06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71006-Layer 3 - IP Routing Command Reference
13-Routing policy commands
13-Routing policy commands 194.3 KB
Common routing policy configuration commands
apply as-path
Use apply as-path to set the AS_PATH attribute for BGP routes.
Use undo apply as-path to restore the default.
apply as-path as-number&<1-32> [ replace ]
undo apply as-path
No AS_PATH attribute is set.
Routing policy node view
as-number&<1-32>: Specifies an AS by its number in the range of 1 to 4294967295. &<1-32> indicates that the argument before it can be entered up to 32 times.
replace: Replaces the original AS numbers. If this keyword is not specified, the command adds the specified AS numbers before the original AS_PATH attribute.
# Configure node 10 in permit mode for routing policy policy1 to add AS number 200 before the original AS_PATH attribute of BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] if-match as-path 1
[Sysname-route-policy-policy1-10] apply as-path 200
·           display ip as-path
·           if-match ip as-path
·           ip as-path
apply comm-list delete
Use apply comm-list delete to delete the COMMUNITY attributes from BGP routes.
Use undo apply comm-list to restore the default.
No COMMUNITY attributes are deleted from BGP routes.
comm-list-number: Specifies a basic community list by its number in the range of 1 to 99 or an advanced community list by its number in the range of 100 to 199.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters that cannot comprise only numbers.
# Configure node 10 in permit mode for routing policy policy1 to remove the COMMUNITY attributes specified in community list 1 from BGP routes.
[Sysname-route-policy-policy1-10] apply comm-list 1 delete
ip community-list
apply community
Use apply community to set a specified COMMUNITY attribute for BGP routes.
Use undo apply community to remove the configuration.
undo apply community [ none | additive | { community-number&<1-32> | aa:nn&<1-32> | internet | no-advertise | no-export | no-export-subconfed } * [ additive ] ]
No COMMUNITY attribute is set for BGP routes.
none: Removes the COMMUNITY attributes of BGP routes.
community-number&<1-32>: Specifies a community sequence number in the range of 1 to 4294967295. &<1-32> indicates that the argument before it can be entered up to 32 times.
aa:nn&<1-32>: Specifies a community number; both aa and nn are in the range of 0 to 65535. &<1-32> indicates that the argument before it can be entered up to 32 times.
internet: Sets the INTERNET community attribute for BGP routes. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Sets the NO_ADVERTISE community attribute for BGP routes. Routes with this attribute cannot be advertised to any peers.
no-export: Sets the NO_EXPORT community attribute for BGP routes. Routes with this attribute cannot be advertised out of the AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Sets the NO_EXPORT_SUBCONFED community attribute for BGP routes. Routes with this attribute cannot be advertised out of the local AS or to other sub-ASs in the confederation.
additive: Adds the specified COMMUNITY attribute to the original COMMUNITY attribute of BGP routes.
# Configure node 16 in permit mode for routing policy setcommunity to set the NO_EXPORT community attribute for BGP routes.
[Sysname-route-policy-setcommunity-16] apply community no-export
·           if-match community
·           ip community-list
apply cost
Use apply cost to set a cost for routing information.
Use undo apply cost to restore the default.
apply cost [ + | - ] value
undo apply cost
No cost is set for routing information.
+: Increases a cost value.
-: Decreases a cost value.
value: Specifies a cost in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to set a cost of 120 for OSPF external routes.
[Sysname-route-policy-policy1-10] if-match route-type external-type1or2
[Sysname-route-policy-policy1-10] apply cost 120
apply cost-type
Use apply cost-type to set a cost type for routing information.
Use undo apply cost-type to restore the default.
apply cost-type { external | internal | type-1 | type-2 }
No cost type is set for routing information.
external: Sets the cost type to IS-IS external route.
internal: Sets the cost type to IS-IS internal route, or sets the MED value for a matching BGP route to the IGP metric of the route's next hop.
type-1: Sets the cost type to OSPF Type-1 external route.
type-2: Sets the cost type to OSPF Type-2 external route.
