06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71006-Layer 3 - IP Routing Command Reference
06-BGP commands
06-BGP commands 580.91 KB
BGP commands 1
advertise-rib-active· 1
aggregate· 1
balance· 4
bestroute as-path-neglect 5
bestroute compare-med· 6
bestroute med-confederation· 7
bgp· 8
compare-different-as-med· 9
confederation id· 10
confederation nonstandard· 11
confederation peer-as 11
dampening· 12
default local-preference· 14
default med· 15
default-route imported· 16
display bgp dampening parameter ipv4 unicast 17
display bgp dampening parameter ipv6 unicast 18
display bgp group ipv4 unicast 19
display bgp group ipv6 unicast 21
display bgp network· 23
display bgp paths 24
display bgp peer ipv4 unicast 25
display bgp peer ipv6 unicast 29
display bgp routing-table dampened ipv4 unicast 33
display bgp routing-table dampened ipv6 unicast 34
display bgp routing-table flap-info ipv4 unicast 36
display bgp routing-table flap-info ipv6 unicast 38
display bgp routing-table ipv4 unicast 40
display bgp routing-table ipv4 unicast advertise-info· 43
display bgp routing-table ipv4 unicast as-path-acl 44
display bgp routing-table ipv4 unicast community-list 45
display bgp routing-table ipv4 unicast peer 46
display bgp routing-table ipv4 unicast statistics 48
display bgp routing-table ipv6 unicast 48
display bgp routing-table ipv6 unicast as-path-acl 52
display bgp routing-table ipv6 unicast community-list 53
display bgp routing-table ipv6 unicast inlabel 54
display bgp routing-table ipv6 unicast outlabel 55
display bgp routing-table ipv6 unicast peer 56
display bgp routing-table ipv6 unicast statistics 58
ebgp-interface-sensitive· 59
filter-policy export 59
filter-policy import 61
graceful-restart 63
graceful-restart timer restart 64
graceful-restart timer wait-for-rib· 65
group· 66
ignore-first-as 67
import-route· 68
ip vpn-instance (BGP view) 69
ipv4-family· 70
ipv6-family· 71
log-peer-change· 72
network· 73
network short-cut 74
peer advertise-community· 76
peer advertise-ext-community· 77
peer allow-as-loop· 78
peer as-number (for a BGP peer) 80
peer as-number (for a BGP peer group) 81
peer as-path-acl 82
peer bfd· 83
peer capability-advertise conventional 84
peer capability-advertise route-refresh· 85
peer capability-advertise suppress-4-byte-as 87
peer connect-interface· 88
peer default-route-advertise· 89
peer description· 90
peer ebgp-max-hop· 91
peer enable· 92
peer fake-as 94
peer filter-policy· 95
peer group· 97
peer ignore· 99
peer ignore-originatorid· 100
peer keep-all-routes 101
peer label-route-capability· 102
peer low-memory-exempt 103
peer next-hop-local 104
peer password· 105
peer preferred-value· 107
peer prefix-list 108
peer public-as-only· 110
peer reflect-client 111
peer route-limit 112
peer route-policy· 114
peer route-update-interval 116
peer substitute-as 117
peer timer 117
preference· 119
reflect between-clients 120
reflector cluster-id· 121
refresh bgp ipv4 unicast 123
refresh bgp ipv6 unicast 124
reset bgp all 125
reset bgp dampening ipv4 unicast 125
reset bgp dampening ipv6 unicast 126
reset bgp flap-info ipv4 unicast 127
reset bgp flap-info ipv6 unicast 128
reset bgp ipv4 unicast 129
reset bgp ipv6 unicast 130
router id· 130
router-id· 131
summary automatic· 132
timer 133
BGP commands
Use advertise-rib-active to enable BGP to advertise optimal routes in the IP routing table.
Use undo advertise-rib-active to restore the default.
BGP advertises optimal routes in the BGP routing table, regardless of whether they are optimal in the IP routing table.
BGP view
The advertise-rib-active command does not apply to the following routes:
·           Routes redistributed by the import-route command
·           Routes advertised by the network command
·           Default routes redistributed by the default-route imported command
·           VPNv4 routes
This command takes effect for only the routes generated after you execute this command. To make this command take effect for the routes generated before you execute this command, use the reset bgp command to reset BGP sessions.
# Enable BGP to advertise optimal routes in the IP routing table.
[Sysname] bgp 100
[Sysname-bgp] advertise-rib-active
aggregate
Use aggregate to create a summary route in the BGP routing table.
Use undo aggregate to remove a summary route.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view:
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
undo aggregate ip-address { mask | mask-length }
In BGP IPv6 unicast instance view:
undo aggregate ipv6-address prefix-length
No summary route is configured.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP IPv6 unicast instance view
ip-address: Specifies a summary address.
mask: Specifies a mask for the summary address, in dotted decimal notation.
mask-length: Specifies a mask length for the summary address, in the range of 0 to 32.
ipv6-address: Specifies an IPv6 summary address.
prefix-length: Specifies a prefix length for the IPv6 summary address, in the range of 0 to 128.
as-set: Enables the AS_PATH attribute of the summary route to contain the AS path information of all summarized routes. The AS_PATH attribute is of the AS_SET type that requires no sequence when arranging AS numbers. If this keyword is not specified, the AS_PATH attribute of the summary route contains only the AS number of the local router.
attribute-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set attributes for the summary route.
detail-suppressed: Advertises only the summary route. If this keyword is not specified, BGP advertises both the summary route and the more specific routes.
origin-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to select routes to be summarized.
suppress-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter more specific routes to be advertised.
This command creates a summary route. If the BGP routing table has routes whose destination addresses fall within the specified network, the summary route is added to the BGP routing table. For example, if two routes 10.1.1.0/24 and 10.1.2.0/24 exist in the BGP routing table, configuring the aggregate 10.1.0.0 16 command creates a summary route 10.1.0.0/16.
If the summarized routes have different ORIGIN attributes, the summary route selects the ORIGIN attribute in the sequence of INCOMPLETE, EGP, and IGP. For example, if the ORIGIN attributes of the summarized routes include INCOMPLETE and IGP, the ORIGIN attribute of the summary route is INCOMPLETE.
If the summarized routes have different COMMUNITY attributes, the summary route that does not have the ATOMIC_AGGREGATE attribute carries all the COMMUNITY attributes.
Table 1 Functions of the keywords
Keywords
Function
as-set
Enables the summary route to carry the AS path information of all summarized routes. This feature can help avoid routing loops. However, if many routes are summarized and are changed frequently, do not specify this keyword because this configuration causes the summary route to flap with the more specific routes.
attribute-policy
Sets attributes except the AS-PATH attribute for the summary route. The peer route-policy command can achieve the same purpose.
detail-suppressed
Disables advertisement of all more specific routes. To disable advertisement of some more specific routes, use the suppress-policy keyword or the peer filter-policy command.
origin-policy
Summarizes only routes satisfying a routing policy.
If the destination address of a route falls within the summary network but does not match the routing policy, the route is not summarized, and is not controlled by the detail-suppressed and suppress-policy keywords.
There is no need to configure apply clauses for the routing policy referenced by the origin-policy keyword because they do not take effect.
suppress-policy
Disables advertisement of some more specific routes filtered by a routing policy. The routing policy uses if-match clauses to filter routes.
There is no need to configure apply clauses for the routing policy referenced by the suppress-policy keyword because they do not take effect.
# In BGP IPv4 unicast instance view, create a summary route 1.1.0.0/16 in the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family unicast
[Sysname-bgp-ipv4] aggregate 1.1.0.0 255.255.0.0
# In BGP IPv4 unicast instance view, create a summary route 1.1.0.0/16 in the BGP routing table. Specify the AS_PATH attribute for the summary route to contain the AS path information of all summarized routes, and advertise only the summary route.
[Sysname] bgp 100
[Sysname-bgp-ipv4] aggregate 1.1.0.0 255.255.0.0 as-set detail-suppressed
# In BGP IPv4 unicast instance view, create a summary route 1.1.0.0/16 in the BGP routing table, and set the COMMUNITY attribute of the summary route to INTERNET.
[Sysname] route-policy commu permit node 0
[Sysname-route-policy-commu-0] apply community internet
[Sysname-route-policy-commu-0] quit
[Sysname] bgp 100
[Sysname-bgp-ipv4] aggregate 1.1.0.0 255.255.0.0 attribute-policy commu
# In BGP IPv4 unicast instance view, create a summary route 1.1.0.0/16 in the BGP routing table, and configure BGP to not summarize route 1.1.1.0/24.
[Sysname] ip prefix-list spert deny 1.1.1.0 24
[Sysname] ip prefix-list spert permit 0.0.0.0 0 less-equal 32
[Sysname] route-policy srcrt permit node 0
[Sysname-route-policy-srcrt-0] if-match ip address prefix-list spert
[Sysname-route-policy-srcrt-0] quit
[Sysname] bgp 100
[Sysname-bgp-ipv4] aggregate 1.1.0.0 255.255.0.0 origin-policy srcrt
# In BGP IPv4 unicast instance view, create a summary route 1.1.0.0/16 in the BGP routing table, and disable BGP to advertise the specific route 1.1.1.0/24.
[Sysname] route-policy suprt permit node 0
[Sysname-route-policy-suprt-0] if-match ip address prefix-list spert
[Sysname-route-policy-suprt-0] quit
[Sysname] bgp 100
[Sysname-bgp-ipv4] aggregate 1.1.0.0 255.255.0.0 suppress-policy suprt
# In BGP-VPN IPv4 unicast instance view, create a summary route 1.1.0.0/16 in BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1] ipv4-family unicast
[Sysname-bgp-ipv4-vpn1] aggregate 1.1.0.0 255.255.0.0
# In BGP IPv6 unicast instance view, create a summary route 12::/64 in the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family
[Sysname-bgp-ipv6] aggregate 12:: 64
·           display bgp routing-table ipv4 unicast
·           display bgp routing-table ipv6 unicast
·           summary automatic
balance
Use balance to specify the maximum number of BGP ECMP routes for load balancing.
Use undo balance to disable load balancing.
balance number
undo balance
Load balancing is not enabled.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view
number: Specifies the maximum number of BGP ECMP routes, in the range of 1 to 32. When it is set to 1, load balancing is disabled.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing by modifying route selection rules. If multiple BGP routes destined for a network have the same AS_PATH, ORIGIN, LOCAL_PREF, and MED attributes, you can use the balance command to implement load balancing over these routes.
# In BGP IPv4 unicast instance view, enable load balancing and specify the maximum number of BGP ECMP routes used for load balancing as 2.
[Sysname] bgp 100
[Sysname-bgp-ipv4] balance 2
# In BGP-VPN IPv6 unicast instance view, enable load balancing and specify the maximum number of BGP ECMP routes for load balancing as 2.
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv6-family unicast
[Sysname-bgp-ipv6-vpn1] balance 2
Use bestroute as-path-neglect to configure BGP to not consider the AS_PATH during best route selection.
Use undo bestroute as-path-neglect to configure BGP to consider the AS_PATH during best route selection.
BGP considers the AS_PATH during best route selection.
# In BGP IPv4 unicast instance view, ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp-ipv4] bestroute as-path-neglect
# In BGP-VPN IPv6 unicast instance view, ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] bestroute as-path-neglect
Use bestroute compare-med to enable MED comparison for routes on a per-AS basis.
Use undo bestroute compare-med to restore the default.
MED comparison for routes on a per-AS basis is disabled.
By default, BGP does not compare MEDs for routes from the same AS. When a router learns a new route, it compares the route with the optimal route in its BGP routing table. If the new route is more optimal, it becomes the optimal route in the BGP routing table. In this way, route learning sequence might affect optimal route selection.
With the bestroute compare-med command configured, the router puts routes received from the same AS into a group. The router then selects the route with the lowest MED from the same group, and compares routes from different groups. This mechanism avoids the above-mentioned problem.
If the bestroute compare-med and balance commands are configured at the same time, the balance command does not take effect.
# In BGP IPv4 unicast instance view, enable MED comparison for routes on a per-AS basis.
[Sysname] bgp 100
[Sysname-bgp-ipv4] bestroute compare-med
# In BGP-VPN IPv4 unicast instance view, enable MED comparison for routes on a per-AS basis.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] bestroute compare-med
# In BGP IPv6 unicast instance view, enable MED comparison for routes on a per-AS basis.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family unicast
[Sysname-bgp-ipv6] bestroute compare-med
Use bestroute med-confederation to enable MED comparison for routes received from confederation peers.
Use undo bestroute med-confederation to restore the default.
MED comparison is disabled for routes received from confederation peers.
This command enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
# In BGP IPv4 unicast instance view, enable MED comparison for routes received from confederation peers.
[Sysname] bgp 100
[Sysname-bgp-ipv4] bestroute med-confederation
# In BGP-VPN IPv4 unicast instance view, enable MED comparison for routes received from confederation peers.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] bestroute med-confederation
# In BGP IPv6 unicast instance view, enable MED comparison for routes received from confederation peers.
[Sysname] bgp 100
[Sysname-bgp-ipv6] bestroute med-confederation
bgp
Use bgp to enable BGP and enter the BGP view.
Use undo bgp to disable BGP.
bgp as-number
undo bgp [ as-number ]
BGP is not enabled.
as-number: Specifies a local AS by its number in the range of 1 to 4294967295.
A router can reside in only one AS, so the router can run only one BGP process.
A router supports 4-byte AS number.
# Enable BGP, set the local AS number to 100, and enter BGP view.
[Sysname] bgp 100
[Sysname-bgp]
Use compare-different-as-med to enable MED comparison for routes from peers in different ASs.
Use undo compare-different-as-med to disable the comparison.
The comparison is disabled.
If multiple routes to a destination exist, the route with the smallest MED is selected.
Do not use this command unless relevant ASs adopt the same IGP protocol and routing selection method.
# In BGP IPv4 unicast instance view, enable MED comparison for routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-ipv4] compare-different-as-med
# In BGP-VPN IPv4 unicast instance view, enable MED comparison for routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] compare-different-as-med
# In BGP IPv6 unicast instance view, enable MED comparison for routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-ipv6] compare-different-as-med
confederation id
Use confederation id to configure a confederation ID.
Use undo confederation id to remove the specified confederation ID.
confederation id as-number
No confederation ID is configured.
BGP view
as-number: Specifies an AS number that identifies the confederation, in the range of 1 to 4294967295.
You can split an AS into several sub-ASs, and each sub-AS remains fully meshed. These sub-ASs form a confederation. Key path attributes of a route, such as the Next_HOP, MED, and LOCAL_PREF, are not discarded when crossing each sub-AS. The sub-ASs still look like one AS from the perspective of other ASs. The AS number is the confederation ID.
Confederation can ensure the integrity of the former AS, and solve the problem of too many IBGP connections in the AS.
Configure the same confederation ID for all routers in one confederation.
On a member outside of a confederation, to establish a BGP connection to a specific router in that confederation, specify the AS number of the router as the confederation ID.
# Confederation 9 consists of four sub-ASs numbered 38, 39, 40 and 41. The peer 10.1.1.1 is a member of sub-AS 38. The peer 200.1.1.1 is a member outside of confederation 9, which belongs to AS 98. Confederation 9 looks like one AS (with AS number 9) from the perspective of the peer 200.1.1.1. This example uses a router in sub-AS 41.
[Sysname] bgp 41
[Sysname-bgp] confederation id 9
[Sysname-bgp] confederation peer-as 38 39 40
[Sysname-bgp] group Confed38 external
[Sysname-bgp] peer Confed38 as-number 38
[Sysname-bgp] peer 10.1.1.1 group Confed38
[Sysname-bgp] group Remote98 external
[Sysname-bgp] peer Remote98 as-number 98
[Sysname-bgp] peer 200.1.1.1 group Remote98
·           confederation nonstandard
·           confederation peer-as
Use confederation nonstandard to enable compatibility with routers not compliant with RFC 3065 in the confederation.
