06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71006-Layer 3 - IP Routing Command Reference
04-OSPF commands
04-OSPF commands 354.74 KB
OSPF commands 1
abr-summary (OSPF area view) 1
area (OSPF view) 2
asbr-summary· 2
authentication-mode· 3
bandwidth-reference (OSPF view) 4
default 5
default-cost (OSPF area view) 6
default-route-advertise (OSPF view) 6
description (OSPF/OSPF area view) 8
display ospf abr-asbr 8
display ospf asbr-summary· 9
display ospf brief 11
display ospf cumulative· 14
display ospf error 16
display ospf graceful-restart 17
display ospf interface· 20
display ospf lsdb· 22
display ospf peer 25
display ospf peer statistics 27
display ospf request-queue· 29
display ospf retrans-queue· 30
display ospf routing· 31
display ospf vlink· 33
display router id· 34
enable link-local-signaling· 35
enable out-of-band-resynchronization· 35
fast-reroute (OSPF view) 36
filter (OSPF area view) 36
filter-policy export (OSPF view) 37
filter-policy import (OSPF view) 39
graceful-restart (OSPF view) 40
graceful-restart helper enable· 41
graceful-restart helper strict-lsa-checking· 42
graceful-restart interval (OSPF view) 42
host-advertise· 43
import-route (OSPF view) 44
ispf enable· 45
log-peer-change· 46
lsa-arrival-interval 46
lsdb-overflow-interval 47
lsa-generation-interval 48
lsdb-overflow-limit 49
maximum load-balancing (OSPF view) 49
maximum-routes 50
network (OSPF area view) 50
nssa· 51
opaque-capability enable· 52
ospf 53
ospf authentication-mode· 53
ospf bfd enable· 55
ospf cost 56
ospf dr-priority· 56
ospf fast-reroute lfa-backup· 57
ospf mib-binding· 57
ospf mtu-enable· 58
ospf network-type· 59
ospf timer dead· 60
ospf timer hello· 60
ospf timer poll 61
ospf timer retransmit 62
ospf trans-delay· 62
peer 63
preference· 64
reset ospf counters 65
reset ospf process 65
reset ospf redistribution· 66
rfc1583 compatible· 67
router id· 67
silent-interface (OSPF view) 68
snmp-agent trap enable ospf 69
snmp trap rate-limit 70
spf-schedule-interval 71
stub (OSPF area view) 71
stub-router 72
transmit-pacing· 73
vlink-peer (OSPF area view) 74
Use abr-summary to configure a summary route on an area border router (ABR).
Use undo abr-summary to remove a summary route.
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ]
undo abr-summary ip-address { mask | mask-length }
No route summarization is configured on an ABR.
OSPF area view
ip-address: Specifies the destination IP address of the summary route in dotted decimal notation.
mask: Specifies the mask of the IP address in dotted decimal notation.
mask-length: Specifies the mask length in the range of 0 to 32 bits.
advertise | not-advertise: Advertises the summary route or not. By default, the command advertises the summary route.
cost cost: Specifies the cost of the summary route, in the range of 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
This command is available only on an ABR to summarize multiple contiguous networks into one network.
To enable ABR to advertise more-specific routes, issue the undo abr-summary command.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 into 36.42.0.0/16.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area (OSPF view)
Use area to create an area and enter area view.
Use undo area to remove an area.
area area-id
undo area area-id
No OSPF area is created.
OSPF view
area-id: Specifies an area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format by the system.
# Create area 0 and enter area 0 view.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary
Use asbr-summary to configure a summary route on an ASBR.
Use undo asbr-summary to remove a summary route on an ASBR.
asbr-summary ip-address { mask | mask-length } [ cost cost | not-advertise | tag tag ] *
undo asbr-summary ip-address { mask | mask-length }
No route summarization is configured on an ASBR.
OSPF view
ip-address: Specifies the destination IP address of the summary route.
mask: Specifies the mask in dotted decimal notation.
cost cost: Specifies the cost of the summary route, in the range of 1 to 16777214. For Type-1 external routes, the cost defaults to the largest cost among routes that are summarized. For Type-2 external routes, the cost defaults to the largest cost among routes that are summarized plus 1.
not-advertise: Disables advertising the summary route. Without this keyword, the command advertises the route.
tag tag: Specifies a tag for marking the summary route, in the range of 0 to 4294967295. The default is 1. The tag can be used by a routing policy to control summary route advertisement.
With the asbr-summary command configured, an ASBR summarizes redistributed routes that fall into the specified address range into a single route and advertises the summary route in a Type-5 LSA to neighbors. If the ASBR resides in an NSSA area, it advertises the summary route in a Type-7 LSA.
With the asbr-summary command configured, an NSSA ABR summarizes matching routes described by Type-5 LSAs that are translated from Type-7 LSAs, and advertises the summary route to neighbors. This command does not take effect on non NSSA ABRs.
To enable ASBR to advertise more-specific routes, issue the undo asbr-summary command.
# Summarize redistributed static routes into a single route, and specify a tag value of 2 and a cost of 100 for the summary route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode
Use authentication-mode to specify an authentication mode for the OSPF area.
Use undo authentication-mode to restore the default.
authentication-mode { md5 | simple }
No authentication mode is configured for an area.
OSPF area view
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
Routers that reside in the same area must have the same authentication mode: no authentication, simple, or MD5.
# Configure OSPF Area 0 to use the MD5 authentication mode.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5
Use bandwidth-reference to specify a reference bandwidth value for link cost calculation.
Use undo bandwidth-reference to restore the default value.
bandwidth-reference value
The default value is 100 Mbps.
OSPF view
value: Specifies the bandwidth reference value for link cost calculation, in the range of 1 to 4294967 Mbps.
If no cost values are configured for links, OSPF calculates their cost values by using the formula: Cost = Reference bandwidth value/Link bandwidth. If the calculated cost is greater than 65535, the value of 65535 is used.
# Specify the reference bandwidth value as 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
default
Use default to configure default parameters for redistributed routes.
Use undo default to remove the configuration.
default { cost cost | tag tag | type type } *
undo default { cost | tag | type } *
The cost is 1, the tag is 1, and the route type is 2.
OSPF view
cost cost: Specifies the default cost for redistributed routes, in the range of 0 to 16777214.
tag tag: Specifies the tag for marking redistributed routes, in the range of 0 to 4294967295.
type type: Specifies the type for redistributed routes: 1 or 2.
# Configure the default cost, tag, and type as 10, 100, and 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 tag 100 type 2
import-route
Use default-cost to configure a cost for the default route advertised to the stub or NSSA area.
Use undo default-cost to restore the default value.
default-cost cost
undo default-cost
The cost is 1.
OSPF area view
cost: Specifies a cost for the default route advertised to the Stub or NSSA area, in the range of 0 to 16777214.
This command takes effect only on the ABR of a stub area or the ABR/ASBR of an NSSA area.
# Configure Area 1 as a stub area, and specify the cost of the default route advertised to the stub area as 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
·           nssa
·           stub
Use default-route-advertise to redistribute a default route into the OSPF routing domain.
Use undo default-route-advertise to restore the default.
default-route-advertise [ [ [ always | permit-calculate-other ] | cost cost | route-policy route-policy-name | type type ] * | summary cost cost ]
No default route is redistributed into the OSPF routing domain.
OSPF view
always: Generates a default route in a Type-5 LSA into the OSPF routing domain regardless of whether or not there is a default route in the routing table. If this keyword is not specified, the router generates a default route in a Type-5 LSA into the OSPF routing domain only when an active default route that does not belong to the current OSPF process exists in the IP routing table.
permit-calculate-other: Enables OSPF to calculate default routes received from other routers. Without this keyword, OSPF does not calculate default routes from other routers. If the router does not generate any default route in a Type-5 LSA into the OSPF routing domain, the router calculates default routes from other routers regardless of whether this keyword is specified.
cost cost: Specifies a cost for the default route, in the range of 0 to 16777214. If no cost is specified, the default cost specified by the default cost command applies.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When a default route exists in the routing table and the specified routing policy is matched, the command distributes a default route in a Type-5 LSA into the OSPF routing domain, and the routing policy modifies some values in the Type-5 LSA. If the always keyword is specified at the same time, the command can distribute a default route in a Type-5 LSA into the OSPF routing domain when the specified routing policy is matched, regardless of whether a default route exists in the routing table, and the routing policy modifies some values in the Type-5 LSA.
type type: Specifies a type for the Type-5 LSA: 1 or 2. If no type is specified, the default type for the Type-5 LSA specified by the default type command applies.
summary: Advertises the specified default route in a Type-3 LSA. This keyword is available only for VPNs.
This command redistributes a default route in a Type-5 LSA, which cannot be redistributed with the import-route command. If the local routing table has no default route, you must provide the always keyword for the command.
The default-route-advertise summary cost command is applicable only to VPNs. It enables a PE router to redistribute a default external route in a Type-3 LSA to CE routers.
# Generate a default route into the OSPF routing domain, regardless of whether the default route exists in the local routing table.
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
·           default
·           import-route
Use description to configure a description for an OSPF process or area.
description description
No description is configured for an OSPF process or area.