Used for IS-IS, the apply cost-type internal command sets the cost type for a matching IS-IS route to IS-IS internal route.
Used for BGP, the apply cost-type internal command sets the MED for a matching BGP route learned from an IBGP peer to the IGP metric of the route's next hop before BGP advertises the route to an EBGP peer.
# Configure node 10 in permit mode for routing policy policy1 to set the cost type for routes that have a tag of 8 to IS-IS internal route.
[Sysname-route-policy-policy1-10] if-match tag 8
[Sysname-route-policy-policy1-10] apply cost-type internal
apply extcommunity
Use apply extcommunity to apply the specified extended community attribute.
Use undo apply extcommunity to restore the default.
No extended community attribute is set for BGP routes.
{ rt route-target }&<1-32>: Sets the RT extended community attribute, a string of 3 to 21 characters. &<1-32> indicates that the argument before it can be entered up to 32 times.
A route-target has the following forms:
·           16-bit AS numberA 32-bit self-defined number, for example, 101:3. The AS number is in the range of 0 to 65535, and the self-defined number is in the range of 0 to 4294967295.
·           32-bit IP addressA 16-bit self-defined number, for example, 192.168.122.15:1. The self-defined number is in the range of 0 to 65535.
·           32-bit AS numberA 16-bit self-defined number, for example, 70000:3. The AS number is in the range of 65536 to 4294967295, and the self-defined number is in the range of 0 to 65535.
additive: Adds the specified attribute to the original extended community attribute.
# Configure node 10 in permit mode for routing policy policy1 to add the RT extended community attribute 100:2 to BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply extcommunity rt 100:2 additive
apply isis
Use apply isis to redistribute routes into a specified ISIS level.
Use undo apply isis to restore the default.
undo apply isis
No IS-IS level is set.
level-1: Redistributes routes into IS-IS Level-1.
level-1-2: Redistributes routes into both IS-IS Level-1 and Level-2.
level-2: Redistributes routes into IS-IS Level-2.
# Configure node 10 in permit mode for routing policy policy1 to redistribute routes that have a tag of 8 to IS-IS level-2.
[Sysname-route-policy-policy1-10] apply isis level-2
apply local-preference
Use apply local-preference to set a local preference for BGP routes.
Use undo apply local-preference to restore the default.
No local preference is set for BGP routes.
preference: Specifies a local preference in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to set a local preference of 130 for routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply local-preference 130
apply mpls-label
Use apply mpls-label to set MPLS labels for routing information.
Use undo apply mpls-label to restore the default.
apply mpls-label
No MPLS label is set for routing information.
If this command fails to assign an MPLS label to a route, the route will not be advertised.
# Configure node 10 in permit mode for routing policy policy1 to set MPLS labels for routes.
[Sysname-route-policy-policy1-10] apply mpls-label
apply origin
Use apply origin to set an ORIGIN attribute for BGP routes.
Use undo apply origin to restore the default.
undo apply origin
No ORIGIN attribute is set for BGP routes.
egp as-number: Sets the ORIGIN attribute to EGP. The as-number argument specifies an AS number in the range 1 to 4294967295 for EGP routes.
igp: Sets the ORIGIN attribute to IGP.
incomplete: Sets the ORIGIN attribute to UNKNOWN.
# Configure node 10 in permit mode for routing policy policy1 to set the ORIGIN attribute for routes matching AS path list 1 to IGP.
[Sysname-route-policy-policy1-10] apply origin igp
apply preference
Use apply preference to set a preference for a routing protocol.
Use undo apply preference to restore the default.
apply preference preference
No preference is set for a routing protocol.
preference: Specifies a preference in the range of 1 to 255.
If you have set preferences for routing protocols with the preference command, the apply preference command sets a new preference for the matching routing protocol. Non-matching routing protocols still use the preferences set by the preference command.
