06-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18206-Layer 3 - IP Services Configuration Guide
03-DHCP Configuration
03-DHCP Configuration 655.18 KB
DHCP overview·· 1
DHCP address allocation· 1
Allocation mechanisms 1
Dynamic IP address allocation process 2
IP address lease extension· 2
DHCP message format 3
DHCP options 4
DHCP options overview·· 4
Introduction to DHCP options 4
Self-defined options 5
Protocols and standards 8
Configuring the DHCP server 10
Overview·· 10
Application environment 10
DHCP address pool 10
IP address allocation sequence· 11
DHCP server configuration task list 12
Configuring an address pool for the DHCP server 12
Configuration task list 12
Creating a DHCP address pool 13
Configuring address allocation mode for a common address pool 13
Configuring dynamic address allocation for an extended address pool 15
Configuring a domain name suffix for the client 16
Configuring DNS servers for the client 16
Configuring WINS servers and NetBIOS node type for the client 17
Configuring BIMS server information for the client 17
Configuring gateways for the client 18
Configuring Option 184 parameters for the client with voice service· 18
Configuring the TFTP server and bootfile name for the client 19
Specifying a server's IP address for the DHCP client 19
Configuring self-defined DHCP options 20
Enabling DHCP· 21
Enabling the DHCP server on an interface· 21
Applying an extended address pool on an interface· 21
Configuring the DHCP server security functions 22
Configuration prerequisites 22
Enabling unauthorized DHCP server detection· 22
Configuring IP address conflict detection· 22
Configuring the DHCP server to support authorized ARP· 23
Enabling client offline detection· 24
Enabling Option 82 handling· 24
Configuration prerequisites 24
Enabling Option 82 handling· 25
Specifying the threshold for sending trap messages 25
Configuration prerequisites 25
Configuration procedure· 25
Displaying and maintaining the DHCP server 25
DHCP server configuration examples 26
Static IP address assignment configuration example· 27
Dynamic IP address assignment configuration example· 28
Self-defined option configuration example· 29
Troubleshooting DHCP server configuration· 30
Symptom·· 30
Analysis 30
Solution· 31
Configuring the DHCP relay agent 32
Introduction to DHCP relay agent 32
Application environment 32
Fundamentals 32
DHCP relay agent support for Option 82· 33
DHCP relay agent configuration task list 34
Enabling DHCP· 34
Enabling the DHCP relay agent on an interface· 34
Correlating a DHCP server group with a relay agent interface· 35
Configuration guidelines 35
Configuration procedure· 35
Configuring the DHCP relay agent security functions 36
Configuring address check· 36
Configuring periodic refresh of dynamic client entries 37
Configuring the DHCP relay agent to support authorized ARP· 37
Enabling unauthorized DHCP server detection· 38
Enabling DHCP starvation attack protection· 38
Enabling client offline detection· 39
Configuring the DHCP relay agent to release an IP address 40
Configuring the DHCP relay agent to support Option 82· 40
Configuration prerequisites 40
Configuration guidelines 40
Configuration procedure· 41
Displaying and maintaining the DHCP relay agent 41
DHCP relay agent configuration examples 42
DHCP relay agent configuration example· 42
DHCP relay agent Option 82 support configuration example· 44
Troubleshooting DHCP relay agent configuration· 44
Symptom·· 44
Analysis 44
Solution· 45
Configuring DHCP client 46
Enabling the DHCP client on an interface· 46
Configuration guidelines 46
Configuration procedure· 46
Displaying and maintaining the DHCP client 47
DHCP client configuration example· 47
Network requirements 47
Configuration procedure· 48
Verifying the configuration· 48
Configuring DHCP snooping· 50
Overview·· 50
DHCP snooping functions 50
Application environment of trusted ports 51
DHCP snooping support for Option 82· 52
Configuring DHCP snooping basic functions 53
Configuration guidelines 53
Configuration procedure· 53
Configuring DHCP snooping to support Option 82· 54
Configuration guidelines 54
Configuration procedure· 54
Configuring DHCP snooping entries backup· 56
Enabling DHCP starvation attack protection· 57
Enabling DHCP-request message attack protection· 57
Displaying and maintaining DHCP snooping· 58
DHCP snooping configuration examples 59
DHCP snooping configuration example· 59
DHCP snooping Option 82 support configuration example· 59
DHCP overview
The Dynamic Host Configuration Protocol (DHCP) provides a framework to assign configuration information to network devices.
A DHCP client can obtain an IP address and other configuration parameters from a DHCP server on another subnet through a DHCP relay agent. For information about the DHCP relay agent, see "Configuring the DHCP relay agent."
The term "router" in this document refers to both routers and Layer 3 switches.
Figure 1 A typical DHCP application
DHCP supports the following mechanisms for IP address allocation:
·     Manual allocationThe network administrator assigns an IP address to a client such as a WWW server, and DHCP conveys the assigned address to the client.
·     Automatic allocationDHCP assigns a permanent IP address to a client.
·     Dynamic allocationDHCP assigns an IP address to a client for a limited period of time, which is called a lease. Most DHCP clients obtain their addresses in this way.
Figure 2 Dynamic IP address allocation process
As shown in Figure 2, a DHCP client obtains an IP address from a DHCP server by using the four steps:
1.     The client broadcasts a DHCP-DISCOVER message to locate a DHCP server.
2.     A DHCP server offers configuration parameters such as an IP address to the client in a DHCP-OFFER message. The sending mode of the DHCP-OFFER is determined by the flag field in the DHCP-DISCOVER message. For related information, see "DHCP message format."
3.     If several DHCP servers send offers to the client, the client accepts the first received offer, and broadcasts it in a DHCP-REQUEST message to formally request the IP address.
4.     All DHCP servers receive the DHCP-REQUEST message, but only the server from which the client accepts the offered IP address returns a DHCP-ACK message to the client, confirming that the IP address has been allocated to the client, or returns a DHCP-NAK unicast message, denying the IP address allocation.
After the client receives the DHCP-ACK message, it broadcasts a gratuitous ARP packet to verify whether the IP address assigned by the server is in use. If the client receives no response within the specified time, the client can use this IP address. Otherwise, the client sends a DHCP-DECLINE message to the server and requests an IP address again.
IP addresses offered by other DHCP servers are still assignable to other clients.
The IP address dynamically allocated by a DHCP server to a client has a lease. When the lease expires, the IP address is reclaimed by the DHCP server. To continue using the IP address, the client must extend the lease duration.
After half the lease duration, the DHCP client sends a DHCP-REQUEST unicast to the DHCP server to extend the lease duration. Depending on availability of the IP address, the DHCP server returns a DHCP-ACK unicast confirming that the client's lease duration has been extended, or a DHCP-NAK unicast denying the request.
If the client receives no reply, it broadcasts another DHCP-REQUEST for lease extension after 7/8 lease duration. Again, depending on availability of the IP address, the DHCP server returns a DHCP-ACK unicast confirming that the client's lease has been extended, or a DHCP-NAK unicast denying the request.
DHCP message format
Figure 3 shows the DHCP message format, which is based on the BOOTP message format although DHCP uses some of the fields in significantly different ways. The numbers in parentheses indicate the size of each field in bytes.
Figure 3 DHCP message format
·     opMessage type defined in option field. 1 = REQUEST, 2 = REPLY
·     htype, hlenHardware address type and length of a DHCP client.
·     hopsNumber of relay agents a request message traveled.
·     xidTransaction ID, a random number chosen by the client to identify an IP address allocation.
·     secsFilled in by the client, the number of seconds elapsed since the client began address acquisition or renewal process. This field is reserved and set to 0.
·     flagsThe leftmost bit is defined as the BROADCAST (B) flag. If this flag is set to 0, the DHCP server sent a reply back by unicast. If this flag is set to 1, the DHCP server sent a reply back by broadcast. The remaining bits of the flags field are reserved for future use.
·     ciaddrClient IP address.
·     yiaddr—"Your" (client) IP address, assigned by the server.
·     siaddrServer IP address, from which the clients obtained configuration parameters.
·     giaddrIP address of the first relay agent a request message traveled.
·     chaddrClient hardware address.
·     snameThe server host name, from which the client obtained configuration parameters.
·     fileBootfile name and path information, defined by the server to the client.
·     optionsOptional parameters field that is variable in length, which includes the message type, lease, domain name server IP address, and WINS IP address.
DHCP options
DHCP uses the same message format as BOOTP, but DHCP uses the Option field to carry information about dynamic address allocation and to provide additional configuration information to clients.
Figure 4 DHCP option format
The common DHCP options are as follows:
·     Option 3Router option. It specifies the gateway address to be assigned to the client.
·     Option 6DNS server option. It specifies the DNS server IP address to be assigned to the client.
·     Option 33Static route option. It specifies a list of classful static routes (the destination addresses in these static routes are classful.) that a client should add into its routing table. If both Option 33 and Option 121 exist, Option 33 is ignored.
·     Option 51IP address lease option.
·     Option 53DHCP message type option. It identifies the type of the DHCP message.
·     Option 55Parameter request list option. It is used by a DHCP client to request specified configuration parameters. The option contains values that correspond to the parameters requested by the client.
·     Option 60Vendor class identifier option. It is used by a DHCP client to identify its vendor, and by a DHCP server to distinguish DHCP clients by vendor class and assign specific IP addresses for the DHCP clients.
·     Option 66TFTP server name option. It specifies a TFTP server to be assigned to the client.
·     Option 67Bootfile name option. It specifies the bootfile name to be assigned to the client.
·     Option 150TFTP server IP address option. It specifies the TFTP server IP address to be assigned to the client.
·     Option 121Classless route option. It specifies a list of classless static routes (the destination addresses in these static routes are classless) that the requesting client should add into its routing table. If both Option 33 and Option 121 exist, Option 33 is ignored.
For more information about DHCP options, see RFC 2132 and RFC 3442.
Some options, such as Option 43, have no unified definitions in RFC 2132.
Vendor-specific option (Option 43)
DHCP servers and clients use Option 43 to exchange vendor-specific configuration information.
The DHCP client can obtain the following information through Option 43:
·     Auto-Configuration Server (ACS) parameters, including the ACS URL, username, and password.
·     Service provider identifier acquired by the customer premises equipment (CPE) from the DHCP server and sent to the ACS for selecting vender-specific configurations and parameters.
·     Preboot Execution Environment (PXE) server address for further obtaining the bootfile or other control information from the PXE server.