Use undo confederation nonstandard to restore the default.
The device is compatible with only routers compliant with RFC 3065 in the confederation.
BGP view
Configure this command on all routers compliant with RFC 3065 to interact with those routers not compliant with RFC 3065 in the confederation.
# Confederation 100 comprises two sub-ASs, 64000 and 65000, and contains routers not compliant with RFC 3065. Enable compatibility with routers not compliant with RFC 3065 in the confederation.
[Sysname] bgp 64000
[Sysname-bgp] confederation id 100
[Sysname-bgp] confederation peer-as 65000
[Sysname-bgp] confederation nonstandard
·           confederation id
Use confederation peer-as to specify confederation peer sub-ASs.
Use undo confederation peer-as to remove specified confederation peer sub-ASs.
undo confederation peer-as [ as-number-list ]
No confederation peer sub-ASs are specified.
BGP view
as-number-list: Specifies a sub-AS number list. Up to 32 sub-ASs can be configured in one command line. The expression is as-number-list = as-number &<1-32>. The as-number argument specifies a sub-AS number in the range of 1 to 4294967295, and &<1-32> indicates up to 32 numbers can be specified.
Before this configuration, use the confederation id command to specify the confederation for the sub-ASs.
If the undo confederation peer-as command without the as-number-list argument is used, all confederation peer sub-ASs are removed.
# Specify confederation peer sub-ASs 2000 and 2001.
[Sysname] bgp 100
[Sysname-bgp] confederation peer-as 2000 2001
·           confederation id
dampening
Use dampening to enable BGP route dampening.
Use undo dampening to disable route dampening.
undo dampening
Route dampening is disabled.
half-life-reachable: Specifies a half-life for active routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes, in the range of 1 to 20000. A suppressed route whose penalty value decreases under the value is reused. By default, the reuse value is 750. The reuse threshold value must be less than the suppression threshold value.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The route with a penalty value higher than the threshold is suppressed. The default value is 2000.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The value must be bigger than the suppress value. By default, the value is 16000.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
The command dampens only EBGP routes.
# In BGP IPv4 unicast instance view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp-ipv4] dampening 10 10 1000 2000 10000
# In BGP-VPN IPv4 unicast instance view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] dampening 10 10 1000 2000 10000
# In BGP IPv6 unicast instance view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp-ipv6] dampening 10 10 1000 2000 10000
# In BGP-VPN IPv6 unicast instance view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] dampening 10 10 1000 2000 10000
·           display bgp dampening parameter ipv4 unicast
·           display bgp dampening parameter ipv6 unicast
Use default local-preference to configure a default local preference.
Use undo default local-preference to restore the default.
The default local preference is 100.
value: Specifies a default local preference in the range of 0 to 4294967295. The larger the value, the higher the preference.
You can also use the apply local-preference command in a routing policy to configure the local preference for BGP routes. If no routing policy is configured, all BGP routes use the local preference set by the default local-preference command. If a routing policy is configured, BGP routes matching the routing policy use the local preference set by the apply local-preference command, and other BGP routes use the local preference set by the default local-preference command.
# In BGP IPv4 unicast instance view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp-ipv4] default local-preference 180
# In BGP-VPN IPv6 unicast instance view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] default local-preference 180
·           apply local-preference
·           route-policy
default med
Use default med to specify a default MED value.
Use undo default med to restore the default.
default med med-value
undo default med
The default med-value is 0.
med-value: Specifies the default MED value in the range of 0 to 4294967295.
BGP selects a MED value in the following order:
1.      MED set by the apply cost command.
2.      MED set by the med keyword in the import-route command.
3.      MED set by the default med command.
4.      Original MED of a BGP route, or MED changed from the metric of a redistributed IGP route.
# In BGP IPv4 unicast instance view, configure the default MED as 25.
[Sysname] bgp 100
[Sysname-bgp-ipv4] default med 25
# In BGP-VPN IPv6 unicast instance view, configure the default MED as 25.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] default med 25
·           apply cost
·           import-route
·           route-policy
Use default-route imported to enable default route redistribution into the BGP routing table.
Use undo default-route imported to restore the default.
Default route redistribution is not enabled.
By default, BGP does not redistribute default IGP routes. You must use the default-route imported command together with the import-route command to redistribute default IGP routes into the BGP routing table.
# In BGP IPv4 unicast instance view, enable default route redistribution from OSPF process 1 into the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv4] default-route imported
[Sysname-bgp-ipv4] import-route ospf 1
# In BGP-VPN IPv4 unicast instance view, enable default route redistribution from OSPF process 1 into the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] default-route imported
[Sysname-bgp-ipv4-vpn1] import-route ospf 1
# In BGP IPv6 unicast instance view, enable default route redistribution from OSPFv3 process 1 into the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv6] default-route imported
[Sysname-bgp-ipv6] import-route ospfv3 1
# In BGP-VPN IPv6 unicast instance view, enable default route redistribution from OSPFv3 process 1 into the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] default-route imported
[Sysname-bgp-ipv6-vpn1] import-route ospfv3 1
import-route
Use display bgp dampening parameter ipv4 unicast to display BGP IPv4 unicast route dampening parameters.
display bgp dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast route dampening parameters for the public network.
The command with the unicast keyword has the same effect as that without the unicast keyword.
# Display BGP IPv4 unicast route dampening parameters for the public network.
<Sysname> display bgp dampening parameter ipv4
Maximum suppression time (in seconds)              : 3973
Ceiling value                                      : 16000
Reuse value                                        : 750
Half-life time for reachable routes (in seconds)   : 900
Half-life time for unreachable routes (in seconds) : 900
Suppression threshold                              : 2000
Maximum time (in seconds) for the penalty value to decrease from the ceiling value to the reuse value.
Ceiling value
Penalty ceiling value.
Reuse value
Reuse threshold.
dampening
Use display bgp dampening parameter ipv6 unicast to display BGP IPv6 unicast route dampening parameters.
display bgp dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast route dampening parameters for the public network.
# Display BGP IPv6 unicast route dampening parameters for the public network.
<Sysname> display bgp dampening parameter ipv6
Reuse value                                        : 750
Ceiling value
Reuse value
Reuse threshold.
dampening
Use display bgp group ipv4 unicast to display BGP IPv4 unicast peer group information.
display bgp group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast peer group information for the public network.
group-name: Specifies a BGP IPv4 unicast peer group by its name, a case-sensitive string of 1 to 47 characters. If no group is specified, this command displays brief information about all BGP IPv4 unicast peer groups.
# Display brief information about all BGP IPv4 unicast peer groups for the public network.
 BGP peer group: group1
 Remote AS: 600
 Type: external
 Members:
  1.1.1.10
 BGP peer group: group2
 Remote AS number: not specified
 Type: external
 Members:
  2.2.2.2
# Display detailed information about BGP IPv4 unicast peer group group1 for the public network.
<Sysname> display bgp group ipv4 group1
 Remote AS: 600
 Type: external
 Maximum number of prefixes allowed: 4294967295
 Threshold: 75%
 Configured hold time: 180 seconds
 Keepalive time: 60 seconds
 Minimum time between advertisements: 30 seconds
 Peer preferred value: 0
 Routing policy configured:
 Members:
  1.1.1.10               600        0        0    0       0 00:00:55 Established
BGP peer group
Name of the BGP peer group.
Remote AS
AS number of the peer group.
Type of the peer groups:
·       external—IBGP peer group.
·       internal—EBGP peer group.
Maximum number of routes allowed to learn from the peer.
Threshold
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates alarm messages.
Configured Hold Interval in seconds.
Keepalive time
Keepalive interval in seconds.
Minimum route advertisement interval in seconds.
Preferred value specified for routes from the peer.
Routing policy configured for the peer group.
If no routing policy is specified, this field displays "No routing policy is configured."
Members
Information about peers included in the peer group.
Peer
IP address of the peer.
AS
AS number of the peer.
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages to be sent.
PrefRcv
Number of prefixes received.
Up/Down
Lasting time of the current BGP session state.
Current state of the BGP session between the local router and the peer.
Use display bgp group ipv6 unicast to display BGP IPv6 unicast peer group information.
display bgp group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast peer group information for the public network.
group-name: Specifies a BGP IPv6 unicast peer group by its name, a case-sensitive string of 1 to 47 characters. If no group is specified, this command displays brief information about all BGP IPv6 unicast peer groups.
# Display brief information about all BGP IPv6 unicast peer groups for the public network.
<Sysname> display bgp group ipv6
 BGP peer group: abc
 Type: external
 Members:
  1::1
 Remote AS: 600
 Type: external
 Members:
  2::2
  3::3
# Display detailed information about BGP IPv6 unicast peer group group1 for the public network.
<Sysname> display bgp group ipv6 group1
 Remote AS: 600
 Type: external
 Threshold: 75%
 Members:
  2::2                   600        0        0    0       0 00:00:45 Established
  3::3                   600        0        0    0       0 00:00:40 Established
Table 5 Command output
BGP peer group
Remote AS
Threshold
Keepalive time
Preferred value specified for the routes from the peer.
Members
Information of the peers included in the peer group.
Peer
IPv6 address of the peer.
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Up/Down
display bgp network
Use display bgp network to display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp network { ipv4 | ipv6 } [ unicast ] [ vpn-instance vpn-instance-name ]
ipv4: Displays IPv4 address family information.
ipv6: Displays IPv6 address family information.
unicast: Displays IPv4 or IPv6 unicast address family information regardless of whether this keyword is specified or not.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays routing information for the public network.
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv4 unicast address family for the public network.
<Sysname> display bgp network ipv4
  Local AS number: 100
  Network           Mask            Route-policy        Short-cut
  20.1.1.0          255.255.255.0                       No
  40.1.1.0          255.255.255.0   abc                 No
  30.1.1.0          255.255.255.0                       Yes
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv6 unicast address family for the public network.
<Sysname> display bgp network ipv6
  Network           PrefixLen       Route-policy        Short-cut
  1::               24                                  No
  2::               24                                  No
  3::               64              policy1             No
  2::               24                                  Yes
# Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command in the IPv4 unicast address family in VPN instance vpn1.
<Sysname> display bgp network ipv4 vpn-instance vpn1
  50.1.1.0          255.255.255.0                       No
  40.1.1.0          255.255.255.0                       Yes
Table 6 Command output
Network
Destination network address of the routes advertised by the network command and the shortcut routes.
Mask
Mask of the destination network address.
PrefixLen
Prefix length of the destination network address.
Route-policy
Routing policy that is applied to the route.
Short-cut
Indicates whether the route is a shortcut route:
·       Yes
·       No
display bgp paths
Use display bgp paths to display BGP path attribute information.
display bgp paths [ as-regular-expression ]
as-regular-expression: Displays information about BGP path attributes whose AS_PATH attribute matches the specified regular expression. The as-regular-expression argument is a string of 1 to 256 characters. Without this argument, this command displays information about all BGP path attributes.
# Display information about all BGP path attributes.
<Sysname> display bgp paths
  RefCount    MED         Path/Origin
  3           0           ?
  2           0           100i
  3           0           100i
  1           0           ?
  1           0           ?
  1           0           ?
Table 7 Command output
RefCount
Number of BGP routes with these path attributes.
MED
MED attribute value.
Path/Origin
AS_PATH and ORIGIN attributes of the route:
·       AS_PATH attribute—Records the ASs the route has passed to avoid routing loops.
·       ORIGIN attribute—Identifies the origin of the route:
¡ i—Originated in the AS. The origin of summary routes and routes advertised with the network command is IGP.
¡ e—Learned through EGP.
¡ ?—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
Use display bgp peer ipv4 unicast to display BGP IPv4 unicast peer or peer group information.
display bgp peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name log-info | ip-address { log-info | verbose } | verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast peer or peer group information for the public network.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
ip-address: Specifies a peer by its IP address.
log-info: Displays log information.
verbose: Displays detailed information.
If no parameter is specified, this command displays brief information about all BGP IPv4 unicast peers.
# Display brief information about all BGP IPv4 unicast peers for the public network.
<Sysname> display bgp peer ipv4
 BGP local router ID: 192.168.100.1
 Total number of peers: 1                  Peers in established state: 1
  10.2.1.2               200       13       16    0       0 00:10:34 Established
Table 8 Command output
Peer
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Up/Down
# Display detailed information about BGP IPv4 unicast peer 10.2.1.2 for the public network.
<Sysname> display bgp peer ipv4 10.2.1.2 verbose
         Peer: 10.2.1.2  Local: 192.168.100.1
         Type: EBGP link
         BGP version 4, remote router ID 192.168.100.2
         BGP current state: Established, Up for 00h11m10s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 60672
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support BGP multi-protocol extended
         Peer support BGP route refresh capability
         Peer support BGP route AS4 capability
         Address family IPv4 Unicast: advertised and received
 Received: Total 13 messages, Update messages 0
 Sent: Total 16 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
 Peer Preferred Value: 0
 BFD: Enabled
Table 9 Command output
Peer
Local
Local router ID.
BGP connection type between the local router and the peer:
·       IBGP link—IBGP connection.
·       EBGP link—EBGP connection.
remote router ID
Router ID of the peer.
BGP current state
Up for
Lasting time of the BGP session.
BGP current event
Current event of the BGP session between the local router and the peer.
BGP last state
Previous state of the BGP session.
Port
TCP port numbers of the local router and its peer.
Configured
Timers configured on the local router in seconds, including the holdtime (Active Hold Time) and keepalive interval (Keepalive Time).
Received
Received timer (configured on the peer) in seconds, including the holdtime (Active Hold Time).
Negotiated
Negotiated timers in seconds, including the holdtime (Active Hold Time) and keepalive interval (Keepalive Time).
Optional capabilities supported by the peer.
The peer supports 4-byte AS number.
IPv4 unicast address family capability: Routes of the address family can be advertised and received.
Received
Total numbers of received messages and updates.
Sent
Total numbers of sent messages and updates.
Threshold
Optional capabilities supported by the local end.
BFD
Indicates whether BFD is enabled to detect the link to the BGP peer.
Routing policy configured for the peer.
# Display log information about BGP IPv4 unicast peer 1.1.1.1 for the public network.
<Sysname> display bgp peer ipv4 1.1.1.1 log-info
 Peer : 1.1.1.1
     Date      Time    State Notification
                             Error/SubError
  10-Jul-2008 15:46:17 Down  Send Notification with Error 1/1
                             Message Header Error/Connection Not Synchronized
  10-Jul-2008 09:23:00 Up
  10-Jul-2008 07:46:17 Down  Receive Notification with Error 3/2
                             UPDATE Message Error/Unsupported optional Parameter
  10-Jul-2008 06:23:00 Up
  10-Jul-2008 05:46:17 Down  Send Notification with Error 6/4
                             Cease/Administrative Reset
Table 10 Command output
Peer
Date
Date on which the Notification was sent or received.
Time
Time at which the Notification was sent or received.
BGP session state:
·       Up—The BGP session is in Established state.
·       Down—The BGP session is down.
Notification Error/SubError
Error code of the Notification, indicating the cause of why the BGP session is down.
·       Error—Refers to the error code, which identifies the type of the Notification.
·       SubError—Refers to the error subcode of the Notification, which identifies the specific information about the reported error.
Use display bgp peer ipv6 unicast to display BGP IPv6 unicast peer or peer group information.
display bgp peer ipv6 [ unicast ] [ group-name log-info | ip-address { log-info | verbose } | ipv6-address { log-info | verbose } | verbose ]
display bgp peer ipv6 [ unicast ] vpn-instance vpn-instance-name [ group-name log-info | ipv6-address { log-info | verbose } | verbose ]
ipv6-address: Specifies a peer by its IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast peer or peer group information for the public network.
