit
[PE1] multicast routing vpn-instance b
[PE1-mrib-b] rpf proxy vector
[PE1-mrib-b] quit
[PE1] multicast-domain vpn-instance b
[PE1-md-b] address-family ipv4
[PE1-md-b-ipv4] default-group 232.3.3.3
[PE1-md-b-ivp4] source loopback 1
[PE1-md-b-ivp4] data-group 232.4.4.0 28
[PE1-md-b-ipv4] quit
[PE1-md-b] quit
# Assign an IP address to VLAN-interface 2.
[PE1-Vlan-interface2] ip address 10.1.1.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 2.
[PE1-Vlan-interface2] pim sm
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
[PE1-Vlan-interface2] quit
[PE1-Vlan-interface11] ip address 11.1.1.1 24
# Associate VLAN-interface 12 with VPN instance b.
[PE1-Vlan-interface12] ip binding vpn-instance b
# Assign an IP address to VLAN-interface 12, and enable PIM-SM on the interface.
[PE1-Vlan-interface12] ip address 11.2.1.1 24
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 1
[PE1-bgp-default-ipv4-a] import-route ospf 2
[PE1–bgp-default] ip vpn-instance b
[PE1-bgp-default-b] address-family ipv4
[PE1-bgp-default-ipv4-b] import-route ospf 3
[PE1-bgp-default-ipv4-b] import-route direct
[PE1-bgp-default-ipv4-b] quit
[PE1-bgp-default-b] quit
[PE1–bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default] address-family ipv4 mdt
[PE1-bgp-default-mdt] peer 2.2.2.2 enable
[PE1-bgp-default-mdt] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
[PE1] ospf 2 vpn-instance a
[PE1-ospf-2] area 0.0.0.0
[PE1-ospf-2-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-2-area-0.0.0.0] quit
[PE1-ospf-2] quit
[PE1] ospf 3 vpn-instance b
[PE1-ospf-3] area 0.0.0.0
[PE1-ospf-3-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[PE1-ospf-3-area-0.0.0.0] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 2.2.2.2
[PE2-mrib] quit
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
# Assign an IP address to VLAN-interface 3.
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] ip address 10.2.1.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 3.
[PE2-Vlan-interface3] pim sm
[PE2-Vlan-interface3] mpls enable
[PE2-Vlan-interface3] mpls ldp enable
[PE2-Vlan-interface3] quit
# Assign an IP address to VLAN-interface 4.
[PE2] interface vlan-interface 4
[PE2-Vlan-interface4] ip address 10.3.1.1 24
# Enable PIM-SM and MPLS on VLAN-interface 4.
[PE2-Vlan-interface4] pim sm
[PE2-Vlan-interface4] mpls enable
[PE2-Vlan-interface4] quit
[PE2-LoopBack1] ip address 2.2.2.2 32
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE2-bgp-default] peer 10.3.1.2 as-number 200
[PE2-bgp-default-vpnv4] undo policy vpn-target
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] peer 10.3.1.2 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] address-family ipv4 mdt
[PE2-bgp-default-mdt] peer 1.1.1.1 enable
[PE2-bgp-default-mdt] peer 10.3.1.2 enable
[PE2-bgp-default-mdt] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 3.3.3.3
[PE3-mrib] quit
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] quit
# Assign an IP address to VLAN-interface 5.
[PE3] interface vlan-interface 5
[PE3-Vlan-interface5] ip address 10.4.1.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 5.
[PE3-Vlan-interface5] pim sm
[PE3-Vlan-interface5] mpls enable
[PE3-Vlan-interface5] mpls ldp enable
[PE3-Vlan-interface5] quit
[PE3] interface vlan-interface 4
[PE3-Vlan-interface4] ip address 10.3.1.2 24
[PE3-Vlan-interface4] pim sm
[PE3-Vlan-interface4] mpls enable
[PE3-Vlan-interface4] quit
[PE3-LoopBack1] ip address 3.3.3.3 32
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] group 4.4.4.4 as-number 200
[PE3-bgp-default] peer 4.4.4.4 connect-interface loopback 1
[PE3-bgp-default] peer 10.3.1.1 as-number 100
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] undo policy vpn-target
[PE3-bgp-default-vpnv4] peer 4.4.4.4 enable
[PE3-bgp-default-vpnv4] peer 10.3.1.1 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default] address-family ipv4 mdt
[PE3-bgp-default-mdt] peer 4.4.4.4 enable
[PE3-bgp-default-mdt] peer 10.3.1.1 enable
[PE3-bgp-default-mdt] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 4.4.4.4
[PE4] multicast routing
[PE4-mrib] quit
[PE4] service-loopback group 1 type multicast-tunnel
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 6, VLAN 13, or VLAN 14.