1.     Format of Option 43
Figure 5 Option 43 format
Network configuration parameters are carried in different sub-options of Option 43 as shown in Figure 5. The sub-option fields are described as follows:
¡     Sub-option typeType of a sub-option. The field value can be 0x01, 0x02, or 0x80. 0x01 indicates an ACS parameter sub-option. 0x02 indicates a service provider identifier sub-option. 0x80 indicates a PXE server address sub-option.
¡     Sub-option lengthLength of a sub-option excluding the sub-option type and sub-option length fields.
¡     Sub-option valueValue of a sub-option. The value format varies with sub-options.
2.     Format of the sub-option value field of Option 43
¡     As shown in Figure 6, the value field of the ACS parameter sub-option is filled in with variable ACS URL, username, and password separated with a space (0x20) in between.
Figure 6 ACS parameter sub-option value field
¡     The value field of the service provider identifier sub-option contains the service provider identifier.
¡     Figure 7 shows the format of the value field of the PXE server address sub-option. The value of the PXE server type can only be 0. The server number field indicates the number of PXE servers contained in the sub-option. The server IP addresses filed contains the IP addresses of the PXE servers.
Figure 7 PXE server address sub-option value field
Relay agent option (Option 82)
Option 82 is the relay agent option in the option field of the DHCP message. It records the location information about the DHCP client. When a DHCP relay agent or DHCP snooping switch receives a client's request, it adds Option 82 to the request message and sends it to the server.
The administrator can locate the DHCP client to further implement security control and accounting. The Option 82 supporting server can also use such information to define individual assignment policies of IP address and other parameters for the clients.
Option 82 involves at most 255 sub-options. At least one sub-option must be defined. DHCP relay agent supports two sub-options: sub-option 1 (Circuit ID) and sub-option 2 (Remote ID). A DHCP snooping device supports three sub-options: sub-option 1 (Circuit ID), sub-option 2 (Remote ID), and sub-option 9.
Option 82 has no unified definition. Its padding formats vary with vendors.
There are two methods for configuring Option 82:
·     User-defined methodManually specify the content of Option 82.
·     Non-user-defined methodPad Option 82 in the default normal or verbose format, private format, or standard format.
If you choose the second method, you can specify the code type for the sub-options as ASCII or HEX.
1.     Normal padding format
The padding contents for sub-options in the normal padding format are as follows:
¡     Sub-option 1Contains the VLAN ID and interface number of the interface that received the client's request. The value of the sub-option type is 1, and that of the circuit ID type is 0.
Figure 8 Sub-option 1 in normal padding format
¡     Sub-option 2Contains the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping switch that received the client's request. The value of the sub-option type is 2, and that of the remote ID type is 0.
Figure 9 Sub-option 2 in normal padding format
2.     Verbose padding format
The padding contents for sub-options in the verbose padding format are:
¡     Sub-option 1Contains the user-specified access node identifier (ID of the switch that adds Option 82 in DHCP messages), and type, number, and VLAN ID of the interface that received the client's request. The VLAN ID field has a fixed length of 2 bytes. All the other padding contents of sub-option 1 are length variable. See Figure 10.
Figure 10 Sub-option 1 in verbose padding format
¡     Sub-option 2Contains the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping switch that received the client's request. It has the same format as that in normal padding format. See Figure 9.
3.     Private padding format
¡     Sub-option 1—Contains the VLAN ID of the interface that received the client's request, module (slot number of the receiving port), and port (port number of the receiving port). The value of the sub-option type is 1.
Figure 11 Sub-option 1 in Private padding format
¡     Sub-option 2Contains the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping device that received the client's request. The value of the sub-option type is 2.
Figure 12  Sub-option 2 in Private padding format
¡     Sub-option 9—Contains the sysname and the primary IP address of the Loopback0 interface. The value of the sub-option type is 9.
Figure 13 Sub-option 9 in Private padding format
4.     Standard padding format
¡     Sub-option 1—Contains the VLAN ID of the interface that received the client's request, module (subcard number of the receiving port on a centralized device or slot number of the receiving port on a distributed device) and port (port number of the receiving port). The value of the sub-option type is 1, and the value of the circuit ID type is 0.
Figure 14  Sub-option 1 in standard padding format
¡     Sub-option 2Contains the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping device that received the client's request. The value of the sub-option type is 2, and that of the remote ID type is 0. It has the same format as sub-option 2 in normal padding format. See Figure 9.
Option 184
Option 184 is a reserved option, and parameters in the option can be defined as needed. The switch supports Option 184 carrying voice related parameters, so a DHCP client with voice functions can get an IP address along with specified voice parameters from the DHCP server.
Option 184 involves the following sub-options:
·     Sub-option 1IP address of the primary network calling processor, which serves as the network calling control source and provides program downloads.
·     Sub-option 2IP address of the backup network calling processor that DHCP clients will contact when the primary one is unreachable.
·     Sub-option 3Voice VLAN ID and the result whether DHCP clients take this ID as the voice VLAN or not.
·     Sub-option 4Failover route that specifies the destination IP address and the called number (SIP users use such IP addresses and numbers to communicate with each other) that a SIP user uses to reach another SIP user when both the primary and backup calling processors are unreachable.
For Option 184, you must define sub-option 1 to make other sub-options take effect.
·     RFC 2131, Dynamic Host Configuration Protocol
·     RFC 2132, DHCP Options and BOOTP Vendor Extensions
·     RFC 1542, Clarifications and Extensions for the Bootstrap Protocol
·     RFC 3046, DHCP Relay Agent Information Option
·     RFC 3442, The Classless Static Route Option for Dynamic Host Configuration Protocol (DHCP) version 4
The DHCP server configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, Layer 3 aggregate interfaces, and loopback interfaces. The subaddress pool configuration is not supported on loopback interfaces.
Overview
The DHCP server is well suited to the networks where:
·     Manual configuration and centralized management are difficult to implement.
·     Many hosts need to acquire IP addresses dynamically. This might be because the number of hosts exceeds the number of assignable IP addresses, so it is impossible to assign a fixed IP address to each host. For example, an ISP has a limited number of host addresses.
·     A few hosts need fixed IP addresses.
In addition to assigning IP addresses to DHCP clients on public networks, a multi-VPN-instance customer edge (MCE) switch serving as the DHCP server can also assign IP addresses to DHCP clients on private networks. The IP address ranges of public and private networks or those of private networks on the DHCP server cannot overlap each other. For more information about MCE, see MPLS Configuration Guide.
DHCP address pool
Address pool types
DHCP address pools include the following types:
·     Common address poolSupports both static binding and dynamic allocation.
·     Extended address poolSupports only dynamic allocation.
Common address pool structure
The common address pool database is organized as a tree. The root of the tree is the address pool for natural networks, branches are address pools for subnets, and leaves are addresses statically bound to clients. For the same level address pools, a previously configured pool has a higher selection priority than a new one.
At the very beginning, subnets inherit network parameters and clients inherit subnet parameters. Therefore, common parameters, for example a DNS server address, should be configured at the highest (network or subnet) level of the tree.
The new configuration at the higher level (parent) of the tree is:
·     Inherited if the lower level (child) has no such configuration.
·     Overridden if the lower level (child) has such configuration.
·     The extended address pools on a DHCP server are independent of each other and no inheritance relationship exists among them.
·     IP address lease durations are not inherited.
Principles for selecting an address pool
The DHCP server observes the following principles to select an address pool when assigning an IP address to a client:
1.     If there is an address pool where an IP address is statically bound to the MAC address or ID of the client, the DHCP server will select this address pool and assign the statically bound IP address to the client. For more information about the address pool configuration, see "Configuring static address allocation."
2.     If the receiving interface has an extended address pool referenced, the DHCP server will assign an IP address from this address pool. If no IP address is available in the address pool, the DHCP server will fail to assign an address to the client. For more information about the address pool configuration, see "Configuring dynamic address allocation for an extended address pool."
3.     Otherwise, the DHCP server will select the smallest common address pool that contains the IP address of the receiving interface (if the client and the server reside in the same subnet), or the smallest common address pool that contains the IP address specified in the giaddr field of the client's request (if a DHCP relay agent is in-between). If no IP address is available in the address pool, the DHCP server will fail to assign an address to the client because it cannot assign an IP address from the parent address pool to the client. For more information about the address pool configuration, see "Configuring dynamic address allocation."
For example, two common address pools, 1.1.1.0/24 and 1.1.1.0/25, are configured on the DHCP server. If the IP address of the interface receiving DHCP requests is 1.1.1.1/25, the DHCP server will select IP addresses for clients from address pool 1.1.1.0/25. If no IP address is available in the address pool, the DHCP server will fail to assign addresses to clients. If the IP address of the interface receiving DHCP requests is 1.1.1.130/25, the DHCP server will select IP addresses for clients from the 1.1.1.0/24 address pool.
Keep the IP addresses for dynamic allocation within the subnet where the interface of the DHCP server or DHCP relay agent resides to avoid wrong IP address allocation.
A DHCP server assigns an IP address to a client according to the following sequence:
1.     The IP address manually bound to the client's MAC address or ID
2.     The IP address that was ever assigned to the client
3.     The IP address designated by the Option 50 field in a DHCP-DISCOVER message
4.     The first assignable IP address found in an extended or a common address pool
5.     The IP address that was a conflict or passed its lease duration
If no IP address is assignable, the server will not respond.
Option 50 is the requested IP address field in DHCP-DISCOVER messages. It is padded by the client to specify the IP address that the client wants to obtain. The contents to be padded depend on the client.
Remarks
Required.
Enabling DHCP
Required.
Required.
Required by the extended address pool configuration.
When configuring a common address pool, ignore this task.
Optional.
Required.
Optional.
Optional.
Remarks
Required.
Required to configure either of the two for the common address pool configuration.
Required for the extended address pool configuration.
Optional.
When creating a DHCP address pool, specify it as a common address pool or an extended address pool
To create a DHCP address pool:
Step
Remarks
N/A
2.     Create a DHCP address pool and enter its view.
dhcp server ip-pool pool-name [ extended ]
By default, no DHCP address pool is created.
A common address pool and an extended address pool are different in address allocation mode configuration. Configurations of other parameters (such as the domain name suffix and DNS server address) for them are the same.
IMPORTANT:
You can configure either a static binding or dynamic address allocation for a common address pool but not both.
You need to specify a network segment for the dynamic address allocation. A static binding is a special address pool containing only one IP address.
Some DHCP clients, such as a WWW server, need fixed IP addresses. To provide a fixed IP address, you can create a static binding of a client's MAC address or ID to IP address in the DHCP address pool.
When the client with that MAC address or ID requests an IP address, the DHCP server assigns the IP address from the binding to the client.
A DHCP address pool supports only one static binding, which can be a MAC-to-IP or client's ID-to-IP binding.
