06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71006-Layer 3 - IP Routing Command Reference
05-IS-IS commands
05-IS-IS commands 308.83 KB
IS-IS commands 1
area-authentication-mode· 1
auto-cost enable· 2
bandwidth-reference (IS-IS view) 3
circuit-cost 3
cost-style· 4
default-route-advertise (IS-IS view) 5
display isis brief 6
display isis graceful-restart status 8
display isis interface· 9
display isis lsdb· 12
display isis mesh-group· 15
display isis name-table· 16
display isis peer 17
display isis redistribute· 19
display isis route· 21
display isis statistics 23
domain-authentication-mode· 26
fast-reroute· 27
filter-policy export 28
filter-policy import 29
flash-flood· 30
graceful-restart 31
graceful-restart suppress-sa· 32
graceful-restart t1· 32
graceful-restart t2· 33
graceful-restart t3· 34
import-route· 35
import-route isis level-1 into level-2· 36
import-route isis level-2 into level-1· 37
import-route limit 38
isis 39
isis authentication-mode· 40
isis bfd enable· 41
isis circuit-level 41
isis circuit-type p2p· 42
isis cost 43
isis dis-name· 44
isis dis-priority· 44
isis enable· 45
isis mesh-group· 46
isis silent 47
isis small-hello· 47
isis timer csnp· 48
isis timer hello· 49
isis timer holding-multiplier 50
isis timer lsp· 51
isis timer retransmit 52
ispf enable· 53
is-level 53
is-name· 54
is-name map· 55
log-peer-change· 55
lsp-fragments-extend· 56
lsp-length originate· 56
lsp-length receive· 57
maximum load-balancing (IS-IS view) 58
network-entity· 58
preference· 59
priority· 60
reset isis all 61
reset isis peer 61
set-overload· 62
summary (IS-IS view) 63
timer lsp-generation· 64
timer lsp-max-age· 65
timer lsp-refresh· 66
timer spf 67
virtual-system·· 67
Use area-authentication-mode to specify an area authentication mode and a password.
Use undo area-authentication-mode to restore the default.
area-authentication-mode { md5 | simple } { cipher cipher-string | plain plain-string } [ ip | osi ]
No area authentication or password is configured.
IS-IS view
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
cipher: Sets a ciphertext password.
cipher-string: Specifies a ciphertext password, a case-sensitive string of 33 to 53 characters.
plain: Sets a plaintext password.
plain-string: Specifies a plaintext password, a case-sensitive string of 1 to 16 characters.
ip: Checks IP-related fields in LSPs.
osi: Checks OSI-related fields in LSPs.
The password in the specified mode is inserted into all outbound Level-1 packets (LSP, CSNP, and PSNP) and is used to authenticate inbound Level-1 packets.
Area authentication enables IS-IS to discard routes from untrusted routers.
Routers in an area must have the same authentication mode and password.
If neither ip nor osi is specified, OSI-related fields are checked.
For secrecy, all passwords, including passwords configured in plain text, are saved in cipher text.
The actual network environment does not impact whether a password should use ip or osi.
# Configure the area authentication mode as simple, and set the plaintext password to 123456.
[Sysname] isis 1
[Sysname-isis-1] area-authentication-mode simple plain 123456
·           domain-authentication-mode
·           isis authentication-mode
auto-cost enable
Use auto-cost enable to enable automatic link cost calculation.
Use undo auto-cost enable to disable the function.
auto-cost enable
This function is disabled.
IS-IS view
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the formula: Cost=(reference bandwidth value/link bandwidth) × 10. For other cost styles, Table 1 applies.
Table 1 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Cost
≤10 Mbps
60
≤100 Mbps
50
≤155 Mbps
40
≤622 Mbps
30
≤2500 Mbps
20
>2500 Mbps
10
# Enable automatic link cost calculation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] auto-cost enable
·           bandwidth-reference
·           cost-style
Use bandwidth-reference to set the bandwidth reference value for automatic link cost calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The bandwidth reference value is 100 Mbps.
IS-IS view
value: Specifies the bandwidth reference value in the range of 1 to 2147483648 Mbps.
# Configure the bandwidth reference of IS-IS process 1 as 200 Mbps.
[Sysname] isis 1
[Sysname-isis-1] bandwidth-reference 200
auto-cost enable
circuit-cost
Use circuit-cost to set a global IS-IS link cost.
Use undo circuit-cost to remove the configuration.
circuit-cost value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
No global link cost is configured.
IS-IS view
value: Specifies the link cost value. The value range varies by cost style.
·           For styles narrow, narrow-compatible, and compatible, the cost value is in the range of 0 to 63.
·           For styles wide and wide-compatible, the cost value is in the range of 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
# Set the global Level-1 link cost of IS-IS process 1 to 11.
[Sysname] isis 1
[Sysname-isis-1] circuit-cost 11 level-1
·           cost-style
·           isis cost
cost-style
Use cost-style to set a cost style.
Use undo cost-style to restore the default.
undo cost-style
Only narrow cost style packets can be received and sent.
IS-IS view
narrow: Receives and sends only narrow cost style packets. (The narrow cost is in the range of 0 to 63.)
wide: Receives and sends only wide cost style packets. (The wide cost is in the range of 0 to 16777215.)
compatible: Receives and sends both wide and narrow cost style packets.
narrow-compatible: Receives both narrow and wide cost style packets, but sends only narrow cost style packets.
wide-compatible: Receives both narrow and wide cost style packets, but sends only wide cost style packets.
relax-spf-limit: Allows receiving routes with a cost greater than 1023. If this keyword is not specified, any route with a cost bigger than 1023 will be discarded. This keyword is only available when compatible or narrow-compatible is included.
# Configure the router to send only narrow cost style packets, but receive both narrow and wide cost style packets.
[Sysname] isis 1
[Sysname-isis-1] cost-style narrow-compatible
·           circuit-cost
·           isis cost
Use default-route-advertise to advertise a default route of 0.0.0.0/0.
Use undo default-route-advertise to restore the default.
default-route-advertise [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ] *
Default route advertisement is disabled.
IS-IS view
level-1: Advertises a Level-1 default route.
level-1-2: Advertises both Level-1 and Level-2 default routes.
level-2: Advertises a Level-2 default route.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
If no level is specified, a Level-2 default route is advertised.
The Level-1 default route is advertised to other routers in the same area, and the Level-2 default route is advertised to all the Level-2 and Level-1-2 routers.
You can use a routing policy to specify a level for the default route. The apply isis level-1 command in routing policy view can generate a Level-1 default route. The apply isis level-2 command in routing policy view can generate a Level-2 default route. The apply isis level-1-2 command in routing policy view can generate both a Level-1 default route and Level-2 default route.
# Configure IS-IS process 1 to advertise a Level-2 default route.
[Sysname] isis 1
[Sysname-isis-1] default-route-advertise
display isis brief
Use display isis brief to display brief configuration information for an IS-IS process.
display isis brief [ process-id ]
process-id: Specifies a process by its ID in the range of 1 to 65535. If no process is specified, the command displays brief configuration information for all IS-IS processes.