OSPF view, OSPF area view
description: Configures a description for the OSPF process in OSPF view, or for the OSPF area in OSPF area view. The description argument specifies a string of 1 to 80 characters.
The description specified by this command is used to identify an OSPF process or area.
# Describe OSPF process 100 as abc.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Describe OSPF area 0 as bone area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
Use display ospf abr-asbr to display routes to the ABR or ASBR.
display ospf [ process-id ] abr-asbr
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535.
If no process ID is specified, this command displays routes to the ABR/ASBR for all OSPF processes.
If you use this command on routers in a stub area, the commands displays no ASBR information.
# Display information about routes to the ABR or ASBR.
<Sysname> display ospf abr-asbr
          OSPF Process 1 with Router ID 192.168.1.2
                  Routing Table to ABR and ASBR
 Type        Destination       Area       Cost  Nexthop         RtType
 Inter       3.3.3.3           0.0.0.0    3124  10.1.1.2        ASBR
 Intra       2.2.2.2           0.0.0.0    1562  10.1.1.2        ABR
Type of the route to the ABR or ASBR:
·       IntraIntra-area route.
·       InterInter-area route.
Destination
Router ID of an ABR/ASBR.
Area
ID of the area of the next hop.
Cost
Cost from the router to the ABR/ASBR.
Nexthop
Next hop address.
RtType
Router type: ABR or ASBR.
Use display ospf asbr-summary to display information about the redistributed routes that are summarized.
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ]
ip-address: Specifies an IP address in dotted decimal notation.
If no OSPF process is specified, this command displays the summarized redistributed routes for all OSPF processes.
If no IP address is specified, this command displays all summarized redistributed routes.
# Display information about all summarized redistributed routes.
<Sysname> display ospf asbr-summary
                  Summary Addresses
 Total Summary Address Count: 1
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 The Count of Route is : 2
 Destination     Net Mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       2         2        1
 30.1.1.0        255.255.255.0   OSPF       2         2        1
Total number of summary routes.
Net
Address of the summary route.
Mask
Mask of the summary route address.
Tag
Tag of the summary route.
Status
Advertisement status of the summary route.
Cost
Cost to the summary network.
The Count of Route
Number of summarized routes.
Destination
Destination address of a summarized route.
Net Mask
Network mask of a summarized route.
Proto
Routing protocol.
Process
Process ID of the routing protocol.
Type of a summarized route.
Metric
Metric of a summarized route.
asbr-summary
display ospf brief
Use display ospf brief to display OSPF brief information.
display ospf [ process-id ] brief
If no OSPF process is specified, this command displays brief information about all OSPF processes.
# Display OSPF brief information.
<Sysname> display ospf brief
                  OSPF Protocol Information
 RouterID: 192.168.1.2      Router Type:  NSSA
 Route Tag: 0
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5
 LSA arrival interval: 1000
 Route Preference: 10
 ASE Route Preference: 150
 SPF Computation Count: 22
 RFC 1583 Compatible
 Graceful restart interval: 120
 This process is currently bound to MIB
 Area Count: 1   Nssa Area Count: 1
 ExChange/Loading Neighbors: 0
 SNMP trap rate limit interval: 2  Count: 300
 Area: 0.0.0.1          (MPLS TE  not enabled)
 Authtype: None Area flag: NSSA
 SPF Scheduled Count: 5
 Interface: 192.168.1.2 (GigabitEthernet3/0/1)
 Cost: 1       State: DR        Type: Broadcast    MTU: 1500
 Priority: 1
 Designated Router: 192.168.1.2
 Backup Designated Router: 192.168.1.1
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
 FRR backup: enable
OSPF process ID and OSPF router ID.
RouterID
Router ID.
Router Type
Router type:
·       ABR.
·       ASBR.
·       NSSA.
·       Null.
Route Tag
Tag of redistributed routes.
The OSPF process does not support multi-VPN-instance.
Applications Supported
MPLS Traffic-Engineering means MPLS TE is supported.
Interval for SPF calculations.
LSA generation interval.
LSA arrival interval.
Transmit pacing
LSU packet transmit rate of the interface:
·       Interval—LSU transmit interval of the interface.
·       Count—Maximum number of LSU packets sent each time.
Default ASE Parameter
Default ASE Parameters: metric, tag, route type.
Route Preference
Internal route preference.
External route preference.
SPF Computation count
SPF computation count of the OSPF process.
RFC1583 Compatible
Compatible with RFC 1583.
Area Count
Area number of the current process.
Nssa Area Count
NSSA area number of the current process.
SNMP trap sending interval.
Count
Number of sent SNMP traps.
State of the translator that translates Type-7 LSAs to Type-5 LSAs. The value can be one of the following:
·       Enabled—The translator is specified through commands.
·       Elected—The translator is designated through election.
·       Disabled—The device is not a translator that translates Type-7 LSAs to Type-5 LSAs.
Stability interval for Type-7 LSA-to-Type-5 LSA translation.
Neighbors in ExChange/Loading state.
Area
Area ID in the IP address format.
Authtype
Authentication type of the area:
·       None—No authentication.
·       Simple—Simple authentication.
·       MD5—MD5 authentication.
Area flag
Type of the area:
·       Normal.
·       Stub.
·       StubNoSummary (totally stub area).
·       NSSA.
·       NSSANoSummary (totally NSSA area).
SPF scheduled Count
SPF calculation count in the OSPF area.
Interface in the area.
Cost
Interface cost.
Interface state.
Interface network type.
MTU
Interface MTU.
Priority
Router priority.
Timers
OSPF timers:
·       HelloInterval for sending hello packets.
·       Dead—Interval within which the neighbor is down.
·       PollInterval for sending hello packets.
·       Retransmit—Interval for retransmitting LSAs.
FRR backup
Indicates whether Loop Free Alternate (LFA) calculation is enabled on an interface.
Use display ospf cumulative to display OSPF statistics.
display ospf [ process-id ] cumulative
If no process is specified, this command displays statistics for all OSPF processes.
# Display OSPF statistics.
<Sysname> display ospf cumulative
                  Cumulations
  IO Statistics
             Type        Input     Output
            Hello           61        122
   DB Description            2          3
   Link-State Req            1          1
Link-State Update            3          3
   Link-State Ack            3          2
  LSAs originated by this router
  Router: 4
  Network: 0
  Sum-Net: 0
  Sum-Asbr: 0
  External: 0
  NSSA: 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As: 0
  LSAs Originated: 4  LSAs Received: 7
  Routing Table:
    Intra Area: 2  Inter Area: 3  ASE/NSSA: 0
IO statistics
Statistics about input/output packets and LSAs.
OSPF packet type.
Input
Packets received.
Output
Packets sent.
Hello
Hell packet.
DB Description
Database Description packet.
Link-State Req
Link-State Request packet.
Link-State Update
Link-State Update packet.
Link-State Ack
Link-State Acknowledge packet.
LSAs originated by this router.
Router
Number of Type-1 LSAs originated.
Network
Number of Type-2 LSAs originated.
Sum-Net
Number of Type-3 LSAs originated.
Sum-Asbr
Number of Type-4 LSAs originated.
External
Number of Type-5 LSAs originated.
NSSA
Number of Type-7 LSAs originated.
Opq-Link
Number of Type-9 LSAs originated.
Opq-Area
Number of Type-10 LSAs originated.
Opq-As
Number of Type-11 LSAs originated.
LSA originated
Number of LSAs originated.
LSA Received
Number of LSAs received.
Routing Table
Routing table information.
Intra Area
Intra-area route number.
Inter Area
Inter-area route number.
ASE
ASE route number.
display ospf error
Use display ospf error to display OSPF error information.
display ospf [ process-id ] error
If no process is specified, this command displays OSPF error information for all OSPF processes.
# Display OSPF error information.
<Sysname> display ospf error
          OSPF Process 1 with Router ID 192.168.1.112
                  OSPF Packet Error Statistics
 0     : OSPF Router ID confusion      0     : OSPF bad packet
 0     : OSPF bad version              0     : OSPF bad checksum
 0     : OSPF bad area ID              0     : OSPF drop on unnumbered interface
 0     : OSPF bad virtual link         0     : OSPF bad authentication type
 0     : OSPF bad authentication key   0     : OSPF packet too small
 0     : OSPF Neighbor state low       0     : OSPF transmit error
 0     : OSPF interface down           0     : OSPF unknown neighbor
 0     : HELLO: Netmask mismatch       0     : HELLO: Hello timer mismatch
 0     : HELLO: Dead timer mismatch    0     : HELLO: Extern option mismatch
 0     : DD: MTU option mismatch       0     : DD: Unknown LSA type
 0     : DD: Extern option mismatch    0     : LS ACK: Bad ack
 0     : LS ACK: Unknown LSA type      0     : LS REQ: Empty request
 0     : LS REQ: Bad request           0     : LS UPD: LSA checksum bad
 0     : LS UPD: Unknown LSA type      0     : LS UPD: Received less recent LSA
Table 5 Command output
Packets with duplicate route ID.
OSPF bad packet
Packets illegal.
OSPF bad version
Packets with wrong version.
OSPF bad checksum
Packets with wrong checksum.