# Configure node 10 in permit mode for routing policy policy1 to set the preference for OSPF external routes to 90.
[Sysname-route-policy-policy1-10] apply preference 90
apply preferred-value
Use apply preferred-value to set a preferred value for BGP routes.
Use undo apply preferred-value to restore the default.
No preferred value is set for BGP routes.
preferred-value: Specifies a preferred value in the range of 0 to 65535.
# Configure node 10 in permit mode for routing policy policy1 to set a preferred value of 66 for BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply preferred-value 66
apply tag
Use apply tag to set a specified tag for RIP, OSPF, or IS-IS routing information.
Use undo apply tag to restore the default.
apply tag value
undo apply tag
No routing tag is set for RIP, OSPF, or IS-IS routing information.
value: Specifies the tag value in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to set a tag of 100.
[Sysname-route-policy-policy1-10] apply tag 100
continue
Use continue to specify the next node to be matched.
Use undo continue to restore the default.
continue [ node-number ]
undo continue
No next node is specified.
node-number: Specifies the routing policy node number in the range of 0 to 65535.
The specified next node must have a larger number than the current node.
Example
# Specify the next node 20 for node 10 of routing policy policy1.
[Sysname-route-policy-policy1-10] continue 20
display ip as-path
Use display ip as-path to display BGP AS path list information.
display ip as-path [ as-path-number ]
as-path-number: Specifies an AS path list by its number in the range of 1 to 256. Without this argument, the command displays information about all BGP AS path lists.
# Display information about BGP AS path list 1.
ListID    Mode      Expression
1         permit    2
ListID
AS path list ID.
Mode
Match mode:
·       permit
·       deny
Expression
Regular expression used to match routes.
display ip community-list
Use display ip community-list to display BGP community list information.
display ip community-list [ basic-community-list-number | adv-community-list-number | comm-list-name ]
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
If no community list is specified, this command displays information about all BGP community lists.
# Display information about all BGP community lists.
<Sysname> display ip community-list
Community List Basic aaa
        permit
Community List Advanced bbb
        permit  3333
Basic community list.
Advanced community list.
permit
Match mode:
·       permit
·       deny
display ip extcommunity-list
Use display ip extcommunity-list to display BGP extended community list information.
ext-comm-list-number: Specifies an extended community list by its number in the range of 1 to 199. Without this argument, the command displays information about all BGP extended community lists.
# Display information about BGP extended community list 1.
         permit rt : 9:6
Extended community list.
permit
Match mode:
·       permit.
·       deny
rt
Route Target (RT) extended community attribute.
display route-policy
Use display route-policy to display routing policy information.
display route-policy [ route-policy-name ]
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. Without this argument, this command displays information about all routing policies.
# Display information about routing policy 1.
<Sysname> display route-policy policy1
Route-policy: policy1
  permit : 1
          if-match cost 10
          continue: next node 11
          apply comm-list a delete
Route-policy
Routing policy name.
permit
Match mode:
·       permit
·       deny
if-match
Match criterion.
continue
Specify the next node to be matched.
apply
Action.
if-match as-path
Use if-match as-path to match BGP routes whose AS_PATH attribute matches a specified AS path list.
Use undo if-match as-path to remove the configuration.
if-match as-path as-path-number&<1-32>
undo if-match as-path [ as-path-number&<1-32> ]
No match criterion is configured.
as-path-number&<1-32>: Specifies an AS path list by its number in the range of 1 to 256. &<1-32> indicates that the argument before it can be entered up to 32 times.
# Define AS path list 2 to permit BGP routes containing AS number 200 or 300 to pass. Configure node 10 in permit mode for routing policy test to match AS path list 2.
[Sysname-route-policy-policy1-10] if-match as-path 2
·           apply as-path
·           ip as-path-acl
if-match community
Use if-match community to match BGP routes whose COMMUNITY attribute matches a specified community list.
Use undo if-match community to remove the configuration.
undo if-match community [ { basic-community-list-number | name comm-list-name } [ whole-match ] | adv-community-list-number ]&<1-32>
No community list match criterion is configured.
whole-match: Exactly matches the specified community list.