If no parameter is specified, the command displays brief information about all BGP IPv6 unicast peers.
# Display brief information about all BGP IPv6 unicast peers for the public network.
<Sysname> display bgp peer ipv6
 Total number of peers: 4                  Peers in established state: 1
  1.1.1.1                600        0        0    0       0 01:08:19 Connect
  1.1.1.10               600        0        0    0       0 00:03:21 Connect
  1::1                   600        9        9    0       0 00:05:12 Established
  3::3                   600        0        0    0       0 00:03:16 Connect
Table 11 Command output
Peer
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Up/Down
# Display detailed information about BGP IPv6 unicast peer 1::2 for the public network.
<Sysname> display bgp peer ipv6 1::2 verbose
         Peer: 1::2      Local: 192.168.1.136
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.135
         BGP current state: Established, Up for 00h05m48s
         Port:  Local - 13184    Remote - 179
 Received: Total 9 messages, Update messages 1
 Sent: Total 10 messages, Update messages 1
 Threshold: 75%
 BFD: Enabled
Table 12 Command output
Peer
Local
Local router ID.
remote router ID
BGP current state
Up for
BGP current event
BGP last state
Port
Configured
Timer configured on the local router in seconds, including the holdtime (Active Hold Time) and keepalive interval (Keepalive Time).
Received
Negotiated
Negotiated timer in seconds, including the holdtime (Active Hold Time) and keepalive interval (Keepalive Time).
IPv6 unicast address family capability: Routes of the address family can be advertised and received.
Received
Sent
Threshold
BFD
Indicates whether BFD is enabled to detect the link to the specified BGP peer.
# Display log information about BGP IPv6 unicast peer 1::2 for the public network.
<Sysname> display bgp peer ipv6 1::2 log-info
 Peer : 1::2
                             Error/SubError
  22-Nov-2011 09:31:12 Up
Table 13 Command output
Peer
Date
Time
BGP session state:
Use display bgp routing-table dampened ipv4 unicast to display dampened BGP IPv4 unicast routes.
display bgp routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays dampened BGP IPv4 unicast routes for the public network.
# Display dampened BGP IPv4 unicast routes.
<Sysname> display bgp routing-table dampened ipv4
 Total number of routes: 1
 BGP local router ID is 192.168.1.135
     Network            From            Reuse                         Path/Ogn
  de 20.1.1.0/24        10.1.1.2        00:56:27                      100i
Table 14 Command output
Status codes
Status codes:
·       * – valid—Valid route.
·       > – best—Best route.
·       d – damped—Dampened route.
·       h – history—History route.
·       s – suppressed—Suppressed route.
·       S – Stale—Stale route.
·       i – internal—Internal route.
·       e – external—External route.
Origin
Origin of the route:
·       i – IGP—Originated in the AS. The origin of summary routes and routes advertised with the network command is IGP.
·       e – EGP—Learned through EGP.
·       ?– incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
Network
Destination network address.
From
IP address from which the route was received.
Reuse
Reuse time of the route.
Path/Ogn
·       ORIGIN attribute—Identifies the origin of the route.
·           dampening
·           reset bgp dampening ipv4 unicast
Use display bgp routing-table dampened ipv6 unicast to display dampened BGP IPv6 unicast routes.
display bgp routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays dampened BGP IPv6 unicast routes for the public network.
# Display dampened BGP IPv6 unicast routes.
<Sysname> display bgp routing-table dampened ipv6
 Total number of routes: 2
  de Network : 2::                                      PrefixLen : 64
     From    : 10.1.1.1                                 Reuse     : 00:39:49
     Path/Ogn: 100i
     From    : 1::1                                     Reuse     : 00:39:49
     Path/Ogn: 100i
Table 15 Command output
Status codes
Status codes:
Origin
Network
From
Reuse
Path/Ogn
·           dampening
·           reset bgp dampening ipv6 unicast
Use display bgp routing-table flap-info ipv4 unicast to display BGP IPv4 unicast route flap statistics.
display bgp routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast route flap statistics for the public.
network-address: Specifies a destination network address.
mask: Specifies a network mask, in dotted decimal notation.
mask-length: Specifies a mask length in the range of 0 to 32.
longest-match: Displays the routing entries selected through the following steps:
1.      AND the specified network address with the specified mask.
2.      Display the route with the longest mask among the matching routes that have a mask shorter than or equal to the specified mask.
as-path-acl as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256 to filter BGP IPv4 unicast route flap statistics.
When you execute the display bgp routing-table flap-info ipv4 unicast command:
·           If the network-address, mask, and mask-length arguments are not specified, the command displays flap statistics of all BGP IPv4 unicast routes for the public network or the specified VPN.
·           If only the network-address argument is specified, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays flap statistics of the route.
·           If the network-address mask or network-address mask-length argument is specified, and the longest-match keyword is not specified, the command displays flap statistics of the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
# Display BGP IPv4 unicast route flap statistics for the public network.
<Sysname> display bgp routing-table flap-info ipv4
     Network            From            Flaps  Duration  Reuse        Path/Ogn
  de 20.1.1.0/24        10.1.1.2        1      00:02:36  00:53:58     100i
Table 16 Command output
Status codes
Status codes:
Origin
Network
From
Source IP address of the route.
Flaps
Number of routing flaps.
Duration
Duration time of the flap route.
Reuse
Path/Ogn
·           dampening
·           reset bgp flap-info ipv4 unicast
Use display bgp routing-table flap-info ipv6 unicast to display BGP IPv6 unicast route flap statistics.
display bgp routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ network-address prefix-length | as-path-acl as-path-acl-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast route flap statistics for the public network.
network-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128.
as-path-acl as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256 to filter BGP IPv6 unicast route flap statistics.
When you execute the display bgp routing-table flap-info ipv6 unicast command without specifying any argument, the command displays flap statistics of all BGP IPv6 unicast routes for the public network.
# Display BGP IPv6 unicast route flap statistics for the public network.
<Sysname> display bgp routing-table flap-info ipv6
     From    : 10.1.1.1                                 Flaps     : 5
     Duration: 00:03:25                                 Reuse     : 00:39:28
     Path/Ogn: 100i
     From    : 1::1                                     Flaps     : 5
     Path/Ogn: 100i
Table 17 Command output
Status codes
Status codes:
Origin
Network
PrefixLen
From
Flaps
Duration
Reuse
Path/Ogn
·           dampening
·           reset bgp flap-info ipv6 unicast
Use display bgp routing-table ipv4 unicast to display BGP IPv4 unicast routing information.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays the BGP IPv4 unicast routing information for the public network.
·           If the network-address, mask, and mask-length arguments are not specified, the command displays brief information about all BGP IPv4 unicast routes.
·           If only the network-address argument is specified, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays detailed information about the route.
·           If the network-address mask or network-address mask-length argument is specified and the longest-match keyword is not specified, the command displays detailed information about the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
# Display brief information about all BGP IPv4 unicast routes for the public network.
<Sysname> display bgp routing-table ipv4
 Total number of routes: 4
 BGP local router ID is 192.168.100.1
 Status codes: * - valid, > - best, d - damped, h - history,
               s - suppressed, S - Stale, i - internal, e - external
  >  10.2.1.0/24        10.2.1.1        0                     0       i
   e                    10.2.1.2        0                     0       200i
  >  192.168.1.0        192.168.1.135   0                     0       i
*  e                    10.2.1.2        0                     0       200i
Table 18 Command output
Status codes
Status codes:
Origin
Network
NextHop
Next hop IP address.
MED
MULTI_EXIT_DISC attribute.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path/Ogn
·       AS_PATH—Records the ASs the route has passed to avoid routing loops.
·       ORIGIN—Identifies the origin of the route.
# Display detailed information about BGP IPv4 unicast routes destined to network 10.2.1.0/24 for the public network.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24
 Paths:   2 available, 1 best
 BGP routing table information of 10.2.1.0/24:
 Imported route.
 Original nexthop: 10.2.1.1
 OutLabel        : NULL
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, pref-val 0, pre 0
 State           : valid, local, best,
 Relay nexthop   : not resolved
 Original nexthop: 10.2.1.2
 OutLabel        : NULL
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0, pref-val 0, pre 255
 State           : external,
Table 19 Command output
Paths
Number of routes:
·       available—Number of valid routes.
·       best—Number of optimal routes.
Original nexthop
Original next hop of the route. If the route is received from a BGP update message, the original next hop is the next hop IP address in the message.
OutLabel
Outgoing label of the route.
AS-path
AS_PATH attribute of the route, which records the ASs the route has passed to avoid routing loops.
Origin
·       igp—Originated in the AS. The origin of summary routes and routes advertised with the network command is IGP.
·       egp—Learned through EGP.
·       incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is INCOMPLETE.
Attribute value
BGP path attributes:
·       MED—MED value.
·       localpref—Local preference value.
·       pref-val—Preferred value.
·       pre—Route preference.
Current state of the route:
·       valid.
·       internal.
·       external.
·       local.
·       synchronize.
·       best.
From
IP address of BGP peer that advertised the route.
Relay Nexthop
Next hop found by route recursion. If no next hop is found, this field displays "not resolved."
Use display bgp routing-table ipv4 unicast advertise-info to display advertisement information for BGP IPv4 unicast routes.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] network-address [ mask | mask-length ] advertise-info
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays advertisement information of BGP IPv4 unicast routes for the public network.
·           If the mask and mask-length arguments are not specified, the system ANDs the specified network address with the mask of a route. If the result matches the network address of the route, the command displays advertisement information for the route.
·           If the mask or mask-length argument is specified, the command displays advertisement information for the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
# Display advertisement information of BGP IPv4 unicast routes destined to network 10.2.1.0/24 for the public network.
<Sysname> display bgp routing-table ipv4 10.2.1.0 24 advertise-info
 Paths:   1 best
    10.2.1.2
Table 20 Command output
Paths
Number of optimal routes destined to the specified network.
Advertisement information of BGP routes destined to network 10.2.1.0/24.
Peers to which the route has been advertised and the number of peers.
Use display bgp routing-table ipv4 unicast as-path-acl to display BGP IPv4 unicast routes permitted by an AS path list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast routes permitted by an AS path list for the public network.
as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256.
# Display BGP routes permitted by AS path list 1.
<Sysname> display bgp routing-table ipv4 as-path-acl 1
  >e 30.1.1.0/24        20.1.1.1                              0       200i
For command output, see Table 18.
ip as-path
Use display bgp routing-table ipv4 unicast community-list to display BGP IPv4 unicast routing information matching the specified BGP community list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast routing information matching the specified BGP community list for the public network.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a string of 1 to 63 characters.
whole-match: Displays routes exactly matching the specified community list. Without this keyword, the command displays routes whose COMMUNITY attributes comprise the specified community list.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
# Display BGP routing information matching BGP community list 100.
<Sysname> display bgp routing-table ipv4 community-list 100
ip community-list
Use display bgp routing-table ipv4 unicast peer to display BGP IPv4 unicast routing information advertised to or received from the specified BGP peer.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistics ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv4 unicast routing information advertised to or received from the specified BGP peer for the public network.
advertised-routes: Displays routing information advertised to the specified peer.
received-routes: Displays routing information received from the specified peer.
network-address: Specifies the IP address of the destination network.
mask: Specifies the mask of the destination network, in dotted decimal notation.
statistics: Displays route statistics.
·           If the network-address, mask, and mask-length arguments are not specified, the command displays all BGP IPv4 unicast routing information advertised to or received from the specified BGP peer.
·           If only the network-address argument is specified, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays information about the route.
·           If the network-address mask or network-address mask-length argument is specified, the command displays information about the route that matches both the specified destination network address and the mask (or mask length).
# Display all BGP IPv4 unicast routing information advertised to BGP peer 10.2.1.2 for the public network.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes
# Display all BGP IPv4 unicast routing information received from BGP peer 10.2.1.2 for the public network.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
   e 10.2.1.0/24        10.2.1.2        0                     0       200i
*  e 192.168.1.0        10.2.1.2        0                     0       200i
# Display statistics of BGP IPv4 unicast routes advertised to BGP peer 10.2.1.2 for the public network.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 advertised-routes statistics
 Advertised routes total: 2
# Display statistics of BGP IPv4 unicast routes received from BGP peer 10.2.1.2 for the public network.
<Sysname> display bgp routing-table ipv4 peer 10.2.1.2 received-routes statistics
 Received routes total: 2
Table 21 Command output
Total number of routes advertised to the specified peer.
Total number of routes received from the specified peer.
Use display bgp routing-table ipv4 unicast statistics to display BGP IPv4 unicast route statistics.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] statistics
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays the BGP IPv4 unicast route statistics for the public network.
# Display statistics of BGP IPv4 unicast routes for the public network.
<Sysname> display bgp routing-table ipv4 statistics
Use display bgp routing-table ipv6 unicast to display BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length | advertise-info ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays the BGP IPv6 unicast routing information for the public network.
network-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If this argument is not specified, the command displays brief information about all BGP IPv6 unicast routing information.
advertise-info: Displays advertisement information for BGP IPv6 unicast routes. If this keyword is not specified, the command displays the BGP IPv6 unicast routing table.
# Display brief information about all BGP IPv6 unicast routes for the public network.
<Sysname> display bgp routing-table ipv6
 BGP local router ID is 192.168.1.136
  >e Network : 3::                                      PrefixLen : 64
     NextHop : 1::2                                     LocPrf    :
     MED     :
     Path/Ogn: 100i
Table 22 Command output
Status codes
Status codes:
Origin
Network
PrefixLen
NextHop
Next hop IPv6 address.
LocPrf
PrefVal
OutLabel
MED
Path/Ogn
# Display detailed information about BGP IPv6 unicast routes destined to network 2::/64 for the public network.
<Sysname> display bgp routing-table ipv6 2:: 64
 Local AS number: 200
 BGP routing table information of 2::/64:
 Relay nexthop   : ::FFFF:10.1.1.1
 Original nexthop: ::FFFF:10.1.1.1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 State           : valid, external, best,
 Relay nexthop   : 1::1
 Original nexthop: 1::1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
Table 23 Command output
Paths
Number of routes:
Original nexthop
OutLabel
AS-path
Origin
Attribute value
·       MED—MED value.
·       valid.
·       internal.
·       external.
·       local.
·       best.
From
Relay Nexthop
# Display advertisement information about BGP IPv6 unicast routes destined to network 2::/64 for the public network.
<Sysname> display bgp routing-table ipv6 2:: 64 advertise-info
 BGP local router ID: 192.168.1.136
 Paths:   1 best
 Advertised to peers (2 in total):
    10.1.1.2
    1::2
Table 24 Command output
Paths
Advertisement information of BGP routes destined to network 2::/64.
Peers to which the route has been advertised, and the number of peers.
display bgp routing-table ipv6 unicast as-path-acl
Use display bgp routing-table ipv6 unicast as-path-acl to display BGP IPv6 unicast routes permitted by an AS path list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast routes permitted by an AS path list for the public network.
# Display BGP IPv6 unicast routes permitted by AS path list 1.
<Sysname> display bgp routing-table ipv6 as-path-acl 1
  >e Network : 2::                                      PrefixLen : 64
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
For command output, see Table 22.
ip as-path
display bgp routing-table ipv6 unicast community-list
Use display bgp routing-table ipv6 unicast community-list to display BGP IPv6 unicast routing information matching a specified BGP community list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays BGP IPv6 unicast routing information matching the specified BGP community list for the public network.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
whole-match: Displays routes exactly matching the specified community list. Without this keyword, this command displays routes whose COMMUNITY attributes comprise the specified community list.
