09-ACL and QoS Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10009-ACL and QoS Configuration Examples
01-S12500_Packet_Filtering_Configuration_Examples
Introduction
This document provides packet filtering configuration examples.
Packet filtering uses ACLs to identify traffic based on matching criteria such as source IP address, destination IP address, and port number. When a packet matches an ACL rule, the device performs the predefined action, such as dropping or forwarding.
This document assumes that you have basic knowledge of H3C packet filtering.
Example: Configuring packet filtering
Network requirements
As shown in Figure 1, the FTP server at 129.1.1.2 in the internal IPv4 network provides FTP services (port 21) to external users.
Configure packet filtering on GigabitEthernet 4/0/1 to allow only the host at 20.3.3.3 to access the internal FTP server and deny all the other incoming FTP traffic.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S12500-CMW520-R1825P01.
Configuration procedures
# Configure VLAN 10 and VLAN 20.
[Device] vlan 10
[Device-vlan10] port Gigabitethernet 4/0/2
[Device-vlan10] quit
[Device] vlan 20
[Device-vlan20] port Gigabitethernet 4/0/1
[Device-vlan20] quit
[Device] interface GigabitEthernet 4/0/1
[Device-GigabitEthernet4/0/1] undo shutdown
[Device-GigabitEthernet4/0/1] quit
[Device] interface GigabitEthernet 4/0/2
[Device-GigabitEthernet4/0/2] undo shutdown
[Device-GigabitEthernet4/0/2] quit
[Device] interface vlan-interface 10
[Device-Vlan-interface10] ip address 192.1.1.1 24
[Device–Vlan-interface10] undo shutdown
[Device-Vlan-interface10] quit
[Device] interface vlan-interface 20
[Device-Vlan-interface20] ip address 20.1.1.1 24
[Device–Vlan-interface20] undo shutdown
[Device-Vlan-interface20] quit
# Create advanced IPv4 ACL 3000, and configure two rules: one permits TCP packets from the host to the internal FTP server, and the other denies packets sent to TCP port 21.
[Device] acl number 3000
[Device-acl-adv-3000] rule permit tcp destination-port eq 21 source 20.3.3.3 0 destination 129.1.1.2 0
[Device-acl-adv-3000] rule deny tcp destination-port eq 21
[Device-acl-adv-3000] quit
# Apply ACL 3000 to the inbound direction of GigabitEthernet 4/0/1.
[Device-GigabitEthernet4/0/1] packet-filter 3000 inbound
# Display packet filtering configuration on GigabitEthernet 4/0/1.
[Device] display packet-filter interface GigabitEthernet 4/0/1
Interface: GigabitEthernet4/0/1
 In-bound Policy:
  acl 3000, Successful
 Out-bound Policy:
Configuration files
acl number 3000
 rule 0 permit tcp source 20.3.3.3 0 destination 129.1.1.2 0 destination-port eq ftp
 rule 5 deny tcp destination-port eq ftp
vlan 1
vlan 10
vlan 20
interface Vlan-interface10
 ip address 129.1.1.1 255.255.255.0
interface Vlan-interface20
 ip address 20.1.1.1 255.255.255.0
interface GigabitEthernet4/0/1
 port link-mode bridge
 port access vlan 20
interface GigabitEthernet4/0/2
 port access vlan 10
Related documentation
·     H3C S12500 Routing Switch Series ACL and QoS Configuration Guide
·     H3C S12500 Routing Switch Series ACL and QoS Command Reference