Follow these guidelines when you configure static address allocation:
·     Use the static-bind ip-address command together with static-bind mac-address or static-bind client-identifier command to accomplish a static binding configuration.
·     In a DHCP address pool, if you execute the static-bind mac-address command before the static-bind client-identifier command, the latter will overwrite the former and vice versa.
·     If you use the static-bind ip-address, static-bind mac-address, or static-bind client-identifier command multiple times in the DHCP address pool, the most recent configuration takes effect.
·     The IP address of the static binding cannot be an interface address of the DHCP server. Otherwise, an IP address conflict might occur and the bound client cannot obtain an IP address correctly.
·     The ID of the static binding must be identical to the ID displayed by using the display dhcp client verbose command on the client. Otherwise, the client cannot obtain an IP address.
·     The specified lease duration takes effect for the static binding, but the lease duration displayed by the display dhcp server ip-in-use all command is still Unlimited.
·     When the switch serves as a DHCP client, you must configure the static binding of the DHCP client's ID to IP address on the DHCP server. Otherwise, the DHCP client cannot obtain a static IP address.
·     If the interfaces on a DHCP client share the same MAC address, you must specify the client ID, rather than MAC address, in a static binding to identify the requesting interface. Otherwise, the client might fail to obtain an IP address.
To configure a static binding in a common DHCP address pool:
Step
Remarks
N/A
2.     Enter common address pool view.
N/A
3.     Bind IP addresses statically.
static-bind ip-address ip-address [ mask-length | mask mask ]
No IP addresses are statically bound by default.
4.     Bind MAC addresses or IDs statically.
·     Specify the MAC address:
mac-address
·     Specify the ID:
static-bind client-identifier client-identifier
Use either command.
Neither is bound statically by default.
5.     Specify the lease duration for the IP address.
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
Optional.
By default, the lease duration of the IP address is unlimited.
For dynamic address allocation, you must configure a DHCP address pool, specify one and only one address range for the pool, and specify the lease duration. A DHCP address pool can have only one lease duration.
To avoid address conflicts, configure the DHCP server to exclude IP addresses used by the gateway or FTP server from dynamic allocation.
Follow these guidelines when you configure dynamic address allocation:
·     In common address pool view, if you use the network or network ip range command multiple times, the most recent configuration takes effect.
·     After you exclude IP addresses from automatic allocation using the dhcp server forbidden-ip command, neither a common address pool nor an extended address pool can assign these IP addresses through dynamic address allocation.
·     You can exclude multiple IP address ranges from allocation.
To configure the dynamic address allocation:
Step
Remarks
N/A
N/A
3.     Specify a network segment.
network network-address [ mask-length | mask mask ]
Not specified by default, meaning no assignable address.
4.     Specify the IP address range on the subnet for dynamic allocation.
network ip range min-address max-address
Optional.
Not specified by default.
5.     Specify the address lease duration.
expired { day day [ hour hour [ minute minute ] [ second second ] ] | unlimited }
Optional.
One day by default.
6.     Return to system view.
N/A
7.     Exclude IP addresses from automatic allocation.
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
Optional.
Except IP addresses of the DHCP server interfaces, all addresses in the DHCP address pool are assignable by default.
Extended address pools support dynamic address allocation only.
When configuring an extended address pool, you must specify:
·     Assignable IP address range
·     Mask
After the assignable IP address range and the mask are specified, the address pool becomes valid.
To configure dynamic address allocation for an extended address pool:
Step
Remarks
N/A
2.     Enter extended address pool view.
dhcp server ip-pool pool-name extended
N/A
3.     Specify the IP address range.
4.     Specify the IP address mask.
network mask mask
5.     Specify the IP address range for the DHCP clients of a specific vendor.
vendor-class-identifier hex-string&<1-255> ip range min-address max-address
Optional.
Not configured by default.
6.     Specify the address lease duration.
Optional.
One day by default.
7.     Exclude IP addresses from dynamic allocation.
forbidden-ip ip-address&<1-8>
Optional.
Excluded IP addresses specified with the forbidden-ip command in DHCP address pool view are not assignable in the current extended address pool, but are assignable in other address pools.
You can specify a domain name suffix in each DHCP address pool on the DHCP server to provide the clients with the domain name suffix. With this suffix assigned, the client only needs to input part of a domain name, and the system will add the domain name suffix for name resolution. For more information about DNS, see "Configuring IPv4 DNS."
To configure a domain name suffix in the DHCP address pool:
Step
Remarks
N/A
2.     Enter the DHCP address pool view.
N/A
3.     Specify a domain name suffix for the client.
domain-name domain-name
A DHCP client contacts a Domain Name System (DNS) server to resolve names. You can specify up to eight DNS servers in the DHCP address pool.
To configure DNS servers in the DHCP address pool:
Step
Remarks
N/A
2.     Enter DHCP address pool view.
N/A
3.     Specify DNS servers for the client.
dns-list ip-address&<1-8>
A Microsoft DHCP client using NetBIOS protocol contacts a Windows Internet Naming Service (WINS) server for name resolution. Therefore, the DHCP server should assign a WINS server address when assigning an IP address to the client.
You can specify up to eight WINS servers in a DHCP address pool.
In addition, you must specify a NetBIOS node type for the clients to approach name resolution. There are four NetBIOS node types:
·     b (broadcast)-node—A b-node client sends the destination name in a broadcast message. The destination returns its IP address to the client after receiving the message.
·     p (peer-to-peer)-node—A p-node client sends the destination name in a unicast message to the WINS server and the WINS server returns the destination IP address.
·     m (mixed)-nodeAn m-node client broadcasts the destination name. If it receives no response, it unicasts the destination name to the WINS server to get the destination IP address.
·     h (hybrid)-nodeAn h-node client unicasts the destination name to the WINS server. If it receives no response, it broadcasts the destination name to get the destination IP address.
To configure WINS servers and NetBIOS node type in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Specify WINS server IP addresses for the client.
nbns-list ip-address&<1-8>
Optional for b-node.
No address is specified by default.
4.     Specify the NetBIOS node type.
If b-node is specified for the client, you do not need to specify any WINS server address.
Some DHCP clients perform regular software update and backup by using configuration files obtained from a branch intelligent management system (BIMS) server. Therefore, the DHCP server must provides these DHCP clients with the BIMS server IP address, port number, and shared key from the DHCP address pool.
To configure the BIMS server IP address, port number, and shared key in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Specify the BIMS server IP address, port number, and shared key.
bims-server ip ip-address [ port port-number ] sharekey [ cipher | simple ] key
You can specify up to eight gateways in a DHCP address pool.
To configure the gateways in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Specify gateways.
gateway-list ip-address&<1-8>
By default, no gateway is specified.
To assign voice calling parameters along with an IP address to DHCP clients with voice service, you need to configure Option 184 on the DHCP server. For more information about Option 184, see " DHCP overview."
To configure option 184 parameters in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Specify the IP address of the primary network calling processor.
voice-config ncp-ip ip-address
4.     Specify the IP address of the backup network calling processor.
voice-config as-ip ip-address
Optional.
5.     Configure the voice VLAN.
voice-config voice-vlan vlan-id { disable | enable }
Optional.
6.     Specify the failover IP address and dialer string.
voice-config fail-over ip-address dialer-string
Optional.
By default, no failover IP address or dialer string is specified.
Specify an IP address for the network calling processor before performing other configurations.
For the DHCP server to support client auto-configuration, you must specify the IP address or name of a TFTP server and the bootfile name in the DHCP address pool. You do not need to perform any configuration on the DHCP client.
The DHCP client uses these parameters to contact the TFTP server and request the configuration file used for system initialization.
1.     When a router starts up without loading any configuration file, the system sets an active interface (such as the interface of the default VLAN or a Layer 3 Ethernet interface) as the DHCP client to request from the DHCP server for parameters, such as an IP address and name of a TFTP server, and the bootfile name.
2.     After getting related parameters, the DHCP client sends a TFTP request to obtain the configuration file from the specified TFTP server for system initialization. If the client cannot get such parameters, it performs system initialization without loading any configuration file.
To configure the IP address and name of the TFTP server and the bootfile name in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Specify the TFTP server or the name of the TFTP server.
·     Specify the TFTP server:
tftp-server ip-address
ip-address
·     Specify the name of the TFTP server:
tftp-server domain-name
domain-name
Use either command.
4.     Specify the bootfile name.
bootfile-name bootfile-name
Some DHCP clients need to obtain configuration information from a server, such as a TFTP server. You can specify the IP address of that server in each address pool of the DHCP server. The DHCP server sends the server's IP address to DHCP clients along with other configuration information.
To specify the IP address of a server:
Step
Remarks
N/A
N/A
3.     Specify the IP address of a server.
next-server ip-address
CAUTION
CAUTION:
Be cautious when configuring self-defined DHCP options because such configuration might affect the operation of DHCP.
By configuring self-defined DHCP options, you can
·     Define new DHCP options. New configuration options will come out with DHCP development. To support these new options, you can add them into the attribute list of the DHCP server.
·     Define existing DHCP options. Vendors use Option 43 to define options that have no unified definitions in RFC 2132. The self-defined DHCP option enables DHCP clients to obtain vendor-specific information.
·     Extend existing DHCP options. When the current DHCP options cannot meet the customers' requirements (for example, you cannot use the dns-list command to configure more than eight DNS server addresses), you can configure a self-defined option for extension.
To configure a self-defined DHCP option in the DHCP address pool:
Step
Remarks
N/A
N/A
3.     Configure a self-defined DHCP option.
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> }
By default, no DHCP option is configured.
Table 1 Description of common options
Option
Option name
Corresponding command
Command parameter
3
Router Option
gateway-list
ip-address
6
Domain Name Server Option
dns-list
ip-address
15
Domain Name
domain-name
ascii
44
NetBIOS over TCP/IP Name Server Option
nbns-list
ip-address
46
NetBIOS over TCP/IP Node Type Option
netbios-type
hex
66
TFTP server name
tftp-server
ascii
67
Bootfile name
bootfile-name
ascii
43
Vendor Specific Information
N/A
hex
Enabling DHCP
Enable DHCP before performing other configurations.
To enable DHCP:
Step
Remarks
N/A
2.     Enable DHCP.
dhcp enable
Disabled by default.
With the DHCP server enabled on an interface, upon receiving a client's request, the DHCP server will assign an IP address from its address pool to the DHCP client.
To enable the DHCP server on an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Enable the DHCP server on an interface.
dhcp select server global-pool [ subaddress ]
Optional.
Enabled by default.