# Display BGP IPv6 unicast routing information matching BGP community list 100.
<Sysname> display bgp routing-table ipv6 community-list 100
     MED     :
     Path/Ogn: 100i
     MED     :
     Path/Ogn: 100i
ip community-list
display bgp routing-table ipv6 unicast inlabel
Use display bgp routing-table ipv6 unicast inlabel to display incoming labels for BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] inlabel
# Display incoming labels for all BGP IPv6 unicast routing information.
<Sysname> display bgp routing-table ipv6 inlabel
  >  Network : 1::1                                     PrefixLen : 128
     NextHop : 10::1                                    OutLabel  : NULL
     InLabel : 1279
  >  Network : 10::                                     PrefixLen : 64
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1278
Table 25 Command output
Status codes
Status codes. For more information, see Table 22.
Origin
Origin of the route. For more information, see Table 22.
Network
PrefixLen
NextHop
OutLabel
Outgoing label of the IPv6 unicast route, which is assigned by the peer 6PE device.
InLabel
Incoming label of the IPv6 unicast route, which is assigned by the local 6PE device.
display bgp routing-table ipv6 unicast outlabel
Use display bgp routing-table ipv6 unicast outlabel to display outgoing labels for BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] outlabel
# Display outgoing labels for all BGP IPv6 unicast routing information.
<Sysname> display bgp routing-table ipv6 outlabel
  >i Network : 4::4                                     PrefixLen : 128
     NextHop : ::FFFF:3.3.3.3                           OutLabel  : 1279
  >i Network : 20::                                     PrefixLen : 64
     NextHop : ::FFFF:3.3.3.3                           OutLabel  : 1278
Table 26 Command output
Status codes
Origin
Network
PrefixLen
NextHop
OutLabel
display bgp routing-table ipv6 unicast peer
Use display bgp routing-table ipv6 unicast peer to display BGP IPv6 unicast routing information advertised to or received from the specified BGP peer.
display bgp routing-table ipv6 [ unicast ] peer { ip-address | ipv6-address } { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
display bgp routing-table ipv6 [ unicast ] vpn-instance vpn-instance-name peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
ip-address: Specifies the IP address of a peer.
ipv6-address: Specifies the IPv6 address of a peer.
network-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If this argument is not specified, the command displays all BGP IPv6 unicast routing information.
# Display all BGP IPv6 unicast routing information advertised to BGP peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes
  >  Network : 2::                                      PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: i
# Display all BGP IPv6 unicast routing information received from BGP peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes
     NextHop : ::FFFF:10.1.1.1                          LocPrf    :
     MED     : 0
     Path/Ogn: 100i
# Display statistics of BGP IPv6 unicast routes advertised to BGP peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 advertised-routes statistics
 Advertised routes total: 1
# Display statistics of BGP IPv6 unicast routes received from BGP peer 1::1.
<Sysname> display bgp routing-table ipv6 peer 1::1 received-routes statistics
 Received routes total: 1
Table 27 Command output
display bgp routing-table ipv6 unicast statistics
Use display bgp routing-table ipv6 unicast statistics to display BGP IPv6 unicast route statistics.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] statistics
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays the BGP IPv6 unicast route statistics for the public network.
# Display statistics of BGP IPv6 unicast routes.
<Sysname> display bgp routing-table ipv6 statistics
ebgp-interface-sensitive
Use ebgp-interface-sensitive to enable quick reestablishment of direct EBGP sessions.
Use undo ebgp-interface-sensitive to disable the function.
Quick reestablishment of direct EBGP sessions is enabled.
BGP view
This command enables BGP to quickly handle direct EBGP link failures. When a direct link to an EBGP peer fails, BGP tears down the session and reestablishes a session to the peer immediately. If the function is not enabled, the router does not tear down the session until the holdtime expires. However, disabling this function can prevent routing flaps from affecting EBGP session state.
This command applies to only direct EBGP sessions.
# Enable quick reestablishment of direct EBGP sessions.
[Sysname] bgp 100
[Sysname-bgp] ebgp-interface-sensitive
filter-policy export
Use filter-policy export to filter outbound routes by using a specified filter.
Use undo filter-policy export to cancel filtering of outbound routes.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view:
filter-policy { acl-number | prefix-list prefix-list-name } export [ protocol process-id ]
undo filter-policy { acl-number | prefix-list prefix-list-name } export [ protocol process-id ]
In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view/BGP VPNv6 instance view:
filter-policy { acl6-number | prefix-list ipv6-prefix-name } export [ protocol process-id ]
undo filter-policy { acl6-number | prefix-list ipv6-prefix-name } export [ protocol process-id ]
No outbound routing information is filtered.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view, BGP VPNv6 instance view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to match routes by destination.
acl6-number: Specifies an ACL6 by its number in the range of 2000 to 3999 to match routes by destination.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
prefix-list ipv6-prefix-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to match routes by destination.
protocol: Filters routes redistributed from the routing protocol. In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view, it can be direct, isis, ospf, rip, or static. In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view/BGP VPNv6 instance view, it can be direct, isisv6, ospfv3, ripng, or static.
process-id: Specifies a routing protocol by its ID in the range of 1 to 65535. In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view, it is available only when the protocol is isis, ospf, or rip. In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view/BGP VPNv6 instance view, it is available only when the protocol is isisv6, ospfv3, or ripng.
If a protocol is specified, this command filters only routes redistributed from the specified protocol. If no protocol is specified, this command filters all redistributed routes, including routes redistributed from IGP and injected by the network command.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination addresses match the source-address source-wildcard argument without matching the masks of the destination addresses.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following steps:
·           To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·           To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination. The subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# In BGP IPv4 unicast instance view, use ACL 2000 to filter outbound BGP routes.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family unicast
[Sysname-bgp-ipv4] filter-policy 2000 export
# In BGP-VPN IPv6 unicast instance view, use ACL6 2000 to filter outbound BGP routes.
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1] ipv6-family unicast
[Sysname-bgp-ipv6-vpn1] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and use ACL 3000 to filter outbound routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] bgp 100
[Sysname-bgp-ipv4] filter-policy 3000 export
·           filter-policy import
·           peer as-path-acl
·           peer filter-policy
·           peer prefix-list
·           peer route-policy
Use filter-policy import to filter inbound routing information by using a specified filter.
Use undo filter-policy import to cancel filtering inbound routing information.
filter-policy { acl-number | prefix-list prefix-list-name } import
undo filter-policy { acl-number | prefix-list prefix-list-name } import
filter-policy { acl6-number | prefix-list ipv6-prefix-name } import
undo filter-policy { acl6-number | prefix-list ipv6-prefix-name } import
No inbound routing information is filtered.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches routes whose destination network addresses match the source-address source-wildcard argument without matching  the masks of the destination addresses.
·           To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
# In BGP IPv4 unicast instance view, use ACL 2000 to filter inbound BGP routes.
[Sysname] bgp 100
[Sysname-bgp-ipv4] filter-policy 2000 import
# In BGP-VPN IPv6 unicast instance view, use ACL6 2000 to filter inbound BGP routes.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] filter-policy 2000 import
# Configure ACL6 3000 to permit only route 113.0.0.0/16 to pass, and use ACL 3000 to filter inbound routes.
[Sysname] bgp 100
[Sysname-bgp-ipv4] filter-policy 3000 import
·           filter-policy export
·           peer as-path-acl
·           peer prefix-list
·           peer route-policy
graceful-restart
Use graceful-restart to enable BGP Graceful Restart capability.
Use undo graceful-restart to disable BGP Graceful Restart capability.
graceful-restart
BGP Graceful Restart capability is disabled.
BGP view
Graceful Restart (GR) ensures continuous forwarding when BGP restarts or an active/standby switchover occurs.
BGP peers exchange Open messages containing GR information. If both parties have GR capability, they establish a GR-capable session.
After you execute this command, the device reestablishes BGP sessions.
# Enable Graceful Restart capability for BGP process 100.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart
·           graceful-restart timer restart
·           graceful-restart timer wait-for-rib
Use graceful-restart timer restart to configure the GR timer.
Use undo graceful-restart timer restart to restore the default.
The GR timer is 150 seconds.
BGP view
timer: Specifies the GR time in the range of 3 to 600 seconds.
The GR Restarter sends the GR timer to the GR Helper in an Open message. When the GR Helper detects that an active/standby switchover or a BGP restart occurs on the GR Restarter, the GR Helper marks all routes learned from the GR Restarter as stale and starts the GR timer. If no BGP session is established before the GR timer expires, the GR Helper removes the stale routes.
Before you configure this command, enable the BGP GR capability.
To apply a new GR timer, you must reestablish BGP sessions.
# Configure the GR timer as 300 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer restart 300
·           graceful-restart
Use graceful-restart timer wait-for-rib to configure the time to wait for the End-of-RIB marker.
Use undo graceful-restart timer wait-for-rib to restore the default.
The time to wait for the End-of-RIB marker is 180 seconds.
BGP view
timer: Specifies the time to wait for the End-of-RIB marker, in the range of 3 to 300 seconds.
BGP uses this timer to control the time to receive updates from the peer. The timer is not advertised to the peer.
After the GR Restarter and GR Helper reestablish a BGP session, they start this timer. If they do not complete route exchange before the timer expires, the GR Restarter does not receive new routes but updates its routing table and forwarding table with learned BGP routes, and the GR Helper removes the stale routes.
This command controls the routing convergence speed. A smaller timer value means faster routing convergence but possibly results in incomplete routing information.
Before configuring this command, you must enable the BGP GR capability.
# Set the time to wait for the End-of-RIB marker on the local end to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer wait-for-rib 100
·           graceful-restart
group
Use group to create a peer group.
Use undo group to delete a peer group.
group group-name [ external | internal ]
undo group group-name
No peer group is created.
BGP view, BGP-VPN view
group-name: Specifies a name for the peer group, a case-sensitive string of 1 to 47 characters.
external: Creates an EBGP peer group.
internal: Creates an IBGP peer group.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. In this way, peers can share the same policy as the peer group. When the policy of the group is modified, the modification also applies to peers in it.
If the internal or external keyword is not specified, the command creates an IBGP peer group.
If you perform configurations on a peer group and peers of the peer group, the last configuration takes effect.
After you create a peer group, you must use the peer enable command to enable BGP to exchange routing information with the specified peer group.
# In BGP view, create an EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp] peer test as-number 200
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp] peer 10.1.2.1 group test
# In BGP-VPN view, create an EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp-vpn1] group test external
[Sysname-bgp-vpn1] peer test as-number 200
[Sysname-bgp-vpn1] peer 10.1.1.1 group test
[Sysname-bgp-vpn1] peer 10.1.2.1 group test
# In BGP view, create an EBGP peer group test with AS number 200, and add EBGP peers 1::1 and 1::2 into the group.
[Sysname] bgp 100
[Sysname-bgp] peer 1::1 group test
[Sysname-bgp] peer 1::2 group test
# In BGP-VPN view, create an EBGP peer group test with AS number 200, and add EBGP peers 1::1 and 1::2 into the group.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 group test
[Sysname-bgp-vpn1] peer 1::2 group test
·           display bgp group ipv4 unicast
·           display bgp group ipv6 unicast
·           peer enable
·           peer group
ignore-first-as
Use ignore-first-as to configure BGP to ignore the first AS number of EBGP route updates.
Use undo ignore-first-as to restore the default.
ignore-first-as
BGP checks the first AS number of a received EBGP route update. If the first AS number is not that of the BGP peer, the BGP router discards the route update.
BGP view
# Configure BGP to ignore the first AS number of EBGP route updates.
[Sysname] bgp 100
[Sysname-bgp] ignore-first-as
import-route
Use import-route to enable BGP to redistribute routes from an IGP protocol.
Use undo import-route to disable route redistribution from an IGP protocol.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view:
import-route protocol [ { process-id | all-processes } [ med med-value | route-policy route-policy-name ] * ]
In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view:
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
undo import-route protocol [ process-id ]
BGP does not redistribute IGP routes.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view
protocol: Redistributes routes from a specified IGP protocol. In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view, it can be direct, isis, ospf, rip, or static. In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view, it can be direct, isisv6, ospfv3, ripng, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default is 1. In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view, it is available only when the protocol is isis, ospf, or rip. In BGP IPv6 unicast instance view/BGP-VPN IPv6 unicast instance view, it is available only when the protocol is isisv6, ospfv3, or ripng.
all-processes: Redistributes routes from all the processes of the specified IGP protocol. This keyword takes effect only when the protocol is isis, ospf, or rip.
med med-value: Specifies a MED value for redistributed routes, in the range of 0 to 4294967295. If no MED is specified, the metric of a redistributed route is used as its MED.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes or set route attributes for redistributed routes.
The import-route command cannot redistribute default IGP routes. To redistribute default IGP routes, use the default-route imported command together with the import-route command.
Only active routes can be redistributed. You can use the display ip routing-table protocol or display ipv6 routing-table protocol command to view route state information.
The ORIGIN attribute of routes redistributed by the import-route command is INCOMPLETE.
# In BGP IPv4 unicast instance view, redistribute routes from RIP process 1, and set the MED value for redistributed routes to 100.
[Sysname] bgp 100
[Sysname-bgp-ipv4] import-route rip 1 med 100
# In BGP-VPN IPv4 unicast instance view, redistribute routes from RIP process 1, and reference a routing policy imprt to exclude route 1.1.1.0/24 from route redistribution.
[Sysname] ip prefix-list imprt deny 1.1.1.0 24
[Sysname] ip prefix-list imprt permit 0.0.0.0 0 less-equal 32
[Sysname] route-policy imprt permit node 0
[Sysname-route-policy-imprt-0] if-match ip address prefix-list imprt
[Sysname-route-policy-imprt-0] quit
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv4-family unicast
[Sysname-bgp-ipv4-vpn1] import-route rip 1 route-policy imprt
# In BGP IPv6 unicast instance view, redistribute routes from RIP process 1.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family unicast
[Sysname-bgp-ipv6] import-route ripng
# In BGP-VPN IPv6 unicast instance view, redistribute routes from RIP process 1.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] import-route ripng
·           display ip routing-table protocol
·           display ipv6 routing-table protocol
ip vpn-instance (BGP view)
Use ip vpn-instance to enter BGP-VPN view.
Use undo ip vpn-instance to remove all configurations in BGP-VPN view.
BGP view
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After you create a BGP peer in BGP-VPN view, the BGP routes learned from the peer are added into the routing table of the specified VPN instance.
This command and all commands in BGP-VPN view are usually executed on provider edge (PE) or Multi-VPN-Instance CE (MCE) devices to add routes learned from different sites into different VPN instances.
Before you execute this command, use the ip vpn-instance command to create the VPN instance in system view, and use the route-distinguisher command to configure a route distinguisher (RD) for the VPN instance.
# Enter BGP-VPN view of VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-vpn1]
·           ip vpn-instance (system-view) (MPLS Command reference)
·           route-distinguisher (MPLS Command reference)
ipv4-family
Use ipv4-family to create and enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
Use undo ipv4-family to remove all configurations in BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
ipv4-family [ unicast ]
undo ipv4-family [ unicast ]
The BGP IPv4 unicast instance view or the BGP-VPN IPv4 unicast instance view is not created.
unicast: Specifies the IPv4 unicast instance view. The IPv4 unicast instance view is specified for the command regardless of whether the unicast keyword is specified.
Configurations made in BGP IPv4 unicast instance view apply to only the BGP IPv4 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv4 unicast instance view apply to only the BGP IPv4 unicast routes and peers of the specified VPN instance.
# In BGP view, create and enter BGP IPv4 unicast instance view.
[Sysname] bgp 100
[Sysname-bgp-ipv4]
# In BGP-VPN view, create and enter BGP-VPN IPv4 unicast instance view.
[Sysname] bgp 100
ipv6-family
Use ipv6-family to create and enter BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
Use undo ipv6-family to remove all configurations in BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
ipv6-family [ unicast ]
undo ipv6-family [ unicast ]
The BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view is not created.
unicast: Specifies the IPv6 unicast instance view. The IPv6 unicast instance view is specified for the command regardless of whether the unicast keyword is specified.