[PE4] interface gigabitethernet 1/0/4
[PE4-GigabitEthernet1/0/4] port service-loopback group 1
[PE4-GigabitEthernet1/0/4] quit
[PE4] mpls lsr-id 4.4.4.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] ip vpn-instance a
[PE4-vpn-instance-a] route-distinguisher 100:1
[PE4-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE4-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE4-vpn-instance-a] quit
[PE4] multicast routing vpn-instance a
[PE4-mrib-a] rpf proxy vector
[PE4-mrib-a] quit
[PE4] multicast-domain vpn-instance a
[PE4-md-a] address-family ipv4
[PE4-md-a-ipv4] default-group 232.1.1.1
[PE4-md-a-ipv4] source loopback 1
[PE4-md-a-ipv4] data-group 232.2.2.0 28
[PE4-md-a-ipv4] quit
[PE4-md-a] quit
# Create a VPN instance named b, and configure the RD and route targets for the VPN instance.
[PE4] ip vpn-instance b
[PE4-vpn-instance-b] route-distinguisher 200:1
[PE4-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE4-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE4-vpn-instance-b] quit
[PE4] multicast routing vpn-instance b
[PE4-mrib-b] rpf proxy vector
[PE4-mrib-b] quit
[PE4] multicast-domain vpn-instance b
[PE4-md-b] address-family ipv4
[PE4-md-b-ipv4] default-group 232.3.3.3
[PE4-md-b-ipv4] source loopback 1
[PE4-md-b-ipv4] data-group 232.4.4.0 28
[PE4-md-b-ipv4] quit
[PE4-md-b] quit
# Assign an IP address to VLAN-interface 6.
[PE4] interface vlan-interface 6
[PE4-Vlan-interface6] ip address 10.5.1.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 6.