# Display brief IS-IS configuration information.
<Sysname> display isis brief
        IS-IS(1) Protocol Brief Information
network-entity              : 10.0000.0000.0001.00
is-level                    : level-1-2
cost-style                  : narrow
fast-reroute                : disable
preference                  : 15
lsp-length receive          : 1497
    level-1                 : 1497
    level-2                 : 1497
maximum imported routes     : 1000000
timers
    lsp-max-age             : 1200
    lsp-refresh             : 900
    SPF intervals           : 5 50 200
IPv6 enable
    preference              : 15
network-entity
Network entity name.
is-level
IS-IS routing level.
cost-style
Cost style.
fast-reroute
Whether FRR is enabled:
·       disable—FRR is disabled.
·       enable—FRR is enabled.
preference
IS-IS route preference.
Lsp-length receive
Maximum LSP that can be received.
Lsp-length originate
Maximum LSP that can be generated.
Maximum number of redistributed Level-1/Level-2 IPv4/IPv6 routes.
Timers
Timers:
·       lsp-max-age—Maximum life period of LSP.
·       lsp-refresh—Refresh interval of LSPs.
·       Interval between SPFs—Interval between SPF calculations.
IPv6 enable
IPv6 is enabled.
Use display isis graceful-restart status to display IS-IS GR state.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
level-1: Displays the IS-IS Level-1 GR state.
level-2: Displays the IS-IS Level-2 GR state.
# Display IS-IS GR state.
<Sysname> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
Restart status
Current GR state:
·       RESTARTINGIn this state, forwarding can be ensured.
·       STARTINGIn this state, forwarding cannot be ensured.
·       COMPLETE—GR is completed.
Restart phase
Current Restart phase:
·       LSDB synchronization.
·       First SPF computation.
·       Redistribution.
·       Second SPF computation.
·       LSP generation.
·       Finish.
Restart t1
T1 timer, in seconds.
count
Number of T1 expirations.
Restart t2
T2 timer, in seconds.
Restart t3
T3 timer, in seconds.
SA Bit
Whether SA is supported:
·       Supported.
·       Not supported.
Total number of IS-IS interfaces.
Number of LSPs not obtained by the GR Restarter from GR Helpers during LSDB synchronization.
Use display isis interface to display IS-IS interface information.
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ]
interface-type interface-number: Displays statistics of a specified IS-IS interface.
verbose: Displays detailed information about an interface. If this keyword is not specified, this command displays brief information about an interface.
statistics: Displays IS-IS interface statistics.
process-id: Displays IS-IS interface information for an IS-IS process specified by its ID in the range of 1 to 65535.
If no interface is specified, the command displays information about all interfaces.
If no IS-IS process is specified, the command displays all interface information for all processes.
# Display brief IS-IS interface information.
<Sysname> display isis interface
  Interface:  GigabitEthernet3/0/2
  Id      IPv4.State      IPv6.State     MTU   Type   DIS
  001         Up             Down        547   L1/L2  Yes/No
# Display detailed IS-IS interface information.
<Sysname> display isis interface verbose
  SNPA Address                 :  000c-29b2-a5e3
  IP Address                   :  8.8.8.7
  Secondary IP Address(es)     :
  IPv6 Link Local Address      :
  Csnp Timer Value             :  L1    10   L2    10
  Hello Timer Value            :  L1     3   L2    10
  Hello Multiplier Value       :  L1     3   L2     3
  Lsp Timer Value              :  L12   33
  Lsp Transmit-Throttle Count  :  L12    5
  Cost                         :  L1    10   L2    10
  Priority                     :  L1    64   L2    64
  IPv4 BFD                     :  Disabled
  IPv6 BFD                     :  Disabled
Interface type and number.
Id
Circuit ID.
IPv4.State
IPv4 state.
IPv6.State
IPv6 state.
MTU
Interface MTU.
Interface link adjacency type.
DIS
Whether the interface is elected as the DIS or not.
SNPA Address
Subnet access point address.
IP Address
Primary IP address.
Secondary IP addresses.
IPv6 link local address.
Csnp Timer Value
Interval for sending CSNP packets.
Hello Timer Value
Interval for sending Hello packets.
Number of invalid Hello packets.
Lsp Timer Value
Minimum interval for sending LSP packets.
Number of LSP packets sent each time.
Cost
Cost of the interface.
Priority
DIS priority.
IPv4 BFD
Whether BFD for IS-IS is enabled:
·       Disabled.
·       Enabled.
IPv6 BFD
Whether BFD for IPv6 IS-IS is enabled:
·       Disabled.
·       Enabled.
# Display IS-IS interface statistics.
<Sysname> display isis interface statistics
                  Interface Statistics information for ISIS(1)
  Type            IPv4 Up/Down           IPv6 Up/Down
  LAN                   1/0                    0/0
  P2P                   0/0                    0/0
Table 5 Command output
Network type of the interface:
·       LAN for broadcast network.
·       P2P for point-to-point network.
IPv4 UP
Number of IS-IS interfaces in up state.
IPv4 Down
Number of IS-IS interfaces in down state.
IPv6 UP
Number of IS-ISv6 interfaces in up state. If IPv6 is not enabled, this field displays 0.
IPv6 Down
Number of IS-ISv6 interfaces in down state. If IPv6 is not enabled, this field displays 0.
display isis lsdb
Use display isis lsdb to display IS-IS link state database.
display isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose ] * [ process-id ]
level-1: Displays the level-1 LSDB.
level-2: Displays the level-2 LSDB.
local: Displays LSP information generated locally.
lsp-id lspid: Specifies an LSP ID, in the form of sysID. Pseudo ID-fragment num, where sysID represents the originating node or pseudo node, and Pseudo ID is separated by a dot from sysID and by a hyphen from fragment num.
lspname: Specifies the LSP name, in the form of Symbolic name.Pseudo ID-fragment num, where Pseudo ID is separated by a dot from Symbolic name and by a hyphen from fragment num. If the Pseudo ID is 0, specify the LSP name in the form Symbolic name-fragment num.
verbose: Displays LSDB detailed information. Without this argument, the command displays brief information about LSDB.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to display the LSDB of the IS-IS process.
If no level is specified, the command displays both Level-1 and Level-2 link state databases.
If no IS-IS process ID is specified, the command displays link state databases for all IS-IS processes.
# Display brief Level-1 LSDB information.
<Sysname> display isis lsdb level-1
                        Database information for ISIS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
5555.1111.1111.00-00  0x00000006   0x8519        1150          75      0/0/0
5555.1111.1111.00-01  0x00000001   0x4995        1139          41      0/0/0
7777.8888.1111.00-00* 0x00000020   0xceeb        1159          68      0/0/0
7777.8888.1111.01-00* 0x00000004   0xb4a4        1150          55      0/0/0
# Display detailed Level-1 LSDB information.
<Sysname> display isis lsdb level-1 verbose
5555.1111.1111.00-00  0x00000006   0x8519        1124          75      0/0/0
 SOURCE       5555.1111.1111.00
 NLPID        IPV4
 AREA ADDR    18
 INTF ADDR    8.8.8.5
 NBR  ID
         5555.5555.5555.00                COST: 0
 NBR  ID
         7777.8888.1111.01                COST: 10
5555.1111.1111.00-01  0x00000001   0x4995        1113          41      0/0/0
 IP-Internal
         8.8.8.0         255.255.255.0    COST: 10
7777.8888.1111.00-00* 0x00000020   0xceeb        1133          68      0/0/0
 SOURCE       7777.8888.1111.00
 NLPID        IPV4
 AREA ADDR    18
 INTF ADDR    8.8.8.7
 NBR  ID
 IP-Internal
7777.8888.1111.01-00* 0x00000004   0xb4a4        1124          55      0/0/0
 SOURCE       7777.8888.1111.01
 NLPID        IPV4
 NBR  ID
         5555.1111.1111.00                COST: 0
 NBR  ID
         7777.8888.1111.00                COST: 0
Table 6 Command output
LSPID
LSP ID.