&<1-32>: Indicates that the argument before it can be entered up to 32 times.
# Configure community list 1 to permit BGP routes with community number 100 or 200. Then configure node 10 in permit mode for routing policy test to use community list 1 to match BGP routes.
[Sysname-route-policy-test-10] if-match community 1
·           apply community
·           ip community-list
if-match cost
Use if-match cost to match routing information having the specified cost.
Use undo if-match cost to restore the default.
if-match cost value
undo if-match cost
No cost match criterion is configured.
# Configure node 10 in permit mode for routing policy policy1 to permit routing information with a cost of 8.
[Sysname-route-policy-policy1-10] if-match cost 8
if-match extcommunity
Use if-match extcommunity to match BGP routes whose extended community attribute matches a specified extended community list.
Use undo if-match extcommunity to remove the configuration.
undo if-match extcommunity [ ext-comm-list-number&<1-32> ]
ext-comm-list-number&<1-32>: Specifies an extended community list by its number in the range of 1 to 199. &<1-32> indicates that the argument before it can be entered up to 32 times.
# Configure node 10 in permit mode for routing policy policy1 to match BGP routes whose extended community attribute matches extended community lists 100 and 150.
[Sysname] ip extcommunity-list 100 permit rt 100:100
[Sysname] ip extcommunity-list 150 permit rt 150:150
[Sysname-route-policy-policy1-10] if-match extcommunity 100 150
·           apply extcommunity
·           ip extcommunity-list
if-match interface
Use if-match interface to match routes having the specified output interface.
Use undo if-match interface to remove the configuration.
&<1-16>: Indicates that the argument before it can be entered up to 16 times.
BGP does not support criteria for matching against the output interface of routing information.
# Configure node 10 in permit mode for routing policy policy1 to permit routes with the output interface VLAN-interface 1.
[Sysname-route-policy-policy1-10] if-match interface vlan-interface 1
if-match local-preference
Use if-match local-preference to match BGP routes having the specified local preference.
Use undo if-match local-preference to restore the default.
No local preference match criterion is configured.
# Create node 10 in permit mode for routing policy policy1 to match BGP routes having a local preference of 2.
[Sysname-route-policy-policy1-10] if-match preference 2
if-match mpls-label
Use if-match mpls-label to specify the MPLS label match criterion.
Use undo if-match mpls-label to restore the default.
if-match mpls-label
No MPLS label match criterion is configured.
# Configure node 10 in permit mode for routing policy policy1 to match routes having MPLS labels.
[Sysname-route-policy-policy1-10] if-match mpls-label
if-match route-type
Use if-match route-type to configure a route-type match criterion.
Use undo if-match route-type to remove the configuration.
if-match route-type { external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
undo if-match route-type [ external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 ] *
No route-type match criterion is configured.
external-type1: Matches OSPF Type 1 external routes.
external-type1or2: Matches OSPF Type 1 and Type 2 external routes.
external-type2: Matches OSPF Type 2 external routes.
internal: Matches OSPF internal routes (including OSPF intra-area and inter-area routes).
is-is-level-1: Matches IS-IS Level-1 routes.
is-is-level-2: Matches IS-IS Level-2 routes.
nssa-external-type1: Matches OSPF NSSA Type 1 external routes.
nssa-external-type1or2: Matches OSPF NSSA Type 1 and 2 external routes.
nssa-external-type2: Matches OSPF NSSA Type 2 external routes.
# Configure node 10 in permit mode for routing policy policy1 to match OSPF internal routes.
[Sysname-route-policy-policy1-10] if-match route-type internal
if-match tag
Use if-match tag to match routing information having the specified tag.
Use undo if-match tag to restore the default.
if-match tag value
undo if-match tag
No tag match criterion is configured.
value: Specifies a tag in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to match RIP, OSPF, and IS-IS routing information having a tag of 8.
ip as-path
Use ip as-path to create an AS path list.