If a DHCP relay agent exists between the DHCP server and client, the DHCP server, regardless of whether the subaddress keyword is used, will select an IP address from the address pool containing the primary IP address of the DHCP relay agent's interface (connected to the client).
After you create an extended address pool and apply it on an interface, a DHCP server, upon receiving a client's request on the interface, attempts to assign the client the statically bound IP address first and then an IP address from the specified address pool. If no IP address is available, address allocation fails, and the DHCP server will not assign the client any IP address from other address pools.
To apply an extended address pool on an interface:
Step
Remarks
N/A
N/A
3.     Apply an extended address pool on the interface.
Optional.
By default, the DHCP server has no extended address pool applied on its interface, and assigns an IP address from a common address pool to a requesting client.
Only an extended address pool can be applied to the interface. The address pool to be applied must already exist.
Before performing this configuration, complete the following configurations on the DHCP server:
1.     Enable DHCP.
2.     Configure the DHCP address pool.
Unauthorized DHCP servers on networks might assign wrong IP addresses to DHCP clients.
With unauthorized DHCP server detection enabled, the DHCP server checks whether a DHCP request contains Option 54 (Server Identifier Option). If yes, the DHCP server records the IP address in the option, which is the IP address of the DHCP server that assigned an IP address to the DHCP client and records the receiving interface. The administrator can use this information to check for unauthorized DHCP servers.
To enable unauthorized DHCP server detection:
Step
Remarks
N/A
2.     Enable unauthorized DHCP server detection.
dhcp server detect
With unauthorized DHCP server detection enabled, the switch logs each detected DHCP server once and logs each again if an entry is cleared. The administrator can use the log information to find unauthorized DHCP servers.
With IP address conflict detection enabled, the DHCP server pings each address to be assigned is in use by using ICMP.
If the server receives a response within the specified period, the server selects and pings another IP address. If it receives no response, the server continues to ping the IP addresses until the specified number of ping packets are sent. If still no response is received, the server assigns the IP address to the requesting client (The DHCP client probes the IP address by sending gratuitous ARP packets).
To configure IP address conflict detection:
Step
Remarks
N/A
2.     Specify the number of ping packets.
Optional.
One ping packet by default.
The value 0 indicates that no ping operation is performed.
3.     Configure a timeout waiting for ping responses.
Optional.
500 ms by default.
A DHCP server can work in cooperation with authorized ARP to block unauthorized clients, avoid learning incorrect ARP entries, and guard against attacks such as MAC address spoofing. Only the clients that have valid leases on the DHCP server are considered legal clients.
When authorized ARP is enabled, the ARP automatic learning function is disabled. ARP entries can be added by the DHCP server which notifies authorized ARP to add/delete/change authorized ARP entries when adding/deleting/changing IP address leases. Only the clients that have obtained IP addresses from the DHCP server can access the network correctly, but other clients are considered unauthorized clients and are unable to access the network.
Follow these guidelines when you configure the DHCP server to support authorized ARP:
·     Authorized ARP can only be configured on Ethernet interfaces that operate in Layer 3 mode. For more information about the working mode of Ethernet interfaces, see Interface Configuration Guide.
·     When the working mode of the interface is changed from DHCP server to DHCP relay agent, neither the IP address leases nor the authorized ARP entries will be deleted. However, these ARP entries might conflict with new ARP entries generated on the DHCP relay agent. Therefore, H3C recommends that you delete the existing IP address leases when changing the interface working mode to DHCP relay agent.
·     Disabling the DHCP server to support authorized ARP will not delete the IP address leases, but will delete the corresponding authorized ARP entries.
·     For more information about authorized ARP, see Security Configuration Guide. For more information about the arp authorized enable command, see Security Command Reference.
To configure the DHCP server to support authorized ARP:
Step
Remarks
N/A
N/A
3.     Configure the Ethernet interface to operate in Layer 3 mode.
port link-mode route
For more information about the operating mode of Ethernet interfaces, see Interface Configuration Guide.
4.     Configure the DHCP server to support authorized ARP.
dhcp update arp
Not supported by default.
5.     Enable authorized ARP.
With this feature enabled, the DHCP server considers a DHCP client goes offline when the ARP entry for the client ages out. In addition, it removes the client's IP-to-MAC binding entry and releases the IP address of the client.
To enable offline detection:
Step
Remarks
N/A
N/A
3.     Enable offline detection.
dhcp server client-detect enable
Removing an ARP entry manually does not remove the corresponding client's IP-to-MAC binding.
With handling mode for Option 82 enabled, when the DHCP server receives a request with Option 82, it adds Option 82 in the response.
If the server is configured to ignore Option 82, it will assign an IP address to the client without adding Option 82 in the response message.
Before performing this configuration, complete the following tasks:
1.     Enable DHCP.
Step
Remarks
N/A
2.     Enable the server to handle Option 82.
dhcp server relay information enable
Optional.
Enabled by default.
To support Option 82 requires configuring both the DHCP server and relay agent (or the switch enabled with DHCP snooping). For information about related configurations, see "Configuring the DHCP server" and "Configuring the DHCP relay agent."
Before performing the configuration, use the snmp-agent target-host command to specify the destination address of the trap messages. For more information about the command, see Network Management and Monitoring Command Reference.
A DHCP server sends trap messages to the network management server when one of the following reaches the specified threshold:
·     The ratio of successfully allocated IP addresses to received DHCP requests
·     The average IP address utilization of the address pool
·     The maximum IP address utilization of the address pool
Trap messages help network administrators know the latest usage information about the DHCP server.
To specify the threshold for sending trap messages:
Step
Remarks
N/A
2.     Specify the threshold for sending trap messages to the network management server.
dhcp server threshold { allocated-ip threshold-value | average-ip-use threshold-value | max-ip-use threshold-value }
Optional.
Remarks
Display information about IP address conflicts.
display dhcp server conflict { all | ip ip-address } [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display information about lease expiration.
display dhcp server expired { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
Display information about assignable IP addresses.
display dhcp server free-ip [ | { begin | exclude | include } regular-expression ]
Display IP addresses excluded from automatic allocation in the DHCP address pool.
display dhcp server forbidden-ip [ | { begin | exclude | include } regular-expression ]
Display information about bindings.
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
Display information about DHCP server statistics.
display dhcp server statistics [ | { begin | exclude | include } regular-expression ]
Display tree organization information about address pools.
display dhcp server tree { all | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
Clear information about IP address conflicts.
reset dhcp server conflict { all | ip ip-address }
Available in user view.
Clear information about dynamic bindings.
reset dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
Clear information about DHCP server statistics.
reset dhcp server statistics
A restart of the DHCP server or execution of the reset dhcp server ip-in-use command deletes all lease information. The DHCP server will deny any DHCP request for lease extension, and the client must request an IP address again.
IMPORTANT:
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure such an interface, bring the interface up by executing the undo shutdown command.
DHCP networking involves the following types:
·     The DHCP server and client are on the same subnet and exchange messages directly.
·     The DHCP server and client are not on the same subnet and they communicate with each other through a DHCP relay agent.
The DHCP server configuration for the two types is the same.
The device does not support the BOOTP client.
As shown in Figure 15, Switch A (DHCP server) assigns a static IP address, DNS server address, and gateway address to Switch B (DHCP client) and Switch C (BOOTP client) respectively.
The client ID of VLAN-interface 2 on Switch B is 3030-3066-2e65-3234-392e-3830-3530-2d56-6c61-6e2d-696e-7465-7266-6163-6532. The MAC address of VLAN-interface 2 on Switch C is 000f-e249-8050.
Figure 15 Network diagram
1.     Configure the IP address of VLAN-interface 2 on Switch A:
[SwitchA-Vlan-interface2] ip address 10.1.1.1 25
2.     Configure the DHCP server:
# Enable DHCP.
[SwitchA] dhcp enable
# Enable the DHCP server on VLAN-interface 2.
[SwitchA-Vlan-interface2] dhcp select server global-pool
# Create DHCP address pool 0, configure a static binding, DNS server and gateway in it.
[SwitchA] dhcp server ip-pool 0
[SwitchA-dhcp-pool-0] static-bind ip-address 10.1.1.5 25
[SwitchA-dhcp-pool-0] static-bind client-identifier 3030-3066-2e65-3234-392e-3830-3530-2d56-6c61-6e2d-696e-7465-7266-6163-6532
[SwitchA-dhcp-pool-0] dns-list 10.1.1.2
[SwitchA-dhcp-pool-0] gateway-list 10.1.1.126
[SwitchA-dhcp-pool-0] quit
# Create DHCP address pool 1, configure a static binding, DNS server and gateway in it.
[SwitchA] dhcp server ip-pool 1
[SwitchA-dhcp-pool-1] static-bind ip-address 10.1.1.6 25
[SwitchA-dhcp-pool-1] static-bind mac-address 000f-e249-8050
[SwitchA-dhcp-pool-1] dns-list 10.1.1.2
[SwitchA-dhcp-pool-1] gateway-list 10.1.1.126
After the preceding configuration is completed, Switch B can obtain IP address 10.1.1.5 and other network parameters, and Switch C can obtain IP address 10.1.1.6 and other network parameters from Switch A. You can use the display dhcp server ip-in-use command on the DHCP server to view the IP addresses assigned to the clients.
As shown in Figure 16, the DHCP server (Switch A) assigns IP address to clients in subnet 10.1.1.0/24, which is subnetted into 10.1.1.0/25 and 10.1.1.128/25. The IP addresses of VLAN-interfaces 1 and 2 on Switch A are 10.1.1.1/25 and 10.1.1.129/25 respectively. In address pool 10.1.1.0/25, the address lease duration is ten days and twelve hours, domain name suffix aabbcc.com, DNS server address 10.1.1.2/25, gateway 10.1.1.126/25, and WINS server 10.1.1.4/25. In address pool 10.1.1.128/25, the address lease duration is 5 days, domain name suffix aabbcc.com, DNS server address 10.1.1.2/25, and gateway address 10.1.1.254/25, and there is no WINS server address. The domain name and DNS server address on subnets 10.1.1.0/25 and 10.1.1.128/25 are the same. Therefore, the domain name suffix and DNS server address can be configured only for subnet 10.1.1.0/24. Subnet 10.1.1.128/25 can inherit the configuration of subnet 10.1.1.0/24.