Configurations made in BGP IPv6 unicast instance view apply to only the BGP IPv6 unicast routes and peers of the public network.
Configurations made in BGP-VPN IPv6 unicast instance view apply to only the BGP IPv6 unicast routes and peers of the specified VPN instance.
# In BGP view, create and enter BGP IPv6 unicast instance view.
[Sysname] bgp 100
[Sysname-bgp-ipv6]
# In BGP-VPN view, create and enter BGP-VPN IPv6 unicast instance view.
[Sysname] bgp 100
log-peer-change
Use log-peer-change to enable the logging of session state changes globally.
Use undo log-peer-change to disable the function.
log-peer-change
Logging of session state changes is enabled globally.
BGP view
After you execute the log-peer-change command, BGP logs session establishment and disconnection events. To view the log information, use the display bgp ipv4 peer log-info command.
If you disable the logging of session state changes globally, the display bgp ipv4 peer log-info command does not show relevant log information.
# Enable the logging of session state changes globally.
[Sysname] bgp 100
[Sysname-bgp] log-peer-change
network
Use network to inject a network to the BGP routing table.
Use undo network to remove the configuration.
network ip-address [ mask | mask-length ] [ route-policy route-policy-name ]
undo network ip-address [ mask | mask-length ]
undo network ipv6-address prefix-length
BGP does not advertise any local network.
ip-address: Specifies an IPv4 network address. If the mask or mask-length is not specified, natural mask is used.
mask: Specifies a mask in dotted decimal notation.
ipv6-address: Specifies an IPv6 network address.
prefix-length: Specifies a prefix length in the range of 0 to 128.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes or set the route attributes.
·           The network to be injected must be available and active in the local IP routing table.
·           The ORIGIN attribute of the route injected with the network command is IGP.
·           When you execute the undo network command, you must specify the same mask or mask length/prefix length that you specified for the network command. Otherwise, the configuration cannot be removed.
# In BGP IPv4 unicast instance view, inject local network 10.0.0.0/16 to the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv4] network 10.0.0.0 255.255.0.0
# In BGP-VPN IPv4 unicast instance view, inject local network 10.0.0.0/16 to the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] network 10.0.0.0 255.255.0.0
# In BGP IPv6 unicast instance view, inject local network 2002::/64 to the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv6] network 2002:: 64
# In BGP-VPN IPv6 unicast instance view, inject local network 2002::/64 to the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] network 2002:: 64
network short-cut
Use network short-cut to increase the preference for a received EBGP route. This EBGP route is called shortcut route.
Use undo network short-cut to cancel the configuration.
network ip-address [ mask | mask-length ] short-cut
undo network ip-address [ mask | mask-length ] short-cut
undo network ipv6-address prefix-length short-cut
A received EBGP route has a preference of 255.
mask: Specifies a mask of the network address in dotted decimal notation.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
By default, the preference of an EBGP route is lower than a local route. If a device has an EBGP route and a local route to reach the same destination, the device does not select the EBGP route. You can use the network shortcut command to configure the EBGP route to have the same preference as the local route so the EBGP route is more likely to become the optimal route.
You can use the preference command to modify the preferences for external and local BGP routes.
# In BGP IPv4 unicast instance view, increase the preference of EBGP route 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp-ipv4] network 10.0.0.0 255.255.0.0 short-cut
# In BGP-VPN IPv6 unicast instance view, increase the preference of EBGP route 10::/16.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] network 10:: 16 short-cut
preference
peer advertise-community
Use peer advertise-community to advertise the COMMUNITY attribute to a peer or peer group.
Use undo peer advertise-community to disable the COMMUNITY attribute advertisement to a peer or peer group.
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
In BGP IPv6 unicast instance view:
peer { group-name | ip-address | ipv6-address } advertise-community
undo peer { group-name | ip-address | ipv6-address } advertise-community
No COMMUNITY attribute is advertised to any peer or peer group.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ip-address: Specifies a peer by its IP address. The peer must have been created.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
The COMMUNITY attribute is a group of specific data carried in update messages. A route can carry one or more COMMUNITY attribute values (each is represented by a 4-byte integer). The receiving router processes the route (for example, determining whether to advertise the route and the scope for advertising the route) based on the COMMUNITY attribute values.
After you execute the peer advertise-community command, routing updates advertised to the peer carry the COMMUNITY attribute.
After you execute the undo peer advertise-community command, BGP, upon receiving a route with the COMMUNITY attribute, removes the COMMUNITY attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast instance view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test advertise-community
# In BGP-VPN IPv4 unicast instance view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test advertise-community
# In BGP IPv6 unicast instance view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer test advertise-community
·           apply community
·           if-match community
·           ip community-list
peer advertise-ext-community
Use peer advertise-ext-community to advertise the extended community attribute to a peer or peer group.
Use undo peer advertise-ext-community to disable the extended community attribute advertisement to a peer or peer group.
peer { group-name | ip-address } advertise-ext-community
undo peer { group-name | ip-address } advertise-ext-community
peer { group-name | ip-address | ipv6-address } advertise-ext-community
undo peer { group-name | ip-address | ipv6-address } advertise-ext-community
No extended community attribute is advertised to a peer or peer group.
To satisfy increasing user demands, BGP defines a new attribute—extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
·           The extended community attribute has an 8-byte length.
·           The extended community attribute supports various types. You can select an extended community attribute type as needed to implement route filtering and control. This simplifies configuration and management.
After you execute the peer advertise-ext-community command, route updates sent to the peer or peer group carry the extended community attribute.
After you execute the undo peer advertise-ext-community command, BGP, upon receiving a route with the extended community attribute, removes the extended community attribute before sending the route to the peer or peer group.
# In BGP IPv4 unicast instance view, advertise the extended community attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test advertise-ext-community
# In BGP-VPN IPv4 unicast instance view, advertise the extended community attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test advertise-ext-community
# In BGP IPv6 unicast instance view, advertise the extended community attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer test advertise-ext-community
·           apply extcommunity
·           if-match extcommunity
·           ip extcommunity-list
peer allow-as-loop
Use peer allow-as-loop to allow a local AS number to exist in the AS_PATH attribute of routes from a peer or peer group, and to configure the number of times the local AS number can appear.
Use undo peer allow-as-loop to restore the default.
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
peer { group-name | ip-address | ipv6-address } allow-as-loop [ number ]
undo peer { group-name | ip-address | ipv6-address } allow-as-loop
In BGP VPN IPv6 unicast instance view:
peer { group-name | ipv6-address } allow-as-loop [ number ]
undo peer { group-name | ipv6-address } allow-as-loop
The local AS number is not allowed to exist in the AS_PATH attribute of routes from a peer or peer group.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP-VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view
number: Specifies the number of times for which the local AS number can appear, in the range of 1 to 10. The default number is 1. If the number of times for which the local AS number appears in a route is more than the specified number, BGP considers that a routing loop occurs and discards the route.
By default, BGP does not receive routes that contain the local AS number in the AS_PATH attribute to avoid routing loops. However, in certain network environments (a Hub&Spoke network in MPLS L3VPN, for example), the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
# In BGP IPv4 unicast instance view, configure the number of times the local AS number can appear in AS_PATH attribute of routes from peer group test as 2.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test allow-as-loop 2
# In BGP VPNv4 instance view, configure the number of times the local AS number can appear in AS_PATH attribute of routes from peer group test as 2.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family unicast vpnv4
[Sysname-bgp-vpnv4] peer test allow-as-loop 2
# In BGP-VPN IPv6 unicast instance view, configure the number of times the local AS number can appear in AS_PATH attribute of routes from peer group test as 2.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test allow-as-loop 2
peer as-number (for a BGP peer)
Use peer as-number to create a BGP peer and specify its AS number.
Use undo peer to delete a BGP peer.
peer { ip-address | ipv6-address } as-number as-number
undo peer { ip-address | ipv6-address }
No BGP peer is created.
as-number: Specifies an AS number for the peer, in the range of 1 to 4294967295. If the AS numbers of the peer and the local router are the same, the peer is an IBGP peer. If they are different, the peer is an EBGP peer.
You can also create a peer and add it to a peer group by using the peer group command.
To modify the AS number of a peer, do not execute the peer as-number command repeatedly. Instead, you must first delete the peer and configure it again.
After you create a peer, you must use the peer enable command to enable BGP to exchange routing information with the specified peer.
# In BGP view, create BGP peer 1.1.1.1 and specify its AS number as 100.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 100
# In BGP-VPN view, create BGP peer 1::1 and specify its AS number as 100.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 as-number 100
·           display bgp peer ipv4 unicast
·           display bgp peer ipv6 unicast
·           peer enable
·           peer group
peer as-number (for a BGP peer group)
Use peer as-number to specify an AS number for a peer group.
Use undo peer as-number to delete the AS number of a peer group.
undo peer group-name as-number
No AS number is specified for a peer group.
group-name: Specifies a name for a peer group, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
as-number: Specifies an AS number for a peer group, in the range of 1 to 4294967295.
·           This command applies to only a peer group with no peers in it.
·           When you specify an AS number for a peer group and want to add peers to it, make sure the AS number of the peers is the same as the peer group.
·           If you have specified no AS number for a peer group, peers added to it can use their own AS numbers.
# In BGP view, specify the AS number for peer group test as 100.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 100
# In BGP-VPN view, specify the AS number for peer group test as 100.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test as-number 100
peer group
peer as-path-acl
Use peer as-path-acl to specify an AS path list to filter routes incoming from or outgoing to a peer/peer group.
Use undo peer as-path-acl to remove the configuration.
peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
peer { group-name | ip-address | ipv6-address } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ip-address | ipv6-address } as-path-acl as-path-acl-number { export | import }
No AS path list is specified for filtering.
ip-address: Specifies a peer by its IPv4 address. The peer must have been created.
export: Filters outgoing routes.
import: Filters incoming routes.
The specified AS path list must have been created with the ip as-path command in system view. Otherwise, all routes can pass the AS path list.
# In BGP IPv4 unicast instance view, specify the AS path list 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test as-path-acl 1 export
# In BGP-VPN IPv4 unicast instance view, specify the AS path list 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test as-path-acl 1 export
# In BGP IPv6 unicast instance view, specify the AS path list 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer test as-path-acl 1 export
·           ip as-path
·           peer prefix-list
·           peer route-policy
peer bfd
Use peer bfd to enable BFD for the link to a BGP peer.
Use undo peer bfd to restore the default.
peer { ip-address | ipv6-address } bfd
undo peer { ip-address | ipv6-address } bfd
BFD is disabled.
BFD helps speed up BGP routing convergence upon link failures. However, if you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, resulting in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
# In BGP view, enable BFD for the link to BGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 bfd
# In BGP view, enable BFD for the link to BGP peer 1::1.
[Sysname] bgp 100
[Sysname-bgp] peer 1::1 bfd
# In BGP-VPN view, enable BFD for the link to BGP peer 2.2.2.2.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 2.2.2.2 bfd
# In BGP-VPN view, enable BFD for the link to BGP peer 2::2.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 2::2 bfd
·           display bfd session (High Availability Command Reference)
peer capability-advertise conventional
Use peer capability-advertise conventional to disable BGP multi-protocol extension and route refresh for a peer or peer group.
Use undo peer capability-advertise conventional to enable BGP multi-protocol extension and route refresh for a peer or peer group.
peer { group-name | ip-address | ipv6-address } capability-advertise conventional
undo peer { group-name | ip-address | ipv6-address } capability-advertise conventional
BGP multi-protocol extension and route refresh are enabled.
The route refresh function enables BGP to send and receive Route-refresh messages and implement BGP session soft-reset.
The multi-protocol extension function enables BGP to advertise and receive routing information for various protocols (for example, IPv6 routing information).
If both the peer capability-advertise conventional and peer capability-advertise route-refresh commands are executed, the last configuration takes effect.
# In BGP view, disable multi-protocol extension and route refresh for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 capability-advertise conventional
# In BGP-VPN view, disable multi-protocol extension and route refresh for peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 capability-advertise conventional
·           peer capability-advertise route-refresh
Use peer capability-advertise route-refresh to enable BGP route refresh for a specified peer or peer group.
Use undo peer capability-advertise route-refresh to disable the function.
peer { group-name | ip-address | ipv6-address } capability-advertise route-refresh
undo peer { group-name | ip-address | ipv6-address } capability-advertise route-refresh
BGP route refresh is enabled.
The route refresh function enables BGP to send and receive Route-refresh messages.
BGP uses the route refresh function to implement BGP session soft-reset. After a policy is modified, the router advertises a Route-refresh message to the peers. The peers resend their routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy. This method allows you to refresh the BGP routing table and apply the new route selection policy without tearing down BGP sessions.
BGP route refresh requires that both the local router and the peer support route refresh.
If both the peer capability-advertise route-refresh and peer capability-advertise conventional commands are executed, the last configuration takes effect.
# In BGP view, enable BGP route refresh for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 capability-advertise route-refresh
# In BGP-VPN view, enable BGP route refresh for peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 as-number 200
[Sysname-bgp-vpn1] peer 1::1 capability-advertise route-refresh
·           peer capability-advertise conventional
·           peer keep-all-routes
·           refresh bgp ipv4 unicast
·           refresh bgp ipv6 unicast
peer capability-advertise suppress-4-byte-as
Use peer capability-advertise suppress-4-byte-as to enable 4-byte AS number suppression.
Use undo peer capability-advertise suppress-4-byte-as to disable the function.
peer { group-name | ip-address | ipv6-address } capability-advertise suppress-4-byte-as
undo peer { group-name | ip-address | ipv6-address } capability-advertise suppress-4-byte-as
The 4-byte AS number suppression function is disabled.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device does not support 4-byte AS numbers (supports only 2-byte AS numbers), the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression function. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression function. Otherwise, the BGP session cannot be established.
# In BGP view, enable 4-byte AS number suppression for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 capability-advertise suppress-4-byte-as
# In BGP-VPN instance view, enable 4-byte AS number suppression for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1.1.1.1 as-number 200
[Sysname-bgp-vpn1] peer 1.1.1.1 capability-advertise suppress-4-byte-as
peer connect-interface
Use peer connect-interface to specify a source interface (IP address/IPv6 address) for establishing TCP connections to a peer or peer group.
Use undo peer connect-interface to restore the default.
peer { group-name | ip-address | ipv6-address } connect-interface interface-type interface-number
undo peer { group-name | ip-address | ipv6-address } connect-interface
BGP uses the output interface (IP address/IPv6 address) of the best route destined for the BGP peer or peer group as the source interface for establishing a TCP connection to the peer or peer group.
If the peer's IP address/IPv6 address belongs to an interface indirectly connected to the local router, specify that interface as the source interface for TCP connections on the peer. For example, interface A on the local end is directly connected to interface B on the peer. When you execute the peer x.x.x.x as-number as-number command on the local end to specify the BGP peer, and x.x.x.x is not the IP address of interface B, use the peer connect-interface command on the peer to specify the interface whose IP address is x.x.x.x as the source interface for establishing a TCP connection.
If a BGP router has multiple links to a peer, and the source interface fails, BGP has to reestablish TCP connections, causing network oscillation. To improve link availability, H3C recommends that you use a loopback interface as the source interface.
To establish multiple BGP sessions between two routers, specify the source interface for establishing TCP connections to each peer on the local router. Otherwise, the local BGP router might fail to establish TCP connections to a peer when using the outbound interface of the best route to the peer as the source interface.
The source interfaces on the local router and the peer must be reachable.