Use undo ip as-path to remove an AS path list.
ip as-path as-path-number { deny | permit } regular-expression
undo ip as-path as-path-number [ regular-expression | deny | permit ]
No AS path list is created.
as-path-number: Specifies a number for the AS path list, in the range of 1 to 256.
deny: Specifies the match mode for the AS path list as deny.
permit: Specifies the match mode for the AS path list as permit.
regular-expression: Specifies an AS path regular expression, a string of 1 to 63 characters.
BGP routing updates contain an AS_PATH attribute field that identifies the ASs through which the routes have passed. An AS path regular expression, for example, ^200. *100$, matches the AS_PATH attribute that starts with AS 200 and ends with AS 100. For the meanings of special characters used in regular expressions, see Fundamentals Configuration Guide.
# Create AS path list 1 to permit routes whose AS_PATH attribute starts with 10.
·           apply as-path
ip community-list
Use ip community-list to configure a community list entry.
Use undo ip community-list to remove a community list or entry.
undo ip community-list { basic-comm-list-num | basic basic-comm-list-name } [ deny | permit ] [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] *
undo ip community-list { adv-comm-list-num | advanced adv-comm-list-name } [ deny | permit ] [ regular-expression ]
No community list is configured.
basic-comm-list-num: Specifies a number for the basic community list, in the range of 1 to 99.
basic: Specifies a name for the basic communist list.
advanced: Specifies a name for the advanced communist list.
basic-comm-list-name: Specifies the basic community list name, a case-sensitive string of 1 to 63 characters that cannot comprise only letters.
adv-comm-list-name: Specifies the advanced community list name, a case-sensitive string of 1 to 63 characters that cannot comprise only letters.
adv-comm-list-num: Specifies the advanced community list number in the range of 100 to 199.
regular-expression: Specifies a regular expression for the advanced community list, a string of 1 to 63 characters. For more information about regular expressions, see Fundamentals Configuration Guide.
deny: Specifies the match mode for the community list as deny.
permit: Specifies the match mode for the community list as permit.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that the argument before it can be entered up to 32 times.
internet: Specifies the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Specifies the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to other BGP peers.
no-export: Specifies the NO_EXPORT community attribute. Routes with this attribute cannot be advertised out of the local AS or the local confederation but can be advertised to other ASs in the confederation.
no-export-subconfed: Specifies the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised out of the local AS, or to other sub-ASs in the local confederation.
# Configure basic community list 1 to permit routing information with the INTERNET community attribute.
# Configure advanced community list 100 to permit routing information with the COMMUNITY attribute starting with 10.
·           apply comm-list delete
·           apply community
·           display ip community-list
Use ip extcommunity-list to define an extended community list entry.
Use undo ip extcommunity-list to remove an extended community list.
ip extcommunity-list ext-comm-list-number { deny | permit } { rt route-target }&<1-32>
undo ip extcommunity-list ext-comm-list-number [ { deny | permit } [ rt route-target ]&<1-32> ]
No extended community list is defined.
ext-comm-list-number: Specifies a number for the extended community list, in the range of 1 to 199.
deny: Specifies the match mode for the extended community list as deny.
permit: Specifies the match mode for the extended community list as permit.
{ rt route-target }&<1-32>: Specifies the RT extended community attribute, a string of 3 to 21 characters. &<1-32> indicates that the argument before it can be entered up to 32 times.
·           A 16-bit AS number—A 32-bit self-defined number, for example, 101:3. The AS number is in the range of 0 to 65535, and the self-defined number is in the range of 0 to 4294967295.
·           A 32-bit IP address—A 16-bit self-defined number, for example, 192.168.122.15:1. The self-defined number is in the range of 0 to 65535.
·           A 32-bit AS number—A 16-bit self-defined number, for example, 70000:3. The AS number is in the range of 65536 to 4294967295, and the self-defined number is in the range of 0 to 65535.