Seq Num
LSP sequence number.
Checksum
LSP checksum.
Holdtime
LSP lifetime, which decreases as time elapses.
Length
LSP length.
ATT/P/OL
·       ATT—Attach bit.
·       P—Partition bit.
·       OLOverload bit.
1 means the LSP bit is set and 0 means the LSP bit is not set.
SOURCE
System ID of the originating router.
NLPID
Network layer protocol the originating router runs.
AREA ADDR
Area address of the originating router.
INTF ADDR
IP address of the originating router’s IS-IS interface.
INTF ADDR V6
IPv6 address of the originating router’s IS-ISv6 interface.
NBR ID
Neighbor ID of the originating router.
IP-Internal
Internal IP address and mask of the originating router.
IP-External
External IP address and mask of the originating router.
IP-Extended
Extended IP address and mask of the originating router.
COST
Cost.
Auth
Authentication information of the originating router.
IPV6
Internal IPv6 address and prefix of the originating router.
IPV6-Ext
External IPv6 address and prefix of the originating router.
Use display isis mesh-group to display IS-IS mesh group configuration information.
display isis mesh-group [ process-id ]
process-id: Displays IS-IS mesh-group configuration for an IS-IS process specified by its ID in the range of 1 to 65535.
# Add VLAN-interface 10 and VLAN-interface 20 to mesh-group 100.
[Sysname-Vlan-interface10] isis mesh-group 100
[Sysname-Vlan-interface10] interface vlan-interface 20
[Sysname-Vlan-interface20] isis mesh-group 100
# Display IS-IS mesh-group configuration information.
[Sysname-Vlan-interface20] display isis mesh-group
                       Mesh Group information for ISIS(1)
 Interface          Status
 Vlan10              100
 Vlan20              100
Table 7 Command output
Interface name.
Status
Mesh group the interface belongs to/whether a blocked interface is configured.
Use display isis name-table to display the host name to system ID mapping table.
display isis name-table [ process-id ]
process-id: Displays the host name to system ID mapping table for an IS-IS process specified by its ID in the range of 1 to 65535.
# Configure a name RUTA for the local IS system.
[Sysname] isis 1
[Sysname-isis-1] is-name RUTA
# Map the host name RUTB to the system ID 0000.0000.0041 of a remote IS.
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
# Display the IS-IS host name to system ID mapping table.
[Sysname-isis-1] display isis name-table
              Name table information for ISIS(1)
 System ID            Hostname                            Type
6789.0000.0001       RUTA                                DYNAMIC
0000.0000.0041       RUTB                                STATIC
Table 8 Command output
System ID
System ID.
Hostname
Host name.
Mapping type:
·       Static.
·       Dynamic.
display isis peer
Use display isis peer to display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id ]
statistics: Displays IS-IS neighbor statistics.
verbose: Displays detailed IS-IS neighbor information. Without the keyword, the command displays brief IS-IS neighbor information.
process-id: Displays IS-IS neighbor information for an IS-IS process specified by its ID in the range of 1 to 65535.
If no IS-IS process ID is specified, this command displays neighbor information for all IS-IS processes.
# Display brief IS-IS neighbor information.
<Sysname> display isis peer
                          Peer information for ISIS(1)
 System Id: 5555.1111.1111
 Interface: GigabitEthernet3/0/2    Circuit Id: 7777.8888.1111.01
 State: Up     HoldTime:  23s       Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime:  28s       Type: L2(L1L2)     PRI: 64
# Display detailed IS-IS neighbor information.
<Sysname> display isis peer verbose
 State: Up     HoldTime:  27s       Type: L1(L1L2)     PRI: 64
 Area Address(es): 18
 Peer IP Address(es):8.8.8.5
 Uptime: 00:03:17
 Adj Protocol:  IPv4
 State: Up     HoldTime:  26s       Type: L2(L1L2)     PRI: 64
 Uptime: 00:03:17
 Adj Protocol:  IPv4
Table 9 Command output
System Id
System ID of the neighbor.
Interface connecting to the neighbor.
Circuit Id
Circuit ID.
Circuit state.
HoldTime
Within the holdtime, if no hellos are received from the neighbor, the neighbor is considered down. If a hello is received, the holdtime is reset to the initial value.
Circuit type:
·       L1—Means the circuit type is Level-1 and the neighbor is a Level-1 router.
·       L2—Means the circuit type is Level-2 and the neighbor is a Level-2 router.
·       L1(L1L2)—Means the circuit type is Level-1 and the neighbor is a Level-1-2 router.
·       L2(L1L2)—Means the circuit type is Level-2 and the neighbor is a Level-1-2 router.
PRI
DIS priority of the neighbor.
Area Address(es)
Area address of the neighbor.
Peer IP Address(es)
IP address of the neighbor.
Uptime
Time elapsed since the neighbor relationship was formed.
Adj Protocol
Adjacency protocol.
# Display IS-IS neighbor statistics.
<Sysname> display isis peer statistics
                    Peer Statistics information for ISIS(1)
  Type              IPv4 Up/Init              IPv6 Up/Init
  LAN Level-1             1/0                       0/0
  LAN Level-2             1/0                       0/0
  P2P                     0/0                       0/0
Table 10 Command output
Neighbor type:
·       LAN Level-1Number of Level-1 neighbors whose network type is broadcast.
·       LAN Level-2Number of Level-2 neighbors whose network type is broadcast.
·       P2PNumber of neighbors whose network type is P2P.
IPv4 Up
Number of IPv4 neighbors in up state.
IPv4 Init
Number of IPv4 neighbors in init state.
IPv6 Up
Number of IPv6 neighbors in up state.
IPv6 Init
Number of IPv6 neighbors in init state.
Use display isis redistribute to display the redistributed IS-IS routing information.
display isis redistribute [ ipv4 [ ip-address mask-length ] ] [ level-1 | level-2 ] [ process-id ]
ipv4: Displays the redistributed IPv4 routing information (the default).
ip-address mask-length: Specifies the destination IP address and mask length.
process-id: Specifies the IS-IS process by its ID in the range of 1 to 65535.
level-1: Displays the IS-IS Level-1 routing information.
level-2: Displays the IS-IS Level-2 routing information.
If no IS-IS level is specified, this command displays both Level-1 and Level-2 routing information.
# Display redistributed IPv4 routing information.
<Sysname> display isis redistribute 1
                        Level-1 IPv4 Redistribute Table
 Type IPv4 Destination     IntCost    ExtCost    Tag        State
 D    192.168.30.0/24      0          0                     Active
 D    11.11.11.11/32       0          0
 D    10.10.10.0/24        0          0
Table 11 Command output
IS-IS process of the redistributed routing information.
Redistributed IPv4 routing information of IS-IS Level-1.
Level-2 IPv4 Redistribute Table
Redistributed IPv4 routing information of IS-IS Level-2.
Redistributed route type:
·       Direct.
·       IS-IS.
·       Static.
·       OSPF.
·       BGP.
·       RIP.
IPV4 Destination
IPv4 destination address.
IntCost
Internal cost of the route.
ExtCost
External cost of the route.
Tag
Tag value.