To specify an indirectly connected interface (except loopback interfaces) on an EBGP peer as the source interface, use the peer ebgp-max-hop command to allow the establishment of an EBGP session to the indirectly connected peer.
If an interface has multiple IP addresses, use the primary IP address for establishing TCP connections. If an interface has multiple IPv6 addresses, select an IPv6 address as defined in RFC 3484 for establishing TCP connections.
# In BGP view, specify loopback 0 as the source interface for TCP connections to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test connect-interface loopback 0
# In BGP-VPN view, specify loopback 0 as the source interface for TCP connections to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test connect-interface loopback 0
peer ebgp-max-hop
peer default-route-advertise
Use peer default-route-advertise to advertise a default route to a peer or peer group.
Use undo peer default-route-advertise to disable default route advertisement to a peer or peer group.
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
In BGP VPNv4 instance view:
peer { group-name | ip-address } default-route-advertise vpn-instance vpn-instance-name
undo peer { group-name | ip-address } default-route-advertise vpn-instance vpn-instance-name
peer { group-name | ip-address | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
No default route is advertised to a peer or peer group.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to modify the route attribute.
The peer default-route-advertise command enables the router to send a default route with the next hop being itself to the peer or peer group regardless of whether the default route exists in the routing table.
# In BGP IPv4 unicast instance view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test default-route-advertise
# In BGP-VPN IPv4 unicast instance view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test default-route-advertise
# In BGP IPv6 unicast instance view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer test default-route-advertise
peer description
Use peer description to configure a description for a peer or peer group.
Use undo peer description to remove the description for a peer or peer group.
peer { group-name | ip-address| ipv6-address } description description-text
undo peer { group-name | ip-address| ipv6-address } description
No description information is configured for a peer or peer group.
description-text: Specifies a description for a peer or peer group, a case-sensitive string of 1 to 79 characters.
# In BGP view, configure a description for the peer group test as ISP1.
[Sysname] bgp 100
[Sysname-bgp] peer test description ISP1
# In BGP-VPN view, configure a description for the peer group test as ISP1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test description ISP1
peer ebgp-max-hop
Use peer ebgp-max-hop to enable BGP to establish an EBGP session to an indirectly-connected peer or peer group and specify the maximum hop count.
Use undo peer ebgp-max-hop to restore the default.
peer { group-name | ip-address | ipv6-address } ebgp-max-hop [ hop-count ]
undo peer { group-name | ip-address | ipv6-address } ebgp-max-hop
BGP does not establish an EBGP session to an indirectly-connected peer or peer group.
hop-count: Specifies the maximum number of hop counts, in the range of 1 to 255. The default is 64.
EBGP peers must be directly connected. If not, use the peer ebgp-max-hop command to establish an EBGP session over multiple hops between two peers. If direct EBGP peers use loopback interfaces to establish a BGP session, you do not need to configure the peer ebgp-max-hop command.
# In BGP view, enable BGP to establish EBGP sessions to an indirectly-connected EBGP peer group test, and specify the maximum hop count as 64 (default).
[Sysname] bgp 100
[Sysname-bgp] peer test ebgp-max-hop
# In BGP-VPN view, enable BGP to establish EBGP sessions to an indirectly-connected EBGP peer group test, and specify the maximum hop count as 64 (default).
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test ebgp-max-hop
peer enable
Use peer enable to enable BGP to exchange routing information for an address family with a peer or peer group.
Use undo peer enable to disable BGP from exchanging routing information for an address family with a peer or peer group.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view/BGP-VPN VPNv4 instance view/BGP VPNv6 instance view:
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
peer { group-name | ip-address | ipv6-address } enable
undo peer { group-name | ip-address | ipv6-address } enable
In BGP-VPN IPv6 unicast instance view:
peer { group-name | ipv6-address } enable
undo peer { group-name | ipv6-address } enable
BGP cannot exchange routing information with a peer or peer group.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP-VPNv4 instance view, BGP-VPN VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view, BGP-VPNv6 instance view
Executing the peer enable command in different views enables BGP to exchange routing information for the corresponding address families with the specified peer.
·           In BGP IPv4 unicast instance view, the command enables the capability to exchange IPv4 unicast routing information, and adds the learned routes to the BGP routing table of the public network.
·           In BGP-VPN IPv4 unicast instance view, the command enables the capability to exchange IPv4 unicast routing information, and adds the learned routes to the BGP routing table of the specified VPN instance.
·           In BGP VPNv4 instance view, the command enables the capability to exchange VPNv4 routing information. In an MPLS L3VPN network, execute the command on PE devices in BGP VPNv4 instance view.
·           In BGP-VPN VPNv4 instance view, the command enables the capability to exchange VPNv4 routing information. In a nested VPN network, execute this command on ISP PE devices in BGP-VPN VPNv4 instance view to enable the PE devices to exchange BGP VPNv4 routing information with ISP CEs, and add the VPNv4 routes learned by the PE devices to the routing table of the specified VPN instance.
·           In BGP IPv6 unicast instance view, the command enables the capability to exchange IPv6 unicast routing information, and adds the learned routes to the IPv6 BGP routing table of the public network.
·           In BGP-VPN IPv6 unicast instance view, the command enables the capability to exchange IPv6 unicast routing information, and adds the learned routes to the IPv6 BGP routing table of the specified VPN instance.
·           In BGP VPNv6 instance view, the command enables the capability to exchange VPNv6 routing information. In an IPv6 MPLS L3VPN network, execute the command on PE devices in BGP VPNv6 instance view.
The undo peer enable command disables BGP to exchange routing information for the corresponding address family with the peer.
# In BGP IPv4 unicast instance view, enable BGP to exchange IPv4 unicast routing information with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer 1.1.1.1 enable
# In BGP-VPN IPv4 unicast instance view, enable BGP to exchange IPv4 unicast routing information with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 1.1.1.1 enable
# In BGP IPv6 unicast instance view, enable BGP to exchange IPv6 unicast routing information with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer 1.1.1.1 enable
# In BGP-VPN IPv6 unicast instance view, enable BGP to exchange IPv6 unicast routing information with peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer 1::1 enable
peer fake-as
Use peer fake-as to advertise a fake AS number to a peer or peer group.
Use undo peer fake-as to restore the default.
peer { group-name | ip-address | ipv6-address } fake-as as-number
undo peer { group-name | ip-address | ipv6-address } fake-as
No fake local AS number is advertised to a peer or peer group.
as-number: Specifies a fake AS number in the range of 1 to 4294967295.
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
The peer fake-as command is only applicable to EBGP peers or peer groups.
If you execute the peer fake-as command on the local router, specify the local router's AS number on the peer as the fake local AS number specified in the command.
# In BGP view, advertise a fake AS number of 200 to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test fake-as 200
# In BGP-VPN view, advertise a fake AS number of 200 to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test fake-as 200
peer filter-policy
Use peer filter-policy to filter routes advertised to or received from a peer or peer group by using an ACL.
Use undo peer filter-policy to remove the configuration.
peer { group-name | ip-address } filter-policy acl-number { export | import }
undo peer { group-name | ip-address } filter-policy [ acl-number ] { export | import }
peer { group-name | ip-address | ipv6-address } filter-policy acl6-number { export | import }
undo peer { group-name | ip-address | ipv6-address } filter-policy acl6-number { export | import }
peer { group-name | ipv6-address } filter-policy acl6-number { export | import }
undo peer { group-name | ipv6-address } filter-policy acl6-number { export | import }
In BGP VPNv6 instance view:
peer { group-name | ip-address } filter-policy acl6-number { export | import }
undo peer { group-name | ip-address } filter-policy acl6-number { export | import }
No ACL-based filtering is configured.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
acl6-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
export: Filters routes advertised to the peer/peer group.
import: Filters routes received from the peer/peer group.
The specified ACL referenced by the peer filter-policy command must have been created with the acl command in system view. Otherwise, all routes can pass the ACL.
If you use a basic ACL (with a number from 2000 to 2999) configured with the rule [ rule-id ] { deny | permit } source source-address source-wildcard command, the command matches whose destination network addresses match the source-address source-wildcard argument without matching the masks of the destination addresses.
If you want to use an advanced ACL (with a number from 3000 to 3999) in the command, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination. The subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# In BGP IPv4 unicast instance view, apply ACL 2000 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test filter-policy 2000 export
# In BGP-VPN IPv6 unicast instance view, apply ACL6 2000 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test filter-policy 2000 export
·           acl (ACL and QoS Command Reference)
·           peer as-path-acl
·           peer prefix-list
·           peer route-policy
peer group
Use peer group to add a peer to a peer group.
Use undo peer group to delete a specified peer from a peer group.
peer { ip-address | ipv6-address } group group-name [ as-number as-number ]
undo peer { ip-address | ipv6-address } group group-name
No peer exists in a peer group.
as-number as-number: Specifies an AS for a peer by its number in the range of 1 to 4294967295.
You can add a peer to a peer group in the following ways:
·           Use the peer as-number command to create a peer and specify its AS number, and then use the peer group command to add the peer to the peer group.
¡  You can specify the as-number keyword for the peer group command. The AS number must be the same as the AS number specified in the peer as-number command.
¡  If you have specified the AS number of the peer group with the peer as-number command, the peer to be added must have the same AS number as the peer group.
¡  To add a peer to an IBGP peer group, the peer must be an IBGP peer.
·           Use the peer group command to create a peer and add it to the peer group.
¡  If you have specified the AS number of the peer group with the peer as-number command, you do not need to specify the as-number keyword when you execute the peer group command, because the AS number of the peer is the same as the peer group. To specify the as-number keyword for the peer group command, make sure that the AS number is the same as the peer group.
¡  If no AS number is specified for an EBGP peer group, specify the as-number keyword when you execute the peer group command.
¡  If no AS number is specified for an IBGP peer group, you do not need to specify the as-number keyword when you execute the peer group command, because the AS number of the IBGP peer group is the local AS number. To specify the as-number keyword for the peer group command, make sure that the AS number is the same as the local AS number.
If you have specified the AS number of a peer group with the peer as-number command, only the peers with the same AS number can be added to the peer group. All peers in the group share the same AS number. If you have not specified the AS number for a peer group, peers added to it can use their own AS numbers.
After you add a peer to a peer group, you must use the peer enable command to enable BGP to exchange routing information with the peer group.
# In BGP view, add peer 10.1.1.1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.1.1 group test as-number 2004
# In BGP-VPN view, add peer 10.1.1.1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 10.1.1.1 group test as-number 2004
# In BGP view, add peer 1::1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer 1::1 group test as-number 2004
# In BGP-VPN view, add peer 1::1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 group test as-number 2004
·           group
·           peer as-number
·           peer enable
peer ignore
Use peer ignore to disable BGP session establishment with a peer or peer group.
Use undo peer ignore to restore the default.
peer { group-name | ip-address | ipv6-address } ignore
undo peer { group-name | ip-address | ipv6-address } ignore
BGP can establish a session to a peer or peer group.
This command enables you to temporarily tear down the BGP session to a specific peer or peer group so that you can perform network upgrade and maintenance without needing to delete and reconfigure the peer or peer group. To recover the session, execute the undo peer ignore command.
If a session has been established to a peer, executing the peer ignore command for the peer tears down the session and clears all related routing information.
If sessions have been established to a peer group, executing the peer ignore command for the peer group disables the sessions to all peers in the group and clears all related routing information.
# In BGP view, disable session establishment with peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 ignore
# In BGP-VPN view, disable session establishment with peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 ignore
peer ignore-originatorid
Use peer ignore-originatorid to ignore the ORIGINATOR_ID attribute of BGP routes.
Use undo peer ignore-originatorid to restore the default.
peer { group-name | ip-address | ipv6-address } ignore-originatorid
undo peer { group-name | ip-address | ipv6-address } ignore-originatorid
A BGP router does not ignore the ORIGINATOR_ID attribute of BGP routes.
After receiving a route from a peer, the route reflector adds the ORIGINATOR_ID attribute to the route and then reflects the route. The ORIGINATOR_ID identifies the router ID of the originating peer. When a BGP router receives the route, it compares the ORIGINATOR_ID of the route with the local router ID. If they are the same, the BGP router discards the route to avoid routing loops.
In some special networks, a BGP router must ignore the ORIGINATOR_ID attribute so it can learn the routes in which the ORIGINATOR_ID is the same as the local router ID. For example, when different VPN instances on the same PE need to exchange the VPN routes through IBGP and one VPN instance is configured as the route reflector, you must execute this command to ignore the ORIGINATOR_ID attribute of BGP routes.
After this command is executed, the CLUSTER_LIST attribute of BGP routes is also ignored.
Use this command only when necessary. If routing loops cannot be avoided in the network, do not execute this command.
# In BGP view, configure the device to ignore the ORIGINATOR_ID attribute of BGP routes received from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 ignore-originatorid
# In BGP-VPN view, configure the device to ignore the ORIGINATOR_ID attribute of BGP routes received from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1.1.1.1 ignore-originatorid
Use peer keep-all-routes to save all route updates from a peer or peer group, regardless of whether the routes have passed the configured routing policy.
Use undo peer keep-all-routes to restore the default.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view:
peer { group-name | ip-address } keep-all-routes
undo peer { group-name | ip-address } keep-all-routes
peer { group-name | ip-address | ipv6-address } keep-all-routes
undo peer { group-name | ip-address | ipv6-address } keep-all-routes
Route updates from a peer or peer group are not saved.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP VPNv4 instance view, BGP IPv6 unicast instance view
To implement BGP session soft-reset when the local router and a peer or peer group do not support the route refresh function, use the peer keep-all-routes command to save all route updates received from the peer or peer group. After modifying the route selection policy, filter all saved routes with the new policy to refresh the routing table. This method avoids tearing down BGP sessions.
# In BGP IPv4 unicast instance view, save all route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer 1.1.1.1 keep-all-routes
# In BGP-VPN IPv4 unicast instance view, save all route updates from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 1.1.1.1 keep-all-routes
# In BGP IPv6 unicast instance view, save all route updates from peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer 1::1 keep-all-routes
peer label-route-capability
Use peer label-route-capability to enable BGP to exchange labeled routes with a peer or peer group.
Use undo peer label-route-capability to disable BGP from exchanging labeled routes with a peer or peer group.
peer { group-name | ip-address } label-route-capability
undo peer { group-name | ip-address } label-route-capability
BGP cannot exchange labeled routes with a peer or peer group.
In an inter-AS VPN Option C network, you must execute the peer label-route-capability command in BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view to enable the local router and the peer to assign labels to BGP IPv4 routes and exchange the labeled routes for establishing the inter-AS public network LSPs.
In a 6PE network, you must execute the peer label-route-capability command in BGP IPv6 unicast instance view to enable the local router and the peer to assign labels to BGP IPv6 routes and exchange the labeled routes for forwarding IPv6 packets over an IPv4 network.
# In BGP IPv4 unicast instance view, enable BGP to exchange labeled IPv4 routes with peer 2.2.2.2.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer 2.2.2.2 label-route-capability
# In BGP-VPN IPv4 unicast instance view, enable BGP to exchange labeled IPv4 routes with peer 2.2.2.2.
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-ipv4-vpn1] peer 2.2.2.2 label-route-capability
# In BGP IPv6 unicast instance view, enable BGP to exchange labeled IPv6 routes with peer 2.2.2.2.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer 2.2.2.2 label-route-capability
peer low-memory-exempt
Use peer low-memory-exempt to configure BGP to protect EBGP peer or peer group when the memory usage reaches level 2 threshold.
Use undo peer low-memory-exempt to restore the default.
peer { group-name | ip-address | ipv6-address } low-memory-exempt
undo peer { group-name | ip-address | ipv6-address } low-memory-exempt
When the memory usage reaches level 2 threshold, BGP tears down an EBGP session to release memory resources periodically.