Figure 16 Network diagram
1.     Specify IP addresses for VLAN interfaces. (Details not shown.)
# Enable DHCP.
# Enable the DHCP server on VLAN-interface 1 and VLAN-interface 2.
[SwitchA-Vlan-interface1] dhcp select server global-pool
# Exclude IP addresses (addresses of the DNS server, WINS server, and gateways).
[SwitchA] dhcp server forbidden-ip 10.1.1.2
[SwitchA] dhcp server forbidden-ip 10.1.1.4
[SwitchA] dhcp server forbidden-ip 10.1.1.126
[SwitchA] dhcp server forbidden-ip 10.1.1.254
# Configure DHCP address pool 0 (network segment, client domain name suffix, and DNS server address).
[SwitchA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
[SwitchA-dhcp-pool-0] domain-name aabbcc.com
# Configure DHCP address pool 1 (network segment, gateway, lease duration, and WINS server).
[SwitchA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.128
[SwitchA-dhcp-pool-1] expired day 10 hour 12
[SwitchA-dhcp-pool-1] nbns-list 10.1.1.4
[SwitchA-dhcp-pool-1] quit
# Configure DHCP address pool 2 (network segment, gateway, and lease duration).
[SwitchA] dhcp server ip-pool 2
[SwitchA-dhcp-pool-2] network 10.1.1.128 mask 255.255.255.128
[SwitchA-dhcp-pool-2] expired day 5
[SwitchA-dhcp-pool-2] gateway-list 10.1.1.254
After the preceding configuration is complete, clients on networks 10.1.1.0/25 and 10.1.1.128/25 can obtain IP addresses on the corresponding network and other network parameters from Switch A. You can use the display dhcp server ip-in-use command on the DHCP server to view the IP addresses assigned to the clients.
As shown in Figure 17, the DHCP client (Switch B) obtains an IP address and PXE server addresses from the DHCP server (Switch A). The IP address that Switch B obtains belongs to subnet 10.1.1.0/24. The PXE server addresses are 1.2.3.4 and 2.2.2.2.
The DHCP server assigns PXE server addresses to DHCP clients through Option 43, a self-defined option. The format of Option 43 and that of the PXE server address list are shown in Figure 5 and Figure 7, respectively. The value of Option 43 configured on the DHCP server in this example is 80 0B 00 00 02 01 02 03 04 02 02 02 02. The number 80 is the value of the sub-option type. The number 0B is the value of the sub-option length. The numbers 00 00 are the value of the PXE server type. The number 02 indicates the number of servers. The numbers 01 02 03 04 02 02 02 02 indicate that the PXE server addresses are 1.2.3.4 and 2.2.2.2.
Figure 17 Network diagram
1.     Specify IP addresses for the interfaces. (Details not shown.)
# Enable DHCP.
# Configure DHCP address pool 0.
[SwitchA-dhcp-pool-0] option 43 hex 80 0B 00 00 02 01 02 03 04 02 02 02 02
After the preceding configuration is complete, Switch B can obtain its IP address on 10.1.1.0/24 and PXE server addresses from the Switch A. You can use the display dhcp server ip-in-use command on the DHCP server to view the IP addresses assigned to the clients.
Symptom
A client's IP address obtained from the DHCP server conflicts with another IP address.
Analysis
A host on the subnet can have the same IP address.
Solution
1.     Disable the client's network adapter or disconnect the client's network cable. Ping the IP address of the client from another host to check whether there is a host using the same IP address.
2.     If a ping response is received, the IP address has been manually configured on a host. Execute the dhcp server forbidden-ip command on the DHCP server to exclude the IP address from dynamic allocation.
3.     Enable the network adapter or connect the network cable. Release the IP address and obtain another one on the client. For example, to release the IP address and obtain another one on a Windows XP DHCP client:
a.     Run cmd to enter DOS window.
b.     Enter ipconfig/release to relinquish the IP address and then ipconfig/renew to obtain another IP address.
c.     Enter ipconfig/all to verify other information such as mask, default gateway, DNS, and lease.
The DHCP relay agent configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, and Layer 3 aggregate interfaces.
Through a relay agent, DHCP clients can communicate with a DHCP server on another subnet to obtain configuration parameters. Thus, DHCP clients on different subnets can contact the same DHCP server rather than having a DHCP server on each subnet.
An MCE switch serving as the DHCP relay agent can forward DHCP packets not only between a DHCP server and clients on a public network, but also between a DHCP server and clients on a private network. Note that the IP address ranges of the public and private networks or those of private networks cannot overlap each other. For more information about MCE, see MPLS Configuration Guide.
Fundamentals
Figure 18 DHCP relay agent application
The DHCP server and client interact with each other in a similar way with or without a relay agent (see "DHCP overview".)
Figure 19 DHCP relay agent work process
1.     After receiving a DHCP-DISCOVER or DHCP-REQUEST broadcast message from a DHCP client, the DHCP relay agent fills the giaddr field of the message with its IP address and forwards the message to the designated DHCP server in unicast mode.
2.     Based on the giaddr field, the DHCP server returns an IP address and other configuration parameters to the relay agent, and the relay agent conveys them to the client.
Option 82 records the location information about the DHCP client, letting the administrator locate the DHCP client for security control and accounting purposes. For more information, see "DHCP overview."
If the DHCP relay agent supports Option 82, it handles a client's request according to the contents defined in Option 82, if any. The handling strategies are described in Table 2.
If a reply returned by the DHCP server contains Option 82, the DHCP relay agent removes the Option 82 before forwarding the reply to the client.
Table 2 Handling strategies of the DHCP relay agent
If a client's requesting message has…
Handling strategy
Padding format
The DHCP relay agent…
Option 82
Drop
Random
Drops the message.
Keep
Random
Forwards the message without changing Option 82.
Replace
normal
Forwards the message after replacing the original Option 82 with the Option 82 padded in normal format.
verbose
Forwards the message after replacing the original Option 82 with the Option 82 padded in verbose format.
user-defined
Forwards the message after replacing the original Option 82 with the user-defined Option 82.
no Option 82
N/A
normal
Forwards the message after adding the Option 82 padded in normal format.
N/A
verbose
Forwards the message after adding the Option 82 padded in verbose format.
N/A
user-defined
Forwards the message after adding the user-defined Option 82.
Remarks
Enabling DHCP
Required.
Required.
Required.
Optional.
Optional.
Optional.
Optional.
Optional.
Enabling DHCP
Enable DHCP before performing other DHCP-related configurations.
To enable DHCP:
Step
Remarks
N/A
2.     Enable DHCP.
dhcp enable
With the DHCP relay agent enabled, an interface forwards incoming DHCP requests to a DHCP server for address allocation.
To enable the DHCP relay agent on an interface:
Step
Remarks
N/A
N/A
3.     Enable the DHCP relay agent on the current interface.
dhcp select relay
With DHCP enabled, interfaces operate in the DHCP server mode.
If the DHCP client obtains an IP address through the DHCP relay agent, the address pool of the subnet to which the IP address of the DHCP relay agent's interface connecting the DHCP client belongs must be configured on the DHCP server. Otherwise, the DHCP client cannot obtain a correct IP address.
To improve reliability, you can specify several DHCP servers as a group on the DHCP relay agent and correlate a relay agent interface with the server group. When the interface receives request messages from clients, the relay agent will forward them to all the DHCP servers of the group.
Follow these guidelines when you correlate a DHCP server group with a relay agent interface:
·     You can specify up to 20 DHCP server groups on the relay agent and eight DHCP server addresses for each DHCP server group.
·     You can specify up to eight DHCP server addresses for each DHCP server group.
·     The IP addresses of DHCP servers and those of relay agent's interfaces that connect DHCP clients cannot be on the same subnet. Otherwise, the client cannot obtain an IP address.
·     The IP addresses of DHCP servers and those of relay agent's interfaces cannot be on the same subnet. Otherwise, the client cannot obtain an IP address.
·     A DHCP server group can correlate with one or multiple DHCP relay agent interfaces, but a relay agent interface can only correlate with one DHCP server group. If you use the dhcp relay server-select command multiple times, the most recent configuration takes effect. However, if the specified DHCP server group does not exist, the interface still uses the previous correlation.
·     The group-id in the dhcp relay server-select command was specified by the dhcp relay server-group command.
To correlate a DHCP server group with a relay agent interface:
Step
Remarks
N/A
2.     Create a DHCP server group and add a server into the group.
dhcp relay server-group group-id ip ip-address
Not created by default.
3.     Enter interface view.
N/A
4.     Correlate the DHCP server group with the current interface.
dhcp relay server-select group-id
By default, no interface is correlated with any DHCP server group.
Address check can block illegal hosts from access external networks.
With this feature enabled, the DHCP relay agent can dynamically record clients' IP-to-MAC bindings after the clients obtain IP addresses through DHCP. You can configure static IP-to-MAC bindings on the DHCP relay agent so that users can access external networks using fixed IP addresses.
Upon receiving an ARP packet, the DHCP relay agent checks the sender's IP and MAC addresses in the packet against the recorded dynamic and static bindings. If no match is found, the DHCP relay agent does not learn the ARP entry and prohibits the requesting client from accessing external networks through the DHCP relay agent.
Follow these guidelines when you configure the address check:
·     The dhcp relay address-check enable command can be executed only on Layer 3 Ethernet interfaces (including subinterfaces), VLAN interfaces and Layer 3 aggregate interfaces.
·     Before enabling address check on an interface, you must enable the DHCP service, and enable the DHCP relay agent on the interface. Otherwise, the address check configuration is ineffective.
·     The dhcp relay address-check enable command only checks IP and MAC addresses of clients.
·     When using the dhcp relay security static command to bind an interface to a static binding entry, make sure the interface is configured as a DHCP relay agent. Otherwise, address entry conflicts might occur.
·     When a synchronous/asynchronous serial interface requests an IP address through DHCP, the DHCP relay agent does not record the corresponding IP-to-MAC binding.
To create a static binding and enable address check:
Step
Remarks
N/A
2.     Create a static binding.
dhcp relay security static ip-address mac-address [ interface interface-type interface-number ]
Optional.
No static binding is created by default.
N/A
4.     Configure address check.
A DHCP client unicasts a DHCP-RELEASE message to the DHCP server when releasing its dynamically obtained IP address. The DHCP relay agent simply conveys the message to the DHCP server and does not remove the IP-to-MAC binding. To solve this problem, the periodic refresh of dynamic client entries feature is introduced.
With this feature, the DHCP relay agent uses the IP address of a client and the MAC address of the DHCP relay interface to periodically send a DHCP-REQUEST message to the DHCP server.
·     If the server returns a DHCP-ACK message or does not return any message within a specific interval, the DHCP relay agent ages out the client entry.
·     If the server returns a DHCP-NAK message, the relay agent keeps the client entry.
To configure dynamic binding update interval:
Step
Remarks
N/A
2.     Enable periodic refresh of dynamic client entries.
dhcp relay security refresh enable
Optional.
Enabled by default.