# Define extended community list 1 to permit routes with RT 200:200 to pass.
·           display ip extcommunity-list
·           if-match extcommunity
route-policy
Use route-policy to create a routing policy and a node, and enter routing policy node view.
Use undo route-policy to remove a routing policy or a node of it.
No routing policy is created.
route-policy-name: Specifies a name for the routing policy, a case-sensitive string of 1 to 63 characters.
deny: Specifies the deny match mode for the routing policy node. If a route satisfies all the if-match clauses of the node, it is denied without matching against the next node. If not, it matches against the next node.
permit: Specifies the permit match mode for the routing policy node. If a route satisfies all the if-match clauses of the node, it is handled by the apply clauses of the node. If not, it matches against the next node.
node node-number: Specifies a number for the node, in the range of 0 to 65535. A node with a smaller number is matched first.
Use a routing policy to filter routing information. A routing policy can contain several nodes and each node comprises a set of if-match and apply clauses. The if-match clauses define the match criteria of the node and the apply clauses define the actions to be taken on packets matching the criteria. The relation between the if-match clauses of a node is logic AND: all the if-match clauses must be satisfied. The relation between nodes is logic OR: a packet passing a node passes the routing policy.
# Create node 10 in permit mode for routing policy policy1 and enter routing policy node view.
IPv4 routing policy configuration commands
apply fast-reroute
Use apply fast-reroute to set a backup link for fast route (FRR).
Use undo apply fast-reroute to remove the configuration.
apply fast-reroute backup-interface interface-type interface-number [ backup-nexthop ip-address ]
No backup link for FRR is configured.
backup-interface interface-type interface-number: Specifies a backup output interface. If the specified interface is a non-P2P interface (including NBMA and broadcast interfaces, such as an Ethernet interface or a VLAN interface), you must also specify a backup next hop.
backup-nexthop ip-address: Specifies a backup next hop.
This command sets a backup link in the routing policy for FRR.
Using the routing policy, a routing protocol can designate a backup link for specific routes to implement FRR. When the primary link fails, FRR immediately directs packets to the backup link to minimize interruption time.
# Configure node 10 of routing policy policy1 to set the backup output interface VLAN-interface 1 and backup next hop 193.1.1.8 for the route destined to 100.1.1.0/24.
[Sysname-route-policy-policy1-10] if-match ip address prefix-list abc
[Sysname-route-policy-policy1-10] apply fast-reroute backup-interface vlan-interface 1 backup-nexthop 193.1.1.8
apply ip-address next-hop
Use apply ip-address next-hop to set a next hop for IPv4 routes.
Use undo apply ip-address next-hop to restore the default.
No next hop is set for IPv4 routes.
ip-address: Specifies the next hop IP address.
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters.
This command cannot set a next hop for redistributed routes.
If you do not provide the public keyword or vpn-instance vpn-instance-name option for this command, the next hop belongs to the public network.
# Configure node 10 in permit mode for routing policy policy1 to set next hop 193.1.1.8 for routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply ip-address next-hop 193.1.1.8
display ip prefix-list
Use display ip prefix-list to display IPv4 prefix list statistics.
display ip prefix-list [ prefix-list-name ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. Without this argument, this command displays statistics for all IPv4 prefix lists.
# Display the statistics for IPv4 prefix list abc.
<Sysname> display ip prefix-list abc
Prefix-list: aaa
 Permitted 0
 Denied 0
         index: 10        deny   6.6.6.0/24              ge  26  le  28
Table 5 Command output
Prefix-list
Name of the IPv4 prefix list.
Permitted
Number of routes satisfying the match criterion.
Denied
Number of routes not satisfying the match criterion.
index
Index of an item.
deny
Match mode of the item:
·       permit
·       deny
6.6.6.0/24
IP address and mask.
ge
Greater-equal, the lower mask length.
le
Less-equal, the upper mask length.
·           ip prefix-list
·           reset ip prefix-list
if-match ip
Use if-match ip to match IPv4 routes whose destination, next hop, or source matches the specified IPv4 prefix list.