BGP view, BGP-VPN instance view
Memory usage includes the following levels of thresholds: normal, level 1, level 2, and level 3. When level 2 threshold is reached, BGP tears down an EBGP session to release memory resources periodically until the memory usage is exempt from level 2 threshold. You can use this command to avoid tearing down the BGP session with a specific EBGP peer when memory usage reaches level 2 threshold.
For more information about thresholds, see Fundamentals Configuration Guide.
# In BGP view, configure BGP to protect EBGP peer 1.1.1.1 when the memory usage reaches level 2 threshold.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 200
[Sysname-bgp] peer 1.1.1.1 low-memory-exempt
# In BGP-VPN instance view, configure BGP to protect EBGP peer 1.1.1.1 when the memory usage reaches level 2 threshold.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1.1.1.1 low-memory-exempt
peer next-hop-local
Use peer next-hop-local to specify a router as the next hop for routes sent to a peer or peer group.
Use undo peer next-hop-local to restore the default.
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
peer { group-name | ipv6-address } next-hop-local
undo peer { group-name | ipv6-address } next-hop-local
The router sets itself as the next hop for routes sent to an EBGP peer or peer group, but does not set itself as the next hop for routes sent to an IBGP peer or peer group.
To make sure that an IBGP peer can find the next hop, you can use this command to specify the router as the next hop for routes sent to the IBGP peer.
# In BGP IPv4 unicast instance view, specify the router as the next hop for routes sent to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test next-hop-local
# In BGP-VPN IPv4 unicast instance view, specify the router as the next hop for routes sent to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test next-hop-local
# In BGP IPv6 unicast instance view, specify the router as the next hop for routes sent to peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6] peer test next-hop-local
peer password
Use peer password to enable MD5 authentication for a BGP peer or peer group.
Use undo peer password to remove MD5 authentication for the BGP peer or peer group.
peer { group-name | ip-address | ipv6-address } password { cipher | simple } password
undo peer { group-name | ip-address | ipv6-address } password
MD5 authentication is disabled.
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies a password, a case-sensitive string of 33 to 137 characters in cipher text, or 1 to 80 characters in plain text.
You can enable MD5 authentication to enhance security in the following ways:
·           Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
·           Perform MD5 calculation on TCP packets to avoid modification to the encapsulated BGP packets.
For secrecy, all passwords, including passwords configured in plain text, are saved in cipher text.
# In BGP view, perform MD5 authentication on the TCP connection between the local router 10.1.100.1 and the peer router 10.1.100.2, and set the plaintext authentication password to aabbcc.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.2 password simple aabbcc
# Perform similar configuration on the peer.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.1 password simple aabbcc
# In BGP-VPN view, perform MD5 authentication on the TCP connection between the local router 10.1.100.1 and the peer router 10.1.100.2, and set the plaintext authentication password to aabbcc.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 10.1.100.2 password simple aabbcc
[Sysname] bgp 200
[Sysname-bgp-vpn1] peer 10.1.100.1 password simple aabbcc
peer preferred-value
Use peer preferred-value to specify a preferred value for routes received from a peer or peer group.
Use undo peer preferred-value to restore the default.
In BGP IPv4 unicast instance view/BGP-VPN IPv4 unicast instance view/BGP VPNv4 instance view/BGP VPNv6 instance view:
peer { group-name | ip-address } preferred-value value
undo peer { group-name | ip-address } preferred-value
peer { group-name | ip-address | ipv6-address } preferred-value value
undo peer { group-name | ip-address | ipv6-address } preferred-value
peer { group-name | ipv6-address } preferred-value value
undo peer { group-name | ipv6-address } preferred-value
The preferred value is 0.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP-VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view, BGP-VPNv6 instance view
value: Specifies the preferred value in the range of 0 to 65535.
If multiple routes that have the same destination are learned from different peers, you can specify different preferred values for the routes as needed to control BGP path selection. The one with the greatest preferred value is selected as the optimal route to the destination.
The preferred value is used for route selection on the local router and is not advertised to the peer. It has only local significance.
You can also use the apply preferred-value command in a routing policy to configure the preferred value for BGP routes. If both the peer preferred-value and apply preferred-value commands are configured, the apply preferred-value command applies. If the preferred value set by the apply preferred-value command is 0 or no routing policy is configured, the peer preferred-value command applies.
# In BGP IPv4 unicast instance view, specify the preferred value as 50 for routes from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer 1.1.1.1 preferred-value 50
# In BGP VPNv4 instance view, specify the preferred value as 50 for routes from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpnv4
[Sysname-bgp-vpnv4] peer 1.1.1.1 preferred-value 50
# In BGP-VPN IPv6 unicast instance view, specify the preferred value as 50 for routes from peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv6-family unicast
[Sysname-bgp-ipv6-vpn1] peer 1::1 preferred-value 50
·           apply preferred-value
·           route-policy
peer prefix-list
Use peer prefix-list to reference a prefix list to filter routes received from or advertised to a peer or peer group.
Use undo peer prefix-list to remove the configuration.
peer { group-name | ip-address } prefix-list prefix-list-name { export | import }
undo peer { group-name | ip-address } prefix-list prefix-list-name { export | import }
peer { group-name | ip-address | ipv6-address } prefix-list ipv6-prefix-name { export | import }
undo peer { group-name | ip-address | ipv6-address } prefix-list ipv6-prefix-name { export | import }
peer { group-name | ipv6-address } prefix-list ipv6-prefix-name { export | import }
undo peer { group-name | ipv6-address } prefix-list ipv6-prefix-name { export | import }
peer { group-name | ip-address } prefix-list ipv6-prefix-name { export | import }
undo peer { group-name | ip-address } prefix-list ipv6-prefix-name { export | import }
No prefix list based filtering is configured.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view, BGP VPNv6 instance view
prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
ipv6-prefix-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the filter to routes advertised to the specified peer/peer group.
import: Applies the filter to routes received from the specified peer/peer group.
The specified IPv4 prefix list or IPv6 prefix list must have been created with the ip prefix-list or ipv6 prefix-list command in system view. Otherwise, all routes can pass the IPv4/IPv6 prefix list.
# In BGP IPv4 unicast instance view, use the IPv4 prefix list list1 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test prefix-list list1 export
# In BGP-VPN IPv6 unicast instance view, use the IPv6 prefix list list1 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test prefix-list list1 export
·           filter-policy export
·           filter-policy import
·           ip prefix-list
·           ipv6 prefix-list
·           peer as-path-acl
·           peer filter-policy
·           peer route-policy
peer public-as-only
Use peer public-as-only to remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
Use undo peer public-as-only to restore the default.
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
peer { group-name | ip-address | ipv6-address } public-as-only
undo peer { group-name | ip-address | ipv6-address } public-as-only
peer { group-name | ipv6-address } public-as-only
undo peer { group-name | ipv6-address } public-as-only
BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
Private AS numbers are typically used in test networks, and need not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
After you execute the command, you can get the following results:
·           If the AS_PATH attribute of a BGP update carries only private AS numbers, the device removes the AS numbers before sending the update to the EBGP peer or peer group.
·           If the AS_PATH attribute carries both public and private AS numbers, the command does not take effect. The device sends the BGP update to the EBGP peer or peer group without removing the private AS numbers.
·           If the AS_PATH attribute carries AS numbers of the peer or peer group, the command does not take effect. The device sends the BGP update to the peer or peer group without removing the private AS numbers.
This command is only applicable to an EBGP peer or peer group.
# In BGP IPv4 unicast instance view, remove private AS numbers in BGP updates sent to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test public-as-only
# In BGP VPNv4 instance view, remove private AS numbers in BGP updates sent to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] peer test public-as-only
# In BGP-VPN IPv6 unicast instance view, remove private AS numbers in BGP updates sent to EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test public-as-only
peer reflect-client
Use peer reflect-client to configure the device as a route reflector and specify a peer or peer group as a client.
Use undo peer reflect-client to restore the default.
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
peer { group-name | ip-address | ipv6-address } reflect-client
undo peer { group-name | ip-address | ipv6-address } reflect-client
Neither the route reflector nor the client is configured.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP VPNv4 instance view, BGP IPv6 unicast instance view, BGP VPNv6 instance view
Using route reflectors can solve the issue brought by too many IBGP connections. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards the routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
# In BGP IPv4 unicast instance view, configure the local device as a route reflector and specify the IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test reflect-client
# In BGP VPNv4 instance view, configure the local device as a route reflector and specify the IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] peer test reflect-client
# In BGP-VPN IPv6 unicast instance view, configure the local device as a route reflector and specify the IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test reflect-client
·           reflect between-clients
·           reflector cluster-id
peer route-limit
Use peer route-limit to specify the maximum number of routes that can be received from a peer or peer group.
Use undo peer route-limit to restore the default.
peer { group-name | ip-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ip-address } route-limit
peer { group-name | ip-address | ipv6-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ip-address | ipv6-address } route-limit
The number of routes that can be received from a peer or peer group is not limited.
prefix-number: Specifies the number of routes that can be received from the peer or peer group, in the range of 1 to 4294967295. If the alert-only and reconnect keywords are not specified, and the number of routes received from the peer or peer group reaches the prefix-number, the router will tear down the connection to the peer or peer group.
alert-only: If the number of routes received from the peer or peer group reaches the prefix-number, the router displays an alarm message instead of tearing down the connection to the peer or peer group.
reconnect reconnect-time: Specifies a reconnect time, after which, the router re-establishes a connection to the peer or peer group when the number of routes received from the peer or peer group reaches the prefix-number. The value range for the reconnect-time argument is 1 to 65535 seconds.
percentage-value: Specifies the threshold value for the router to display an alarm message (the router displays an alarm message when the ratio of the number of received routes to the prefix-number exceeds the percentage value). The value range for this argument is 1 to 100, and the default is 75.
# In BGP IPv4 unicast instance view, specify the maximum number of routes that can be received from peer 1.1.1.1 to 10000, and configure the router to tear down the connection to the peer if the number is exceeded.
[Sysname] bgp 109
[Sysname-bgp-ipv4] peer 1.1.1.1 route-limit 10000
# In BGP-VPN IPv4 unicast instance view, specify the maximum number of routes that can be received from peer 1.1.1.1 to 10000, and configure the router to tear down the connection to the peer if the number is exceeded.
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv4-family unicast
[Sysname-bgp-ipv4-vpn1] peer 1.1.1.1 route-limit 10000
# In BGP IPv6 unicast instance view, specify the maximum number of routes that can be received from peer 1::1 to 10000, and configure the router to tear down the connection to the peer if the number is exceeded.
[Sysname] bgp 109
[Sysname-bgp] ipv6-family unicast
[Sysname-bgp-ipv6] peer 1::1 route-limit 10000
peer route-policy
Use peer route-policy to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use undo peer route-policy to remove the configuration.
peer { group-name | ip-address } route-policy route-policy-name { export | import }
undo peer { group-name | ip-address } route-policy route-policy-name { export | import }
In BGP-VPN VPNv4 instance view:
peer { group-name | ip-address } route-policy route-policy-name import
undo peer { group-name | ip-address } route-policy route-policy-name import
peer { group-name | ip-address | ipv6-address } route-policy route-policy-name { export | import }
undo peer { group-name | ip-address | ipv6-address } route-policy route-policy-name { export | import }
peer { group-name | ipv6-address } route-policy route-policy-name { export | import }
undo peer { group-name | ipv6-address } route-policy route-policy-name { export | import }
No routing policy is applied to routes from/to the peer or peer group.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP VPNv4 instance view, BGP-VPN VPNv4 instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view, BGP VPNv6 instance view
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the routing policy to routes outgoing to the peer or peer group.
import: Applies the routing policy to routes incoming from the peer or peer group.
The specified routing policy must have been configured with the route-policy command in system view. Otherwise, all routes can pass the routing policy.
The if-match interface command, if configured for the referenced routing policy, does not take effect for routes.
# In BGP IPv4 unicast instance view, apply routing policy test-policy to routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv4] peer test route-policy test-policy export
# In BGP-VPN IPv6 unicast instance view, apply the routing policy test-policy to routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] peer test route-policy test-policy export
·           peer as-path-acl
·           peer prefix-list
·           route-policy
peer route-update-interval
Use peer route-update-interval to specify an interval for sending the same update to a peer or peer group.
Use undo peer route-update-interval to restore the default.
peer { group-name | ip-address | ipv6-address } route-update-interval interval
undo peer { group-name | ip-address | ipv6-address } route-update-interval
The interval for sending the same update to an IBGP peer is 15 seconds and the interval for sending the same update to an EBGP peer is 30 seconds.
BGP view, BGP-VPN view
interval: Specifies a minimum interval for sending the same update message. The range is 0 to 600 seconds.
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. By configuring the interval for sending the same update to a peer or peer group, you can avoid such routing flaps.
# In BGP view, specify the interval for sending the same update to peer group test as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp] peer test route-update-interval 10
# In BGP-VPN view, specify the interval for sending the same update to peer group test as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test route-update-interval 10
peer substitute-as
Use peer substitute-as to replace the AS number of a peer or peer group in the AS_PATH attribute with the local AS number.
Use undo peer substitute-as to restore the default.
peer { group-name | ip-address | ipv6-address } substitute-as
undo peer { group-name | ip-address | ipv6-address } substitute-as
The AS number of a peer or peer group in the AS_PATH attribute is not replaced.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ip-address: Specifies a peer by its IP address. The peer must have been created.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
In MPLS L3VPN, if EBGP is used between PE and CE, sites in different geographical areas must have different AS numbers assigned to ensure correct route advertisement. If different CEs use the same AS number, you must configure the relevant PE to replace the AS number of the CE as its own AS number to ensure correct advertisement of private network routes.
# In BGP view, substitute the local AS number for the AS number of peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 substitute-as
# In BGP-VPN view, substitute the local AS number for the AS number of peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer 1::1 substitute-as
peer timer
Use peer timer to configure a keepalive interval and holdtime for a peer or peer group.
Use undo peer timer to restore the default.
peer { group-name | ip-address | ipv6-address } timer keepalive keepalive hold holdtime
undo peer { group-name | ip-address | ipv6-address } timer
The keepalive interval is 60 seconds, and the holdtime is 180 seconds.
keepalive keepalive: Sets a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Sets a holdtime in the range of 3 to 65535 seconds.
After establishing a BGP session, two routers send keepalive messages at the specified keepalive interval to each other to keep the session.
If a router receives no keepalive or update message from the peer within the holdtime, it tears down the session.
The timers configured with this command are preferred to the timers configured with the timer command.
If the holdtime settings on the local and peer routers are different, the smaller one is used.
If the holdtime is configured as 0, no keepalive message will be sent to the peer, and the peer session will never time out. If the keepalive interval is configured as 0 and the negotiated holdtime is not 0, one third of the holdtime is taken as the interval for sending keepalive messages. If neither the holdtime nor the keepalive interval is configured as 0, the actual keepalive interval is the smaller one between one third of the holdtime and the keepalive interval.
After this command is executed, the peer session is closed at once, and a new session to the peer is negotiated by using the configured holdtime.
# In BGP view, configure the keepalive interval and holdtime for peer group test as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp] peer test timer keepalive 60 hold 180
# In BGP-VPN view, configure the keepalive interval and holdtime interval for peer group test as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test timer keepalive 60 hold 180
# In BGP view, configure both the keepalive interval and holdtime for peer group test as 0 seconds, indicating the session will never time out.
[Sysname] bgp 100
[Sysname-bgp] peer test timer keepalive 0 hold 0
# In BGP-VPN view, configure both the keepalive interval and holdtime for peer group test as 0 seconds, indicating the session will never time out.
[Sysname] bgp 100
[Sysname-bgp-vpn1] peer test timer keepalive 0 hold 0
·           timer
preference
Use preference to configure preferences for BGP routes.
Use undo preference to restore the default.
undo preference
The preferences of external, internal, and local BGP routes are 255, 255, and 130.