3.     Configure binding update interval.
dhcp relay security tracker { interval | auto }
Optional.
auto by default. (auto interval is calculated by the relay agent according to the number of bindings.)
A DHCP relay agent can work in cooperation with authorized ARP to block illegal clients.
With this feature enabled, when a client obtains an IP address from the DHCP server through a DHCP relay agent, the DHCP relay agent can automatically record the client's IP-to-MAC binding and use this client entry to update the corresponding ARP entry.
When authorized ARP is enabled on the DHCP relay agent, the ARP automatic learning function is disabled. Then dynamic client entries are used to update ARP entries and avoid learning incorrect ARP entries.
This feature makes sure that:
·     The clients that obtain IP addresses through DHCP have ARP entries on the DHCP relay agent, and can access the network.
·     The clients that do not obtain IP addresses through DHCP have no ARP entries on the DHCP relay agent, and are considered illegal clients and unable to access the network.
Follow these guidelines when you configure the DHCP relay agent to support authorized ARP:
·     Authorized ARP can only be configured on Layer 3 Ethernet interfaces.
·     Disabling the DHCP relay agent to support authorized ARP will delete the corresponding authorized ARP entries.
·     The DHCP relay agent does not notify the authorized ARP module of the static bindings. You must configure the corresponding static ARP entries for authorized ARP.
To configure the DHCP relay agent to support authorized ARP:
Step
Remarks
N/A
N/A
3.     Configure the DHCP relay agent to support authorized ARP.
dhcp update arp
4.     Enable authorized ARP.
Not enabled by default.
Enabling unauthorized DHCP server detection
Unauthorized DHCP servers might assign wrong IP addresses to DHCP clients.
With unauthorized DHCP servers detection enabled, the DHCP relay agent checks whether a request contains Option 54 (Server Identifier Option). If yes, the DHCP relay agent records the IP address in the option, which is the IP address of the DHCP server that assigned an IP address to the DHCP client, and records the receiving interface. The administrator can use this information to check for unauthorized DHCP servers.
Step
Remarks
N/A
dhcp relay server-detect
Enabling DHCP starvation attack protection
A DHCP starvation attack occurs when an attacker constantly sends forged DHCP requests using different MAC addresses in the chaddr field to a DHCP server. This exhausts the IP address resources of the DHCP server so that legitimate DHCP clients cannot obtain IP addresses. The DHCP server might also fail to work because of exhaustion of system resources.
·     To relieve a DHCP starvation attack that uses DHCP packets encapsulated with different source MAC addresses, you can limit the number of ARP entries that a Layer 3 interface can learn or MAC addresses that a Layer 2 port can learn. You can also configure an interface that has learned the maximum MAC addresses to discard packets whose source MAC addresses are not in the MAC address table.
·     To prevent a DHCP starvation attack that uses DHCP requests encapsulated with the same source MAC address, enable MAC address check on the DHCP relay agent. With this function enabled, the DHCP relay agent compares the chaddr field of a received DHCP request with the source MAC address field of the frame. If they are the same, the DHCP relay agent decides this request as valid and forwards it to the DHCP server. If not, the DHCP request is discarded.
To enable MAC address check:
Step
Remarks
N/A
N/A
3.     Enable MAC address check.
dhcp relay check mac-address
DHCP relay agents change the source MAC addresses when forwarding DHCP packets. Therefore, you can enable MAC address check only on a DHCP relay agent directly connected to DHCP clients. Otherwise, valid DHCP packets might be discarded and clients cannot obtain IP addresses.
Enabling client offline detection
With this feature enabled, the DHCP relay agent considers a DHCP client goes offline when the ARP entry for the client ages out. In addition, it removes the client entry and sends a DHCP-RELEASE message to the DHCP server to release the IP address of the client.
Step
Remarks
N/A
N/A
dhcp relay client-detect enable
Removing an ARP entry manually does not remove the corresponding client's IP-to-MAC binding. When the client goes offline, use the undo dhcp relay security command to remove the IP-to-MAC binding manually.
Configuring the DHCP relay agent to release an IP address
You can configure the relay agent to release a client's IP address. The relay agent sends a DHCP-RELEASE message that contains the specified IP address. Upon receiving the DHCP-RELEASE message, the DHCP server releases the IP address. Meanwhile, the client entry is removed from the DHCP relay agent.
To configure the DHCP relay agent in system view to send DHCP-RELEASE messages:
Step
2.     Configure the DHCP relay agent to release an IP address.
dhcp relay release ip client-ip
·     The IP address to be released must be available in a dynamic client entry.
·     Dynamic client entries can be generated only after you enable address check, authorized ARP, or IP source guard on the DHCP relay agent. For more information about IP source guard, see Security Configuration Guide.
Configuring the DHCP relay agent to support Option 82
Configuration prerequisites
Before configure the DHCP relay agent to support Option 82, complete the following tasks:
1.     Enable DHCP.
2.     Enable the DHCP relay agent on the specified interface.
3.     Correlate a DHCP server group with relay agent interfaces.
Configuration guidelines
·     To support Option 82, perform related configuration on both the DHCP server and relay agent. For DHCP server configuration of this kind, see "Configuring the DHCP server."
·     If the handling strategy of the DHCP relay agent is configured as replace, configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
·     If sub-option 1 (node identifier) of Option 82 contains the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP relay agent will drop the message.
Configuration procedure
To configure the DHCP relay agent to support Option 82:
Step
Remarks
N/A
N/A
3.     Enable the relay agent to support Option 82.
dhcp relay information enable
4.     Configure the handling strategy for requesting messages containing Option 82.
Optional.
replace by default.
5.     Configure non-user-defined Option 82.
·     Configure the padding format for Option 82:
dhcp relay information format
{ normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
·     Configure the code type for the circuit ID sub-option:
dhcp relay information circuit-id format-type { ascii | hex }
·     Configure the code type for the remote ID sub-option:
dhcp relay information remote-id format-type { ascii | hex }
Optional.
By default:
·     The padding format for Option 82 is normal.
·     The code type for the circuit ID sub-option depends on the padding format of Option 82. Each field has its own code type.
·     The code type for the remote ID sub-option is hex.
The code type configuration for the circuit ID sub-option and for the remote ID sub-option apply to non-user-defined Option 82 only.
6.     Configure user-defined Option 82.
·     Configure the padding content for the circuit ID sub-option:
dhcp relay information circuit-id string
circuit-id
·     Configure the padding content for the remote ID sub-option:
dhcp relay information remote-id string
{ remote-id | sysname }
Optional.
By default, the padding content depends on the padding format of Option 82.
Displaying and maintaining the DHCP relay agent
Remarks
Display information about DHCP server groups correlated to a specific or all interfaces.
display dhcp relay { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
Display Option 82 configuration information on the DHCP relay agent.
display dhcp relay information { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
Display information about bindings of DHCP relay agents.
display dhcp relay security [ ip-address | dynamic | static ] [ | { begin | exclude | include } regular-expression ]
Display statistics information about bindings of DHCP relay agents.
display dhcp relay security statistics [ | { begin | exclude | include } regular-expression ]
Display information about the refreshing interval for entries of dynamic IP-to-MAC bindings.
display dhcp relay security tracker [ | { begin | exclude | include } regular-expression ]
Display information about the configuration of a specific or all DHCP server groups.
display dhcp relay server-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
Display packet statistics on relay agent.
display dhcp relay statistics [ server-group { group-id | all } ] [ | { begin | exclude | include } regular-expression ]
Clear packet statistics from relay agent.
reset dhcp relay statistics [ server-group group-id ]
DHCP relay agent configuration examples
Network requirements
As shown in Figure 20, DHCP clients reside on network 10.10.1.0/24. The IP address of DHCP server (Switch B) is 10.1.1.1/24, and the IP address of DHCP server (Switch C) is 10.2.1.1/24. Because the DHCP clients reside on a different network with the DHCP servers, a DHCP relay agent is deployed to forward messages between DHCP clients and the DHCP servers.
VLAN-interface 1 of the DHCP relay agent (Switch A) connects to the subnet where DHCP clients reside. The IP address of VLAN-interface 1 is 10.10.1.1/24.
Figure 20 Network diagram
# Specify IP addresses for the interfaces. (Details not shown.)
# Enable DHCP.
# Add DHCP servers 10.1.1.1 and 10.2.1.1 into DHCP server group 1.
[SwitchA] dhcp relay server-group 1 ip 10.1.1.1
[SwitchA] dhcp relay server-group 1 ip 10.2.1.1
# Enable the DHCP relay agent on VLAN-interface 1.
[SwitchA-Vlan-interface1] dhcp select relay
# Correlate VLAN-interface 1 to DHCP server group 1.
[SwitchA-Vlan-interface1] dhcp relay server-select 1
After the preceding configuration is complete, DHCP clients can obtain IP addresses and other network parameters through the DHCP relay agent from the DHCP servers. You can use the display dhcp relay statistics command to view statistics of DHCP packets forwarded by DHCP relay agents. After you enable address check of the DHCP relay agents with the dhcp relay address-check enable command, use the display dhcp relay security command to view bindings of DHCP relay agents.
·     Because the DHCP relay agent and servers are on different subnets, you must configure a static route or dynamic routing protocol to make them reachable to each other.
·     Configurations on the DHCP servers are also required to guarantee the client-server communication through the DHCP relay agent. For DHCP server configuration information, see "Configuring the DHCP server."
DHCP relay agent Option 82 support configuration example
As shown in Figure 20, Option 82 is enabled on the DHCP relay agent (Switch A). The handling strategy for DHCP requests containing Option 82 is configured as replace. The padding content for the circuit ID sub-option is configured as company001 and for the remote ID sub-option as device001.
Switch A forwards DHCP requests to the DHCP server (Switch B) after replacing Option 82 in the requests, so that the DHCP clients can obtain IP addresses.
# Enable DHCP.
# Add DHCP server 10.1.1.1 into DHCP server group 1.
# Enable the DHCP relay agent to support Option 82, and perform Option 82-related configurations.
[SwitchA-Vlan-interface1] dhcp relay information enable
[SwitchA-Vlan-interface1] dhcp relay information strategy replace
[SwitchA-Vlan-interface1] dhcp relay information circuit-id string company001
[SwitchA-Vlan-interface1] dhcp relay information remote-id string device001
Configurations on the DHCP server are also required to make the Option 82 configurations function correctly.
Troubleshooting DHCP relay agent configuration
Symptom
DHCP clients cannot obtain any configuration parameters through the DHCP relay agent.
Analysis
Some problems might occur with the DHCP relay agent or server configuration.
Solution
To locate the problem, enable debugging and execute the display command on the DHCP relay agent to view the debugging information and interface state information.