[PE4-Vlan-interface6] pim sm
[PE4-Vlan-interface6] mpls enable
[PE4-Vlan-interface6] mpls ldp enable
[PE4-Vlan-interface6] quit
# Associate VLAN-interface 13 with VPN instance a.
[PE4] interface vlan-interface 13
[PE4-Vlan-interface13] ip binding vpn-instance a
[PE4-Vlan-interface13] ip address 11.3.1.1 24
[PE4-Vlan-interface13] pim sm
[PE4-Vlan-interface13] quit
# Associate VLAN-interface 14 with VPN instance b.
[PE4] interface vlan-interface 14
[PE4-Vlan-interface14] ip binding vpn-instance b
[PE4-Vlan-interface14] ip address 11.4.1.1 24
[PE4-Vlan-interface14] pim sm
[PE4-Vlan-interface14] quit
[PE4] interface loopback 1
[PE4-LoopBack1] ip address 4.4.4.4 32
[PE4-LoopBack1] pim sm
[PE4-LoopBack1] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] peer 3.3.3.3 as-number 200
[PE4-bgp-default] peer 3.3.3.3 connect-interface loopback 1
[PE4–bgp-default] ip vpn-instance a
[PE4-bgp-default-a] address-family ipv4
[PE4-bgp-default-ipv4-a] import-route ospf 2
[PE4-bgp-default-ipv4-a] import-route direct
[PE4-bgp-default-ipv4-a] quit
[PE4-bgp-default-a] quit
[PE4–bgp-default] ip vpn-instance b
[PE4-bgp-default-b] address-family ipv4
[PE4-bgp-default-ipv4-b] import-route ospf 3
[PE4-bgp-default-ipv4-b] import-route direct
[PE4-bgp-default-ipv4-b] quit
[PE4-bgp-default-b] quit
[PE4–bgp-default] address-family vpnv4
[PE4–bgp-default-vpnv4] peer 3.3.3.3 enable
[PE4–bgp-default-vpnv4] quit
[PE4-bgp-default] address-family ipv4 mdt
[PE4-bgp-default-mdt] peer 3.3.3.3 enable
[PE4-bgp-default-mdt] quit
[PE4–bgp-default] quit
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] area 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[PE4-ospf-1-area-0.0.0.0] quit
[PE4-ospf-1] quit
[PE4] ospf 2 vpn-instance a
[PE4-ospf-2] area 0.0.0.0
[PE4-ospf-2-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[PE4-ospf-2-area-0.0.0.0] quit
[PE4-ospf-2] quit
[PE4] ospf 3 vpn-instance b
[PE4-ospf-3] area 0.0.0.0
[PE4-ospf-3-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[PE4-ospf-3-area-0.0.0.0] quit
[PE4-ospf-3] quit
5.     Configure P 1:
<P1> system-view
[P1] multicast routing
[P1-mrib] quit
[P1] mpls lsr-id 5.5.5.5
[P1] mpls ldp
[P1-ldp] quit
[P1] interface vlan-interface 2
[P1-Vlan-interface2] ip address 10.1.1.2 24
[P1-Vlan-interface2] pim sm
[P1-Vlan-interface2] mpls enable
[P1-Vlan-interface2] mpls ldp enable
[P1-Vlan-interface2] quit
[P1] interface vlan-interface 3
[P1-Vlan-interface3] ip address 10.2.1.1 24
[P1-Vlan-interface3] pim sm
[P1-Vlan-interface3] mpls enable
[P1-Vlan-interface3] mpls ldp enable
[P1-Vlan-interface3] quit
[P1] interface loopback 1
[P1-LoopBack1] ip address 5.5.5.5 32
[P1-LoopBack1] pim sm
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
[P1-ospf-1] area 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
6.     Configure P 2:
<P2> system-view
[P2] multicast routing
[P2-mrib] quit
[P2] mpls lsr-id 6.6.6.6
[P2] mpls ldp
[P2-ldp] quit
[P2] interface vlan-interface 6
[P2-Vlan-interface6] ip address 10.5.1.1 24
[P2-Vlan-interface6] pim sm
[P2-Vlan-interface6] mpls enable
[P2-Vlan-interface6] mpls ldp enable
[P2-Vlan-interface6] quit
[P2] interface vlan-interface 5
[P2-Vlan-interface5] ip address 10.4.1.2 24
[P2-Vlan-interface5] pim sm
[P2-Vlan-interface5] mpls enable
[P2-Vlan-interface5] mpls ldp enable
[P2-Vlan-interface5] quit
[P2] interface loopback 1
[P2-LoopBack1] ip address 6.6.6.6 32
[P2-LoopBack1] pim sm
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
[P2-ospf-1] area 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 6.6.6.6 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Assign an IP address to VLAN-interface 21, and enable PIM-SM on the interface.
[CEa1] interface vlan-interface 21
[CEa1-Vlan-interface21] ip address 12.1.1.1 24
[CEa1-Vlan-interface21] pim sm
[CEa1-Vlan-interface21] quit
[CEa1-Vlan-interface11] ip address 11.1.1.2 24
# Configure VLAN-interface 11 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 11.1.1.2
[CEa1-pim] c-rp 11.1.1.2
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] area 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] quit
[CEa1-ospf-1] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 22, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 22
[CEb1-Vlan-interface22] ip address 12.2.1.1 24
[CEb1-Vlan-interface22] pim sm
[CEb1-Vlan-interface22] quit
[CEb1] interface vlan-interface 12
[CEb1-Vlan-interface12] ip address 11.2.1.2 24
[CEb1-Vlan-interface12] pim sm
[CEb1-Vlan-interface12] quit
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[CEb1] pim
[CEb1-pim] c-bsr 11.2.1.2 24
[CEb1-pim] c-rp 11.2.1.2 24
[CEb1-pim] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] area 0.0.0.0
[CEb1-ospf-1-area-0.0.0.0] network 12.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] quit
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 23, and enable IGMP on the interface.