Use undo if-match ip to remove the configuration.
if-match ip { address | next-hop | route-source } { acl acl-number | prefix-list prefix-list-name }
undo if-match ip { address | next-hop | route-source } [ acl | prefix-list ]
No IPv4 prefix list match criterion is configured.
address: Matches the destination address of IPv4 routes.
next-hop: Matches the next hop of IPv4 routes.
route-source: Matches the source address of IPv4 route information.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999 for address, and in the range of 2000 to 2999 for next-hop and route-source.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
# Configure node 10 of routing policy policy1 to match IPv4 routing information whose next hop matches IP prefix list p1.
[Sysname-route-policy-policy1-10] if-match ip next-hop prefix-list p1
ip prefix-list
Use ip prefix-list to configure an IPv4 prefix list or an item for the list.
Use undo ip prefix-list to remove an IPv4 prefix list or an item of it.
undo ip prefix-list prefix-list-name [ index index-number ]
No IPv4 prefix list is configured.
prefix-list-name: Specifies a name for the IPv4 prefix list, a case-sensitive string of 1 to 63 characters.
index-number: Specifies an index number for an IPv4 prefix list item, in the range of 1 to 65535. An item with a smaller number is matched first.
deny: Specifies the deny mode. If a route matches the item, the route is denied without matching against the next item; if not, the route matches against the next item (suppose the IPv4 prefix list has multiple items).
permit: Specifies the permit mode. If a route matches the item, it passes the IPv4 prefix list. If not, it matches against the next item (suppose the IPv4 prefix list has multiple items).
ip-address mask-length: Specifies an IPv4 prefix and mask length. The value range for the mask-length argument is 0 to 32.
min-mask-length, max-mask-length: Specifies a prefix length range. The greater-equal keyword means "greater than or equal to" and the less-equal keyword means "less than or equal to." The range relation is mask-length <= min-mask-length <= max-mask-length <= 32. If only the min-mask-length is specified, the prefix length range is [ min-mask-length, 32 ]. If only the max-mask-length is specified, the prefix length range is [ mask-length, max-mask-length ]. If both min-mask-length and max-mask-length are specified, the prefix length range is [ min-mask-length, max-mask-length ].
An IPv4 prefix list is used to filter IPv4 addresses. It can contain multiple items, each of which specifies a range of IPv4 prefixes. The relation between the items is logic OR. If an item is passed, the IPv4 prefix list is passed. If no item is passed, the IP prefix list cannot be passed.
If both ip-address and mask-length are specified as 0.0.0.0 0, only the default route will be matched.
To match all routes, use 0.0.0.0 0 less-equal 32.
# Configure IP prefix list p1 to permit routes destined for network 10.0.0.0/8 and with mask length 17 or 18.
[Sysname] ip prefix-list p1 permit 10.0.0.0 8 greater-equal 17 less-equal 18
·           display ip prefix-list
Use reset ip prefix-list to clear IPv4 prefix list statistics.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. Without this argument, this command clears statistics for all IPv4 prefix lists.
# Clear the statistics for IPv4 prefix list abc.
<Sysname> reset ip prefix-list abc
·           ip prefix-list
IPv6 routing policy configuration commands
apply ipv6 next-hop
Use apply ipv6 next-hop to set a next hop for IPv6 routes.
Use undo apply ipv6 next-hop to restore the default.
No next hop is set for IPv6 routes.
ipv6-address: Specifies the next hop IPv6 address.
# Configure node 10 for routing policy policy1 to set next hop 3ffe:506::1 for IPv6 routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply ipv6 next-hop 3ffe:506::1
display ipv6 prefix-list
Use display ipv6 prefix-list to display IPv6 prefix list statistics.
display ipv6 prefix-list [ prefix-list-name ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. Without this argument, this command displays statistics for all IPv6 prefix lists.