OSPF bad area ID
Packets with invalid area ID.
Packets dropped on the unnumbered interface.
Packets on wrong virtual links.
Packets with invalid authentication type.
Packets with invalid authentication key.
Packets too small in length.
Packets received in low neighbor state.
OSPF transmit error
Packets with error when being transmitted.
OSPF interface down
Shutdown times of the interface.
Packets received from unknown neighbors.
Hello packets with mismatched mask.
Hello packets with mismatched hello timer.
Hello packets with mismatched dead timer.
Hello packets with mismatched option field.
HELLO: Neighbor unknown
Hello packets received from unknown neighbors.
DD packets with mismatched MTU.
DD packets with unknown LSA type.
DD packets with mismatched option field.
LS ACK: Bad ack
Bad LSAck packets for LSU packets.
LSAck packets with unknown LSA type.
LSR packets with no request information.
LS REQ: Bad request
Bad LSR packets.
LSU packets with wrong LSA checksum.
LSU packets without latest LSA.
LSU packets with unknown LSA type.
Use display ospf graceful-restart to display GR information for an OSPF process.
verbose: Displays detailed GR information.
If no process ID is specified, this command displays GR information for all processes.
# Display detailed GR information.
<Sysname> display ospf graceful-restart verbose
              Graceful Restart information
Graceful Restart capability     : Enable(IETF)
Graceful Restart support        : Planned and un-planned,Partial
Helper capability               : Enable(IETF)
Helper support                  : Planned and un-planned(IETF),Strict LSA check
Current GR state                : Normal
Graceful Restart period         : 40 seconds
Number of neighbors under Helper: 0
Number of restarting neighbors  : 0
Last Restarter exit reason      : None
Last Helper exit reason         : None
Area: 0.0.0.0
Authtype: None Area flag: Normal
Area up Interface count: 2
Interface: 40.4.0.1 (Vlan-interface40)
Restarter state: Normal  State: P-2-P     Type: PTP
Neighbor count of this interface: 1
Neighbor        IP address      GR state     Last Helper exit reason
3.3.3.3         40.4.0.3        Normal       None
Virtual-link Neighbor-ID  -> 4.4.4.4, Neighbor-State: Full
Interface: 20.2.0.1 (Vlink)
Transit Area0.0.0.1
4.4.4.4         20.2.0.4        Normal       Reset neighbor
Table 6 Command output
GR information for OSPF process 1 with router ID 1.1.1.1.
Indicates whether GR is enabled:
·       Enable(IETF)—IETF GR is enabled.
·       Enable(nonstandard)—Non-IETF GR is enabled.
·       Disable—GR is disabled.
GR modes that the process supports (the modes are displayed only when GR is enabled):
·       Planned and un-planned—Supports both planned and unplanned GR.
·       Planned only—Supports only planned GR.
·       Partial—Supports partial GR.
·       Global—Supports global GR.
Helper capability
Helper capability that the process supports:
·       Enable (IETF)—Supports IETF GR Helper capability.
·       Enable (Nonstandard)—Supports non IETF GR Helper capability.
·       Enable (IETF and nonstandard)—Supports both IETF GR Helper capability and non IETF GR Helper capability.
·       Disable—Does not support GR Helper capability.
Helper support
Displays policies that the Helper supports (the policies are displayed only when Helper is enabled):
·       Strict lsa check—The Helper supports strict LSA checking.
·       Planned and un-planned—The Helper supports planned and unplanned GR.
·       Planned only—The Helper supports only planned GR.
Current GR state
GR state:
·       Normal—Normal state.
·       Under GR—GR is in process.
·       Under Helper—The process is acting as Helper.
Area
Area ID in IP address format.
Authtype
Area flag
Type of the area:
·       Normal.
·       Stub.
·       NSSA.
Number of up interfaces in the area.
Restarter state
Restarter state on the interface.
Interface state.
Neighbors of an interface.
Neighbor
Neighbor router ID.
IP address
Neighbor IP address.
GR state
Neighbor GR state:
·       Under Helper—The process is acting as GR Helper.
Reason that the Helper exited last time.
Router ID of the virtual link's neighbor.
Neighbor-State
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, and Full.
Output interface of the virtual link.
Use display ospf interface to display OSPF interface information.
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535.
verbose: Displays the OSPF information for all interfaces.
If no OSPF process is specified, this command displays the OSPF interface information for all OSPF processes.
If you do not provide the interface or the verbose keyword, this command displays OSPF brief information for all interfaces.
# Display all OSPF interface brief information.
<Sysname> display ospf interface
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
Table 7 Command output
Area
Area ID of the interface.
IP address
Interface IP address (regardless of whether TE is enabled or not).
Interface network type: PTP, PTMP, Broadcast, or NBMA.
Interface state:
·       DOWNNo protocol traffic can be sent or received on the interface.
·       WaitingThe interface starts sending and receiving Hello packets and the router is trying to determine the identity of the (Backup) designated router for the network.
·       p-2-pThe interface will send Hello packets at the interval of HelloInterval, and try to establish an adjacency with the neighbor.
·       DRThe router is the designated router on the network.
·       BDRThe router is the backup designated router on the network.
·       DROtherThe router is a DROther router on the attached network.
Cost
Interface cost.
Pri
Router priority.
DR
DR on the interface's network segment.
BDR
BDR on the interface's network segment.
# Display detailed information about VLAN-interface 7.
<Sysname> display ospf interface Vlan-interface 7
                  Interfaces
 Interface: 172.16.0.1 (Vlan-interface7)
 Priority: 1
 Designated Router: 172.16.0.1
 Backup Designated Router: 0.0.0.0
 Timers: Hello 10, Dead 40, Poll  40, Retransmit 5, Transmit Delay 1
 FRR backup: enable
Table 8 Command output
Information about the interface, such as the IP address.
Timers
OSPF timers: hello, dead, poll, retransmit, and transmit delay.
FRR backup
Indicates whether LFA calculation is enabled on an interface.
display ospf lsdb
Use display ospf lsdb to display OSPF LSDB information.
display ospf [ process-id ] lsdb [ brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ]
brief: Displays brief LSDB information.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
network: Displays Type-2 LSA (Network LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
router: Displays Type-1 LSA (Router LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
link-state-id: Specifies a Link state ID, in the IP address format.
originate-router advertising-router-id: Displays information about LSAs originated by the specified router.
self-originate: Displays information about self-originated LSAs.
If no OSPF process is specified, this command displays LSDB information for all OSPF processes.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
         OSPF Process 1 with Router ID 192.168.0.1
                 Link State Database
                         Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004   0
 Router    192.168.0.1     192.168.0.1        21   36    80000009   0
 Network   192.168.0.1     192.168.0.1        321  32    80000003   0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002   1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002   1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1        21   36    80000005   0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002   2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002   1
Type 9 Opaque (Link-Local Scope) Database
 Flags: * -Vlink interface LSA
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Interfaces
*Opq-Link  3.0.0.0         7.2.2.1            8    14    80000001   10.1.1.2
*Opq-Link  3.0.0.0         7.2.2.2            8    14    80000001   20.1.1.2
Table 9 Command output
Area
LSDB information of the area.
LSA type (see Table 4).
LinkState ID
Link state ID.
AdvRouter
Advertising router.
Age
Age of the LSA.
Len
Length of the LSA.
Sequence
Sequence number of the LSA.
Metric
Cost of the LSA.
*Opq-Link
Opaque LSA generated by a virtual link.
# Display Type-2 LSA (Network LSA) information in the LSDB.
<Sysname> display ospf 1 lsdb network
                          Area: 0.0.0.0
                  Link State Database
    Type      : Network
    LS ID     : 192.168.0.2
    Adv Rtr   : 192.168.2.1
    LS Age    : 922
    Len       : 32
    Options   :  E
    Seq#      : 80000003
    Checksum    : 0x8d1b
    Net Mask  : 255.255.255.0
       Attached Router    192.168.1.1
       Attached Router    192.168.2.1
                          Area: 0.0.0.1
                  Link State Database
    Type      : Network
    LS ID     : 192.168.1.2
    Adv Rtr   : 192.168.1.2
    LS Age    : 782
    Len       : 32
    Options   :  NP
    Seq#      : 80000003
    Checksum    : 0x2a77
       Attached Router    192.168.1.2
Table 10 Command output
LSA type.
LS ID
DR IP address.
Adv Rtr
Router that advertised the LSA.
LS Age
LSA age time.
Len
LSA length.
Options
LSA options:
·       O—Opaque LSA advertisement capability.
·       E—AS External LSA reception capability.
·       EA—External extended LSA reception capability.
·       DC—On-demand link support.
·       N—NSSA external LSA support.
·       P—Capability of an NSSA ABR to translate Type-7 LSAs into Type-5 LSAs.
Seq#
LSA sequence number.
Checksum
LSA checksum.
Net Mask
Network mask.
Attached Router
ID of the router that established adjacency with the DR, and ID of the DR itself.
display ospf peer
Use display ospf peer to display information about OSPF neighbors.
display ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ]
process-id: Specifies an OSPF process by ID in the range of 1 to 65535.
verbose: Displays detailed neighbor information.
neighbor-id: Specifies a neighbor router ID.