[CEa2] interface vlan-interface 23
[CEa2-Vlan-interface23] ip address 12.3.1.1 24
[CEa2-Vlan-interface23] igmp enable
[CEa2-Vlan-interface23] quit
[CEa2] interface vlan-interface 13
[CEa2-Vlan-interface13] ip address 11.3.1.2 24
[CEa2-Vlan-interface13] pim sm
[CEa2-Vlan-interface13] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] area 0.0.0.0
[CEa2-ospf-1-area-0.0.0.0] network 12.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] quit
[CEa2-ospf-1] quit
10.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
# Assign an IP address to VLAN-interface 24, and enable IGMP on the interface.
[CEb2] interface vlan-interface 24
[CEb2-Vlan-interface24] ip address 12.4.1.1 24
[CEb2-Vlan-interface24] igmp enable
[CEb2-Vlan-interface24] quit
[CEb2] interface vlan-interface 14
[CEb2-Vlan-interface14] ip address 11.4.1.2 24
[CEb2-Vlan-interface14] pim sm
[CEb2-Vlan-interface14] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] area 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 12.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] quit
[CEb2-ospf-1] quit
 232.1.1.1        1.1.1.1          MTunnel0      a
 232.3.3.3        1.1.1.1          MTunnel1      b
# Display information about the remote default-group group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-domain default-group remote
MD remote default-group information:
 Group address   Source address  Next hop         VPN instance
 232.1.1.1       4.4.4.4         2.2.2.2          a
 232.3.3.3       4.4.4.4         2.2.2.2          b
# Display information about the local default-group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-domain default-group local
 232.1.1.1        4.4.4.4          MTunnel0      a
 233.3.3.3        4.4.4.4          MTunnel1      b
# Display information about the remote default-group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-domain default-group remote
 232.1.1.1       1.1.1.1         3.3.3.3          a
 232.3.3.3       1.1.1.1         3.3.3.3          b
MD VPN inter-AS option C configuration example
As shown in Figure 16, configure MD VPN inter-AS option C to meet the following requirements:
Item
·     For VPN instance a, the default-group is 239.1.1.1, and the data-group range is 225.1.1.0 to 225.1.1.15.
·     For VPN instance b, the default-group is 239.4.4.4, and the data-group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PE devices belong
·     PE 1: VLAN-interface 11 belongs to VPN instance b. VLAN-interface 12 belongs to VPN instance a. VLAN-interface 2 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 2, VLAN-interface 3, Loopback 1, and Loopback 2 belong to the public network instance.
·     PE 3: VLAN-interface 3, VLAN-interface 4, Loopback 1, and Loopback 2 belong to the public network instance.
·     PE 4: VLAN-interface 13 belongs to VPN instance a. VLAN-interface 14 belongs to VPN instance b. VLAN-interface 4 and Loopback 1 belong to the public network instance.
·     Establish BGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
IGMP
·     Enable IGMPv2 on VLAN-interface 30 of CE a2.
·     Enable IGMPv2 on VLAN-interface 40 of CE b2.
PIM
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts of CE a1, CE a2, CE b1, and CE b2.
·     Configure Loopback 2 of PE 2 and PE 3 as a C-BSR and a C-RP for their own AS to provide services for all multicast groups.
·     Configure Loopback 0 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 0 of CE b1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
MSDP
Establish an MSDP peering relationship between PE 2 and PE 3 on their Loopback 1.