Check that:
1.     The DHCP is enabled on the DHCP server and relay agent.
2.     The address pool on the same subnet where DHCP clients reside is available on the DHCP server.
3.     The routes between the DHCP server and DHCP relay agent are reachable.
4.     The relay agent interface connected to DHCP clients is correlated with correct DHCP server group and IP addresses for the group members are correct.
Configuring DHCP client
The DHCP client configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, and Layer 3 aggregate interfaces.
Enabling the DHCP client on an interface
An interface enabled with the DHCP client uses DHCP to obtain configuration parameters such as an IP address from the DHCP server.
If the DHCP client enabled on an interface fails to get an IP address multiple times, the DHCP client stops address acquisition.
Follow these guidelines when you enable the DHCP client on an interface:
·     An interface in an aggregation group cannot be enabled with the DHCP client.
·     To enable multiple VLAN interfaces with the same MAC address to use the DHCP client to get IP addresses through a relay agent, the DHCP server must not run on Windows Server 2000 or Windows Server 2003.
·     An interface supports multiple address acquisition methods. A newly configured address acquisition method overwrites the previous one.
·     Secondary IP addresses cannot be configured on an interface that is enabled with the DHCP client.
·     If the IP address that interface A obtains from the DHCP server is on the same network segment as the IP address of interface B, interface A does not use the IP address or request another IP address from the DHCP server, unless the IP address of interface B is manually deleted and interface A is brought up again by first executing the shutdown command and then the undo shutdown command or the DHCP client is re-enabled on interface A by executing the undo ip address dhcp-alloc command and then the ip address dhcp-alloc command.
To enable the DHCP client on an interface:
Step
Remarks
N/A
N/A
3.     Enable the DHCP client on the interface.
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
Displaying and maintaining the DHCP client
Remarks
Display DHCP client information.
display dhcp client [ verbose ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
DHCP client configuration example
As shown in Figure 22, Switch B contacts the DHCP server through VLAN-interface 2 to obtain the following configuration information:
·     IP addresses of DHCP clients on network 10.1.1.0/24
·     DNS server address 20.1.1.1/24
·     ACS address 10.153.114.21/24
·     Static route destined for network 20.1.1.0/24 through next hop 10.1.1.2
The DHCP server uses Option 121 to assign static route information to DHCP clients. Figure 21 shows the format of Option 121. The destination descriptor field comprises two parts, subnet mask length and destination network address. In this example, the value of the destination descriptor field takes 18 14 01 01, a hexadecimal number indicating that the subnet mask length is 24 and destination network address is 20.1.1.0, and the value of the next hop address field takes 0A 01 01 02, a hexadecimal number indicating that the next hop is 10.1.1.2.
Figure 21 Option 121 format
The DHCP server uses Option 43 to assign ACS information to the clients. The ACS can update configuration files for the clients and reboot and monitor the clients. The format of Option 43 is shown in Figure 5, and the format of ACS parameter suboption is shown in Figure 6.
This example uses the ACS address http://10.153.114.21:9090 (the hexadecimal value of the corresponding ASCII code is 01266874 74703A2F 2F31302E 3135332E 3131342E 32313A39 30393020), and the default CPE authentication. The user name is bims (the hexadecimal value of the corresponding ASCII code is 62696D73), the password is imcbims (the hexadecimal value of the corresponding ASCII code is 696D63 62696D73). The hexadecimal value of the ASCII code for space is 20.
The complete Option 43 representation for http:// 10.153.114.21:9090:9090 bims imcbims is:
option 43 hex 01246874 74703A2F 2F313932 2E313638 2E312E32 3A393039 30206269 6D732069 6D636269 6D73.
Figure 22 Network diagram
1.     Configure Switch A:
# Configure the IP address of VLAN-interface 2.
[SwitchA-Vlan-interface2] ip address 10.1.1.1 24
# Enable the DHCP service.
# Exclude an IP address from automatic allocation.
# Configure DHCP address pool 0 and specify the subnet, lease duration, DNS server address, and a static route to subnet 20.1.1.0/24. The ACS address is http://10.153.114.21:9090.
[SwitchA-dhcp-pool-0] expired day 10
[SwitchA-dhcp-pool-0] dns-list 20.1.1.1
[SwitchA-dhcp-pool-0] option 121 hex 18 14 01 01 0A 01 01 02
[SwitchA-dhcp-pool-0] option 43 hex 01266874 74703A2F 2F31302E 3135332E 3131342E 32313A39 30393020 62596D73 20696D63 62696D73
2.     Configure Switch B:
# Enable the DHCP client on VLAN-interface 2.
[SwitchB-Vlan-interface2] ip address dhcp-alloc
# Use the display dhcp client command to display the IP address and other network parameters assigned to Switch B.
[SwitchB-Vlan-interface2] display dhcp client verbose
Vlan-interface2 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 10.1.1.3 255.255.255.0
 Allocated lease: 864000 seconds, T1: 432000 seconds, T2: 756000 seconds
 Lease from 2009.02.20 11:06:35   to   2009.03.02 11:06:35
 DHCP server: 10.1.1.1
 Transaction ID: 0x410090f0
 Classless static route:
   Destination: 20.1.1.0, Mask: 255.255.255.0, NextHop: 10.1.1.2
 DNS server: 20.1.1.1
 Client ID: 3030-3066-2e65-3230-
            302e-3030-3032-2d45-
            7468-6572-6e65-7430-
            2f30
 T1 will timeout in 4 days 23 hours 59 minutes 50 seconds.
# Use the display ip routing-table command to display the route information on Switch B. A static route to network 20.1.1.0/24 is available in the routing table.
[SwitchB-Vlan-interface2] display ip routing-table
Routing Tables: Public
         Destinations : 5        Routes : 5
10.1.1.0/24         Direct 0    0            10.1.1.3        Vlan2
10.1.1.3/32         Direct 0    0            127.0.0.1       InLoop0
20.1.1.0/24         Static 70   0            10.1.1.2        Vlan2
# Use the display cwmp configuration command to display the CWMP configuration on Switch B.
[SwitchB-Vlan-interface2] display cwmp configuration
TR-069 is enabled.
ACS URL                             :http://10.153.114.21:9090
ACS username                        :bims
ACS password                        :imcbims
Inform enable status                :disabled
Inform interval                     :600s
Inform time                         :none
Wait timeout                        :30s
Reconnection times                  :Unlimited
Source IP interface                 :none
For more information about the display cwmp configuration command, see Network Management and Monitoring Command Reference.
The DHCP snooping-enabled switch must be either between the DHCP client and relay agent, or between the DHCP client and server. It does not work if it is between the DHCP relay agent and DHCP server.
Overview
DHCP snooping functions
DHCP snooping can:
·     Ensure DHCP clients to obtain IP addresses from authorized DHCP servers.
·     Record IP-to-MAC mappings of DHCP clients.
Ensuring DHCP clients to obtain IP addresses from authorized DHCP servers
With DHCP snooping, the ports of a switch can be configured as trusted or untrusted to make sure clients obtain IP address only from authorized DHCP servers.
·     TrustedA trusted port forwards DHCP messages correctly.
·     UntrustedAn untrusted port discards the DHCP-ACK or DHCP-OFFER messages from any DHCP server.
Configure ports that connect to authorized DHCP servers or other DHCP snooping devices as trusted, and configure other ports as untrusted.
Recording IP-to-MAC mappings of DHCP clients
DHCP snooping reads DHCP-REQUEST messages and DHCP-ACK messages from trusted ports to record DHCP snooping entries. A DHCP snooping entry includes the MAC and IP addresses of the client., the port that connects to the DHCP client, and the VLAN of the port. With DHCP snooping entries, DHCP snooping can implement the following functions:
·     ARP detectionWhether ARP packets are sent from an authorized client is determined based on DHCP snooping entries. This feature prevents ARP attacks from unauthorized clients. For more information, see Security Configuration Guide.
·     IP source guardIP source guard uses dynamic binding entries generated by DHCP snooping to filter packets on a per-port basis, and prevents unauthorized packets from traveling through. For more information, see Security Configuration Guide.
Application environment of trusted ports
Configuring a trusted port connected to a DHCP server
Figure 23 Trusted port configuration
As shown in Figure 23, the trusted port forwards reply messages from the DHCP server to the client, but the untrusted port connected to the unauthorized DHCP server cannot forward any reply messages. This makes sure the DHCP client can obtain an IP address from the authorized DHCP server.
Configuring trusted ports in a cascaded network
In a cascaded network involving multiple DHCP snooping devices, the ports connected to other DHCP snooping devices should be configured as trusted ports.
To save system resources, you can disable the trusted ports, which are not directly connected to DHCP clients, from recording clients' IP-to-MAC bindings upon receiving DHCP requests.
Figure 24 Configuring trusted ports in a cascaded network
DHCP snooping support for Option 82
Option 82 records the location information about the DHCP client. The administrator can locate the DHCP client for security control and accounting purposes. For more information, see "DHCP overview."
If DHCP snooping supports Option 82, it will handle a client's request according to the contents defined in Option 82, if any. The handling strategies are described in Table 3.
If a reply returned by the DHCP server contains Option 82, the DHCP snooping device will remove the Option 82 before forwarding the reply to the client. If the reply contains no Option 82, the DHCP snooping device forwards it directly.
Table 3 Handling strategies of DHCP snooping
Handling strategy
Padding format
The DHCP snooping switch…
Option 82
Drop
Random
Drops the message.
Keep
Random
Replace
normal
verbose
user-defined
Append
normal
verbose
private
Forwards the message after adding sub-option 9 to option 82 or adding content to sub-option 9 that option 82 contains.
standard
user-defined
no Option 82
N/A
normal
N/A
private
Forwards the message after adding the Option 82 padded in private format.
N/A
standard
Forwards the message after adding the Option 82 padded in standard format.
N/A
verbose
N/A
user-defined
The handling strategy and padding format for Option 82 on the DHCP snooping device are the same as those on the relay agent.
Configuring DHCP snooping basic functions
Follow these guidelines when you configure DHCP snooping basic functions:
·     You need to specify the ports connected to the valid DHCP servers as trusted to make sure DHCP clients can obtain valid IP addresses. The trusted port and the port connected to the DHCP client must be in the same VLAN.
·     You can specify Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces as trusted ports. For more information about aggregate interfaces, see Layer 2—LAN Switching Configuration Guide.
·     If an Ethernet interface is added to an aggregation group, DHCP snooping configured on the interface will not take effect. After the interface quits from the aggregation group, DHCP snooping will be effective.