If no OSPF process is specified, this command displays OSPF neighbor information for all OSPF processes.
If the verbose keyword is not specified, this command displays brief OSPF neighbor information.
If no interface is specified, this command displays the neighbor information for all interfaces.
If no neighbor ID is specified, this command displays all neighbor information.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
                  Neighbors
 Area 0.0.0.0 interface 1.1.1.1(GigabitEthernet3/0/1)'s neighbors
 Router ID: 1.1.1.2          Address: 1.1.1.2          GR State: Normal
   State: Full  Mode: Nbr is Master  Priority: 1
   DR: 1.1.1.2  BDR: 1.1.1.1  MTU: 0
   Dead timer due in 33  sec
   Neighbor is up for 02:03:35
Table 11 Command output
Area areaID interface IPAddress(InterfaceName)'s neighbors
Neighbor information of the interface in the specified area:
·       areaID—Area to which the neighbor belongs.
·       IPAddress—Interface IP address.
·       InterfaceName—Interface name.
Router ID
Neighbor router ID.
Address
Neighbor router address.
GR State
GR state.
Neighbor state:
·       Down—Initial state of a neighbor conversation.
·       Init—The router has seen a Hello packet from the neighbor. However, the router has not established bidirectional communication with the neighbor (the router itself did not appear in the neighbor's hello packet).
·       Attempt— Available only in an NBMA network, Under this state, the OSPF router has not received any information from a neighbor for a period but can send Hello packets at a longer interval to keep neighbor relationship.
·       2-Way—Communication between the two routers is bidirectional. The router itself appears in the neighbor's Hello packet.
·       Exstart—The goal of this state is to decide which router is the master, and to decide upon the initial Database Description (DD) sequence number.
·       Exchange—The router is sending DD packets to the neighbor, describing its entire link-state database.
·       Loading—The router sends LSRs packets to the neighbor, requesting more recent LSAs.
·       Full—The neighboring routers are fully adjacent.
Mode
Neighbor mode for LSDB synchronization.
Priority
Neighboring router priority.
DR
DR on the interface’s network segment.
BDR
BDR on the interface’s network segment.
MTU
Interface MTU.
Options
LSA options:
This dead timer will expire in 33 seconds.
The neighbor has been up for 02:03:35.
Authentication sequence number.
Count of neighbor state changes.
# Display brief OSPF neighbor information.
                        Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time Interface       State
 1.1.1.2         1.1.1.2         1   40        GE3/0/1         Full/DR
Table 12 Command output
Area
Neighbor area.
Router ID
Neighbor router ID.
Address
Neighbor interface address.
Pri
Dead-Time
Dead interval remained.
Interface connected to the neighbor.
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading or Full.
Use display ospf peer statistics to display OSPF neighbor statistics.
If no OSPF process is specified, this command displays OSPF neighbor statistics for all OSPF processes.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
          OSPF Process 1 with Router ID 10.3.1.1
                    Neighbor Statistics
  Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
  0.0.0.0         0    0       0    0     0       0        0       1    1
  0.0.0.2         0    0       0    0     0       0        0       1    1
  Total           0    0       0    0     0       0        0       2    2
Table 13 Command output
Area ID
The state statistics information of all the routers in the area to which the router belongs is displayed.
Down
Number of neighboring routers in Down state in the same area.
Attempt
Number of neighboring routers in Attempt state in the same area.
Init
Number of neighboring routers in Init state in the same area.
2-Way
Number of neighboring routers in 2-Way state in the same area.
ExStart
Number of neighboring routers in ExStart state in the same area.
Exchange
Number of neighboring routers in Exchange state in the same area.
Loading
Number of neighboring routers in Loading state in the same area.
Full
Number of neighboring routers in Full state in the same area.
Total
Total number of neighbors under the same state: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, or Full.
Use display ospf request-queue to display OSPF request queue information.
neighbor-id: Specifies a neighbor's router ID.
If no OSPF process is specified, this command displays the OSPF request queue information for all OSPF processes.
If no interface is specified, this command displays the OSPF request queue information for all interfaces.
If no neighbor is specified, this command displays the OSPF request queue information for all OSPF neighbors.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
  The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
  Interface 10.1.1.1         Area 0.0.0.0
  Request list:
       Type       LinkState ID      AdvRouter         Sequence   Age
       Router     2.2.2.2           1.1.1.1           80000004   1
       Network    192.168.0.1       1.1.1.1           80000003   1
       Sum-Net    192.168.1.0       1.1.1.1           80000002   2
Table 14 Command output
Neighbor router ID.
Address
Neighbor interface IP address.
Local interface IP address.
Area
Area ID.
Request list
Request list information.
LSA type.
LinkState ID
Link state ID.
AdvRouter
Advertising router.
Sequence
Age
LSA age.
Use display ospf retrans-queue to display retransmission queue information.
If no OSPF process is specified, this command displays retransmission queue information for all OSPF processes.
If no interface is specified, this command displays retransmission queue information for all interfaces.
If no neighbor is specified, this command displays retransmission queue information for all neighbors.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
  Retransmit list:
       Router     2.2.2.2           2.2.2.2           80000004   1
       Network    12.18.0.1         2.2.2.2           80000003   1
       Sum-Net    12.18.1.0         2.2.2.2           80000002   2
Table 15 Command output
Neighbor router ID.
Address
Interface address of the router.
Area
Area ID.
Retrans List
Retransmission list.
LSA type.
LinkState ID
Link state ID.
AdvRouter
Advertising router.
Sequence
Age
LSA age.
Use display ospf routing to display OSPF routing information.
display ospf [ process-id ] routing [ ip-address { mask | mask-length } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
ip-address: Specifies a destination IP address.
mask-length: Specifies mask length in the range of 0 to 32 bits.
interface interface-type interface-number: Displays routes passing the specified output interface.
nexthop nexthop-address: Displays routes passing the specified next hop.
verbose: Displays detailed OSPF routing information.
If no OSPF process is specified, this command displays the routing information for all OSPF processes.
If no interface is specified, this command displays OSPF routing information for all interfaces.
If no next hop is specified, this command displays all OSPF routing information.
# Display OSPF routing information.
<Sysname> display ospf routing
                   Routing Tables
 Routing for Network
 Destination        Cost  Type       NextHop         AdvRouter     Area
 192.168.1.0/24     1562  Stub       192.168.1.2     192.168.1.2   0.0.0.0
 172.16.0.0/16      1563  Inter      192.168.1.1     192.168.1.1   0.0.0.0
 Total Nets: 2
 Intra Area: 1  Inter Area: 1  ASE: 0  NSSA: 0
Table 16 Command output
Destination
Destination network.
Cost
Cost to destination.
Route type: intra-area, transit, stub, inter-area, Type-1 external, Type-2 external.
NextHop
Next hop address.
AdvRouter
Advertising router.
Area
Area ID.
Total Nets
Total networks.
Intra Area
Total intra-area routes.
Inter Area
Total inter-area routes.
ASE
Total ASE routes.
NSSA
Total NSSA routes.
# Display detailed OSPF routing information.
<Sysname> display ospf routing verbose
          OSPF Process 2 with Router ID 192.168.1.112
                   Routing Tables
 Routing for Network
 Destination: 192.168.1.0/24
        Cost: 1562                    Type: Stub
   AdvRouter: 192.168.1.2             Area: 0.0.0.0
  SubProtoID: 0x1               Preference: 10
     NextHop: 192.168.1.2        BkNextHop: N/A
 NetworkType: Broadcast      BkNetworkType: N/A
 Destination: 172.16.0.0/16
        Cost: 1563                    Type: Inter
   AdvRouter: 192.168.1.1             Area: 0.0.0.0
     NextHop: 192.168.1.1        BkNextHop: N/A
 Total Nets: 2
 Intra Area: 2  Inter Area: 0  ASE: 0  NSSA: 0
Table 17 Command output
SubProtoID
Sub protocol ID.
Preference
OSPF preference.
NbrId
Neighbor router ID.
NextHop
Primary next hop IP address.
BkNextHop
Backup next hop IP address.
NetworkType
Type of the network to which the primary next hop belongs.
BkNetworkType
Type of the network to which the backup next hop belongs.
Preference
OSPF route preference.
display ospf vlink
Use display ospf vlink to display OSPF virtual link information.
If no OSPF process is specified, this command displays the OSPF virtual link information for all OSPF processes.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
                  Virtual Links
 Virtual-link Neighbor-ID  -> 2.2.2.2, Neighbor-State: Full
 Interface: 10.1.2.1 (GigabitEthernet3/0/1)
 Cost: 1562  State: P-2-P  Type: Virtual
 Transit Area: 0.0.0.1
 Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
Table 18 Command output
ID of the neighbor on the virtual link.
Neighbor-State
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, Full.
IP address and name of the local interface on the virtual link.
Cost
Interface route cost.
Interface state.
Virtual link.
Transit Area
Transit area ID.
Timers
Values of timers: hello, dead, retransmit, and interface transmission delay.
display router id
Use display router id to display the global router ID.
display router id
# Display the global router ID.
<Sysname> display router id
         Configured router ID is 1.1.1.1
Use enable link-local-signaling to enable the OSPF link-local signaling (LLS) capability.