Figure 16 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.11.5.2/24
R 1
10.11.8.2/24
S 2
10.11.6.2/24
R 2
10.11.7.2/24
PE 1
Vlan-int2
10.10.1.1/24
PE 3
Vlan-int4
10.10.2.1/24
PE 1
Vlan-int11
10.11.1.1/24
PE 3
Vlan-int3
192.168.1.2/24
PE 1
Vlan-int12
10.11.2.1/24
PE 3
Loop1
1.1.1.3/32
PE 1
Loop1
1.1.1.1/32
PE 3
Loop2
22.22.22.22/32
PE 2
Vlan-int2
10.10.1.2/24
PE 4
Vlan-int4
10.10.2.2/24
PE 2
Vlan-int3
192.168.1.1/24
PE 4
Vlan-int13
10.11.3.1/24
PE 2
Loop1
1.1.1.2/32
PE 4
Vlan-int14
10.11.4.1/32
PE 2
Loop2
11.11.11.11/32
PE 4
Loop1
1.1.1.4/32
CE a1
Vlan-int10
10.11.5.1/24
CE b1
Vlan-int20
10.11.6.1/24
CE a1
Vlan-int11
10.11.1.2/24
CE b1
Vlan-int12
10.11.2.2/24
CE a1
Loop0
2.2.2.2/32
CE b2
Vlan-int40
10.11.8.1/24
CE a2
Vlan-int30
10.11.7.1/24
CE b2
Vlan-int14
10.11.4.2/24
CE a2
Vlan-int13
10.11.3.2/24
CE b2
Loop0
3.3.3.3/32
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-mrib-a] quit
[PE1-md-a-ipv4] data-group 225.1.1.0 28
[PE1-md-a] quit
[PE1-mrib-b] quit
[PE1-md-b-ipv4] default-group 239.4.4.4
[PE1-md-b-ipv4] source loopback 1
[PE1-md-b-ivp4] data-group 225.4.4.0 28
[PE1-md-b] quit
[PE1-Vlan-interface2] ip address 10.10.1.1 24
[PE1-Vlan-interface11] ip address 10.11.1.1 24
[PE1-Vlan-interface12] ip address 10.11.2.1 24
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group pe1-pe2 internal
[PE1-bgp-default] peer pe1-pe2 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group pe1-pe2
[PE1-bgp-default] group pe1-pe4 external
[PE1-bgp-default] peer pe1-pe4 as-number 200
[PE1-bgp-default] peer pe1-pe4 ebgp-max-hop 255
[PE1-bgp-default] peer pe1-pe4 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.4 group pe1-pe4
[PE1–bgp-default] address-family ipv4
[PE1-bgp-default-ipv4] peer pe1-pe2 enable
[PE1-bgp-default-ipv4] peer pe1-pe2 label-route-capability
[PE1-bgp-default-ipv4] quit
[PE1–bgp-default-vpnv4] peer pe1-pe4 enable
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE1-ospf-1] quit
[PE1-ospf-2] import-route bgp
[PE1-ospf-2-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[PE1-ospf-2] quit
[PE1-ospf-3] import-route bgp
[PE1-ospf-3-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2-mrib] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface vlan-interface 2
[PE2-Vlan-interface2] ip address 10.10.1.2 24
[PE2-Vlan-interface2] pim sm
[PE2-Vlan-interface2] mpls enable
[PE2-Vlan-interface2] mpls ldp enable
[PE2-Vlan-interface2] quit
[PE2-Vlan-interface3] ip address 192.168.1.1 24
# Enable PIM-SM and MPLS on VLAN-interface 3.
[PE2] interface loopback 2
[PE2-LoopBack2] ip address 11.11.11.11 32
[PE2-LoopBack2] pim sm
[PE2-LoopBack2] quit
[PE2] pim
[PE2-pim] c-bsr 11.11.11.11
[PE2-pim] c-rp 11.11.11.11
[PE2-pim] quit
# Configure VLAN-interface 3 as a PIM-SM domain border.
[PE2-Vlan-interface3] pim bsr-boundary
# Establish an MSDP peering relationship.
[PE2] msdp
[PE2-msdp] encap-data-enable
[PE2-msdp] peer 1.1.1.3 connect-interface loopback 1
# Configure a static route.
[PE2] ip route-static 1.1.1.3 32 vlan-interface 3 192.168.1.2
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group pe2-pe1 internal
[PE2-bgp-default] peer pe2-pe1 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group pe2-pe1
[PE2-bgp-default] group pe2-pe3 external
[PE2-bgp-default] peer pe2-pe3 as-number 200
[PE2-bgp-default] peer pe2-pe3 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.3 group pe2-pe3
[PE2-bgp-default-ipv4] peer pe2-pe1 enable
[PE2-bgp-default-ipv4] peer pe2-pe1 route-policy map2 export
[PE2-bgp-default-ipv4] peer pe2-pe1 label-route-capability
[PE2-bgp-default-ipv4] peer pe2-pe3 enable
[PE2-bgp-default-ipv4] peer pe2-pe3 route-policy map1 export
[PE2-bgp-default-ipv4] peer pe2-pe3 label-route-capability
[PE2-bgp-default-ipv4] import-route ospf 1
[PE2-bgp-default-ipv4] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 11.11.11.11 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3-mrib] quit
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Vlan-interface4] ip address 10.10.2.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 4.