Indicates whether the route is valid.
display isis route
Use display isis route to display IS-IS IPv4 routing information.
display isis route [ ipv4 [ ip-address mask-length ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 routing information (the default).
ip-address mask-length: Displays IS-IS IPv4 routing information for the specified IP address. The mask-length argument is in the range of 0 to 32.
verbose: Displays detailed IS-IS IPv4 routing information.
process-id: Displays IS-IS IPv4 routing information for an IS-IS process specified by its ID in the range of 1 to 65535.
level-1: Displays Level-1 IS-IS routes.
level-2: Displays Level-2 IS-IS routes.
If no level is specified, this command displays both Level-1 and Level-2 routing information.
If no IS-IS process ID is specified, this command displays routing information for all IS-IS process IDs.
# Display IS-IS IPv4 routing information.
<Sysname> display isis route
                         Route information for ISIS(1)
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 8.8.8.0/24           10         NULL    GE3/0/2         Direct          D/L/-
 9.9.9.0/24           20         NULL    GE3/0/2         8.8.8.5         R/L/-
                         Level-2 IPv4 Forwarding Table
 9.9.9.0/24           20         NULL
Table 12 Command output
Route information for IS-IS process 1.
ISIS(1) IPv4 Level-1 Forwarding Table
IS-IS IPv4 routing information for Level-1.
ISIS(1) IPv4 Level-2 Forwarding Table
IS-IS IPv4 routing information for Level-2.
IPv4 Destination
IntCost
Internal cost.
ExtCost
External cost.
ExitInterface
Exit interface.
NextHop
Next hop.
Flags
Routing state flag:
·       D—Direct route.
·       R—The route has been added into the routing table.
·       L—The route has been advertised in an LSP.
·       U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
# Display detailed IS-IS IPv4 routing information.
<Sysname> display isis route verbose
 IPV4 Dest : 8.8.8.0/24          Int. Cost : 10               Ext. Cost : NULL
 Admin Tag : -                   Src Count : 2                Flag      : D/L/-
 NextHop   :                     Interface :                  ExitIndex :
    Direct                             GE3/0/2                    0x00000000
 IPV4 Dest : 9.9.9.0/24          Int. Cost : 20               Ext. Cost : NULL
 Admin Tag : -                   Src Count : 1                Flag      : R/L/-
    8.8.8.5                            GE3/0/2                    0x00000003
 Admin Tag : -                   Src Count : 1                Flag      : -/-/-
Table 13 Command output
IPV4 Dest
IPv4 destination.
Int. Cost
Internal cost.
Ext. Cost
External cost.
Admin Tag
Tag.
Src Count
Count of advertising sources.
Flag
Route state flag:
·       RThe route has been installed into the routing table.
·       LThe route has been flooded in an LSP.
·       URoute leaking flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
Next Hop
Next hop.
Output interface.
ExitIndex
Index of the output interface.
Use display isis statistics to display IS-IS statistics.
display isis statistics [ level-1 | level-1-2 | level-2 ] [ process-id ]
level-1: Displays IS-IS Level-1 statistics.
level-1-2: Displays IS-IS Level-1-2 statistics.
level-2: Displays IS-IS Level-2 statistics.
process-id: Displays statistics for an IS-IS process specified by its ID in the range of 1 to 65535.
If no IS-IS process ID is specified, this command displays the statistics for all IS-IS processes.
# Display IS-IS statistics.
<Sysname> display isis statistics
                               Level-1 Statistics
MTR(Basic-V4)
Learnt routes information:
         Total IPv4 Learnt Routes in IPv4 Routing Table: 1
         Total IPv6 Learnt Routes in IPv6 Routing Table: 0
Imported routes information:
         IPv4 Imported Routes:
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Total Number:   0
         IPv6 Imported Routes:
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
                         Total Number:   0
Lsp information:
                  LSP Source ID:          No. of used LSPs
                  7777.8888.1111                  001
                               Level-2 Statistics
MTR(Basic-V4)
         Total IPv4 Learnt Routes in IPv4 Routing Table: 0
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Total Number:   0
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
                         Total Number:   0
Lsp information:
                  7777.8888.1111                  001
Table 14 Command output
Statistics information for ISIS(processid)
Statistics for the IS-IS process.
Level-1 Statistics
Level-1 statistics.
Level-2 Statistics
Level-2 statistics.
Number of learned IPv4 routes.
Number of learned IPv6 routes.
·       IPv4 Imported RoutesNumbers of different types of redistributed IPv4 routes.
·       IPv6 Imported RoutesNumbers of different types of redistributed IPv6 routes.
Lsp information
LSP information:
·       LSP Source IDID of the source system.
·       No. of used LSPsNumber of used LSPs.
Use domain-authentication-mode to specify the routing domain authentication mode and a password.
Use undo domain-authentication-mode to restore the default.
domain-authentication-mode { md5 | simple } { cipher cipher-string | plain plain-string } [ ip | osi ]
No routing domain authentication or password is configured.
IS-IS view
cipher-string: Specifies a ciphertext password of 33 to 53 characters.
plain-string: Specifies a plaintext password of 1 to 16 characters.
The configured password in the specified mode is inserted into all outgoing Level-2 packets (LSP, CSNP, and PSNP) and is used for authenticating the incoming Level-2 packets.
All the backbone routers must have the same authentication mode and password.
If neither ip nor osi is specified, the OSI-related fields in LSPs are checked.
# Configure the routing domain authentication mode as simple, and set the plaintext password to 123456.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication-mode plain 123456
·           area-authentication-mode
fast-reroute
Use fast-reroute to configure IS-IS FRR.
Use undo fast-reroute to restore the default.
fast-reroute { auto | route-policy route-policy-name }
undo fast-reroute
IS-IS FRR is disabled.
IS-IS view
auto: Calculates a backup next hop automatically for all routes.
route-policy route-policy-name: Uses the specified routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
Do not use FRR and BFD at the same time. Otherwise, FRR might fail to take effect.
Example
# Enable IS-IS FRR to automatically calculate a backup next hop for all routes.
[Sysname] isis
[Sysname-isis-1] fast-reroute auto
Use filter-policy export to configure IS-IS to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
IS-IS view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes.
protocol: Filters routes redistributed from the specified routing protocol, which can be bgp, direct, isis, ospf, rip, or static. If no protocol is specified, the command filters all redistributed routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. This argument is available only when the protocol is isis, ospf, or rip. The default process ID is 1.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·           To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·           To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. The specified subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# Use ACL 2000 to filter redistributed routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter redistributed routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 export
Use filter-policy import to configure IS-IS to filter routes calculated using received LSPs.
Use undo filter-policy import to restore the default.
filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
IS-IS accepts all routes calculated using received LSPs.
IS-IS view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes calculated using received LSPs.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes calculated using received LSPs by destination address.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. The subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# Use ACL 2000 to filter routes calculated using received LSPs.
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter routes calculated using received LSPs.
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 import
flash-flood
Use flash-flood to enable IS-IS LSP flash flooding.
Use undo flash-flood to disable IS-IS LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
IS-IS LSP flash flooding is disabled.
IS-IS view
flood-count flooding-count: Specifies the maximum number of LSPs to be flooded before the next SPF calculation, in the range of 1 to 15. The default is 5.
max-timer-interval flooding-interval: Specifies the delay of the flash flooding, in the range of 10 to 50000 milliseconds. The default is 10.
level-1: Enables flash flooding for level-1.
level-2: Enables flash flooding for level-2.
If no level is specified, the command enables IS-IS LSP flash flooding for both Level-1 and Level-2.