Use undo enable link-local-signaling to disable the OSPF LLS capability.
OSPF link-local signaling capability is disabled.
OSPF view
# Enable link-local signaling for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
Use enable out-of-band-resynchronization to enable the OSPF out-of-band resynchronization (OOB-Resynch) capability.
Use undo enable out-of-band-resynchronization to disable the OSPF out-of-band resynchronization capability.
The OSPF out-of-band resynchronization capability is disabled.
OSPF view
Before you configure this command, enable the link-local signaling capability.
# Enable the out-of-band resynchronization capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
Use fast-reroute to configure OSPF FRR.
Use undo fast-reroute to restore the default.
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
OSPF FRR is disabled.
OSPF view
lfa: Uses the LFA algorithm to calculate a backup next hop for all routes.
abr-only: Uses the next hop of the route to the ABR as the backup next hop.
route-policy route-policy-name: Uses a routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
Do not use OSPF FRR and BFD for OSPF at the same time. Otherwise, OSPF FRR might fail to work.
Do not use the fast-reroute lfa command together with the command vlink-peer, sham-link, enable traffic-adjustment, or enable traffic-adjustment advertise in MPLS Command Reference.
# Enable FRR to calculate a backup next hop for all routes by using LFA algorithm in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
This command is available only on an ABR.
Use filter to configure OSPF to filter inbound/outbound Type-3 LSAs on an ABR.
Use undo filter to disable Type-3 LSA filtering.
filter { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
Type-3 LSAs are not filtered.
OSPF area view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter inbound/outbound Type-3 LSAs.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
export: Filters Type-3 LSAs advertised to other areas.
import: Filters Type-3 LSAs advertised into the local area.
# Use IP prefix list my-prefix-list to filter inbound Type-3 LSAs, and use ACL 2000 to filter outbound Type-3 LSAs in OSPF Area 1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
Use filter-policy export to configure OSPF to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
Redistributed routes are not filtered.
OSPF view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes by destination address.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
protocol: Filters routes redistributed from the specified routing protocol, which can be bgp, direct, isis, ospf, rip, and static. If no protocol is specified, this command filters all redistributed routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. This argument is available only when the protocol is rip, ospf or isis.
To reference an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·           To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·           To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. The specified subnet mask must be contiguous. Otherwise, the mask configuration does not take effect.
# Use ACL 2000 to filter redistributed routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16. Use ACL 3000 to filter redistributed routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
import-route
Use filter-policy import to configure OSPF to filter routes calculated using received LSAs.
Use undo filter-policy import to restore the default.
filter-policy { acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
Routes calculated using received LSAs are not filtered.
OSPF view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter inbound routes by destination.
gateway prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound routes by next hop.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound routes by destination.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter inbound routes.
To reference an advanced ACL (with a number from 3000 to 3999) in the command or in the specified routing policy, configure the ACL in one of the following ways:
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address. The specified subnet mask must be contiguous. Otherwise, the mask configuration does not take effect.
# Use ACL 2000 to filter inbound routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16. Use ACL 3000 to filter inbound routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
Use graceful-restart to enable OSPF GR.
Use undo graceful-restart to disable OSPF GR.
graceful-restart [ ietf | nonstandard ] [ global | planned-only ] *
OSPF GR is disabled.
OSPF view
ietf: Enables IETF GR.
nonstandard: Enables non-IETF GR.
global: Enables global GR. In global GR mode, a GR process can be completed only when all GR Helpers exist. A GR process fails if a GR Helper fails (for example, the interface connected to the GR Helper goes down). Without this keyword, this command enables partial GR. In partial GR mode, a GR process can be completed if a GR Helper exists.
planned-only: Enables planned only GR. Without this keyword, this command enables both planned GR and unplanned GR.
GR includes planned GR and unplanned GR:
·           Planned GRManually restart OSPF or perform an active/standby switchover. Before OSPF restart or active/standby switchover, the GR Restarter sends Grace-LSAs to GR Helpers.
·           Non-planned GR—OSPF restarts or an active/standby switchover occurs because of device failure. Before OSPF restart or active/standby switchover, the GR Restarter does not send Grace-LSAs to GR Helpers.
Before enabling IETF GR for OSPF, enable Opaque LSA advertisement and reception with the opaque-capability enable command.
Before enabling non-IETF GR for OSPF, enable OSPF LLS with the enable link-local-signaling command and OOB-Resynch with the enable out-of-band-resynchronization command.
If you do not provide the nonstandard or ietf keyword, the command enables non-IETF GR for OSPF.
# Enable IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# Enable non-IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
·           enable link-local-signaling
·           enable out-of-band-resynchronization
·           opaque-capability enable
Use graceful-restart helper enable to enable OSPF GR Helper capability.
Use undo graceful-restart helper enable to disable OSPF GR Helper capability.
OSPF GR Helper capability is enabled.
OSPF view
planned-only: Enable only planned GR for the GR Helper. Without this keyword, this command enables both planned GR and unplanned GR for the GR Helper.
The planned-only keyword is available only for the IETF GR Helper.
# Enable GR Helper capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper enable
Use graceful-restart helper strict-lsa-checking to enable strict LSA checking capability for GR Helper.
Use undo graceful-restart helper strict-lsa-checking to disable strict LSA checking capability for GR Helper.
Strict LSA checking capability for GR Helper is disabled.
OSPF view
When an LSA change on the GR Helper is detected, the GR Helper device exits the GR Helper mode.
# Enable strict LSA checking capability for GR Helper in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper strict-lsa-checking
Use graceful-restart interval to configure the GR interval.
Use undo graceful-restart interval to restore the default GR interval.
graceful-restart interval interval-value
The GR interval is 120 seconds.
OSPF view
interval-value: Specifies the GR interval in the range of 40 to 1800 seconds.
The value of the GR restart interval cannot be smaller than the maximum OSPF neighbor dead time of all the OSPF interfaces. Otherwise, GR restart might fail.
# Configure the GR interval for OSPF process 1 as 100 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
ospf timer dead
host-advertise
Use host-advertise to advertise a host route.
Use undo host-advertise to remove a host route.
host-advertise ip-address cost
undo host-advertise ip-address
No host route is advertised.
OSPF area view
ip-address: Specifies the IP address of a host.
cost: Specifies a cost for the route, in the range of 1 to 65535.
# Advertise host route 1.1.1.1 with a cost of 100.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
Use import-route to redistribute AS-external routes from another routing protocol.
Use undo import-route to disable route redistribution from another routing protocol.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | [ cost cost | route-policy route-policy-name | tag tag | type type ] *
OSPF does not redistribute AS-external routes from any other routing protocol.
OSPF view
protocol: Redistributes routes from the specified protocol, which can be bgp, direct, isis, ospf, rip, or static.
process-id: Specifies an process by its ID in the range of 1 to 65535. The default is 1. It is available only when the protocol is rip, ospf, or isis.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. It is available only when the protocol is bgp.
cost cost: Specifies a route cost in the range of 0 to 16777214. The default is 1.
route-policy route-policy-name: Uses the specified routing policy to filter redistributed routes. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag for marking external LSAs, in the range of 0 to 4294967295. The default is 1.
type type: Specifies a cost type, 1 or 2. The default is 2.
This command redistributes routes destined for other ASs from another protocol. AS external routes include the following types:
·           Type-1 external route
·           Type-2 external route
A Type-1 external route has high reliability. Its cost is comparable with the cost of OSPF internal routes. The cost from an OSPF router to a Type-1 external route's destination equals the cost from the router to the ASBR plus the cost from the ASBR to the external route's destination.
A Type-2 external route has low credibility. OSPF considers the cost from the ASBR to the destination of a Type-2 external route is much bigger than the cost from the ASBR to an OSPF internal router. The cost from an internal router to a Type-2 external route's destination equals the cost from the ASBR to the Type-2 external route's destination.
The import-route command cannot redistribute default external routes.
The import-route bgp command redistributes only EBGP routes. Because the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes and might cause routing loops, use it with caution.
Only active routes can be redistributed. To view information about active routes, use the display ip routing-table protocol command.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute routes from RIP process 40 and specify the type, tag, and cost as 2, 33, and 50 for redistributed routes.
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
ispf enable
Use ispf enable to enable OSPF incremental SPF (ISPF).
Use undo ispf enable to disable OSPF ISPF.
ispf enable
undo ispf enable
OSPF ISPF is enabled.
OSPF view
Upon topology changes, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Enable ISPF for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] ispf enable
log-peer-change
Use log-peer-change to enable the logging of OSPF neighbor state changes.
Use undo log-peer-change to disable the logging of OSPF neighbor state changes.
log-peer-change
The logging of OSPF neighbor state changes is enabled.
OSPF view
After you enable this feature, the information about OSPF neighbor state changes will be output to the terminal.
# Disable the logging of neighbor state changes for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
Use lsa-arrival-interval to specify the LSA arrival interval.
Use undo lsa-arrival-interval to restore the default.
lsa-arrival-interval interval
The LSA arrival interval is 1000 milliseconds.