·     DHCP snooping can work with basic QinQ or flexible QinQ. When receiving a packet without any VLAN tag from the DHCP client to the DHCP server, the DHCP snooping device adds a VLAN tag to the packet. If the packet has one VLAN tag, the device adds another VLAN tag to the packet and records the two VLAN tags in a DHCP snooping entry. The newly added VLAN tag is the outer tag. If the packet has two VLAN tags, the device directly forwards the packet to the DHCP server without adding any tag. If you need to add a new VLAN tag and meanwhile modify the original VLAN tag for the packet, DHCP snooping cannot work with flexible QinQ.
To configure DHCP snooping basic functions:
Step
Remarks
N/A
2.     Enable DHCP snooping.
dhcp-snooping
3.     Enter Ethernet interface view.
The interface connects to the DHCP server.
4.     Specify the port as a trusted port that records the IP-to-MAC bindings of clients.
dhcp-snooping trust
After DHCP snooping is enabled, a port is an untrusted port by default.
5.     Return to system view.
N/A
6.     Enter interface view.
The interface indirectly connects to the DHCP client.
7.     Specify the port as a trusted port that does not record the IP-to-MAC bindings of clients.
dhcp-snooping trust no-user-binding
Optional.
Configuring DHCP snooping to support Option 82
Follow these guidelines when you configure DHCP snooping to support Option 82:
·     You can configure DHCP snooping to support Option 82 on Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces only.
·     If a Layer 2 Ethernet interface is added to an aggregation group, enabling DHCP snooping to support Option 82 on the interface will not take effect. After the interface quits the aggregation group, the configuration will be effective.
·     To support Option 82, perform related configuration on both the DHCP server and the switch enabled with DHCP snooping. For DHCP server configuration of this kind, see "Configuring the DHCP server."
·     If the handling strategy of the DHCP-snooping-enabled switch is configured as replace, you need to configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
·     If the Option 82 contains the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP-snooping-enabled switch will drop the message. You can use the sysname command to specify the device name. For more information about this command, see Fundamentals Command Reference.
·     If DHCP snooping and QinQ work together or the DHCP snooping device receives a DHCP packet with two VLAN tags, and the normal or verbose padding format is adopted for Option 82, DHCP snooping fills the VLAN ID field of sub-option 1 with outer VLAN tag.inter VLAN tag. For example, if the outer VLAN tag is 10 (a in hexadecimal) and the inner VLAN tag is 20 (14 in hexadecimal), the VLAN ID is 000a.0014.
To configure DHCP snooping to support Option 82:
Step
Remarks
N/A
N/A
3.     Enable DHCP snooping to support Option 82.
dhcp-snooping information enable
dhcp-snooping information strategy { append | drop | keep | replace }
Optional.
replace by default.
5.     Configure Option 82 in the non-user-defined.
dhcp-snooping information format { normal | private <1-1> | standard | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
dhcp-snooping information circuit-id format-type { ascii | hex }
dhcp-snooping information remote-id format-type { ascii | hex }
·     Enable sub-option 9:
[ vlan vlan-id ] sub-option sub-option-code
Optional.
By default:
·     Sub-option 9 is not enabled.
The code type configuration for the circuit ID sub-option and the remote ID sub-option apply to non-user-defined Option 82 only.
The private padding format supports only the hex code type.
For sub-option 9, when append strategy is adopted, the sysname and the primary IP address of the Loopback0 interface are padded. When some other strategy is adopted, only the sysname is padded.
[ vlan vlan-id ] circuit-id string circuit-id
[ vlan vlan-id ] remote-id string { remote-id | sysname }
·     Configure the padding content for the sub-option 9:
dhcp-snooping
information [ vlan vlan-id ] sub-option sub-option-code [ string user-string&<1-8> ]
Optional.
By default:
·     The padding content for the circuit ID sub-option depends on the padding format of Option 82.
·     The padding content for the remote ID sub-option depends on the padding format of Option 82.
·     Sub-option 9 is not padded.
Configuring DHCP snooping entries backup
DHCP snooping entries cannot survive a reboot. If the DHCP snooping device is rebooted, security modules (such as IP source guard) that use DHCP snooping entries to authenticate users will reject requests from clients until new entries are learned.
The DHCP snooping entries backup feature enables you to store DHCP snooping entries in a file. When the DHCP snooping device reboots, it reads DHCP snooping entries from this file.
Follow these guidelines when you configure DHCP snooping entries backup:
·     After DHCP snooping is disabled with the undo dhcp-snooping command, the switch will delete all DHCP snooping entries, including those stored in the file.
·     If you specify a subdirectory in the name of the file that stores DHCP snooping entries, make sure the subdirectory is available on each MPU. Otherwise, the system will fail to create the file on MPUs without the specified subdirectory. To solve this problem, cancel the current configuration and specify a new subdirectory in the file name.
To configure DHCP snooping entries backup:
Step
Remarks
N/A
2.     Specify the name of the file for storing DHCP snooping entries.
dhcp-snooping binding database filename filename
Not specified by default.
DHCP snooping entries are stored immediately after this command is used and then updated at the interval set by the dhcp-snooping binding database update interval command.
3.     Back up DHCP snooping entries to the file.
dhcp-snooping binding database update now
Optional.
DHCP snooping entries will be stored to the file each time this command is used.
4.     Set the interval at which the DHCP snooping entry file is refreshed.
dhcp-snooping binding database update interval minutes
Optional.
By default, the file is not refreshed periodically.
A DHCP starvation attack occurs when an attacker constantly sends forged DHCP requests using different MAC addresses in the chaddr field to a DHCP server. This exhausts the IP address resources of the DHCP server so legitimate DHCP clients cannot obtain IP addresses. The DHCP server might also fail to work because of exhaustion of system resources.
·     To relieve a DHCP starvation attack that uses DHCP packets encapsulated with different source MAC addresses, you can limit the number of MAC addresses that a Layer 2 port can learn.
·     To prevent a DHCP starvation attack that uses DHCP requests encapsulated with the same source MAC address, enable MAC address check on the DHCP snooping device. With this function enabled, the DHCP snooping device compares the chaddr field of a received DHCP request with the source MAC address field of the frame. If they are the same, the request is considered valid and forwarded to the DHCP server. If not, the request is discarded.
Step
Remarks
N/A
N/A
dhcp-snooping check mac-address
Enabling DHCP-request message attack protection
Attackers can forge DHCP-REQUEST messages to renew the IP address leases for legitimate DHCP clients that no longer need the IP addresses. These forged messages keep a victim DHCP server renewing the leases of IP addresses instead of releasing the IP addresses. This wastes IP address resources.
To prevent such attacks, you can enable DHCP-REQUEST message check on DHCP snooping devices. With this feature enabled, upon receiving a DHCP-REQUEST message, a DHCP snooping device looks up local DHCP snooping entries for the corresponding entry of the message. If an entry is found, the DHCP snooping device compares the entry with the message information. If they are consistent, the DHCP-REQUEST message is considered as a valid lease renewal request and forwarded to the DHCP server. If they are not consistent, the message is considered as a forged lease renewal request and discarded. If no corresponding entry is found, the message is considered valid and forwarded to the DHCP server.
To enable DHCP-REQUEST message check:
Step
Remarks
N/A
N/A
3.     Enable DHCP-REQUEST message check.
dhcp-snooping check request-message
You can enable DHCP-REQUEST message check only on Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
Displaying and maintaining DHCP snooping
Remarks
Display DHCP snooping entries.
display dhcp-snooping [ ip ip-address ] [ | { begin | exclude | include } regular-expression ]
Display Option 82 configuration information on the DHCP snooping device.
display dhcp-snooping information { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
Display DHCP packet statistics on the DHCP snooping device (in standalone mode).
display dhcp-snooping packet statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display DHCP packet statistics on the DHCP snooping device (in IRF mode).
display dhcp-snooping packet statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display information about trusted ports.
display dhcp-snooping trust [ | { begin | exclude | include } regular-expression ]
Display the DHCP snooping entry file information.
display dhcp-snooping binding database [ | { begin | exclude | include } regular-expression ]
Clear DHCP snooping entries.
reset dhcp-snooping { all | ip ip-address }
Clear DHCP packet statistics on the DHCP snooping device (in standalone mode).
reset dhcp-snooping packet statistics [ slot slot-number ]
Clear DHCP packet statistics on the DHCP snooping device (in IRF mode).
reset dhcp-snooping packet statistics [ chassis chassis-number slot slot-number ]
DHCP snooping configuration examples
IMPORTANT:
As shown in Figure 25, Switch B is connected to a DHCP server through GigabitEthernet 3/0/1, and to two DHCP clients through GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3. GigabitEthernet 3/0/1 forwards DHCP server responses but the other two do not.
Switch B records clients' IP-to-MAC address bindings in DHCP-REQUEST messages and DHCP-ACK messages received from trusted ports.
Figure 25 Network diagram
# Enable DHCP snooping.
[SwitchB] dhcp-snooping
# Specify GigabitEthernet 3/0/1 as trusted.
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] dhcp-snooping trust
[SwitchB-GigabitEthernet3/0/1] quit
DHCP snooping Option 82 support configuration example
As shown in Figure 25, DHCP snooping and Option 82 support are enabled on Switch B. The handling strategy for DHCP requests containing Option 82 is configured as replace.
On GigabitEthernet 3/0/2, configure the padding content for the circuit ID sub-option as company001 and for the remote ID sub-option as device001. On GigabitEthernet 3/0/3, configure the padding format as verbose, access node identifier as sysname, and code type as ascii for Option 82. Switch B forwards DHCP requests to the DHCP server (Switch A) after replacing Option 82 in the requests, so that the DHCP clients can obtain IP addresses.
# Configure GigabitEthernet 3/0/2 to support Option 82.
[SwitchB] interface GigabitEthernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] dhcp-snooping information enable
[SwitchB-GigabitEthernet3/0/2] dhcp-snooping information strategy replace
[SwitchB-GigabitEthernet3/0/2] dhcp-snooping information circuit-id string company001
[SwitchB-GigabitEthernet3/0/2] dhcp-snooping information remote-id string device001
[SwitchB-GigabitEthernet3/0/2] quit
# Configure GigabitEthernet 3/0/3 to support Option 82.
[SwitchB] interface GigabitEthernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] dhcp-snooping information enable
[SwitchB-GigabitEthernet3/0/3] dhcp-snooping information strategy replace
[SwitchB-GigabitEthernet3/0/3] dhcp-snooping information format verbose node-identifier sysname
[SwitchB-GigabitEthernet3/0/3] dhcp-snooping information circuit-id format-type ascii
[SwitchB-GigabitEthernet3/0/3] dhcp-snooping information remote-id format-type ascii