# Enable fast flooding and specify the maximum LSPs to be sent as 10 and the delay time as 100 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
graceful-restart
Use graceful-restart to enable IS-IS GR.
Use undo graceful-restart to disable IS-IS GR.
graceful-restart
IS-IS GR is disabled.
IS-IS view
In IRF mode, execute the irf mac-address persistent always command before you perform master/subordinate switchover. This helps avoid IS-IS GR configuration failure resulted from interface MAC address change.
# Enable GR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
Use graceful-restart suppress-sa to suppress the Suppress-Advertisement (SA) bit during restart.
Use undo graceful-restart suppress-sa to set the SA bit.
The SA bit is set during restart.
IS-IS view
Suppressing the SA bit is mainly for avoiding black hole route. If a router starts or reboots without keeping the local forwarding table, sending packets to the router might result in a severe packet loss. To avoid this, you can set the SA bit of the hello packet sent by the GR Restarter to 1. Upon receiving such hello packets, the GR Helpers will not advertise the GR Restarter through LSP.
# Suppress the SA bit during Graceful Restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
graceful-restart
graceful-restart t1
Use graceful-restart t1 to configure the T1 timer.
Use undo graceful-restart t1 to restore the default.
graceful-restart t1 seconds count count
The T1 timer is 3 seconds and can expire 10 times.
IS-IS view
seconds: Specifies the T1 timer in the range of 3 to 10 seconds.
count: Specifies the number of times that the T1 timer can expire, in the range of 1 to 20.
The T1 timer specifies the number of times that GR Restarter can send a Restart TLV with the RR bit set. After restart, the GR Restarter sends a Restart TLV with the RR bit set to its neighbor. If the restarting router receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
# Configure the T1 timer of IS-IS process 1 as 5 seconds, and the expiration times as 5.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t1 5 count 5
·           graceful-restart
·           graceful-restart t2
·           graceful-restart t3
graceful-restart t2
Use graceful-restart t2 to configure the T2 timer.
Use undo graceful-restart t2 to restore the default.
graceful-restart t2 seconds
The T2 timer is 60 seconds.
IS-IS view
seconds: Specifies the T2 timer in the range of 30 to 65535 seconds.
The T2 timer specifies the LSDB synchronization interval. Each router has a T2 timer. The Level-1-2 router has two T2 timers: a Level-1 timer and a Level-2 timer. If the LSDBs have not achieved synchronization before the two timers expire, the GR process fails.
# Configure the T2 timer of IS-IS process 1 as 50 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t2 50
·           graceful-restart
·           graceful-restart t1
graceful-restart t3
Use graceful-restart t3 to configure the T3 timer.
Use undo graceful-restart t3 to restore the default.
graceful-restart t3 seconds
The T3 timer is 300 seconds.
IS-IS view
seconds: Specifies the T3 timer in the range of 300 to 65535 seconds.
The T3 timer specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors keep their adjacency with the GR Restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
# Configure the T3 timer of IS-IS process 1 as 500 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t3 500
·           graceful-restart
import-route
Use import-route to redistribute routes from another routing protocol or another IS-IS process.
Use undo import-route to remove the redistribution.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
No route redistribution is configured.
IS-IS view
protocol: Redistributes routes from a routing protocol, which can be BGP, direct, IS-IS, OSPF, RIP, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. It is available only when the protocol is isis, ospf, or rip.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. It is available when the protocol is BGP.
cost: Specifies a cost for redistributed routes, which is in the range of 0 to 4261412864.
·           For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63.
·           For the styles of wide and wide-compatible, the cost is in the range of 0 to 4261412864.
cost-type { external | internal }: Specifies the cost type. The internal type indicates internal routes, and the external type indicates external routes. If external is specified, the cost of a redistributed route is added by 64 to make internal routes take priority over external routes. The type is external by default. The keywords are available only when the cost type is narrow, narrow-compatible, or compatible.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, the routes are redistributed into the Level-2 routing table by default.
route-policy route-policy-name: Redistributes only routes satisfying the matching criteria of the specified routing policy. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for marking redistributed routes, in the range of 1 to 4294967295.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
The effective cost depends on the cost style. For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63. If the cost is more than 63, 63 is used. For the style of wide or wide-compatible, the configured value is the effective value.
This import-route command cannot redistribute default routes. The command redistributes only active routes. To display route state information, use the display ip routing-table protocol command.
The import-route bgp command redistributes only EBGP routes.
The import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes. Because this command might cause routing loops, use it with caution.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute static routes into IS-IS, and set the cost for redistributed routes to 15.
[Sysname] isis 1
[Sysname-isis-1] import-route static cost 15
import-route limit
Use import-route isis level-1 into level-2 to enable route advertisement from Level-1 to Level-2.
Use undo import-route isis level-1 into level-2 to disable route advertisement from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement from Level-1 to Level-2 is enabled.
IS-IS view
filter-policy: Specifies a filtering policy.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-1 to Level-2.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2 by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2.
tag tag: Specifies a tag for marking redistributed routes, in the range of 1 to 4294967295.
If a routing policy is used, the routing policy must be specified in the import-route isis level-1 into level-2 command to filter routes from Level-1 to Level-2. Other routing policies specified for route reception and redistribution do not affect the route leaking.
If a filtering policy is configured, only Level-1 routes not filtered out can be advertised into the Level-2 area.
# Enable route advertisement from Level-1 to Level-2.
[Sysname] isis 1
[Sysname-isis-1] import-route isis level-1 into level-2
·           import-route
·           import-route isis level-1 into level-2
Use import-route isis level-2 into level-1 to enable route advertisement from Level-2 to Level-1.
Use undo import-route isis level-2 into level-1 to disable route advertisement from Level-2 to Level-1.
import-route isis level-2 into level-1 [ filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement is not enabled.
IS-IS view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-2 to Level-1.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-2 to Level-1 by destination address.
route-policy route-policy-name: Uses the specified routing policy to filter routes from Level-2 to Level-1. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
If a routing policy is used, the routing policy must be specified in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
If a filtering policy is configured, only Level-2 routes not filtered out can be advertised into the Level-1 area.
# Enable route advertisement from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] import-route isis level-2 into level-1
·           import-route
import-route limit
Use import-route limit to configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
Use undo import-route limit to restore the default.
import-route limit number
The maximum number of redistributed Level 1/Level 2 IPv4 routes is 262144.
IS-IS view
number: Specifies the maximum number of redistributed Level 1/Level 2 IPv4 routes, in the range of 1 to 262144.
# Configure IS-IS process 1 to redistribute up to 1000 Level 1/Level 2 IPv4 routes.
[Sysname] isis 1
[Sysname-isis-1] import-route limit 1000
import-route limit
isis
Use isis to enable an IS-IS process and enter IS-IS view.
Use undo isis to disable an IS-IS process.
undo isis [ process-id ]
The system does not run any IS-IS process.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS process runs on the public network.
# Enable IS-IS process 1 and specify the system ID as 0000.0000.0002 and area ID as 01.0001.
[Sysname] isis 1
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
·           isis enable
·           network-entity
Use isis authentication-mode to set the IS-IS authentication mode and password for an interface.
Use undo isis authentication-mode to remove the configuration.
isis authentication-mode { md5 | simple } { cipher cipher-string | plain plain-string } [ level-1 | level-2 ] [ ip | osi ]
undo isis authentication-mode [ level-1 | level-2 ]
No neighbor relationship authentication is configured.