OSPF view
interval: Specifies the LSA arrival interval in the range of 0 to 60000 milliseconds.
If an LSA that has the same LSA type, LS ID, originating router ID as the previous LSA is received within the interval, OSPF discards the LSA. This feature helps protect resources from being over consumed due to frequent network changes.
The interval set with the lsa-arrival-interval command should be smaller or equal to the initial interval set with the lsa-generation-interval command.
# Set the LSA arrival interval to 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
Use lsdb-overflow-interval to configure the interval that OSPF exits overflow state.
Use undo lsdb-overflow-interval to restore the default.
The OSPF exit overflow interval is 300 seconds.
OSPF view
interval: Specifies the interval that OSPF exits overflow state, in the range of 0 to 2147483647 seconds.
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. In this state, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself to save system resources.
You can configure the interval that OSPF exits overflow state. An interval of 0 indicates that the timer is not started and OSPF does not exit overflow state.
# Configure the OSPF exit overflow interval as 10 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-interval 10
Use lsa-generation-interval to configure the OSPF LSA generation interval.
Use undo lsa-generation-interval to restore the default.
The maximum interval is 5 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 0 milliseconds.
OSPF view
maximum-interval: Specifies the maximum LSA generation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum LSA generation interval in the range of 10 to 60000 milliseconds. 0 indicates that the minimum interval can be any value.
incremental-interval: Specifies the LSA generation incremental interval in the range of 10 to 60000 milliseconds.
When network changes are not frequent, LSAs are generated at the minimum-interval. If network changes become frequent, the LSA generation interval is incremented by incremental-interval × 2n-2 (n is the number of generation times) each time a LSA generation occurs until the maximum-interval is reached.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Configure the maximum LSA generation interval as 2 seconds, minimum interval as 100 milliseconds and incremental interval as 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
lsdb-overflow-limit
Use lsdb-overflow-limit to specify the upper limit of external LSAs in the LSDB.
Use undo lsdb-overflow-limit to restore the default.
lsdb-overflow-limit number
The number of external LSAs is not limited.
OSPF view
number: Specifies the upper limit of external LSAs in the LSDB, in the range of 1 to 1000000.
# Specify the upper limit of external LSAs as 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
maximum load-balancing (OSPF view)
Use maximum load-balancing to specify the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing maximum
The maximum number of ECMP routes is 32.
OSPF view
maximum: Specifies the maximum number of ECMP routes, in the range of 1 to 32. No ECMP load balancing is available when the number is set to 1.
# Specify the maximum number of ECMP routes as 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
maximum-routes
Use maximum-routes to specify the maximum number of OSPF routes.
Use undo maximum-routes to restore the default.
maximum-routes number
undo maximum-routes
The maximum number of OSPF routes is 4294967295.
OSPF view
number: Specifies the maximum number of OSPF routes, in the range of 0 to 4294967295.
# Specify the maximum number of OSPF routes as 500.
[Sysname] ospf 100
[Sysname-ospf-100] maximum-routes 500
network (OSPF area view)
Use network to enable OSPF on the interface attached to the specified network in the area.
Use undo network to disable OSPF for the interface attached to the specified network in the area.
undo network ip-address wildcard-mask
OSPF is not enabled for any interface.
OSPF area view
View
OSPF area view
ip-address: Specifies the IP address of a network.
wildcard-mask: Specifies the wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
This command enables OSPF on the interface attached to the specified network. The interface's primary IP address must be in the specified network. If only the interface's secondary IP address is in the network, the interface cannot run OSPF.
# Specify the interface whose primary IP address falls into 131.108.20.0/24 to run OSPF in Area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
ospf
nssa
Use nssa to configure the current area as an NSSA area.
Use undo nssa to restore the default.
nssa [ default-route-advertise | no-import-route | no-summary | translate-always | translator-stability-interval value ] *
undo nssa
No area is configured as an NSSA area.
OSPF area view
default-route-advertise: Usable on an NSSA ABR or an ASBR only. If it is configured on an NSSA ABR, the ABR generates a default route in a Type-7 LSA into the NSSA area regardless of whether a default route is available in the routing table. If it is configured on an ASBR, the ASBR generates a default route in a Type-7 LSA only when the default route is available in the routing table.
no-import-route: Usable only on an NSSA ABR that is also the ASBR of the OSPF routing domain to disable redistributing routes in Type-7 LSAs into the NSSA area, making sure that correct external routes are redistributed.
no-summary: Usable only on an NSSA ABR to advertise a default route in a Type-3 summary LSA into the NSSA area and to not advertise other summary LSAs into the area. Such an area is a totally NSSA area.
translate-always: Specifies the NSSA ABR as a translator to translate Type-7 LSAs to Type-5 LSAs.
translator-stability-interval value: Specifies the stability interval of the translator, during which the translator can maintain its translating capability after a device with a higher priority becomes the new translator. The value argument is the stability interval in the range of 0 to 900 seconds and defaults to 0 (which means the translator does not maintain its translating capability when a new translator arises).
All routers attached to an NSSA area must be configured with the nssa command in area view.
# Configure Area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] nssa
default-cost
Use opaque-capability enable to enable opaque LSA advertisement and reception.
Use undo opaque-capability to disable opaque LSA advertisement and reception.
The feature is enabled.
OSPF view
After the opaque LSA advertisement and reception is enabled, OSPF can receive and advertise Type-9, Type-10, and Type-11 opaque LSAs.
# Disable opaque LSA advertisement and reception.
[Sysname] ospf 100
[Sysname-ospf-100] undo opaque-capability
ospf
Use ospf to enable an OSPF process.
Use undo ospf to disable an OSPF process.
ospf [ process-id | router-id router-id | vpn-instance vpn- instance-name ] *
undo ospf [ process-id ]
No OSPF process is enabled.
router-id router-id: Specifies an OSPF router ID in dotted decimal notation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the OSPF process runs on the public network.
You can enable multiple OSPF processes on a router and specify different router IDs for them.
Enable an OSPF process before performing other tasks.
# Enable OSPF process 100 and specify router ID 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
ospf authentication-mode
Use ospf authentication-mode to set the authentication mode and key ID on an interface.
Use undo ospf authentication-mode to remove specified configuration.
For MD5/HMAC-MD5 authentication:
ospf authentication-mode { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string }
undo ospf authentication-mode { hmac-md5 | md5 } key-id
For simple authentication:
ospf authentication-mode simple { cipher cipher-string | plain plain-string }
undo ospf authentication-mode simple
No authentication is configured.
Interface view
hmac-md5: Enables HMAC-MD5 authentication.
md5: Enables MD5 authentication.
simple: Enables simple authentication.
key-id: Specifies a key by its ID in the range of 1 to 255.
cipher: Sets a ciphertext key.
cipher-string: Specifies a ciphertext key. For simple authentication, specify a case-sensitive key of 33 to 41 characters. For MD5/HMAC-MD5 authentication, specify a key of 33 to 53 characters.
plain: Sets a plaintext key.
plain-string: Specifies a plaintext key. For simple authentication, specify a case-sensitive key of 1 to 8 characters. For MD5/HMAC-MD5 authentication, specify a key of 1 to 16 characters.
Interfaces attached to the same network segment must have the same authentication password and authentication mode.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
# Enable MD5 authentication for the network 131.119.0.0/16 in Area 1. Set the interface key ID to 15, and plaintext authentication password to 123456.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] network 131.119.0.0 0.0.255.255
[Sysname-ospf-100-area-0.0.0.1] authentication-mode md5
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-Vlan-interface10] ospf authentication-mode md5 15 plain 123456
# Enable simple authentication for the network 131.119.0.0/16 in Area 1. Set the plaintext authentication password to 123456.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] authentication-mode simple
[Sysname-Vlan-interface10] ospf authentication-mode simple plain 123456
authentication-mode
ospf bfd enable
Use ospf bfd enable to enable BFD on an OSPF interface.
Use undo ospf bfd enable to disable BFD on an OSPF interface.
ospf bfd enable [ echo ]
BFD for OSPF is disabled.
Interface view
echo: Enables BFD single-hop echo detection. Without this keyword, this command enables BFD bidirectional control detection.
Do not use OSPF FRR and BFD for OSPF at the same time. Otherwise, OSPF FRR might fail to take effect.
# Enable BFD for OSPF on VLAN-interface 11.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[Sysname-Vlan-interface11] ospf bfd enable
ospf cost
Use ospf cost to set an OSPF cost for an interface.
Use undo ospf cost to restore the default.
ospf cost value
undo ospf cost
An interface computes its OSPF cost according to the interface bandwidth.
Interface view
value: Specifies an OSPF cost in the range of 0 to 65535 for a loopback interface and in the range of 1 to 65535 for other interfaces.
The ospf cost command sets an OSPF cost for an interface. If you do not use this command, the interface automatically computes its OSPF cost.
# Set the OSPF cost on VLAN-interface 10 to 65.
[Sysname-Vlan-interface10] ospf cost 65
ospf dr-priority
Use ospf dr-priority to set the router priority for DR/BDR election on an interface.
Use undo ospf dr-priority to restore the default value.
ospf dr-priority priority
The router priority is 1.