[PE3-Vlan-interface4] mpls ldp enable
[PE3] interface vlan-interface 3
[PE3-Vlan-interface3] ip address 192.168.1.2 24
[PE3-Vlan-interface3] pim sm
[PE3-Vlan-interface3] mpls enable
[PE3-Vlan-interface3] quit
[PE3-LoopBack2] ip address 22.22.22.22 32
[PE3] pim
[PE3-pim] c-bsr 22.22.22.22
[PE3-pim] c-rp 22.22.22.22
[PE3-pim] quit
[PE3-Vlan-interface3] pim bsr-boundary
[PE3] msdp
[PE3-msdp] encap-data-enable
[PE3-msdp] peer 1.1.1.2 connect-interface loopback 1
[PE3] ip route-static 1.1.1.2 32 vlan-interface 3 192.168.1.1
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] group pe3-pe4 internal
[PE3-bgp-default] peer pe3-pe4 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.4 group pe3-pe4
[PE3-bgp-default] group pe3-pe2 external
[PE3-bgp-default] peer pe3-pe2 as-number 100
[PE3-bgp-default] peer pe3-pe2 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.2 group pe3-pe2
[PE3-bgp-default-ipv4] peer pe3-pe4 enable
[PE3-bgp-default-ipv4] peer pe3-pe4 route-policy map2 export
[PE3-bgp-default-ipv4] peer pe3-pe4 label-route-capability
[PE3-bgp-default-ipv4] peer pe3-pe2 enable
[PE3-bgp-default-ipv4] peer pe3-pe2 route-policy map1 export
[PE3-bgp-default-ipv4] peer pe3-pe2 label-route-capability
[PE3-bgp-default-ipv4] import-route ospf 1
[PE3-bgp-default-ipv4] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 22.22.22.22 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 1.1.1.4
[PE4-mrib] quit
# Assign GigabitEthernet 1/0/4 to service loopback group 1. The interface does not belong to VLAN 4, VLAN 13, or VLAN 14.
[PE4] mpls lsr-id 1.1.1.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4-mrib-a] quit
[PE4-md-a-ipv4] default-group 239.1.1.1
[PE4-md-a-ivp4] source loopback 1
[PE4-md-a-ivp4] data-group 225.1.1.0 28
[PE4-md-a] quit
[PE4-mrib-b] quit
[PE4-md-b-ipv4] default-group 239.4.4.4
[PE4-md-b-ivp4] data-group 225.4.4.0 28
[PE4-md-b] quit
[PE4] interface vlan-interface 4
[PE4-Vlan-interface4] ip address 10.10.2.2 24
[PE4-Vlan-interface4] pim sm
[PE4-Vlan-interface4] mpls enable
[PE4-Vlan-interface4] mpls ldp enable
[PE4-Vlan-interface4] quit
[PE4-Vlan-interface13] ip address 10.11.3.1 24
[PE4-Vlan-interface14] ip address 10.11.4.1 24
[PE4-LoopBack1] ip address 1.1.1.4 32
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] group pe4-pe3 internal
[PE4-bgp-default] peer pe4-pe3 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.3 group pe4-pe3
[PE4-bgp-default] group pe4-pe1 external
[PE4-bgp-default] peer pe4-pe1 as-number 100
[PE4-bgp-default] peer pe4-pe1 ebgp-max-hop 255
[PE4-bgp-default] peer pe4-pe1 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.1 group pe4-pe1
[PE4–bgp-default] address-family ipv4
[PE4-bgp-default-ipv4] peer pe4-pe3 enable
[PE4-bgp-default-ipv4] peer pe4-pe3 label-route-capability
[PE4-bgp-default-ipv4] quit
[PE4–bgp-default-vpnv4] peer pe4-pe1 enable
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1-area-0.0.0.0] network 1.1.1.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE4-ospf-1] quit
[PE4-ospf-2] import-route bgp
[PE4-ospf-2-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[PE4-ospf-2] quit
[PE4-ospf-3] import-route bgp
[PE4-ospf-3-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[PE4-ospf-3] quit
5.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
[CEa1-Vlan-interface10] ip address 10.11.5.1 24
[CEa1-Vlan-interface11] ip address 10.11.1.2 24
[CEa1] interface loopback 1
[CEa1-LoopBack1] ip address 2.2.2.2 32
[CEa1-LoopBack1] pim sm
[CEa1-LoopBack1] quit
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 10.11.5.0 0.0.0.255
[CEa1-ospf-1] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 20, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 20
[CEb1-Vlan-interface20] ip address 10.11.6.1 24
[CEb1-Vlan-interface20] pim sm
[CEb1-Vlan-interface20] quit
[CEb1-Vlan-interface12] ip address 10.11.2.2 24
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 10.11.6.0 0.0.0.255
[CEb1-ospf-1] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 30, and enable IGMP on the interface.