Interface view
level-1: Configures the password for Level-1.
level-2: Configures the password for Level-2.
ip: Checks IP-related fields in LSPs and SNPs.
osi: Checks OSI-related fields in LSPs and SNPs.
The password in the specified mode is inserted into all outbound hello packets and is used for authenticating inbound hello packets. Only if the authentication succeeds can the neighbor relationship be formed.
For two routers to become neighbors, the authentication mode and password at both ends must be identical.
If you configure a password without specifying a level, the password applies to both Level-1 and Level-2.
The level-1 and level-2 keywords are configurable on an interface that has had IS-IS enabled with the isis enable command.
# On VLAN-interface 10, configure the authentication mode as simple, and set the plaintext password to 123456.
[Sysname-Vlan-interface10] isis authentication-mode simple plain 123456
·           domain authentication-mode
isis bfd enable
Use isis bfd enable to enable BFD.
Use undo isis bfd enable to disable BFD.
isis bfd enable
IS-IS BFD is disabled.
Interface view
# Enable BFD for IS-IS on VLAN-interface 11.
[Sysname-Vlan-interface11] isis enable
[Sysname-Vlan-interface11] isis bfd enable
isis circuit-level
Use isis circuit-level to set the circuit level for the interface.
Use undo isis circuit-level to restore the default.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
An interface can establish either the Level-1 or Level-2 adjacency.
Interface view
level-1: Sets the circuit level to Level-1.
level-1-2: Sets the circuit level to Level-1-2.
level-2: Sets the circuit level to Level-2.
For a Level-1 (Level-2) router, the circuit level can only be Level-1 (Level-2). For a Level-1-2 router, you must specify a circuit level for a specific interface to form only the specified level neighbor relationship.
# VLAN-interface 10 is connected to a non-backbone router in the same area. Configure the circuit level of VLAN-interface 10 as Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-Vlan-interface10] isis enable
[Sysname-Vlan-interface10] isis circuit-level level-1
is-level
Use isis circuit-type p2p to configure the network type of an interface as P2P.
Use undo isis circuit-type to remove the configuration.
The network type of an interface depends on the physical media. (The network type of a VLAN interface is broadcast.)
Interface view
Perform this configuration only for a broadcast network with only two attached routers.
Interfaces with different network types operate differently. For example, broadcast interfaces must elect a DIS and flood CSNP packets to synchronize the LSDBs, and P2P interfaces do not need to elect a DIS, and use a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, configure the network type of attached interfaces as P2P to avoid DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
# Configure the network type of VLAN-interface 10 as P2P.
[Sysname-Vlan-interface10] isis circuit-type p2p
isis cost
Use isis cost to set the IS-IS cost for an interface.
Use undo isis cost to remove the configuration.
isis cost value [ level-1 | level-2 ]
undo isis cost [ level-1 | level-2 ]
No IS-IS cost is configured for an interface.
Interface view
value: Specifies an IS-IS cost in the range of 1 to 16777215.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
# Configure the Level-2 IS-IS cost as 5 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis cost 5 level-2
isis dis-name
This command does not take effect on a Point-to-Point interface.
Use isis dis-name to configure a name for a DIS to represent the pseudo node on a broadcast network.
Use undo isis dis-name to restore the default.
isis dis-name symbolic-name
undo isis dis-name
No name is configured for the DIS.
Interface view
symbolic-name: Specifies a DIS name, a string of 1 to 64 characters.
This command takes effect only on routers that have dynamic system ID to host name mapping enabled.
# Configure the DIS name as LOCALAREA.
[Sysname-Vlan-interface10] isis dis-name LOCALAREA
isis dis-priority
Use isis dis-priority to specify a DIS priority at a specified level for an interface.
Use undo isis dis-priority to remove the configuration.
isis dis-priority value [ level-1 | level-2 ]
undo isis dis-priority [ level-1 | level-2 ]
The priority of Level-1 and Level-2 is 64.
Interface view
value: Specifies a DIS priority in the range of 0 to 127.
level-1: Applies the DIS priority to Level-1.
level-2: Applies the DIS priority to Level-2.
If neither level-1 nor level-2 is specified, the DIS priority applies to both Level-1 and Level-2.
On an IS-IS broadcast network, a router must be elected as the DIS at each routing level. Specify a DIS priority at a level for an interface. The greater the interface’s priority is, the more likelihood it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest Subnetwork Point of Attachment (SNPA) address (SNPA addresses are MAC addresses on a broadcast network) becomes the DIS.
IS-IS has no backup DIS. The router with a priority of 0 can also participate in DIS election.
# Configure the Level-2 DIS priority as 127 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis dis-priority 127 level-2
isis enable
Use isis enable to enable an IS-IS process on an interface.
Use undo isis enable to disable IS-IS.
isis enable [ process-id ]
undo isis enable
No IS-IS process is enabled on an interface.
Interface view
# Enable IS-IS process 1 globally and enable it on VLAN-interface 10.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
[Sysname-Vlan-interface10] isis enable 1
·           isis
·           network-entity
isis mesh-group
Use isis mesh-group to add an interface into a mesh group or block the interface.
Use undo isis mesh-group to restore the default.
isis mesh-group { mesh-group-number | mesh-blocked }
An interface does not belong to any mesh group and is not blocked.
Interface view
mesh-group-number: Specifies a mesh group by its number in the range of 1 to 4294967295.
mesh-blocked: Blocks the interface.
An interface not in a mesh group floods received LSPs to other interfaces. For an NBMA network with multiple point-to-point links, this mechanism causes repeated LSP flooding and bandwidth waste.
To solve this problem, use this command to add relevant interfaces to a mesh group. An interface in a mesh group only floods a received LSP or a generated LSP to interfaces not in the same mesh group.
You can also use this command to block an interface. A blocked interface sends LSPs only after receiving LSP requests.
The mesh-group feature takes effect only on point-to-point links.
# Add VLAN-interface 10 that is configured with IS-IS to mesh-group 100.
isis silent
Use isis silent to disable the interface from sending and receiving IS-IS packets.
Use undo isis silent to restore the default.
isis silent
undo isis silent
An interface is not disabled from sending and receiving IS-IS packets.
Interface view
The feature is not supported on the loopback interface.
# Disable VLAN-interface 10 from sending and receiving IS-IS packets.
[Sysname-Vlan-interface10] isis silent
isis small-hello
This command is not available in loopback interface view.
Use isis small-hello to configure the interface to send small hello packets without CLVs.
Use undo isis small-hello to restore the default.
isis small-hello
An interface sends standard hello packets.
Interface view
# Configure VLAN-interface 10 to send small Hello packets.
[Sysname-Vlan-interface10] isis small-hello
isis timer csnp
Use isis timer csnp to specify on the DIS of a broadcast network the interval for sending CSNP packets.
Use undo isis timer csnp to remove the configuration.
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ level-1 | level-2 ]
The default CSNP interval is 10 seconds.
Interface view
seconds: Specifies on the DIS of a broadcast network the interval in seconds for sending CSNP packets, ranging from 1 to 600.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
If no level is specified, the CSNP interval applies to both Level-1 and Level-2.
This command only applies to the DIS of a broadcast network, which sends CSNP packets periodically for LSDB synchronization.
# Configure Level-2 CSNP packets to be sent every 15 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer csnp 15 level-2
isis timer hello
Use isis timer hello to specify the interval for sending hello packets.
