06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71006-Layer 3 - IP Routing Command Reference
07-Policy-based routing commands
07-Policy-based routing commands 99.88 KB
The switch operates in IRF or standalone (the default) mode. For more information about IRF, see IRF Configuration Guide.
apply next-hop
Use apply next-hop to set a next hop.
Use undo apply next-hop to remove the configuration.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] { ip-address }&<1-2> ]
No next hop is set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If no VPN is specified, the next hop belongs to the public network.
ip-address: Specifies the next-hop IP address.
direct: Specifies that the next hop must be directly connected to take effect.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered twice at most.
To configure two next hops for a policy node, you can enter two next hops in one command line or execute the command twice. The first next hop configured is the active next hop and the second is the standby next hop. With two next hops specified, only the active next hop takes effect. When the active next hop is not available, the standby next hop takes effect. When neither next hop is available, packets are forwarded according to the routing table.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters.
If no policy is specified, this command displays information about all policies.
If a policy name is specified, this command displays information about the specified policy.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Matches packets against the ACL.
apply next-hop
Specify a next hop for permitted packets.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
In standalone mode:
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ip policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Displays the PBR configuration and statistics on a card. The slot-number argument is the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the PBR configuration and statistics of a card on an IRF member device. The chassis-number argument is the ID of the IRF member device, and the slot-number argument is the number of the slot that holds the card. (In IRF mode.)
# Display PBR configuration and statistics on GigabitEthernet 3/0/1.
<Sysname> display ip policy-based-route interface GigabitEthernet 3/0/1
Policy based routing information for interface GigabitEthernet3/0/1(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Policy based routing information for interface GigabitEthernet 3/0/1:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit(no resource):
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
failed indicates that the policy (including all its nodes) failed to be assigned to the driver.
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), failed can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
Match mode of the node, permit or deny.
not support means the device does not support match criteria configured on the node; no resource means the device has insufficient ACL resources, and failed to assign ACL resources to the node.
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), not support and no resource can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
if-match acl
apply next-hop
Number of successful matches on the node (no statistics resource indicates insufficient statistics resources).
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), no statistics resource can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
Total matched
Total number of successful matches on all nodes.
reset ip policy-based-route statistics
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy Name              Interface Name
pr01                     GigabitEthernet 3/0/1
Interface Name
Interface where the policy is applied.
if-match acl
Use if-match acl to configure an ACL match criterion.
Use undo if-match acl to remove the ACL match criterion.
if-match acl acl-number
undo if-match acl
No ACL match criterion is configured.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 for a basic ACL and in the range of 3000 to 3999 for an advanced ACL.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
Use ip policy-based-route to configure interface PBR by applying a policy on an interface.
Use undo ip policy-based-route to remove the configuration.
ip policy-based-route policy-name
No policy is applied on an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
You can apply only one policy on an interface. Before you apply a new policy, you must first remove the current policy from the interface.
# Apply policy aaa on VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan2] interface vlan-interface 2
[Sysname-Vlan-interface2] ip policy-based-route aaa
·           display ip policy-based-route setup
·           policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter policy node view.
Use undo policy-based-route to remove a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy node is created.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number in the range of 0 to 65535. A smaller number has a higher priority.
If the specified policy node already exists, the command directly places you into policy node view.
A policy that has been applied on an interface cannot be removed. To remove it, you must first cancel the application.
If a policy node is specified, the undo policy-based-route command removes the specified policy node; if a match mode is specified, the command removes all nodes configured with the match mode; if no policy node or match mode is specified, the command removes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter policy node view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
If no policy is specified, the command clears all PBR statistics.
If a policy is specified, the command clears the PBR statistics for the specified policy.
To view PBR statistics, use the display ip policy-based-route interface command.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