Interface view
priority: Specify the router priority for the interface, in the range of 0 to 255.
The greater the value, the higher the priority for DR/BDR election. If a device has a priority of 0, it will not be elected as a DR or BDR.
# Set the router priority on VLAN-interface 10 to 8.
[Sysname-Vlan-interface10] ospf dr-priority 8
ospf fast-reroute lfa-backup
Use ospf fast-reroute lfa-backup to enable LFA on the interface.
Use undo ospf fast-reroute lfa-backup to disable LFA on the interface.
LFA is enabled on the interface.
If you enable LFA on an interface, it can be selected as a backup interface. After you disable LFA on the interface, it cannot be selected as a backup.
# Disable VLAN-interface 11 from calculating a backup next hop by using the LFA algorithm.
[Sysname-Vlan-interface11] undo ospf fast-reroute lfa-backup
ospf mib-binding
Use ospf mib-binding to bind an OSPF process to MIB operation for responding to SNMP requests.
Use undo ospf mib-binding to restore the default.
ospf mib-binding process-id
MIB operation is bound to the OSPF process with the smallest process ID.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535.
# Bind MIB operation to OSPF process 100.
[Sysname] ospf mib-binding 100
ospf mtu-enable
Use ospf mtu-enable to enable an interface to add the interface MTU into DD packets.
Use undo ospf mtu-enable to restore the default.
ospf mtu-enable
The MTU in DD packets is 0.
Interface view
After a virtual link is established through a Virtual-Template or Tunnel, two devices on the link from different vendors might have different MTU values. To make them consistent, restore the interfaces' MTU to the default value 0.
After you configure this command, the interface checks whether the MTU in a received DD packet is greater than its own MTU. If yes, the interface discards the packet.
# Enable VLAN-interface 10 to add the interface MTU value into DD packets.
[Sysname-Vlan-interface10] ospf mtu-enable
ospf network-type
Use ospf network-type to set the network type for an interface.
Use undo ospf network-type to restore the default network type for an interface.
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p }
The network type of an interface is broadcast.
Interface view
broadcast: Specifies the network type as broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
unicast: Specifies the P2MP interface to unicast OSPF packets. By default, a P2MP interface multicasts OSPF packets.
p2p: Specifies the network type as P2P.
If a router on a broadcast network does not support multicast, configure the network type for the connected interfaces as NBMA.
If any two routers on an NBMA network are directly connected through a virtual link, the network is fully meshed, and you can configure the network type for the connected interfaces as NBMA. If two routers are not directly connected, configure the P2MP network type so that the two routers can exchange routing information through another router.
When the network type of an interface is NBMA or P2MP unicast, you must use the peer command to specify the neighbor.
If only two routers run OSPF on a network, you can configure the network type for the connected interfaces as P2P.
When the network type of an interface is P2MP unicast, all OSPF packets are unicast by the interface.
# Configure the OSPF network type for VLAN-interface 10 as NBMA.
[Sysname-Vlan-interface10] ospf network-type nbma
ospf dr-priority
ospf timer dead
Use ospf timer dead to set the neighbor dead interval.
Use undo ospf timer dead to restore the default.
ospf timer dead seconds
The dead interval is 40 seconds for broadcast and P2P interfaces. The dead interval is 120 seconds for P2MP and NBMA interfaces.
Interface view
seconds: Specifies the dead interval in the range of 1 to 2147483647 seconds.
If an interface receives no hello packet from a neighbor within the dead interval, the interface considers the neighbor down. The dead interval on an interface is at least four times the hello interval. Routers attached to the same segment must have the same dead interval.
# Configure the dead interval for VLAN-interface 10 as 60 seconds.
[Sysname-Vlan-interface10] ospf timer dead 60
ospf timer hello
ospf timer hello
Use ospf timer hello to set the hello interval on an interface.
Use undo ospf timer hello to restore the default.
ospf timer hello seconds
The hello interval is 10 seconds for P2P and broadcast interfaces, and is 30 seconds for P2MP and NBMA interfaces.
Interface view
seconds: Specifies the hello interval in the range of 1 to 65535 seconds.
The shorter the hello interval, the faster the topology converges, and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Configure the hello interval on VLAN-interface as 20 seconds.
[Sysname-Vlan-interface10] ospf timer hello 20
ospf timer dead
ospf timer poll
Use ospf timer poll to set the poll interval on an NBMA interface.
Use undo ospf timer poll to restore the default.
ospf timer poll seconds
The poll interval is 120 seconds on an interface.
Interface view
seconds: Specifies the poll interval in the range of 1 to 2147483647 seconds.
When an NBMA interface finds its neighbor is down, it sends hello packets at the poll interval.
The poll interval must be at least four times the hello interval.
# Set the poll timer interval on VLAN-interface 10 to 130 seconds.
[Sysname-Vlan-interface10] ospf timer poll 130
ospf timer hello
ospf timer retransmit
Use ospf timer retransmit to set the LSA retransmission interval on an interface.
Use undo ospf timer retransmit to restore the default.
ospf timer retransmit interval
The LSA retransmission interval is 5 seconds on an interface.
Interface view
interval: Specifies the LSA retransmission interval in the range of 1 to 3600 seconds.
After sending an LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement within the retransmission interval, it retransmits the LSA.
To avoid unnecessary retransmissions, set the retransmission interval as needed.
# Set the LSA retransmission interval to 8 seconds on VLAN-interface 10.
[Sysname-Vlan-interface10] ospf timer retransmit 8
ospf trans-delay
Use ospf trans-delay to set the LSA transmission delay on an interface.
Use undo ospf trans-delay to restore the default.
ospf trans-delay seconds
The LSA transmission delay is 1 second.
Interface view
seconds: Specifies the LSA transmission delay in the range of 1 to 3600 seconds.
Each LSA in the LSDB has an age that is incremented by 1 every second, but the age does not change during transmission. Adding a transmission delay into the age time is important in low speed networks.
# Set the LSA transmission delay to 3 seconds on VLAN-interface 10.
[Sysname-Vlan-interface10] ospf trans-delay 3
peer
Use peer to specify a neighbor and a DR priority for the neighbor.
Use undo peer to remove the configuration.
peer ip-address [ cost value | dr-priority dr-priority ]
undo peer ip-address
No neighbor is specified.
OSPF view
ip-address: Specifies a neighbor IP address.
cost value: Specifies the cost to reach the neighbor, in the range of 1 to 65535.
dr-priority dr-priority: Specifies the neighbor DR priority, in the range of 0 to 255. The default neighbor DR priority is 1.
On an X.25 or Frame Relay network, you can configure mappings to make the network fully meshed (any two routers have a direct link in between), so OSPF can handle DR/BDR election as it does on a broadcast network.
Routers on the network cannot find neighbors through broadcasting hello packets, so you must specify neighbors and neighbor DR priorities on the routers.
After startup, a router sends a hello packet to neighbors with DR priorities higher than 0. When the DR and BDR are elected, the DR will send hello packets to all neighbors for adjacency establishment.
The cost set with the peer command applies only to P2MP neighbors. If no cost is specified, the cost to the neighbor equals the local interface's cost.
A router uses the priority set with the peer command to determine whether to send a hello packet to the neighbor rather than for DR election. The DR priority set with the ospf dr-priority command is used for DR election.
# Specify the neighbor 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
ospf dr-priority
preference
Use preference to set a preference for OSPF.
Use undo preference to restore the default.
preference [ ase ] [ route-policy route-policy-name ] value
undo preference [ ase ]
The preference is 10 for OSPF internal routes and 150 for OSPF external routes (or ASE routes).
OSPF view
ase: Sets a preference for OSPF external routes. Without this keyword, the command sets a preference for OSPF internal routes.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a preference for the specified routes.
value: Specifies the preference value in the range of 1 to 255. The smaller the value, the higher the preference.
If multiple routing protocols find routes to the same destination, the router uses the route found by the protocol with the highest preference.
# Set a preference of 200 for OSPF external routes.
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
# Use a routing policy to set a preference.
[Sysname] ip prefix-list test index 10 permit 100.1.1.0 24
[Sysname] route-policy pre permit node 10
[Sysname-route-policy-pre-10] if-match ip-prefix test
[Sysname-route-policy-pre-10] quit
[Sysname] ospf 100
[Sysname-ospf-100] preference route-policy pre
reset ospf counters
Use reset ospf counters to clear OSPF statistics.
reset ospf [ process-id ] counters
process-id: Clears the statistics an OSPF process specified by its ID in the range of 1 to 65535.
# Clear OSPF statistics for all processes.
<Sysname> reset ospf counters
reset ospf process
Use reset ospf process to restart all OSPF processes or a specified process.
graceful-restart: Resets the OSPF process by using GR.
If no process is specified, this command restarts all OSPF processes.
The reset ospf process command performs the following actions:
·           Clears all invalid LSAs without waiting for their timeouts.
·           Makes a newly configured Router ID take effect.
·           Starts a new round of DR/BDR election.
·           Does not remove previous OSPF configurations.
The system prompts you to select whether to reset OSPF process upon execution of this command.