# Display the statistics for all IPv6 prefix lists.
<Sysname> display ipv6 prefix-list
Prefix-list6: 666
 Permitted 0
 Denied 0
         index: 10        permit 6::/64                  ge  66  le  88
Table 6 Command output
Prefix-list6
Name of the IPv6 prefix list.
Permitted
Denied
index
Index number of an item.
permit
·       permit
·       deny
6::/64
IPv6 address and prefix length for matching.
ge
Greater-equal, the lower prefix length.
le
Less-equal, the upper prefix length.
·           ipv6 prefix-list
·           reset ipv6 prefix-list
if-match ipv6
Use if-match ipv6 to match IPv6 routes whose destination, next hop, or source matches the specified IPv6 prefix list.
Use undo if-match ipv6 to remove the configuration.
if-match ipv6 { address | next-hop | route-source } { acl acl6-number | prefix-list prefix-list-name
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
No IPv6 prefix list match criterion is configured.
address: Matches the destination address of IPv6 routing information.
next-hop: Matches the next hop of IPv6 routing information.
route-source: Matches the source address of IPv6 routing information.
acl acl6-number: Specifies an IPv6 ACL for filtering by its number in the range of 2000 to 3999 for address, and 2000 to 2999 for next-hop and route-source.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
# Configure node 10 of routing policy policy1 to permit routing information whose next hop matches IPv6 prefix list p1.
[Sysname-route-policy-policy1-10] if-match ipv6 next-hop prefix-list p1
ipv6 prefix-list
Use ipv6 prefix-list to configure an IPv6 prefix list or an item for it.
Use undo ipv6 prefix-list to remove an IPv6 prefix list or an item.
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
undo ipv6 prefix-list prefix-list-name [ index index-number ]
No IPv6 prefix list is configured.
prefix-list-name: Specifies a name for the IPv6 prefix list, a case-sensitive string of 1 to 63 characters.
index-number: Specifies an index number for an IPv6 prefix list item, in the range of 1 to 65535. An item with a smaller number is matched first.
deny: Specifies the deny mode. If a route matches the item, the route is denied without matching against the next item; if not, the route matches against the next item (suppose the IPv6 prefix list has multiple items).
permit: Specifies the permit mode. If a route matches the item, it passes the IPv4 prefix list. If not, it matches against the next item (suppose the IPv6 prefix list has multiple items).
ipv6-address prefix-length: Specifies an IPv6 prefix and prefix length. The value range for the prefix-length argument is 0 to 128. When specified as :: 0, the argument matches the default route.
greater-equal min-prefix-length: Greater than or equal to the minimum prefix length.
less-equal max-prefix-length: Less than or equal to the maximum prefix length.
The length relation is mask-length <= min-mask-length <= max-mask-length <= 128. If only the min-prefix-length is specified, the prefix length range is [ min-prefix-length, 128 ]. If only the max-prefix-length is specified, the prefix length range is [ prefix-length, max-prefix-length ]. If both the min-prefix-length and max-prefix-length are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
An IPv6 prefix list can have multiple items, and each of them specifies a range of IPv6 prefixes. The relation between items is logic OR. If a route passes an item, it passes the IPv6 prefix list.
If ipv6-address prefix-length is specified as :: 0, only the default route matches.
To match all routes, configure :: 0 less-equal 128.
# Permit IPv6 addresses with a mask length between 32 bits and 64 bits.
[Sysname] ipv6 prefix-list abc permit :: 0 greater-equal 32 less-equal 64
# Deny IPv6 addresses with a prefix 3FFE:D00::/32 and a prefix length greater than or equal to 32 bits.
[Sysname] ipv6 prefix-list abc deny 3FFE:D00:: 32 less-equal 128
·           display ipv6 prefix-list
Use reset ipv6 prefix-list to clear IPv6 prefix list statistics.
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. Without this argument, this command clears statistics for all IPv6 prefix lists.
# Clear the statistics for IPv6 prefix list abc.
<Sysname> reset ipv6 prefix-list abc
·           ipv6 prefix-list