BGP IPv4 unicast instance view, BGP-VPN IPv4 unicast instance view, BGP IPv6 unicast instance view, BGP-VPN IPv6 unicast instance view
external-preference: Specifies a preference for EBGP routes, in the range of 1 to 255.
internal-preference: Specifies a preference for IBGP routes, in the range of 1 to 255.
local-preference: Specifies a preference for local routes, in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set the route preference for matching routes. Routes not matching the routing policy use the default preference.
Different routing protocols might find different routes to the same destination. However, not all of those routes are optimal. For route selection, routing protocols, direct routes, and static routes are assigned different preferences. The route with the highest preference is preferred.
Configuring the preferences for BGP routes changes the possibility for the routes to become the optimal route.
To reference a routing policy to set the preference, you must configure the preference with the apply preference command in the routing policy in advance. Otherwise, all matching routes use the default preference.
# In BGP IPv4 unicast instance view, configure preferences for EBGP, IBGP, and local routes as 20, 20, and 200.
[Sysname] bgp 100
[Sysname-bgp-ipv4] preference 20 20 200
# In BGP IPv4 unicast instance view, configure the preference for BGP route 1.1.1.0/24 as 200.
[Sysname] ip prefix-list route permit 1.1.1.0 24
[Sysname] route-policy prefer permit node 0
[Sysname-route-policy-prefer-0] if-match ip address prefix-list route
[Sysname-route-policy-prefer-0] apply preference 200
[Sysname-route-policy-prefer-0] quit
[Sysname] bgp 100
[Sysname-bgp] ipv4-family unicast
[Sysname-bgp-ipv4] preference route-policy prefer
# In BGP-VPN IPv6 unicast instance view, configure preferences for EBGP, IBGP, and local routes as 20, 20, and 200.
[Sysname] bgp 100
[Sysname-bgp-ipv6-vpn1] preference 20 20 200
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable this function.
Route reflection between clients is enabled.
When a route reflector is configured, and the clients of a route reflector are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use the undo reflect between-clients command to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
# In BGP IPv4 unicast instance view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-ipv4] undo reflect between-clients
# In BGP VPNv4 instance view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] undo reflect between-clients
# In BGP-VPN IPv4 unicast instance view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] undo reflect between-clients
# In BGP IPv6 unicast instance view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-ipv6] undo reflect between-clients
·           peer reflect-client
Use reflector cluster-id to configure the cluster ID for a route reflector.
Use undo reflector cluster-id to restore the default.
A route reflector uses its router ID as the cluster ID.
cluster-id: Specifies the cluster ID in the format of an integer, in the range of 1 to 4294967295.
ip-address: Specifies the cluster ID in the format of an IPv4 address in dotted decimal notation.
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the cluster ID.
You can configure more than one route reflector in a cluster to improve network reliability and prevent a single point of failure. Use this command to configure the same cluster ID for all route reflectors in the cluster to avoid routing loops.
Do not configure the router ID of a client as the cluster ID.
# In BGP IPv4 unicast instance view, configure the cluster ID on the local router (a reflector in the cluster) as 80.
[Sysname] bgp 100
[Sysname-bgp-ipv4] reflector cluster-id 80
# In BGP VPNv4 instance view, configure the cluster ID on the local router (a reflector in the cluster) as 80.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] reflector cluster-id 80
# In BGP-VPN IPv4 unicast instance view, configure the cluster ID on the local router (a reflector in the cluster) as 80.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] reflector cluster-id 80
# In BGP IPv6 unicast instance view, configure the cluster ID on the local router (a reflector in the cluster) as 80.
[Sysname] bgp 100
Use refresh bgp ipv4 unicast to manually soft-reset BGP sessions for the IPv4 unicast address family.
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
ip-address: Soft-resets the BGP session to the specified peer. The ip-address argument refers to the IP address of a peer.
all: Soft-resets all BGP sessions.
external: Soft-resets all EBGP sessions.
group group-name: Soft-resets the BGP sessions to the peers of the specified peer group. The group-name argument refers to the name of a peer group, a case-sensitive string of 1 to 47 characters.
internal: Soft-resets all IBGP sessions.
export: Performs outbound soft-reset (filters routes advertised to the specified peer or peer group by using the new configuration).
import: Performs inbound soft-reset (filters routes received from the specified peer or peer group by using the new configuration).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command performs manual soft-reset on BGP sessions for the public network IPv4 unicast address family.
After the route selection policy is modified, execute this command with the export keyword to enable the local router to filter routing information based on the new policy and send the matching routes to the BGP peer. If you execute this command with the import keyword, you enable the local router to advertise a route-refresh message to the peer and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This command requires that both the local router and the peer support route refresh.
If the peer keep-all-routes command is configured, the refresh bgp ipv4 unicast import command does not take effect.
The command with the unicast keyword has the same effect as that without the unicast keyword.
# Manually soft-reset all BGP sessions for the IPv4 unicast address family.
<Sysname> refresh bgp ipv4 all
Use refresh bgp ipv6 unicast to manually soft-reset BGP sessions for the IPv6 unicast address family.
refresh bgp { ipv6-address | all | external | group group-name | internal } { export | import } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
refresh bgp ip-address { export | import } ipv6 [ unicast ]
ipv6-address: Soft-resets the BGP session to the specified peer. The ipv6-address argument refers to the IPv6 address of a peer.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command performs manual soft-reset on BGP sessions for the public network IPv6 unicast address family.
If the peer keep-all-routes command is configured, the refresh bgp ipv6 unicast import command does not take effect.
# Manually soft-reset all BGP sessions for the IPv6 unicast address family.
<Sysname> refresh bgp all ipv6
reset bgp all
Use reset bgp all to reset all BGP sessions.
reset bgp all
To validate a new route selection policy, use this command to reset BGP sessions. BGP re-establishes the BGP sessions, advertises routes, and applies the new policy to routes. This operation breaks down BGP sessions for a short while.
# Reset all BGP sessions.
<Sysname> reset bgp all
reset bgp dampening ipv4 unicast
Use reset bgp dampening ipv4 unicast to clear BGP IPv4 unicast route dampening information and release the suppressed BGP IPv4 unicast routes.
reset bgp dampening ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command clears BGP IPv4 unicast route dampening information for the public network, and releases the suppressed BGP IPv4 unicast routes.
network-address: Specifies a destination network address.
mask: Specifies a network mask, in dotted decimal notation.
mask-length: Specifies a mask length in the range of 0 to 32.
When you execute the reset bgp dampening ipv4 unicast command:
·           If the network-address, mask, and mask-length arguments are not specified, the command clears all BGP IPv4 unicast route dampening information of the public network or the specified VPN, and releases all suppressed BGP IPv4 unicast routes.
·           If only the network-address argument is specified, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command clears dampening information of the route, and releases the suppressed route.
·           If the network-address mask or network-address mask-length argument is specified, the command clears dampening information of the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length), and releases the suppressed route.
# Clear damping information of BGP IPv4 unicast route 20.1.0.0/16 for the public network, and release the suppressed route.
<Sysname> reset bgp dampening ipv4 20.1.0.0 255.255.0.0
·           dampening
·           display bgp routing-table dampened ipv4 unicast
reset bgp dampening ipv6 unicast
Use reset bgp dampening ipv6 unicast to clear BGP IPv6 unicast route dampening information and release suppressed BGP IPv6 unicast routes.
reset bgp dampening ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command clears BGP IPv6 unicast route dampening information for the public network, and releases the suppressed BGP IPv6 unicast routes.
network-address prefix-length: Specifies a destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If this argument is not specified, the command clears all BGP IPv6 unicast route dampening information, and releases all suppressed BGP IPv6 unicast routes.
# Clear damping information of BGP IPv6 unicast route 2345::/16 for the public network, and release the suppressed route.
<Sysname> reset bgp dampening ipv6 2345:: 16
·           dampening
·           display bgp routing-table dampened ipv6 unicast
reset bgp flap-info ipv4 unicast
Use reset bgp flap-info ipv4 unicast to clear the flap statistics of BGP IPv4 unicast routes.
reset bgp flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command clears the flap statistics of the BGP IPv4 unicast routes for the public network.
as-path-acl as-path-acl-number: Specifies an AS path list by its number in the range of 1 to 256, to filter BGP IPv4 unicast route flap statistics.
peer peer-address: Clears flap statistics of BGP IPv4 unicast routes learned from the specified BGP peer.
When you execute the reset bgp flap-info ipv4 unicast command:
·           If the network-address, mask, and mask-length arguments are not specified, the command clears the flap statistics of all BGP IPv4 unicast routes for the public network or the specified VPN.
·           If only the network-address argument is specified, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command clears the flap statistics of the route.
·           If the network-address mask or network-address mask-length argument is specified, the command clears the flap statistics of the BGP IPv4 unicast route that matches both the specified destination network address and the mask (or mask length).
# Clear the flap statistics of BGP IPv4 unicast route 20.1.0.0/16 for the public network.
<Sysname> reset bgp flap-info ipv4 20.1.0.0 16
# Clear the flap statistics for the public network BGP IPv4 unicast routes learned from peer 1.1.1.1.
<Sysname> reset bgp flap-info ipv4 peer 1.1.1.1
·           dampening
·           display bgp routing-table flap-info ipv4 unicast
reset bgp flap-info ipv6 unicast
Use reset bgp flap-info ipv6 unicast to clear the flap statistics of BGP IPv6 unicast routes.
reset bgp flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command clears the flap statistics of the BGP IPv6 unicast routes for the public network.
network-address prefix-length: Specifies the destination network address and prefix length. The value range for the prefix-length argument is 0 to 128. If this argument is not specified, the command clears the flap statistics of all BGP IPv6 unicast routes.
as-path-acl as-path-acl-number: Specifies an AS path list number in the range of 1 to 256 to filter BGP IPv6 unicast route flap statistics.
peer ipv6-address: Clears flap statistics of BGP IPv6 unicast routes learned from the specified BGP peer.
# Clear the flap statistics of BGP IPv6 unicast route 2345::/16 for the public network.
<Sysname> reset bgp flap-info ipv6 2345:: 16
# Clear the flap statistics for the public network BGP IPv6 unicast routes learned from peer 1::1.
<Sysname> reset bgp flap-info ipv6 peer 1::1
·           dampening
·           display bgp routing-table flap-info ipv6 unicast
reset bgp ipv4 unicast
Use reset bgp ipv4 unicast to reset BGP sessions for the IPv4 unicast address family.
reset bgp { as-number | ip-address | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
as-number: Resets BGP sessions to peers in the AS.
ip-address: Specifies the IP address of a peer with which to reset the session.
all: Resets all BGP sessions of IPv4 unicast address family.
external: Resets all the EBGP sessions of IPv4 unicast address family.
group group-name: Resets sessions with peers in the specified BGP peer group.
internal: Resets all the IBGP sessions of IPv4 unicast address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command resets the BGP sessions for IPv4 unicast address family for the public network.
To apply a newly configured route selection policy, you must use this command to reset BGP sessions. BGP re-establishes the BGP sessions, advertises routes, and applies the new policy to routes. This operation breaks down BGP sessions for a short while.
# Reset all BGP sessions for IPv4 unicast address family of the public network.
<Sysname> reset bgp all ipv4
reset bgp ipv6 unicast
Use reset bgp ipv6 unicast to reset BGP sessions for the IPv6 unicast address family.
reset bgp { as-number | ipv6-address | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp ip-address ipv6 [ unicast ]
ipv6-address: Specifies the IPv6 address of a peer with which to reset the session.
all: Resets all BGP sessions of IPv6 unicast address family.
external: Resets all the EBGP sessions of IPv6 unicast address family.
internal: Resets all the IBGP sessions of IPv6 unicast address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, this command resets the BGP sessions for IPv6 unicast address family for the public network.
To validate a newly configured route selection policy, you must use this command to reset BGP sessions. BGP re-establishes the BGP sessions, advertises routes, and applies the new policy to routes. This operation breaks down BGP sessions for a short while.
# Reset all BGP sessions for IPv6 unicast address family for the public network.
<Sysname> reset bgp all ipv6
router id
Use router id to configure a global router ID.
Use undo router id to remove the global router ID.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies a router ID in IP address format.
Some routing protocols use a router ID to identify a device. You can configure a global router ID, which is used by routing protocols that have no router ID configured.
If no global router ID is configured, the highest loopback interface IP address, if any, is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status.
During an active/standby switchover, the standby main processing unit (MPU) checks whether the previous router ID that is backed up before switchover is valid. If not, it selects a new router ID.
If the interface IP address that is selected as the router ID is removed or modified, a new router ID is selected. Other events, (the interface goes down; after a physical interface address is selected as the router ID, an IP address is configured for a loopback interface; a higher interface IP address is configured) will not trigger a router ID re-selection.
After a router ID is changed, use the reset command to make it effective.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
router-id
router-id
Use router-id to specify a router ID.
Use undo router-id to remove the router ID.
router-id router-id
undo router-id
A BGP router uses the global router ID. You can execute the router id command in system view to configure the global router ID.
To run BGP protocol, a router must have a router ID, an unsigned 32-bit integer and  the unique ID of the router in the AS.
To modify a router ID, execute the router-id command in BGP view, rather than the router id command in system view.
To enhance network reliability, you can specify the IP address of a local loopback interface as the router ID.
You can specify a router ID for each VPN instance on a device.
# In BGP view, configure router ID as 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] router-id 1.1.1.1
# In BGP-VPN view, configure router ID as 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-vpn1] router-id 1.1.1.1
router id
summary automatic
Use summary automatic to configure automatic route summarization for redistributed IGP subnet routes.
Use undo summary automatic to remove the configuration.
summary automatic
Automatic route summarization is not performed for redistributed IGP subnet routes.
After the summary automatic command is configured, BGP summarizes IGP subnets redistributed by the import-route command.
Automatic summary routes can be manually summarized, but cannot be added to the IP routing table.
# In BGP IPv4 unicast instance view, configure automatic route summarization for redistributed IGP subnet routes.
[Sysname] bgp 100
[Sysname-bgp-ipv4] summary automatic
# In BGP-VPN IPv4 unicast instance view, configure automatic route summarization for redistributed IGP subnet routes.
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] summary automatic
·           aggregate
·           import-route
timer
Use timer to configure a BGP keepalive interval and holdtime.
Use undo timer to restore the default.
undo timer
The BGP keepalive interval and the holdtime are 60 seconds and 180 seconds.
keepalive keepalive: Configures a keepalive interval in the range of 0 to 21845 seconds.
hold holdtime: Configures a holdtime in seconds, whose value is 0 or in the range of 3 to 65535.
Use the timer command to configure the keepalive interval and holdtime for all BGP peers. Use the peer timer command to configure the keepalive interval and holdtime for a peer or peer group. If both commands are configured, the intervals configured by the peer timer command have higher priority.
The timer command takes effect for only new BGP sessions.
After the timer command is executed, no peer session is closed at once. The configured holdtime is used for negotiation in session reestablishment (for example, when you reset the BGP session).
# In BGP view, configure the keepalive interval and holdtime as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp] timer keepalive 60 hold 180
# In BGP-VPN view, configure the keepalive interval and holdtime as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp-vpn1] timer keepalive 60 hold 180
# In BGP view, configure both the keepalive interval and holdtime as 0 seconds, indicating the sessions will never time out.
[Sysname] bgp 100
[Sysname-bgp] timer keepalive 0 hold 0
# In BGP-VPN view, configure both the keepalive interval and holdtime as 0 seconds for BGP sessions in vpn1, indicating the sessions will never time out.
[Sysname] bgp 100
[Sysname-bgp-vpn1] timer keepalive 0 hold 0
·           display bgp peer ipv4 unicast
·           display bgp peer ipv6 unicast
·           peer timer