# Reset all OSPF processes.
<Sysname> reset ospf process
Reset OSPF process? [Y/N]:y
reset ospf redistribution
Use reset ospf redistribution to restart route redistribution.
If no process ID is specified, this command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
rfc1583 compatible
Use rfc1583 compatible to enable compatibility with RFC 1583.
Use undo rfc1583 compatible to disable compatibility with RFC 1583.
rfc1583 compatible
Compatibility with RFC 1583 is enabled.
OSPF view
RFC 1583 specifies a different method than RFC 2328 for selecting the best route from multiple AS external routes destined for the same network. Using this command makes them compatible. If RFC 2328 is compatible with RFC 1583, the intra-area route in the backbone area is preferred. If not, the intra-area route in the non-backbone area is preferred to reduce the burden of the backbone area.
# Disable compatibility with RFC 1583.
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
router id
Use router id to configure a global router ID.
Use undo router id to restore the default.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies the router ID, in the format of an IPv4 address.
OSPF uses a router ID to identify a device. If no router ID is specified, the global router ID is used.
If no global router ID is configured, the highest loopback interface IP address is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status (up or down).
During an active/standby switchover, the new active main processing unit (MPU) checks whether the previously backed up router ID is valid. If not, it selects a new router ID.
A new router ID is selected only when the interface IP address used as the router ID is removed or changed. Other events will not trigger a router ID re-selection. For example, router ID re-selection is not triggered when the interface goes down, you change the router ID to the address of a loopback interface after a physical interface address is selected as the router ID, or a higher interface IP address is configured as the router ID.
After a router ID is changed, you must use the reset command to enable it.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
silent-interface (OSPF view)
Use silent-interface to disable an interface or all interfaces from sending and receiving OSPF packets.
Use undo silent-interface to remove the configuration.
An interface can send and receive OSPF packets.
OSPF view
all: Specifies all interfaces.
A disabled interface is a passive interface that cannot send or receive any hello packets.
To disable a network from receiving OSPF routes, issue the command on the interface connected to the network.
# Disable VLAN-interface 10 from sending and receiving OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
snmp-agent trap enable ospf
Use snmp-agent trap enable ospf to enable the sending of SNMP traps for a specific OSPF process.
Use undo snmp-agent trap enable ospf to disable the feature.
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
OSPF trap sending is enabled.
authentication-failure: Specifies traps about authentication failures on an interface.
bad-packet: Specifies traps about error messages received on an interface.
config-error: Specifies traps about error configuration of an interface.
grhelper-status-change: Specifies traps about GR Helper state change.
grrestarter-status-change: Specifies traps about GR Restarter state change.
if-state-change: Specifies traps about interface state change.
lsa-maxage: Specifies LSA max age traps.
lsa-originate: Specifies traps about locally generated LSAs.
lsdb-approaching-overflow: Specifies traps about approaching LSDB overflows.
lsdb-overflow: Specifies LSDB overflow traps.
neighbor-state-change: Specifies traps about neighbor state change.
nssatranslator-status-change: Specifies traps about NSSA translator state change.
retransmit: Specifies traps about packets that are received and forwarded on an interface.
virt-authentication-failure: Specifies traps about authentication failures on a virtual interface.
virt-bad-packet: Specifies traps about error messages received on a virtual interface.
virt-config-error: Specifies traps about error configuration of a virtual interface.
virt-retransmit: Specifies traps about packets that are received and forwarded on a virtual interface.
virtgrhelper-status-change: Specifies traps about neighbor GR Helper state changes of a virtual interface.
virtif-state-change: Specifies traps about virtual interface state change.
virtneighbor-state-change: Specifies traps about the neighbor state change of a virtual interface.
# Enable OSPF to send SNMP traps about authentication failures on an interface.
[Sysname] snmp-agent trap enable ospf authentication-failure
snmp trap rate-limit
Use snmp trap rate-limit to configure the number of output traps in a specific time.
Use undo snmp trap rate-limit to restore the default.
OSPF outputs 7 traps in 10 seconds.
OSPF view
trap-interval: Specifies the trap output interval in the range of 1 to 60 seconds.
trap-number: Specifies the number of output traps in a specific time, in the range of 0 to 300.
# Configure OSPF to output 10 traps in 5 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] snmp trap rate-limit interval 5 count 10
spf-schedule-interval
Use spf-schedule-interval to set the OSPF SPF calculation interval.
Use undo spf-schedule-interval to restore the default.
The maximum calculation interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF view
maximum-interval: Specifies the maximum OSPF SPF calculation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
Based on the LSDB, an OSPF router uses SPF to calculate a shortest path tree with itself as the root. OSPF uses the shortest path tree to determine the next hop to a destination. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being over-consumed due to frequent topology changes.
When network changes are not frequent, OSPF performs SPF calculations at the minimum-interval. If network changes become frequent, the SPF calculation interval is incremented by the incremental-interval each time a calculation happens until the maximum-interval is reached.
# Configure the maximum SPF calculation interval as 10 seconds, minimum interval as 500 milliseconds and incremental interval as 300 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 300
stub (OSPF area view)
Use stub to configure an area as a stub area.
Use undo stub to restore the default.
stub [ default-route-advertise | no-summary ] *
undo stub
No area is a stub area.
OSPF area view
default-route-advertise-always: Usable only on a stub ABR. With this keyword, the ABR advertises a default route in a Type-3 LSA into the stub area regardless of whether FULL-state neighbors exist in the backbone area. Without this keyword, the ABR advertises a default route in a Type-3 LSA into the stub area only when at least one FULL-state neighbor exists in the backbone area.
no-summary: Usable only on a stub ABR. With this keyword, the ABR advertises only a default route in a Type-3 LSA into the stub area without advertising any other Type-3 LSAs (such a stub area is a totally stub area).
To remove the default-route-advertise-always or stub no-summary configuration on the ABR, execute the stub command again to overwrite it.
To configure an area as a stub area, issue the stub command on all routers attached to the area.
# Configure Area 1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
default-cost
stub-router
Use stub-router to configure a router as a stub router.
Use undo stub-router to restore the default.
stub-router
undo stub-router
No router is a stub router.
OSPF view
The router LSAs sent by the stub router over different links contain different link type values. A value of 3 represents a link to a stub network, and the cost of the link is not changed. A value of 1, 2, or 4 represents a point-to-point link, a link to a transit network, or a virtual link, and the cost of such links is set to 65535. Neighbors on such links will not send packets to the stub router as long as they have a route with a smaller cost.
# Configure a stub router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
transmit-pacing
Use transmit-pacing to configure the maximum number of LSU packets that can be sent at the specified interval.
Use undo transmit-pacing to restore the default.
An OSPF interface sends up to three LSU packets every 20 milliseconds.
OSPF view
interval interval: Specifies an interval at which an interface sends LSU packets, in the range of 10 to 1000 milliseconds. If the router has multiple OSPF interfaces, increase this interval to reduce the total number of LSU packets sent by the router every second.
count count: Specifies the maximum number of LSU packets sent by an interface at each interval, in the range of 1 to 200. If the router has multiple OSPF interfaces, decrease the maximum number to reduce the total number of LSU packets sent by the router every second.
# Configure all the interfaces running OSPF process 1 to send up to 10 LSU packets every 30 milliseconds.
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
vlink-peer (OSPF area view)
Use vlink-peer to configure a virtual link.
Use undo vlink-peer to remove a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string } | retransmit seconds | simple { cipher cipher-string | plain plain-string } | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | { hmac-md5 | md5 } key-id | retransmit | simple | trans-delay ] *
No virtual link is configured.
OSPF area view
router-id: Specifies the router ID of the neighbor on the virtual link.
hello seconds: Sets the hello interval in the range of 1 to 8192 seconds. The default is 10. It must be identical with the hello interval on the virtual link neighbor.
retransmit seconds: Sets the retransmission interval in the range of 1 to 3600 seconds. The default is 5.
trans-delay seconds: Sets the transmission delay interval in the range of 1 to 3600 seconds. The default is 1.
dead seconds: Sets the dead interval in the range of 1 to 32768 seconds. The default is 40. It must be identical with that on the virtual link neighbor. The dead interval is at least four times the hello interval.
key-id: Specifies the key ID for MD5 or HMAC-MD5 authentication, in the range of 1 to 255.
cipher-string: Specifies a ciphertext key. For simple authentication, specify a key of 33 to 41 characters. For MD5/HMAC-MD5 authentication, specify a key of 33 to 53 characters.
plain-string: Specifies a plaintext key. For simple authentication, specify a key of 1 to 8 characters. For MD5/HMAC-MD5 authentication, specify a key of 1 to 61 characters.
As defined in RFC 2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
When you configure this command, follow these guidelines:
·           The smaller the hello interval is, the faster the network converges, and the more network resources are consumed.
·           A retransmission interval that is too small can cause unnecessary retransmissions. A large value is appropriate for a low speed link.
·           Specify an appropriate transmission delay with the trans-delay keyword.
The authentication mode at the non-backbone virtual link end is determined by the authentication mode at the backbone virtual link end. The two authentication modes (MD5 or simple) are independent, and you cannot specify either mode.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
·           authentication-mode
·           display ospf vlink