[CEa2] interface vlan-interface 30
[CEa2-Vlan-interface30] ip address 10.11.7.1 24
[CEa2-Vlan-interface30] igmp enable
[CEa2-Vlan-interface30] quit
[CEa2-Vlan-interface13] ip address 10.11.3.2 24
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 10.11.7.0 0.0.0.255
[CEa2-ospf-1] quit
8.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
[CEb2] interface vlan-interface 40
[CEb2-Vlan-interface40] ip address 10.11.8.1 24
[CEb2-Vlan-interface40] igmp enable
[CEb2-Vlan-interface40] quit
[CEb2-Vlan-interface14] ip address 10.11.4.2 24
[CEb2] interface loopback 1
[CEb2-LoopBack1] ip address 3.3.3.3 32
[CEb2-LoopBack1] pim sm
[CEb2-LoopBack1] quit
[CEb2] pim
[CEb2-pim] c-bsr 3.3.3.3
[CEb2-pim] c-rp 3.3.3.3
[CEb2-pim] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 10.11.8.0 0.0.0.255
[CEb2-ospf-1] quit
 239.4.4.4        1.1.1.1          MTunnel1      b
 239.1.1.1        1.1.1.4          MTunnel0      a
 239.4.4.4        1.1.1.4          MTunnel1      b
Troubleshooting MD VPN
This section describes common MD VPN problems and how to troubleshoot them.
A default-MDT cannot be established
Symptom
The default-MDT cannot be established. PIM neighboring relationship cannot be established between PE devices' interfaces that are in the same VPN instance.
Solution
To resolve the problem:
1.     Use the display interface command to examine the MTI interface state and address encapsulation on the MTI.
2.     Use the display multicast-domain default-group command to verify that the same default-group address has been configured for the same VPN instance on different PE devices.
3.     Use the display pim interface command to verify the following:
¡     PIM is enabled on a minimum of one interface of the same VPN on different PE devices.
¡     The same PIM mode is running on all the interfaces of the same VPN instance on different PE devices and on all the interfaces of the P router.
4.     Use the display ip routing-table command to verify that a unicast route exists from the VPN instance on the local PE device to the same VPN instance on each remote PE device.
5.     Use the display bgp peer command to verify that the BGP peer connections have been correctly configured.
6.     If the problem persists, contact H3C Support.
An MVRF cannot be created
Symptom
A VPN instance cannot create an MVRF correctly.
Solution
1.     Use the display pim bsr-info command to verify that the BSR information exists on the public network and VPN instance. If it does not, verify that a unicast route exists to the BSR.
2.     Use the display pim rp-info command to examine the RP information. If no RP information is available, verify that a unicast route exists to the RP. Use the display pim neighbor command to verify that the PIM adjacencies have been correctly established on the public network and the VPN.
3.     Use the ping command to examine the connectivity between the VPN DR and the VPN RP.
4.     If the problem persists, contact H3C Support.