Use undo isis timer hello to remove the configuration.
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ level-1 | level-2 ]
The default hello interval is 10 seconds.
Interface view
seconds: Specifies the interval in seconds for sending hello packets, in the range of 3 to 255.
level-1: Specifies the interval for sending Level-1 hello packets.
level-2: Specifies the interval for sending Level-2 hello packets.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify an interval for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify an interval for each level.
You can configure keywords level-1 and level-2 only on broadcast interfaces. Before you do that, enable IS-IS on the interface.
The shorter the interval, the more system resources will be occupied. Configure a proper interval as needed.
If no level is specified, the hello interval applies to both Level-1 and Level-2.
# Configure Level-2 hello packets to be sent every 20 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer hello 20 level-2
Use isis timer holding-multiplier to specify the IS-IS hello multiplier.
Use undo isis timer holding-multiplier to remove the configuration.
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ level-1 | level-2 ]
The default IS-IS hello multiplier is 3.
Interface view
value: Specifies the number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
With the IS-IS hello multiplier configured, a router can uses hello packets to notify its neighbor router of the adjacency hold time (hello multiplier times hello interval). If the neighbor router receives no hello packets from this router within the hold time, it declares the adjacency down. You can adjust the adjacency hold time by changing the hello multiplier or the hello interval on an interface.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify a hello multiplier for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify Level-1 or Level-2.
You can configure keywords level-1 and level-2 only on broadcast interfaces. Before doing that, enable IS-IS on the interface.
If no level is specified, the hello multiplier applies to the current level.
The value of hello multiplier multiplied by hello interval cannot be more than 65535.
# Configure the hello multiplier as 6 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer holding-multiplier 6
isis timer hello
isis timer lsp
Use isis timer lsp to configure the minimum interval for sending LSPs on the interface and specify the maximum number of LSPs that can be sent per time.
Use undo isis timer lsp to restore the default.
isis timer lsp time [ count count ]
undo isis timer lsp
The minimum interval for sending LSPs on the interface is 33 milliseconds, and the maximum number of LSPs that can be sent at a time is 5.
Interface view
time: Specifies the minimum interval in milliseconds for sending link-state packets, in the range of 1 to 1000.
count: Specifies the maximum number of link-state packets to be sent at one time, in the range of 1 to 1000.
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs.
Configure a proper LSP retransmission interval to avoid unnecessary retransmissions.
# Configure the interval as 500 milliseconds for sending LSPs on interface VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer lsp 500
isis timer retransmit
Use isis timer retransmit to configure the interval for retransmitting LSP packets over a point-to-point link.
Use undo isis timer retransmit to restore the default.
isis timer retransmit seconds
The retransmission interval on a P2P link is 5 seconds.
Interface view
seconds: Specifies the interval for retransmitting LSP packets, in the range of 1 to 300 seconds.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgement is received within a configurable interval, IS-IS will retransmit the LSP.
You do not need to use this command over a broadcast link where CNSPs are periodically broadcast to implement LSDB synchronization.
# Configure the LSP retransmission interval on a P2P link as 50 seconds for VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer retransmit 50
·           isis circuit-type p2p
·           isis timer lsp
ispf enable
Use ispf enable to enable IS-IS incremental SPF (ISPF).
Use undo ispf enable to disable IS-IS ISPF.
ispf enable
undo ispf enable
IS-IS ISPF is enabled.
OSPF view
When a network topology is changed, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Enable IS-IS ISPF.
[Sysname] isis 1
[Sysname-isis-1] ispf enable
is-level
Use is-level to specify the IS level.
Use undo is-level to restore the default.
is-level { level-1 | level-1-2 | level-2 }
undo is-level
The IS level is level-1-2.
IS-IS view
level-1: Specifies Level-1, which means IS-IS only calculates intra-area routes and maintains the Level-1 LSDB.
level-1-2: Specifies Level-1-2, which means IS-IS calculates routes and maintains the LSDBs for both Level-1 and Level-2.
level-2: Specifies Level-2, which means IS-IS calculates routes and maintains the LSDB for Level-2 only.
If only one area exists, configure all the routers as either Level-1 or Level-2, because the routers do not need to maintain two identical LSDBs at the same time.
If the only area is an IP network, configure all the routers as Level-2 for scalability.
# Specify the IS level as Level-1 for the IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] is-level level-1
is-name
Use is-name to specify a host name for the IS and enable dynamic system ID to hostname mapping.
Use undo is-name to disable dynamic system ID to hostname mapping.
is-name sys-name
undo is-name
Dynamic system ID to hostname mapping is not enabled.
IS-IS view
symbolic-name: Specifies a host name for the local IS, a case-sensitive string of 1 to 64 characters.
# Configure a host name for the local IS.
[Sysname] isis 1
is-name map
Use is-name map to configure a system ID to host name mapping for a remote IS.
Use undo is-name map to remove the mapping.
is-name map sys-id map-sys-name
undo is-name map sys-id
IS-IS view
sys-id: Specifies the system ID or pseudonode ID of a remote IS.
map-sys-name: Specifies a host name for the remote IS, a string of 1 to 64 characters.
Each remote IS system ID corresponds to only one name.
# Map the host name RUTB to the system ID 0000.0000.0041 of the remote IS.
[Sysname] isis 1
log-peer-change
Use log-peer-change to enable the logging of IS-IS neighbor state changes.
Use undo log-peer-change to disable the logging.
log-peer-change
The logging of IS-IS neighbor state changes is enabled.
IS-IS view
This command enables sending logs about IS-IS neighbor state changes to the configuration terminal.
# Disable the logging of IS-IS neighbor state changes.
[Sysname] isis 1
[Sysname-isis-1] undo log-peer-change
lsp-fragments-extend
Use lsp-fragments–extend to enable LSP fragment extension for a level.
Use undo lsp-fragments–extend to disable LSP fragment extension.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
undo lsp-fragments-extend
LSP fragment extension is disabled.
IS-IS view
level-1: Applies the fragment extension to Level-1 LSPs.
level-1-2: Applies the fragment extension to both Level-1 and Level-2 LSPs.
level-2: Applies the fragment extension to Level-2 LSPs.
If no level is specified, the command enables LSP fragment extension for both Level-1 and Level-2.
# Enable LSP fragment extension for Level-2.
[Sysname] isis 1
[Sysname-isis-1] lsp-fragments-extend level-2
lsp-length originate
Use lsp-length originate to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use undo lsp-length originate to remove the configuration.
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
The maximum size of generated Level-1 and Level-2 LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of LSP packets, in the range of 512 to 16384 bytes.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
# Configure the maximum size of the generated Level-2 LSPs as 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length originate 1024 level-2
lsp-length receive
Use lsp-length receive to configure the maximum size of received LSPs.
Use undo lsp-length receive to restore the default.
lsp-length receive size
The maximum size of received LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of received LSPs, in the range of 512 to 16384 bytes.
# Configure the maximum size of received LSPs.
[Sysname] isis 1
[Sysname-isis-1] lsp-length receive 1024
maximum load-balancing (IS-IS view)
Use maximum load-balancing to configure the maximum number of equal-cost multi-path (ECMP) routes.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of ECMP routes is 32.
IS-IS view
number: Specifies the maximum number of ECMP routes, in the range of 1 to 32.
# Configure the maximum number of ECMP routes as 2.
[Sysname] isis 100
[Sysname-isis-100] maximum load-balancing 2
network-entity
Use network-entity to configure the Network Entity Title (NET) for an IS-IS process.
Use undo network-entity to delete a NET.
network-entity net
undo network-entity net
No NET is configured.
IS-IS view
net: Specifies a NET as a dotted hexadecimal string in the X…X.XXXX....XXXX.00 format. The X…X segment represents the area address, the XXXX....XXXX segment represents the system ID, and the 00 segment is the SEL.
A NET is a special NSAP address with the SEL being 0. The length of the NET is in the range of 8 bytes to 20 bytes.
A NET comprises the following parts:
·           Area IDWith a length of 1 to 13 bytes.
·           System IDA system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·           SELIt has a value of 0 and a fixed 1-byte length.
For example, a NET of ab.cdef.1234.5678.9abc.00 specifies the area ID ab.cdef, the system ID 1234.5678.9abc, and the SEL 00.
# Specify the NET as 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis 1
·           isis
·           isis enable
preference
Use preference to configure the preference for IS-IS.
Use undo preference to restore the default.
undo preference
IS-IS preference is 15.
IS-IS view
preference: Specifies an IS-IS protocol preference in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to assign a priority to the matching routes.
If a routing policy is specified in this command, the preference set by the routing policy applies to the matching routes. Other routes use the preference set by the preference command.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol with the highest preference is selected as the optimal route.
# Configure the preference for IS-IS as 25.
[Sysname] isis 1
[Sysname-isis-1] preference 25
priority
Use priority to assign convergence priorities to specific IS-IS routes.
Use undo priority to remove the configuration.
priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
undo priority { critical | high | medium } [ prefix-list | tag ]
IS-IS routes have the lowest convergence priority.
IS-IS view
critical: Specifies the highest convergence priority.
high: Specifies the high convergence priority.
medium: Specifies the medium convergence priority.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
tag tag-value: Specifies a tag value in the range of 1 to 4294967295.
The higher the convergence priority, the faster the convergence speed.
IS-IS host routes have a medium convergence priority.
# Assign the high convergence priority to IS-IS routes permitted by IP prefix list standtest.
[Sysname] isis 1
[Sysname-isis-1] priority high prefix-list standtest
reset isis all
Use reset isis all to clear all IS-IS data structure information.
reset isis all [ process-id ] [ graceful-restart ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear the data structure information for an IS-IS process.
graceful-restart: Recovers the data through Graceful Restart after the data is cleared.
If no IS-IS process is specified, the command clears data structure information for all IS-IS processes.
Use this command when LSPs must be updated immediately.
# Clear all IS-IS data structure information.
<Sysname> reset isis all
reset isis peer
Use reset isis peer to clear data structure information for a specified IS-IS neighbor.
reset isis peer system-id [ process-id ]
system-id: Specifies an IS-IS neighbor by its system ID.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear data structure information for the neighbor in the specified IS-IS process.
Use this command when you re-establish an IS-IS neighbor relationship.
# Clear the data structure information of the neighbor with the system ID 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
set-overload
Use set-overload to set the overload bit.
Use undo set-overload to clear the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] [ allow { external | interlevel } * ]
undo set-overload
The overload bit is not set.
IS-IS view
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set. If not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
·           system-idSpecifies the neighbor.
·           timeout1The timeout1 interval is in the range of 5 to 86400 seconds and defaults to 600 seconds.
·           nbr-timeoutThe timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The interval is in the range of 5 to 86400 seconds and defaults to 600 seconds.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learned from different IS-IS levels with the allow keyword specified.
If the on-startup keyword is not specified, the command sets the overload bit immediately until the undo set-overload command is executed.
If the on-startup keyword is specified, IS-IS sets the overload bit upon system startup and keeps it set within the timeout2 interval.
# Set overload flag on the current router.
[Sysname] isis 1
[Sysname-isis-1] set-overload
summary (IS-IS view)
Use summary to configure a summary route.
Use undo summary to remove a summary route.
summary ip-address { mask | mask-length } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ip-address { mask | mask-length } [ level-1 | level-1-2 | level-2 ]
No summarization is configured.
IS-IS view
ip-address: Specifies the destination IP address of the summary route.
mask: Specifies the mask of the destination IP address, in dotted decimal format.
mask-length: Specifies the mask length of the summary route, in the range of 0 to 32.
avoid-feedback: Avoids learning summary routes by route calculation.
generate_null0_route: Generates the Null 0 route to avoid routing loops.
level-1: Summarizes only the routes redistributed to Level-1.
level-1-2: Summarizes the routes redistributed to both Level-1 and Level-2.
level-2: Summarizes only the routes redistributed to Level-2.
tag tag: Specifies a management tag in the range of 1 to 4294967295.
If no level is specified, only level-2 routes are summarized.
If no topology is specified, routes for the base topology are summarized.
You can summarize multiple contiguous networks into a single network to reduce the size of the routing table, as well as the size of LSP and LSDB generated by the router. You can summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of those summarized routes.
The router summarizes only routes generated from local LSPs.
# Configure a summary route of 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1] summary 202.0.0.0 255.0.0.0
timer lsp-generation
Use timer lsp-generation to configure LSP generation interval.
Use undo timer lsp-generation to remove the configuration.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
The maximum interval is 2 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 0 milliseconds.
IS-IS view
maximum-interval: Specifies the maximum interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental interval in the range of 10 to 60000 milliseconds.
level-1: Applies the intervals to Level-1.
level-2: Applies the intervals to Level-2. If no level is specified, the specified intervals apply to both Level-1 and Level-2.
By adjusting the LSP generation interval, you can prevent bandwidth and router resources from being overconsumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the LSP generation interval is incremented by the incremental-interval each time a generation occurs until the maximum-interval is reached.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum interval, minimum interval, and incremental interval to 10 seconds, 100 milliseconds, and 200 milliseconds.
[Sysname] isis 1
[Sysname-isis-1]timer lsp-generation 10 100 200
timer lsp-max-age
Use timer lsp-max-age to set the LSP maximum age in the LSDB.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The LSP maximum age is 1200 seconds.
IS-IS view
seconds: Specifies the LSP maximum aging time in the range of 1 to 65535 seconds.
# Set the maximum LSP age to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh
Use timer lsp-refresh to configure the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The default LSP refresh interval is 900 seconds.
IS-IS view
seconds: Specifies the LSP refresh interval in the range of 1 to 65534 seconds.
To refresh LSPs before they are aged out, the interval configured by the timer lsp-refresh command must be smaller than that configured by the timer lsp-max-age command.
# Configure the LSP refresh interval as 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-refresh 1500
timer lsp-max-age
timer spf
Use timer spf to set the SPF calculation interval.
Use undo timer spf to restore the default.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
IS-IS view
maximum-interval: Specifies the maximum SPF calculation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental SPF calculation interval in the range of 10 to 60000 milliseconds.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate a shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being overconsumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval is incremented by the incremental-interval each time a generation happens until the maximum-interval is reached.
# Configure the maximum interval as 10 seconds, the minimum interval as 100 milliseconds, and the incremental interval as 300 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] timer spf 10 100 300
virtual-system
Use virtual-system to configure a virtual system ID for the IS-IS process.
Use undo virtual-system to remove a virtual system ID.
virtual-system virtual-system-id
undo virtual-system virtual-system-id
No virtual system ID is configured.
IS-IS view
virtual-system-id: Specifies a virtual system ID for the IS-IS process.
# Set a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] virtual-system 2222.2222.2222
